Results 1 to 31 of 31
    Senior Member Three Rings B8 Phantom S4's Avatar
    Aug 23 2009
    2010 S4
    SF Bay Area
    Angry Another "Low Coolant" Thread....
    So, I was out enjoying the beautiful weather today in my car when I hear a beep and see the "Shut car off. Low coolant" error message. Man, I'm so irritated right now because my dealership's service dept doesn't open on weekends and I have to wait until Monday to take her in and get checked out. I was really hoping to enjoy this weekend and take a road trip....arrrrrggghhhhhh!
    Does anyone know if this is fixed for good with the metal blade replacement? I'm also a little bit peeved because I took my car in for the 5K mi service about a month ago, and asked the service manager if they could go ahead and switch out the blades preemptively so I could avoid this, but they weren't able to.
    Sorry for ranting, this just really sucks, and just thinking that I'll be without my car for some time makes it even worse.....
    2010 Phantom Black Pearl S4 Prestige 6MT
    Audi Drive Select
    Carbon Atlas Inlay - Driver Assist - Black on Black alcantara
    30% Llumar Ceramic Tint all around
    APR RSC cat-back exhaust
    Oct 25 2009
    Overland Park, KS
    Audi simply need to issue a recall for the water pump problem. So many owners being left stranded because of a known defect. This is really hurting Audi's credibility and may well hurt future sales. This is no way to treat customers who have spent north of $50K on their car.
    Bish
    Aug 23 2009
    2010 S4
    SF Bay Area
    Ok, so I have a pretty shitty update to this story.
    I was able to get my car to the dealership this morning by topping off the coolant with some water. Turns out I didn't have a water pump failure, but instead what they think might have happened is that a rock may have hit the radiator and caused it to start leaking. This is obviously not something that's covered under warranty, so it was my bad luck that this actually happened to me and now I'm going to be out $650 and w/o my car for the day. It doesn't seem like they will be replacing my water pump, even though they are aware that the plastic parts do tend to fail and that I have the defective plastic piece on my car.
    Audi Drive Select
    Sep 16 2006
    SOLD: RS5
    That sux Rob. Can't believe I missed you at the dealership today, I was there for about 2 hours.
    __
    SOLD: []RS 5
    Suzuka Grey Pearl
    HRE|Bilstein|AccuAir|Capristo
    Veteran Member Four Rings NWS4Guy's Avatar
    Sep 29 2009
    2015 Range Rover Evoque 2010 Audi S4
    Yea someone else posted that they had a piece of road trash hit their intercooling radiator a week or 2 ago and cause this
    Like a surgeon with a scalpel, my S4 is a precision instrument, with which I carve and dissect my way through traffic.
    2010 S4 Prem+, Quartz Gray, S-tronic, Sport Diff, B&O, Nav, Gray Birch
    StopTech ST-60 BBK - Stratmosphere intake - APR v2.2 Stage 2 w/pulley + exhaust, v2 Coolant System
    Alu-Kreuz, Apikol rear diff mount, 034 transmission mount
    Veteran Member Four Rings riegeraudi's Avatar
    Apr 16 2009
    Did Audi not shield the radiator enough because this doesn't happen often does it?
    Sep 29 2009
    Quote Originally Posted by riegeraudi View Post
    There is not any shielding other than the grill, look for yourself, you can see everything right there.
    Aug 23 2009
    2010 S4
    SF Bay Area
    Well, I hope for everyone else's sake that this isn't something that would happen often, cause it's pretty annoying. I was thinking of putting up a mesh screen when I get the car back, but I'm not sure how it would affect the airflow to the radiator.
    Audi Drive Select
    Veteran Member Four Rings Ynnekdude's Avatar
    Dec 10 2008
    Chicago
    That's a shame to hear. Sorry about the poor circumstances. I would suggest looking into a mesh. I'm sure it can be done. Maybe you can then sell your own protective mesh... make a little money out of this?
    Regarding the water pump:
    From what I've seen, a majority of the water pumps which failed were in very cold climates. Mine (though on an A6, same engine/problem) went out when it was below 0 degrees outside. Though it sucks you have something which may be prone to failure, I wouldn't let it stress you out too much unless you plan on going on a road trip in the winter months.
    2011 Q5 3.2 Prestige. Meteor Gray.
    2009 A6 3.0T Sedan w/19" Sport Pkg. Phantom Black.
    APR 93 Stage II+. STaSIS Exhaust. SST Intake. Stoptech ST-60. KW V1s. H&R Sways
    V1 Hardwired. LI-Dual. 18" VMR 708s w/Michelin Pilot Alpin PA3s (Winter)
    Sep 29 2009
    Mesh won't hurt things, APR's racing S4 uses it (pics courtest Josh over at QuattroWorld, who has some awesome shots and a writeup from the weekend's fun at VIR - http://www.quattroworld.com/apr-moto...romise-at-vir/ )
    Oct 11 2009
    S4 B8 SprintBlue S-tronic
    Russia
    Hello, guys!
    One of the first things I've done after buying this car in June'09 is installing a fine mesh screen covering intercooling radiator and condenser behind the lower half of the grille.
    Roads are nasty in Russia, especially in winter, there're plenty of - as you call it - road debris.
    I've done it without removing the front bumper, simply removing black front plastic cover atop of the radiators under the hood. Was a little tricky and took me 1,5 hours - but it works.
    Fins of the intercooling radiator are very thin and can be easily bent by little stones and insects at high speeds.
    Mesh screen is universal, made from aluminium, the colour is black - absolutely invisible from the outside.
    Sorry for my English - I'm an ignorant Russian bear... just love Audis.
    Aug 23 2009
    2010 S4
    SF Bay Area
    Quote Originally Posted by Nickyracer View Post
    Hello, guys!
    That doesn't sound like something an "ignorant Russian bear" would do. You should give yourself more credit than that! I'm in the process of looking for some mesh to use. Probably take a trip to home depot this weekend and see what they have.
    Audi Drive Select
    Oct 11 2009
    Russia
    Quote Originally Posted by B8 Phantom S4 View Post
    Thank you. As for the bear, that's just a little bit of humor
    This mesh can be shaped and cut with a scissors.
    And a little off-topic: are you from SF Bay area? Alfred Hitchcock's Vertigo is my favourite movie.
    Dec 10 2008
    Chicago
    You mean you're not a bear!?
    Oct 11 2009
    Russia
    Quote Originally Posted by Ynnekdude View Post
    Not exactly You think every Russian is a bear?
    Like Nikolay Valouyev (famous heavyweight boxer)?
    Aug 23 2009
    2010 S4
    SF Bay Area
    Yes, that's where I'm from. Vertigo is a great movie. I'm a fan of Hitchcock myself.
    Audi Drive Select
    Jan 17 2010
    Cleveland, OH
    So something hit my intercooler radiator and drained all my coolant too. This seems like a design issue in that it is not protected enough. I was on a freeway when I got the notice to turn off my car due to low coolant. I spoke with Audi of America and they did nothing to help as it is normal use or wear and tear. What sort of mesh or screen should I use? I have a bad feeling this is going to happen again. Why can't Audi fix this issue or at least sell a part for people who want to be extra cautious??
    I am not too happy about having to put $600 into my $50k+ car after 2,000 miles.
    Anyone have any suggestions?
    Veteran Member Four Rings LeadToRome's Avatar
    Apr 25 2010
    I-95
    This would be an awesome and very useful project for the DIY crowd to do and document, as it sounds like it might be simple enough for the "mechanically impaired" among us to take on if we, errr, THEY had some guidance.
    Sep 29 2009
    Quote Originally Posted by LeadToRome View Post
    I can do this, likely tomorrow I hope, just got back from a week out of town and meant to do this anyway. Shouldn't be too terribly difficult, I had the cover off to see this area from the top when I did my HID bulb swap DIY.
    Apr 25 2010
    I-95
    Quote Originally Posted by NWS4Guy View Post
    Nice. I look forward to seeing it.
    Sep 29 2009
    Mission accomplished, took about 10 minutes, was pretty easy overall for most anyone to do. Editing pics and uploading them/writing the DIY, will post in a new thread soon.
    Stage 2 Banner Advertiser Four Rings ModBargains II's Avatar
    Mar 09 2010
    La Habra/CA/USA
    Wow, great idea with this mod guys!
    Functional, plus it looks pretty good!
    It would definitely suck to get stuck with a big repair bill because of a little piece of debris..
    If anyone is looking for some high quality mesh for a more OEM quality look, I have access to RaceMesh Grills, that I could have custom cut for this application.
    Theres a lot of high quality and unique finishes available.. check it out:
    Contact me at Jason@ModBargains.com if anyone is interested!
    Eric Lambert | Eric@ModBargains.com | (714) 582-3330 X 8011
    AWE Tuning | Audi Wheels | HRE Flow Form Wheels | Avant Garde Wheels
    Hours: Monday - Friday 8:00am-5:00pm (PST), Saturday 8:00am-5:00pm Modbargains Blog
    Veteran Member Four Rings Deckdout2's Avatar
    Sep 13 2010
    2010 Audi B8S4 Ibis Prestige
    Charlotte, NC
    Items for Sale
    This is the exact reason I went ahead and upgraded to the APR CPS system. My stock intercooler failed. Nice timing too. :)
    APR CF Intake | APR SC Pulley | AWE Non-Res DP & Touring | APR CPS | APR ECMS Stage II v3.0 | H&R SS Springs | Hotchkis F/R Sways | Alu Kreuz Stabilizer Bar | USS F/R Endlinks | SPC Control Arms | 6000K Blesk HID & Fogs | LED Interior | 20 x 9 +35 Rotor Reps | 255/30/20 V12 evo2 | RS6 Pedals | RS6 Shift Knob | Audison/Hertz Amp & Sub | RS4 Grill | Deval CF Splitter | Facelift Flat-Bottom | S6/S7 Start/Stop Button | oCarbon Red CF | Relak v2.0 Paddles | ECS Stage 1 Brake Kit
    Veteran Member Four Rings Leor604's Avatar
    May 25 2010
    Vancouver
    Quote Originally Posted by ModBargains II View Post
    That looks a lot more durable (and is better looking) than the hardware cloth most of us have used. Bet it costs a bit more than $20!!!
    | 2011 S4 | Premium (Canada) | Quartz | Black Nappa | 6MT | ADS | Nav | B&O | SPO goodies |
    Dec 19 2004
    So how much would a piece of Black Chrome or Black Wrinkle cost, including cutting and shipping?
    Veteran Member Four Rings B8 S FOR's Avatar
    Feb 15 2011
    Pittsburgh, PA
    Go to your local hardware store 1/4" Galvanized Metal Mesh...cost me $15 and 45min of my time. Problem solved!
    AUDI 4 LIFE.........B8.5 S5 Cab Prestige/ Mythos Blk Met, Carbon inlays, B&O Stereo, Air Cond Vented Seats, Hardwired V1...yada yada yada. . . . .
    Jun 13 2014
    Albany, NY
    Just took out my supercharger radiator by getting a pinhole leak because of road debris. Apparently a small rock at "highway speed" can cause a serious headache. Does anyone have an update on a good DIY for mesh and for replacement of the radiator? I tried to search but it isn't working on my phone.
    Veteran Member Four Rings PitchS4's Avatar
    May 15 2007
    Falls Church, VA
    This thread is dead for a reason. There is a good DIY and an OEM screen on newer models (which is what I did). Search.
    Current:
    2014 Estoril Blue SQ5 | EPL Stage 1 | H&R-3/Bilstein | Alu Kreuz | 034 RSB | 034 Tube w/ AFE Pro Dry | 10F/15R Spacers
    Stock Golf Mk7 (Wife)
    Previous:
    B8 S4 - Tuned, Loud, Low
    B6 S4 - Tuned, Loudest, Lowest
    B5 S4 - Custom Tuned Stage 3
    Veteran Member Four Rings mr shickadance's Avatar
    Jul 08 2010
    tucson
    danbury
    only on a german auto forum will you have people claiming "defective design" when a rock comes up and cracks a radiator.
    Sorry it happened to you, but these things happen across all auto platforms, it's just a freak thing that happens. You can go cover it up with some mesh, but it seems overkill for something that happens on a rare occurrence.
    [CENTER]Scott
    2011 S4
    America is all about speed, hot, nasty, bad-ass speed - Eleanor Roosevelt
    Senior Member Four Rings jygesq's Avatar
    Aug 22 2014
    1986 Honda CH 150 D scooter bought new
    bloomfield,ct
    not as rare as you think. Some road debris hit my 2015 s4, it entered through the lowest opening in the spoiler. It cracked two of the three ribs that are supposed to prevent stuff from getting in. I used JB plastic weld to reattach the ribs. Each was only broken on one side of the attachment point. The paint inside was scuffed up a bit. but not noticeable unless you get down on your hands and knees and look in with a flash light. The debris was not in the opening, I guess the impact with the ribs pushed it back. The screen that protects the cooler was not even reached. I do think that opening being so low to the ground should have a full screen on it, not just the 3 ribs.
    2015 S4, P+, Florett Silver,black /silver nappa leather, S-tronic ,sport diff,B&O ,tech package ,supercharged badges. All season tires ,cargo net, factory dip stick
    Feb 25 2013
    MI
    Quote Originally Posted by mr shickadance View Post
    Audi put plastic covers on the higher up models and then started putting them on the B8's around 2014. So I would say there was something wrong about the design to begin with. Been a while since I've seen someone with this problem, while back in 2012 (when I got my car), these threads were pretty common. And it's not because all the DIY people here, it's because Audi included the part standard.
