Results 1 to 40 of 79
    Senior Member Four Rings DavidB8's Avatar
    Nov 06 2009
    Oakville, ON, Canada
    LED's in cup holder
    Still in the playing stages. The idea is this would plug into the harness with the 12v power point in the armrest so it would dim with the rest of the lights. Right now there are only 3 LED's in place and I can change their light pattern by moving the LED in and out of it's holder a bit. I'm not thrilled with the mountings just yet but it works pretty good.
    Mods:Votex spoiler, tint, Clear Bra, S4 replicas, Audi winter and trunk mat,mud flaps, Dipstick, oil pan heater, KW V2's, AWE Dual Exhaust, Votex valance, AWE FMIC, Eurocode IC pipe, PIAA fog lights,Vag Com, APR Stage 2, E-Codes, trunk mount emergency triangle, LED plate bulbs, Audi compressor and tire repair kit, RS4 Pedal set, Power Folding Mirrors, S4 steering wheel, heated rear seats, ski pass through.......
    www.audienthusiasts.com
    Senior Member Four Rings a408's Avatar
    Nov 06 2008
    BAT b6 a4
    Bay area, CA
    Mmmm i like it
    - Josh
    Old > 1.8 GT2871R - 278whp on 91 oct [Video]
    Building > 2.0 PTE5857 on E85 [Thread]
    Feb 10 2004
    2009 A4 2.0T Sedan
    Nice!. Now if you could also make it keep drinks cool...
    CURRENT: '95 Ur S6 Avant | '12 A6 3.0 TFSI sedan
    Nov 06 2009
    As soon as I can find one on ebay from a Q5....
    Senior Member Four Rings ThePiombino's Avatar
    Dec 01 2008
    North JerZ
    Quote Originally Posted by DavidB8 View Post
    Love the idea. Is there any way to make these LEDs switchable, independent from the rest of the interior lights? Just wondering if this would be more noticeable to the driver, thus having the ability to switch on/off might be beneficial.
    09 A4 2.0T Quattro - Tip - Black/Black /// MODS: APR Stage II+ l AWE CB Exhaust l 034 HFC l EC HFIC Pipe l Forge DV Spacer l 3M Di-NOC Carbon Fiber Interior Trim l 3M Chrome Grille Trim l SG Supreme 28 l Debadged l Fly Eyes Kit (f&r) l Needle Sweep l Window/Moonroof control w/Keyfob l Seat Belt Chime Disabled l "Wink" Disabled l Double Unlock "Beep"
    Nov 06 2009
    Anything is possible. You could wire them into a switch if you wanted and still had them go to the rest of the lights and dim when they are turned on. The cup holders are back from you so I don't think they would be distracting.
    Dec 01 2008
    North JerZ
    Sounds good. I do think that the light would be caught in our peripheral, but it's not THAT big of a deal. Not like the LEDs are shining in our faces, so it wouldn't be a big deal...like you said.
    Senior Member Three Rings ACowabunga's Avatar
    Feb 24 2010
    OC, CA
    I like where you're headed with this mod. Would wiring them to the foot well lights to do the trick because then you can adjust it via the MMI screen? Also, a cooling cup holder would be wicked cool!
    2010 Audi S5: Meteor Grey || Tuscan Brown
    Nov 06 2009
    I'm sure you could wire them to the underseat lights and it's something I was wondering about. The only thing is trying to do it in a nice easy manor. I like plug and play and I'm not sure off hand where the wiring runs from for the seat lights. If it goes through the centre console it could be as easy as splicing one wire. Wouldn't be plug and play though which I can do using the lighting from the 12v plug from the arm rest.
    Sep 09 2009
    09 RDX
    LongIsland
    Love it now I want it. Did you drill 3 holes under every spring? And what LED are you using?
    Senior Member Four Rings rjpeaks's Avatar
    Sep 11 2009
    boards n wax
    Huntington Beach
    great idea.
    Nov 06 2009
    Quote Originally Posted by linet90 View Post
    On hole under 3 of the springs. Could add more to the rest I suppose. I'm still assessing. I used 3mm flat top LEDs to keep it flush and not interfere with the cup holder along with 3mm led holders and of course some 1/4 watt resistors. Still no where near a DIY yet but should be done playing soon and I'll write one up.
    Sep 09 2009
    09 RDX
    LongIsland
    Cant wait to see. Who is your LED supplier?
    Nov 06 2009
    ebay :)
    Stage 3 Forum Advertiser Four Rings ECS Tuning-Audi's Avatar
    Oct 02 2006
    Wadsworth,OH
    Yet another nice one! How does it look with the cluster/interior lighting?
    Nov 06 2009
    I don't have a center console in my car right now so the cup holder is here in the living room with me:)
    I think it should blend pretty good. This is my trial cup holder, my new cup holder should be here in a week or two and I'll do a permanent install and get the centre console back together. If I can figure out a good angle to shot a pick I may place my console back in over the weekend and snap a few pics. In the interim I thought I would post a bit more of a teaser. This is what it would look like with a bottle of water in it.
    Apr 07 2007
    B6 A4 3.0 (Wife's Ride)
    Mountain View, CA
    Extremely intriguing
    Assume necessary to remove entire center console - PITA (did last month to replace my console wood trim from almond beige to walnut burl).
    Would like to do LEDs in cool white or warm blue. Hope your eBay seller has such or similar colors.
    Wire to dash/console lights so that activated off them/at night, rather than using 12V plug in console possible?
    Cheers
    Senior Member Three Rings ASU Daniel's Avatar
    Oct 03 2009
    2009 A4 2.0T
    Scottsdale, AZ. Vicenza, Italy
    neat
    Nov 06 2009
    Well I'll give a source for the Yanks to get them pre wired. I found a place that has them wired with resistors and ready to use but after I ordered using their checkout and shipping crap they emailed me wanting another $20 for shipping. Can you imagine a $20 surcharge for shipping 20 LED's... But for you guys it would be good since the shipping is cheap in the US and they have multiple colours (sorry colors) to choose from :)
    Greg my thought was to get the power for the lighting from the ring that is around the 12v plug. I haven't checked yet but I assume it dims with the rest of the lights. If not then getting the lighting elsewhere wont be hard. Theres a main harness running through the centre console with lighting wires in it.
    Senior Member Three Rings Sin_city_Rings's Avatar
    May 09 2009
    Las Vegas, Nevada
    Yet another clever mod..... good work!
    '12 Monsoon Gray A4
    |20" RS6 wheels| H&R Sport Springs|H&R Spacers|15% Tint|Vagcom'd|
    PAST: '08 A5; '09 Sline A4; '07 Sline A4
    Senior Member Three Rings CLEAR's Avatar
    Aug 28 2009
    2009 Audi A4 3.2Q Aruba Blue
    Pasadena, CA
    brilliant ! hats off to you david..
    graphic designer - photographer
    Sold : Ducati DESMOSEDICI D16RR
    Nov 06 2009
    I had a quick look at the wiring and there is a light control wire going to the 12v plug in the centre console so this can be made up to be a plug and play type wiring job or splice for those that choose to. I'll have this one written up over the weekend.
    Nov 06 2009
    Oh for those looking here is a link to the US seller that wanted to rip me off for $20 additional shipping. I see they have since added a note about asking them about how bad they are going to rip you off if your not in the US. I just mailed a box to the US for $6.00 and they wanted $20 for a small envelope (yes I'm jaded)...
    Any ways go for the 3mm LED's if your going to buy some. I'll dig up a link for the holders I'm using from ebay. http://c-leds.com/store/category.php?id_category=57
    Active Member Three Rings T-Audi's Avatar
    Jul 19 2009
    Nothing Just My Audi
    Houston,Tx
    Very nice mod !
    T-Audi
    Sep 09 2009
    09 RDX
    LongIsland
    will the holders on their website not work?
    Nov 06 2009
    They only have 1 3mm holder on their site and it's a big metal one. The ones I use are black and pretty well flush mounted in the cup holder to prevent them from interfering with the holder itself.
    Sep 09 2009
    09 RDX
    LongIsland
    sounds good
    Apr 07 2007
    Mountain View, CA
    David,
    Looking forward to this write up for my next interior mod, now that I've FINALLY installed the under-seat storage boxes
    per your earlier write up - greatly helped a warm weather dummy like me
    BTW, the bolts holding the seats to the floor on my 2009 3.2 sedan were M10 Star bolts, not T50 torx - borrowed the socket today from my service guy to get seats out.
    Prices for the LEDs on your link are reasonable for sets of 20 and he's got lotsa colors.
    Again, thanks for all your incredible and amazing efforts.
    Cheers
    Senior Member Four Rings Ryan_T's Avatar
    May 11 2009
    09 A4 2.0T
    T.O - Canada
    I wonder if you can extend this to lighting up the door-card bottle holders. A small hole and an LED would to it, and it'll cast a nice glow along the door.
    We may not have an A8, but why not?
    Ryan - flickr
    Veteran Member Three Rings t0mt0m's Avatar
    Apr 26 2005
    Nothern Va
    little mods like this is why i like the a4 forums more :)
    B8 S4 '10 6MT |Brilliant Black|Atlas Carbon Fiber Inlays|Bang & Olufsen (7/22/10)
    MODS: STRAT INTAKE (8/5/10)|25% TINT ALL (8/7/10)|034 HFCS & Milltek RES W/DPS (1/6/11)|THULE SNOWBOARD ROOF RACK (1/20/11)|JHM SS (2/13/11)|AWE BOOST GAUGE (5/10/11)|BLACK OPTICS GRILLE (6/14/11)|APR 93 FLASH (7/16/11)|APR PULLY (7/2711)|EUROCODE ALU KREUZ(7/27/11)| KW V2 & STRAT SPACERS (8/21/11)| APR STAGE II SOFTWARE V1(10/13/11)| STSTOPTECH STREET KIT & CLUTCHMASTER FX400 (3/7/12)
    Apr 07 2007
    Mountain View, CA
    Ryan_T,
    Amazing suggestion
    Get going, David!
    Cheers
    Nov 06 2009
    Oh sure ruin my next surprise. Actually the thought I was having was to light up the entire pocket not just the bottle holder but I wanted to look at the door more before making a call on it. I was actually wondering about putting LED's on the bottom of the door handle itself so they wouldn't get covered if you put something in the pocket. The advantage there is very little wire to run to get to a lighting source. Any ways I was going to pull a door card off this weekend and look so I'll let you know what I find.
    May 11 2009
    09 A4 2.0T
    T.O - Canada
    Hahah, sorry. It was just natural progression, I suppose. Here's my inspiration:
    Ryan - flickr
    Nov 06 2009
    Its strange looking at the picture, it looks like they use red light where the bottle holder would be we and a white light shining into the pocket. If we can get some closer pictures we could look more at a factory type install.
    May 11 2009
    09 A4 2.0T
    T.O - Canada
    Open image in New tab for Full Size.
    Ryan - flickr
    Nov 06 2009
    Ok wasn't really ready to start thinking about the doors yet but lets get some thoughts going. Light the pockets from the bottom of the door as in up have lights in the bottom of the pocket facing up? OR maybe buying some factory LED lights like that are used under the seats and swapping the LED's over to red instead of the bluish light and cut a hole in the bottom of the door panel and install an actual light.
    Thoughts?
    Sep 09 2009
    09 RDX
    LongIsland
    I think putting one on the bottom of the door cup holder would be cool and having it light up like you have in the picture above, white? One of my friends put small strobe lights in his A4 by the rear window that could be a idea but I think its a over kill. And what about putting a LED in or by the door handle?
    Sep 09 2009
    09 RDX
    LongIsland
    I just took a look at my door and my idea wouldn't work as I posted before. I think putting two LED lights under the window controls would look best one that would shine onto the bottle holder and the other to light up the rest of the pocket
    Nov 06 2009
    So you would go with Red LED's or White? I'm guessing the idea of installing a light like whats in the B8 doesn't appeal?
    May 11 2009
    09 A4 2.0T
    T.O - Canada
    I think for a black interior, red is nicer. In the A8, the white or yellow light was used on lighter interior where the features become a highlight. In the black B8 interior, the white light would highlight dust.
    I'm just gauging this from the fact that even in our dark interior, the existing red light on the door handles and the overhead center panel looks nice, whereas the footwell lights don't.
    Ryan - flickr
