i must say, with all of the other gorgeous and top notch stuff you have going on with this build, i'm probably most impressed by this multifunctional custom bumper support piece. your friend (Jon, i think you said) has crazy skills! props to you both.
The dude that loves cars with character: raw, rambunctious road manners, angry triangles and four devilish rings ...
... i have 3 electric fans on mine. One big one and one small one pushing and another small one pulling, my car was still overheating in traffic, so i put a inline electric water pump to keep things moving in traffic..
just curious about a few things, but i suppose most of them are contigent on if you have an actual temperature gauge, so that's my first question: do you have one?
if so ...
(1) what kinds of temps did you see at moderate load/throttle before adding the electric pump?
(2) what kinds of temps did/do you see after adding it?
(3) do you run an oil cooler as well?
(4) just to clarify, are you running only an electric water pump or are you running it in tandem with the stock mechanical pump?
thanks.
oh and i'm glad to hear that you're out of the hospital. will you need rehab or no?
if so ...
thanks.
I only am working with the factory gauge, but in traffic it starts to overheat unless i give it gas and get the water pump spinning. So when im moving along the temps are fine. I havent ran it with the booster pump yet, but im running it in tandem with the stock pump. Yes i run an oil cooler. Thanks for the thoughts about getting out of the hopital, i have a fairly long road ahead, i have rehab and a lot of follow up doctor appointments.
Are you on stock ecu? My stock gauge reads "190" all the way up until the autronic reads 240*....... NOT GOOD.
I run ViPec V88, Ray Hall split from Autronic and started his own company. We've logged it and it's pretty accurate with the stock gauge, a little off but nothing like yours.
The throttle cable and the acclerator pedal are done. The cable was made from two cables. Part of the
cable was from the unit 034 provided me along with a LOKAR unit I already had. Even the black factory triangle that fits
on the firewall was used. It fits like a OEM unit!
The water pump for the AWIC system is mounted and the hoses have been positioned. The water flow path runs in the
opposite direction of the air flow path. The water pump first sends the cooling medium from the heat exchanger to cool the
intake manifold through a channel underneath the plenum (approx 1 liter of volume). Next the medium flows to the AWIC.
After that, the compressor discharge pipe has been modified and now incorporates an intercooled plenum around it. It is
designed with an internal baffle that swirls the water around the neck 360 degrees and exits directly into the heat exchanger.
It is designed to reduce the inlet temperature before the AWIC and thus to further reduce the entire intake temps.
Pure sex. What's left to do, doesn't look like much?
Looks like the plumbing from the AWIC to TB is all that is left in terms of hardware. Can't wait for an excuse to pop up to Chicago and visit this build and some other dub friends!
The project is getting closer to being finished, but there are still some things left to do.
Here they are in no particular order except for the number 13. That happens 24/7!
1. Alternator bracket
2. New engine mounts
3. Thermostat housing
4. Catch can
5. Exhaust with cut out
6. Skid plate
7. Splitter
8. Longblock assembly
9. Wire the standalone
10. Finish the intercooler end tank
11. Install the fueling system
12. Tune for pump and race gas
13. Hide receipts from wife and enjoy life!!
When it's close to being ready, I'll hit you up and arrange a time we all can get together. Some of the Milwaukee crew said they would roll down with me.
Not sure I'd you mentioned it but which standalone are you going with 034's? That's not to bad of a list to be done, btw love number 13 haha goodluck man looking good.
I have 034's Stage IIc standalone with the plug and play harness.
Originally Posted by A4 TSCHUSS
Thing is insane, I just pray it gets a good tune after all this work.
I'm in the process of looking for an excellent tuner right now. And yes, that receipt will be hidden too......
Here is a quick shot of the shortblock. It is a 2.9L with JE 9:1 polished pistons and Eurospec rods. Honestly, I suspect that 034,
Eurospec and Integrated Engineering rods are all the same. I might be wrong, but after weighing IE and Eurospec units
I found that they weigh EXACTLY the same. The good thing is that all 12 rods were dead on the same weight. Visibly
they look the same too. I've seen these rods support well over 1000chp so I feel confident but at the same time I probably just
jinxed myself.
On another note I decided to upgrade to 288 TT cams. I need a little more, OK a lot more RPM than the 268's will provide. The head
is getting resurfaced and the longblock should be assembled this weekend. I'm going to use the mock up VR6 already in the car
as a spare to build over the winter. I intend to build that engine with a little higher compression, internal coatings and a few other
tricks. It's inevitable that something is going to give sooner or later so I might as well be prepared.
Right now, three separate things are being fabbed. The thermostat housing/coolant system, alternator bracket and new engine mounts. I'll update as soon as all three are complete!
Here are some new pix showing the beginning fabrication of the machined upper alternator bracket and the aluminum plate that
will function as the lower alternator bracket, power steering bracket AND driver's side engine mount. The driver's side should be
completed by Sunday or Monday at the latest.
Not really. Remember, the alternator had to be relocated due to the size of the intake manifold. At this point, many things have been made because of function, it just happens that the form looks cool. I can't apologize about that. Besides, this is a build thread....LOL.
The Fuelab components were ordered on Friday. After the passenger side engine mount is complete, the focus
will switch solely on the cooling system until that's complete. The alternator and power steering pump will be rebuilt or replaced
with new units.
The exhaust fab will begin after the engine mounts are finished.
Originally Posted by FNK re getting more power from a 2.8 a4
"Paint the exhaust and intake with Ceramic paint (heat repellent), thus increasing the exhaust velocity, thus less striction = more Power"
wow amazing build, wish i had skills with a tig welder.
MK4 GTi 1.8T converted to AWD
New 1/8th mile 7.36@102mph-27psi 93 octane, no meth
New build times 23psi pump 11.9@126mph-96mph in the 1/8th
04' A4 1.8t frontrak converted to quattro, was RWD for a lil now its quattro finally
2011 JSW Tdi 6speed manual
I was about to type, what were your intentions with the car, then I read your very first post... HA, that's funny.. Gotta love Prince's advice... Surprised he didn't get you into a Mustang!
Actually, believe it or not, this is will be a daily driven street car. Next year my goal is to put AC back into the car! It's really more fun to have a car that you can drive 9 months out of the year.
Update! The 1/4" thick aluminum skid plate is finished. This part will protect the oil pan against the very thing
that was the cause of this project, a pothole! I don't know the origination of the oilpan, and I waited over three weeks
for this one, so anything that can protect it is a great benefit. Anything that can be done to reduce downtime is also a plus!
