Results 1 to 13 of 13
    Established Member Two Rings quattro004's Avatar
    Aug 27 2009
    Minnesota
    Transmission whine in a 5-speed B5 A4
    Over the past 6 months or so a whine has developed on my manual transmission in my 1996 A4. Occurs only when clutch is engaged and I accelerate or come off pedal to decelerate. If I press the clutch in while at speed the noise disappears. Fluid has been replace in the last year on both transmission and rear diff. Fluid level is correct.
    Transmission is original with 215k miles on it.
    Any ideas?
    Weapon of Choice: quattro
    | Apikol Snub Mount | B5 RS4 Reps | Vogtland Coilovers | Dunlop Direzza Z1 Star Spec-Summer | Dunlop Winter Sport 3D-Winter | Ecode Headlights | 5000k HID | 9500i |
    Veteran Member Four Rings Euromike's Avatar
    Oct 03 2008
    what garage?
    Pittsburgh
    Maybe it has a shitload of miles on it. Haha
    01' B5 S4 Pearl White Stage 3+
    01' B5 S4 Laser Red [For Sale - ish.]
    16' Silverado HD
    12' Tornado Red GTI DSG
    99' Laser Red B5 A4 QM SOLD
    98' Santorin Blue B5 A4 QM SOLD
    Active Member Two Rings nsnoey's Avatar
    Feb 03 2010
    Los Altos
    I am having the same problem, I have been looking around and everything seems to be pointing to the throw out bearing. can anyone back this up?
    while at a dead stop, i shift into first and accelerate and the car make a loud screech/whining noise once the clutch is fully engaged the noise stops.
    -nick
    Aug 27 2009
    Minnesota
    Well see my noise is more of a progressive subtle whine while the clutch is engaged. It only goes away when I depress the clutch pedal or come to a stop.
    Aug 13 2008
    Indiana
    Is the noise in all gears?
    Mine makes a whine in just 1st gear. I need a transmission to get rid of it. Er rather get off my fat ass and replace it with the one I got
    -Nic
    Aug 27 2009
    Minnesota
    Quote Originally Posted by somebody5788 View Post
    Yes. I have a feeling that should tell me something I just can't figure out what..
    Veteran Member Four Rings Kronic Budz's Avatar
    Oct 01 2007
    1997 A4 2.8 QM
    San Diego, California
    my tranny has a whine/grinding sound throughout first gear up to 2800 rpms. hmmm
    1997 Audi A4 2.8 QM black on black
    bilstein sports w/ vogtland sports ~ S4/sport sway bars ~ 17x8 Bremmer Kraft Br05 wheels et33~ BF G's Sport COMP 2's 225/45/17 ~ Custom Exhaust ~ CAI ~ Ebay SS ~ SS brake lines + EBC red stuff ~ 35% tint/70% front tint ~ face lift headlights w/ 5000k HID + tails ~ blacked out grill trim~ kenwood mp3 ~ Polk comp 5.25" Front mm speakers ~ Infinity REF 6.5" rear speaks ~ 10" Rockford Fosgate p2 in sealed box ~ ED nine.4 4ch. amp powering woofer/polks[/I]
    Mar 22 2010
    Arlington Heights, IL
    I have the first gear whine too.
    Doesn't bother me too much, maybe when the clutch goes out, ill tear it down and replace any broken/worn pieces.
    143k miles 2.8l
    Aug 27 2009
    Minnesota
    Noise has become a bit more noticeable over the past month or so.
    Also, did not mention this before but the noise is relatively constant no matter what gear I am in which would seem to suggest it is not the gears themselves but some universal bearing.
    Any help would be really appreciated.
    bump
    Aug 27 2009
    Minnesota
    http://www.youtube.com/watch?v=hFsYarQaLAw
    (Note: Might need to turn up speakers to hear whine)
    This was in 3rd gear on/off throttle...Whine occurs while on throttle when clutch engaged no matter the gear, goes away when clutch pedal is depressed or in neutral
    Transmission whine has gotten slightly louder over the past couple months...
    Repair manual says its either a bearing or input/output shafts but no real help beyond that. Fluid is topped of as well.
    Does anyone know what actual part might be making this noise?
    Jan 31 2008
    1)if the noise is constant regardless of road speed, i would assume its constant depending on RPM?
    if thats so, then its somewhere in the input shaft of the trans.
    2) if the noise happens in all gears, then its obviously not a specific gear.
    3) if the noise changes depening on road speed, but NOT engine speed, it could be anywhere from the trans output shaft to the front and rear final drive.
    my question to you is.. are you considering a trans rebuild? if so, then now would be the time to disassemble and inspect.
    if you are not considering a trans rebuild.. (you have 200k+ miles) and are considering replacing the trans... then now would be the time to replace.
    if you dont plan on doing either of the two, then ignorance is bliss... just drive it till the wheels (or in this case a trans) falls off.
    Aug 27 2011
    Mount Vernon, NY
    Items for Sale
    Do you notice any change in noise when the car is cold vs warmed up? Mine whines in first and second gear as I am releasing the clutch pedal but it only seems to be when I first start and drive the car.
    Aug 27 2009
    Minnesota
    Not really. Its maybe a bit more noticeable on really cold winter mornings but for the most part it makes the noise no matter what time of year or how long I've been driving.
