Page 2 of 2 FirstFirst 12
Results 41 to 79 of 79
  1. #41
    Senior Member Four Rings DavidB8's Avatar
    Nov 06 2009
    Oakville, ON, Canada
    But an actual light like the ones under the seats could be installed instead of just an LED. Would be harder since the plastic would have to be cut out for a light instead of drilled but what do you think would be better? A single light of course wouldn't be as directional as the LED's would be.
    Mods:Votex spoiler, tint, Clear Bra, S4 replicas, Audi winter and trunk mat,mud flaps, Dipstick, oil pan heater, KW V2's, AWE Dual Exhaust, Votex valance, AWE FMIC, Eurocode IC pipe, PIAA fog lights,Vag Com, APR Stage 2, E-Codes, trunk mount emergency triangle, LED plate bulbs, Audi compressor and tire repair kit, RS4 Pedal set, Power Folding Mirrors, S4 steering wheel, heated rear seats, ski pass through.......
    www.audienthusiasts.com
  2. #42
    Senior Member Four Rings Ryan_T's Avatar
    May 11 2009
    09 A4 2.0T
    T.O - Canada
    If you can cut it perfectly, I think getting one of the OEM light sources would be better. In the A8 shot, I think the ones below the door handles are very similar in size to the footwell/trunk lights. I've never taken them out, so I'm not sure if it's a simple opening or if there are tabs involved. But I'm sure the diffuser on the OEM ones would cast a softer, more subtle light than a naked LED poked through a hole.
    Ryan - flickr
  3. #43
    Veteran Member Three Rings Tone-Dogg's Avatar
    May 06 2007
    05 A4 1.8T 6MTQ; 06 A4 2.0T 6MTQ; 10 A4 2.0T 6MTQ Plus
    Newington, Connecticut
    subscribed can't wait to see finished product
  4. #44
    Apr 07 2007
    B6 A4 3.0 (Wife's Ride)
    Mountain View, CA
    Just went down to my car, looked at driver door and took some pics.
    Our doors are quite different than those on the A8.
    Looks like door handle 'grab' opening would have been ideal location to have installed the footwell/glovebox light housing for glow downward
    Doesn't appear to be enough space underneath the window controls for this housing.
    Maybe put the footwell/glovebox light housing in the inside back of the 'grab' opening, as that surface is angled downward?
    The glovebox light housing is about $25 from Audi dealer. It uses the WLED-x6 (6 LEDs, x being LED color) from SuperBrightLEDs.com, we could also use
    the WLED-x4 or WLED-x. They're all wedge bulbs that work in glove box housing, vary in light intensity and angle of dispersion.
    From $1.39 to $3.54 each.
    Have no clue what the footwell light housing looks like, probably similar to glovebox?
    Like idea of a single LED at base of bottle holder as well.
    As I have beige interior, I'd go for single red LED at bottle holder and amber under door handle.
    Gonna go look at rear doors now.
    Cheers
  5. #45
    Nov 06 2009
    Sun of a bi..... I think Audi hates me.. I just took a look at the LED under dash light since it's in my living room instead of in the car :)
    There are no special clips in the under dash cover so you could do it by cutting a hole provided there is a clear surface to do so in the handle. You could also swap the led for Red.. This is where I get annoyed.. Audi used a PLCC4 chip instead of a PLCC2. The 2 chips are whats used in the MMI housing and I have lots of those. The 4's I would have to order to try out and it's $20 shipping... grrrr..... Boy I miss living down south where I would just drive over to the electronics store and pic some up.
    Can you say donations
  6. #46
    Nov 06 2009
    I out a request up on the A8 forum to see if someone would be willing to post a pic of their light so we can see what they use. Not sure how busy that forum is but we'll see.
  7. #47
    Nov 06 2009
    Some more research, there is enough room to put a light in the handle no problem, there is no ambient light wire in the door so it would have to be on the same dimmer as the switches.
  8. #48
    Sep 09 2009
    09 RDX
    LongIsland
    Quote Originally Posted by DavidB8 View Post
    So you would go with Red LED's or White? I'm guessing the idea of installing a light like whats in the B8 doesn't appeal?
    I would go with White since just about everything is red and as it is on the low end of the door it would match the under dash lights
  9. #49
    Nov 06 2009
    I've done some searching on the different plugs inside the door and found one that can be ordered with a male and female end that can be used to bring the lighting power and ground to the new light. So this could essentially be made into a plug and play install with the exception of cutting the hole in the trim.
  10. #50
    Sep 09 2009
    09 RDX
    LongIsland
    how do you find all these harness I cant find any in ETKA
  11. #51
    Nov 06 2009
    It's not really finding a harness it's finding the parts to make a harness. You have to go into the elek section on the bottom of the main screen and look up connectors there and then match the male and female wires..
    Teaser thread about to start.. Check in 2 mins...
  12. #52
    Nov 06 2009
    DIY is more or less complete for the cupholder LED's. I still need to do a write up for centre console removal but there is one on Audizine somewhere if you go looking.
    Here you go
    http://www.audienthusiasts.com/Proje...Cupholder.html
  13. #53
    Apr 07 2007
    Mountain View, CA
    The 'missing link' to center console removal:
    http://www.audizine.com/forum/showth...le+trim+change
    So easy 5 cavemen and 3 polar bears could do it
    Had my mechanic do it when I changed out my center console wood trim!
    The search function on Audizine is NOT user-friendly.
    Cheers
  14. #54
    May 06 2007
    David, great job!!! One day I'll tackle this...
  15. #55
    Apr 07 2007
    Mountain View, CA
    If you buy the stuff from eBay.de or through an audi dealer for Euro only parts, the time is right now folks.
    The Euro is plummeting against the dollar at this moment.
    Cheers
  16. #56
    Nov 06 2009
    It's to bad dealers didn't adjust their prices here when our dollar gets stronger. If it wasn't for the drop in the Euro and US dollar I would have never been able to do half of my mods.
  17. #57
    Apr 07 2007
    Mountain View, CA
    As of one hour ago prices for 3mm flat LEDs at c-leds.com (link in David's article) are $5.97 for qty.20.
    Had been $14.97 for qty.20 - almost 2/3 off.
    I just ordered mine.
    Cheers
  18. #58
    Nov 06 2009
    You bought the premade ones though right? :)
  19. #59
    Apr 07 2007
    Mountain View, CA
    Oh shit, I hope so.
    These http://c-leds.com/store/product.php?id_product=83
    Cheers
  20. #60
    Nov 06 2009
    Email them and cancel the order. These are what you need http://c-leds.com/store/category.php?id_category=134
    Oh and if your up for it I can use these: http://c-leds.com/store/category.php?id_category=60 :)
    I'll pay, just that they want to rape me for an additional $20 shipping. Pretty sure an envelope and stamps cost a lot less than that.
  21. #61
    Nov 06 2009
    Quote Originally Posted by Greg Nelson View Post
    Oh shit, I hope so.
    Cheers
    P.S. I love what your doing with your color choice. I really think it's going to look good with your interior.
  22. #62
    Apr 07 2007
    Mountain View, CA
    I'll order with my pre-wired lights a little later, I'll get the reds for you
    PM your mailing address.
    Here's an article from this month's National Geographic re the 'warming' of Greenland: http://ngm.nationalgeographic.com/20...er/folger-text
    Reading it just might warm you up - or not
    Cheers
  23. #63
    Senior Member Three Rings pretarion's Avatar
    Jan 02 2007
    Plano, Texas
    David, if you get the prewired 12v ones, does that mean you do not need resistors?
    2011 Audi A3 2.0T
  24. #64
    Apr 07 2007
    Mountain View, CA
    Quote Originally Posted by pretarion View Post
    Correct, if you buy the ones David listed in his DIY, resistors not needed. Here's my install using Amber LEDs in Beige interior
    Cheers
    2009 3.2L Sedan BB/Beige. VMR V710 Gunmetal 19" Rims. Exterior Chrome Trim painted Quartz Grey. LED ROW tail lights. KW V1. H&R RSB. StopTech PosiQuiet Pads, Painted Calipers. HOEN Xenon Match Fog Lamps. Fog Grilles converted to S-Line look. Stone Guards. Modified Votex Rear Diffuser. LED interior lights, cup holder lights & door pocket lights. RS4 Pedals. Remus Mufflers.
  25. #65
    Jan 02 2007
    Plano, Texas
    Greg,
    Thanks for getting back to me. Those look great! What source did you tap into to run them and what holders did you mount them with??
    2011 Audi A3 2.0T
  26. #66
    Apr 07 2007
    Mountain View, CA
    Greg,
    Again, I followed David B8's DIY regarding wiring and P/N's needed, including LED holders - buy extra of these, they're somewhat flimsy.
    I purchased an extra Audi cup holder ($55-$60 IRIC), prewired the LEDs myself (including using RTV [Silicon adhesive] to keep all the LED wires adhered to hidden surfaces of cup holders and not loose inside center console).
    Only difference I did from David B8's thread was adding a LED to rectangular opening (where I keep change) and having my mechanic install, as it required removing the center console.
    Cheers
  27. #67
    May 05 2009
    2010 A4 P+ 2.0T sedan
    Los Angeles, CA
    David, as for creating the harness, what is the cheapest way of purchasing the materials? Do they have to be oem? Thanks
    2010 A4 2.0T sedan: ibis white, Premium + : flickr
    debadged, black rear rings, black dash, zaino show car polish, llumar tint, kunst cf filler, chrome tips, höen xenonmatch fogs, VAG-COM
    LEDs: license plate, dome, map's
  28. #68
    Apr 07 2007
    Mountain View, CA
    Quote Originally Posted by l1fegam3r View Post
    DavidB8 has been unresponsive since June/July
    I will attempt to respond, as I have done this mod, based on his DIY - see my previous posts to this thread.
    IMO you really need to purchase the OEM wires and 'housings'/wire harness connectors because:
    1. the wires have Audi-specific connectors (male/female) at each end, which I have been unable to find/purchase. You need these Audi-specific connectors because -
    2. the wire connectors fit into the Audi wire harness connectors (the white plastic pieces - one is 'male' other is 'female') which must be connected to the existing wire harness connectors under your center console - these wires supply power and red surround light to the accessory plug under your center armrest.
    As I recall the OEM wires and harness connectors cost me about $35. If you can't get everything for that price, PM me for a link to purchase from an Audi dealer.
    Strongly recommend you purchase the cup holder P/N 8K0-862-533-6PS to pre-wire the LEDs b/f you remove your center console to install.
    Cup holder part includes the 2 cup holders and the rectangular section close to driver's seat - s/b approx. $55.
    Cheers
  29. #69
    May 05 2009
    Los Angeles, CA
    I have ordered the leds, led holders, and OEM connectors but I figured I would just wire the harness myself. I had a hard time finding the OEM harness parts at a resonable at price. The cheapest I have found the OEM wires are $3.30 per OEM wire so that $12 total for all 4 wires. I did not get the cup holder. But I figure I would once I sell it or decide to remove it. Overall it seems pretty inexpensive $14 for the pre-wired LEDs, $2.50 for the LED holders. The connectors were $1.98 for female and $5.90 for the male. I guess I will purchase the wires for another $12. It does not seem that difficult to remove the center console as per a illustrated guide I have.
  30. #70
    Apr 07 2007
    Mountain View, CA
    If it does not seem so difficult or 'pricey' (since you were looking for non-OEM parts), looking forward to your to your installation PICS.
    Remember, you get what you pay for
  31. #71
    Veteran Member Four Rings Stubek's Avatar
    Feb 13 2004
    2011 A4 Avant
    Santa Clara, CA
    Any luck on the write up for removing the center console yet?
    2011 A4 Avant Meteor Grey/Black, Titanium Package, Prem+ Nav, B&O. Tint, LED license plate lights, LED interior lights, custom sub, lots of VAG updates, APR Stage 1
    Build thread: http://www.audizine.com/forum/showth...ead?highlight=
  32. #72
    Senior Member Four Rings UmIsThisThingOn's Avatar
    Jun 03 2009
    1954 Deluxe Sunroof Volkswagen
    Northern VA
    Quote Originally Posted by Stubek View Post
    There's a write up on how to remove the Center console somewhere on the 'Zine... gonna go look around.
    Edit: Found it - the search actually worked!
    http://www.audizine.com/forum/showth...enter-Console?
    Tschüß!
    Šave
    ____________________________________________
    2010 Brilliant Black A4 Sline • Hüper Optik • Alu Kreuz/ÜSS • Hankook V12's • 034 HiFlo Turbo Hose • EC HFC • Milltek • ST-40 BBK
    Pending: Black Grill • Höen H11 • EC Intercooler
    Wish List: New Wheels • ECodes • EC Short Shifter
  33. #73
    Apr 07 2007
    Mountain View, CA
    http://www.audizine.com/forum/showth...rim?highlight=
    http://ocarbon.com/blog/2010/06/b8-a...removal-guide/
  34. #74
    Jul 20 2010
    Brisbane
    Where are people getting a replacement / extra cup holder from?
  35. #75
    Apr 07 2007
    Mountain View, CA
    Quote Originally Posted by futaris View Post
    http://www.audipartssuperstore.com/ in Westwood, Mass.
    I've been purchasing from them for 7-8 years, never a problem
    P/N 8K0 862 533 6PS - $55+shipping last June.
    Cheers
  36. #76
    Active Member Four Rings Miles M's Avatar
    Jan 17 2011
    Los Angeles, CA
    Cheers
    Greg, between your fog grills and these LEDs in the cup holder, I want to hire you! haha.
    This looks like a fun project, but I'm far too lazy to attempt it.
    New Enthusiast Lifestyle Community > www.TeamUnderground.net
    Find Me On Facebook! - My Build Thread > Miranda
  37. #77
    Nov 06 2009
    ok since I have to replace my cupholder all my hard work to put the LED's in is out the window. So it's actually a hold up to getting my console back in my car so I finally bit the bullet and started looking at alternate methods for the install. Instead of drilling them into the main unit I tried drilling out one of the spring loaded clips instead.
    What do you think of this method? The light will never be visible to the naked eye and just push back when a cup is put in.
    What do you guys think?
    I can always notch the back to allow a little more room for the wires although I don't know if it would be needed.
  38. #78
    Feb 13 2004
    2011 A4 Avant
    Santa Clara, CA
    That is one of two methods I was going to use when I do this mod.
    Just as a teaser, the other method was going to be to trim out an entire ring all the way around that is about 1/16th-3/32nd tall and backlight the entire thing from under neath.
  39. #79
    Nov 06 2009
    I just lit the one up and it lights really well considering. Since the little clips can be removed I can actually put one in each of them making it light more evenly than the past method. I wont be doing any major playing with this cup holder considering I had to get it from Europe and I'm not going to be risky with it.
