Page 2 of 2 FirstFirst 12
Results 41 to 71 of 71
  1. #41
    Senior Member Four Rings Operator's Avatar
    Feb 06 2009
    Audi A4, Mit. Montero, Escort
    Wellington, CO/Cheyenne, WY
    ^^^ Mods?
    Edited: most recent Dyno
    K0R-GT Maestro tuned
    Info:
    Build
    History
  2. #42
    Senior Member Four Rings jimrobbington's Avatar
    Dec 03 2008
    07 Suzuki SV650
    Parker, Colorado
    ^^^ Mods?
    This, and engine? It holds torque better than my dyno, probably because it is lower.
    JR
    05.5 A4 2.0T 6spd, REVO Stage 2, Vast Stage 3 clutch, VMR test pipe, custom 2.5" Techtonics exhaust, Borla mufflers, wastegate adjustment, 034 catch can, BKR7E, JHM Short Shifter, KW V1's, 19" V710's, Podi boost gauge, 640 Mod, 18% tint.
    Dyno proven 221 whp/302 wtq!
    Driving Style: Strategic Aggressor
    Eric Paul Young: "I just tore down my old boy and slapped the internals."
  3. #43
    Nov 02 2011
    800bhp Saab NG 900, Saab 9000 Aero, Saab Viggen, Saab 9000, Saab vert
    Longmont
    This is a 06 A4 quattro B7 2.0 FSI motor on awd dynojet with the stg1 I just finished developing, stock exhaust, diverter valve update kit and that is about it. I will be doing the test pipe to see how that helps, then the exhaust and stg 3 development and then maybe the gt28rs and think that will be about where I put a stop to it for a while. Have done lots of gt3071wg turbos on the Saabs and love that too, but looking for a good compromise of spool and power. Have heard the k04 is not worth messing with
    and only delivers a small gain, so think I will go right to the gt28rs disco potato :-)
    JZW
  4. #44
    New Member One Ring
    Nov 06 2011
    newyork
    Hmm, so if I do the math on the 3.2 dyno that means that at an ideal 255 CHP at sea level, if we take an average of 215 AWHP, the corrected driveline loss is 17%. If it was taken at elevation then the percent loss gets even smaller. Wow, maybe I should tell this to all the guys who go to the dyno with a BAT setup and try and apply a 25% correction factor because they're butthurt about not getting the numbers that they wanted. But ahh, but what do I know.
  5. #45
    Nov 02 2011
    Longmont
    I see no matter where you go, the ol Sae elevation argument is always there and its almost always from people that live at sea-level and go off theory. I do live at elevation and have dyno after dyno after dyno to compare real world data and have over 10 dyno sheets showing almost identical numbers in sae in Denver and at Sea-level and I have had this argument on other forums for years. I don't want to have that argument here, will just say compared it to other name brand tunes and the numbers were right in the ballpark with the best, one was higher by 3bhp and one was lower by 2bhp and one was exactly the same.
    From some of my latest test, sea-level sae car with the same tune made 11bhp more than the sae numbers at elevation, the smaller turbos just cannot make the same boost and or airmass at elevation, they have to work harder to make the same power, they make more heat and the stock ic is less efficient and then the dynamic llosses and the heat dissipation and the list goes on and on and there are many variables that you do not normally thing of when running a car at elevation. I like to look at the end result and compare to other cars on the same brand of dyno at lower elevation and draw some conclusions from that.
    As you probably know, dynos can read different too, its only a guide :-)
    The drive-train loss can also be argued, many are using 21% and many of the top name brand dynos posted here are also using over 20%, so what is the real number? Only an engine dyno would tell you exactly what the loss is, so the only fair thing to do is to use the same loss that other tuners use, even if the numbers are not dead on accurate.
    Will be testing the cat test pipe soon to see what kind of gains are there and it also looks like my maf may be bad.
    JZW
  6. #46
    Active Member Two Rings B7Daily's Avatar
    Dec 25 2010
    B7 A4, MK2 GTI, ummm and alot of other things
    Hopkins/mn
    AWE quad tip Black exhaust | AWE Boost gauge vent | APR HPFP | APR all program software | PSS10's | Stern adj. conrtol arms | 19x9 19x11 Auto Art wheels | H-Sport Front and Rear | Poly Drive train Mounts | RS4 Engine mounts | BBK Porsche 350MM | O34 Studs | Test Pipe |
    AWE quad tip Black exhaust | AWE Boost gauge vent | APR HPFP | APR 2+| PSS10's | Stern adj. conrtol arms | 19x9 19x11 Auto Art wheels | H-Sport Front and Rear | Poly Drive train Mounts | RS4 Engine mounts | BBK Porsche 350MM | Clutch Masters stg. 4 | O34 Studs | Test Pipe | BSH CC | S4 Interior |
  7. #47
    Registered Member Two Rings pandacover's Avatar
    Dec 11 2011
    live in china, business in USA
    detailed date
    thx
    Audi RS6 C5 sedan
    car cover motorcycle cover
    pandacover
  8. #48
    Nov 02 2011
    Longmont
    I put a Cat Test pipe on the 06 A4 Quattro and put it back on the dyno after I tuned it again. I held the torque back a little down low and it seemed to help it run much stronger up top and it really takes off at 4k and pulls hard up top on the road, will probably lean it out just a little bit past 6k. Put down 235whp and 270wtrq, that would be 290bhp and 335 ft-lbs with AWD 20% drive train loss. It feels very strong and it handles so much better than the Saabs I usually tune :-) Its a rocket ship now. Next step will be front mount and probably right to the disco potato :-)
    JZWhttp://www.facebook.com/photo.php?fb...type=1&theater[IMG]
  9. #49
    Dec 03 2008
    07 Suzuki SV650
    Parker, Colorado
    What tuning?
    JR
  10. #50
    Sep 03 2011
    Panama City
    so apr stage 1 isnt really what apr says it is? as for as hp and tq?
  11. #51
    Dec 03 2008
    07 Suzuki SV650
    Parker, Colorado
    APR, while a good, safe option, is one of the lowest powered tunes.
  12. #52
    Active Member Three Rings mec's Avatar
    Jul 25 2010
    Denver, Colorado
    Quote Originally Posted by blakeow14 View Post
    Most tuners report hp and tq with 93 octane fuel
    2006 / A4 Brilliant Red / 2.0TQM /
    AG M310 19x8.5 / KONI FSD / APR / 034HFC OEM RS4 catback/
    HPFP /s1 pump 145 PRV/ A3 RNS-E Retrofit/
  13. #53
    Nov 02 2011
    Longmont
    What tuning?
    JR
    I am a tuner, you can find me under jzw saab :-)
    John
  14. #54
    Registered Member One Ring beastofthewoob's Avatar
    Feb 25 2012
    Boston, MA
    Just had a Unitronic Stage 1+ tune done at Swift Performance Automotive in Norwich, CT. Temps were in the 40s. 93 octane fuel. Dyno was a Dyno Dynamics.
    Stock A4 B7 2.0T auto dyno'ed stock at 175 whp and 175 wtq. We were surprised to see these numbers, especially with the car at 69,000 miles.
    Stage 1+ dyno'ed at 177 whp and 216 wtq, which I felt were low, but the torque and horsepower gains were +46wtq and +31whp respectively, right where I can use them. Tapering off above 5000 rpm was attributed to possible carbon buildup on the intake valves. Also, the tiptronic forced us to dyno in 3rd gear.
    The car pulls much harder than stock, and acceleration on the highway is very quick. I'm looking into cleaning the intake valves and getting an intake or exhaust. I'm pleased with the mod, even if the numbers aren't dramatic...
  15. #55
    Feb 25 2012
    Boston, MA
    Dyno graph below:
  16. #56
    Dec 03 2008
    07 Suzuki SV650
    Parker, Colorado
    A little disappointed in Unitronic lately. What exactly is 1+, as opposed to just 1? Don't worry about an intake at all, exhaust is all you need to go stage 2. Have you gotten a boost gauge yet?
  17. #57
    Dec 03 2008
    07 Suzuki SV650
    Parker, Colorado
    Quote Originally Posted by JZW View Post
    John
    Wow, really awesome! So what mods besides tuning were on that car when you made 235 whp? I like that number, guessing there has to be exhaust. See, I have amazing numbers for stage 2, I mean, I put down bigger numbers than the APR 2+ dyno above, and my torque spike is awesome. I love it. But your tune is the first (I'm guessing on this) "Stage 2" car I have ever seen with more HP than mine. Granted, they were all different dynos. Who cares. Just go with it.
  18. #58
    Feb 25 2012
    Boston, MA
    The 1+ tune is for 93 octane gas. Here in Massachusetts it's difficult to find 91 gas, so I've been using 93 since I bought the car. I figured for an extra $50 (over stage 1) I might as well get tuned for the higher octane fuel I'm using anyway.
    I do not have a boost gauge - I'm trying to keep it as stealth as possible in case I need to go back to the dealer (their intake valve cleaning was about $300 less than the speed shop). Would you recommend - if so, what's the best place for it?
    Any exhaust recommendations?
  19. #59
    Account Terminated Two Rings
    Mar 02 2012
    Miami FL
    I'll have a Revo Stage 2+ with W/M dyno coming within the month
  20. #60
    Dec 03 2008
    07 Suzuki SV650
    Parker, Colorado
    Quote Originally Posted by BlackGecko View Post
    Hurry up!
    JR
  21. #61
    Veteran Member Three Rings TrboPowr's Avatar
    Nov 23 2005
    2007 A4 S-line Turbo, 2007 A6 Avant
    Washington DC
    Recorded 350+ awhp and 330awtq at RAI's Dyno Day a week ago, will post graph up shortly. This was performed on a Mustang dyno.
    Drew
    2007 RAI B7 BORG WARNER EFR
    Deval│Vorsteiner│Bilstein│Brembo│Oettinger│Borg Warner
    Mods = Bitch slap to my bank account
  22. #62
    Senior Member Three Rings audi8844's Avatar
    Jun 17 2009
    Kent Island, MD
    Quote Originally Posted by TrboPowr View Post
    YES!!! This is what I have been waiting for. I want to see the complete powerband. Very impressive on the heart breaker
    Jordan
    2008 A4 2.0t Quattro - Unitronic Stage 1+, K&N Drop-in, KW V1s, VMR V701 19x8.5, RS4 Rear Sway, 034 Snub, Zimmermans & HPS, Podi Boost
    Nothing else right now... saving up for GTX
  23. #63
    Nov 23 2005
    Washington DC
    ^^^ Thanks buddy, ill have Ray email me the file tomorrow while im at work
    Drew
  24. #64
    Jun 17 2009
    Kent Island, MD
    Drew, any luck with getting the dyno file?
    Jordan
  25. #65
    Aug 05 2011
    2005.5 Audi A4, 2005 Wrangler Rubicon
    CO-WY
    Here are all three of my runs- if you noticed my car never boosted past 15.4 or so psi at all. This is because of the timing issues I am having from unitronics software.
    godspeed fmic, bsh pcv stg1, custom exhaust, test pipe, cai,
    First run-
    2005.5 Audi A4 2.0T
    in progress......
  26. #66
    Active Member Three Rings ericpaulyoung's Avatar
    Feb 24 2011
    '08 a4 b7 6MT
    Eugene / OR
    Well, I would like to see that dyno sheet! REally awesome for a mustang and wheel hp.
    -Eric
    2008 B7 A4 S-Line
    Currently = A lot of shit
    Soon = More shit
  27. #67
    Aug 05 2011
    CO-WY
    Btw, I guess photobucket does not want to rotate the damn imagines even though I told it to and saved it 10 Fing times!!!!!! F photobucket piece of shit site!!!!
    2005.5 Audi A4 2.0T
    in progress......
  28. #68
    Senior Member Four Rings Leo14's Avatar
    Mar 09 2010
    North E. Jerz
    Quote Originally Posted by seal66 View Post
    Your doing it wrong! :D Drew where them graphs at -_-
    QG B7 Ti. A4 / S-Line / HID Fogs / Carbonio CAI / ECS Smoked Side Markers / Dark Smoked Side Fender Blinkers / LED License Plate Lights / 034 Turbo Inlet Hose / RS4 Rear Sway Bar / CC + Blackout / LED DRL's / VAG-COM'd / Forge DV / A.W.E Vent Pod Boost Gauge / REVO STG 1
  29. #69
    Jun 17 2009
    Kent Island, MD
    Quote Originally Posted by Leo14 View Post
    This!
    Jordan
  30. #70
    Active Member Two Rings Firefox250's Avatar
    Nov 17 2009
    Boulder, CO
    Dyno scheduled for the 29th of May (9am) at Carz. Stay tunned.
    REVO Stage 2+ | AWE FMIC | RAI CC | APR HPFP | 145 FPRV | 034 HFC | Stasis cat back exhaust | K&N Filter | Fly's Bi-xenons CC | Stasis SS coilovers | VMR 708 18x8 Hyper silver | Continental Extreme Contact DW Summer tires | Blizzak LM-60 Winter tires | Evolutions Aluminum skid plate | AWE Boost gauge | Vortex 3-piece spoiler | RS4 pedals | RS4 Boot Shifter | 2point5 Ipod speck deck| Dension Gateway electronics |
  31. #71
    Nov 17 2009
    Boulder, CO
    Sorry guys the dyno got pushed back till June 1st.
