Evolved to a built 2.8L motor, RS4 intake manifold, Hemi 80mm TB, and a lot more.
7/13/2011 Running on rough base tune, motor broken in, dyno tune soon on stock intake. Then move to big intake components.
12/3/2011 Things just haven't worked out exactly the way I hoped. I have a leaky wastegate actuator on the passenger side, requiring another motor pull.
So the decision was made to go single turbo. Turbo has arrived, project has begun.
So a lot of things have changed since I first posted this 4+ months ago... One disaster after another, but the light is finally at the end of the tunnel. I am going to keep my original post here, but offer the modified version as well.
Months after I started this latest Stage 3 project, I started working for 034Motorsport, which of course allowed me to deviate a little from my original plan. Needless to say, some modifications have been added, and some changes made. I am going to post up the new updated list of parts, although my goals remain pretty much the same (about 450whp).
I am finally near the final brinks of Stage 3, and thought I would start a little build thread if anyone is interested to see the progress of my car.
EDIT August 1st, 2010 - PARTS LIST
I bought this B5 S4 11 months ago, with blown turbos and needing some work, for under $5k with 115k miles. I will have taken it from bone stock to beyond full Stage 3 in under a year. I started with an ECU, and now I am here, with 3" downpipes, 4" exhaust, meth injection, Sparco seats, and more. The car is a 2001.5 Mbox with the factory sports package, I've put over 15k miles on it since I bought it and pulled the engine twice to replace the blown K03's with used K03's while I saved for K04's. I have replaced half of the vehicle in the time I have owned it, and it is finally nearing "completion" (is there ever such a thing with an S4?).
The goal of the car is that never-quite-attainable quest for a daily driver that can also destroy the track. It doesn't make financial or spacial sense right now for me to own 2 cars, and if I had a devoted track car, I would still have the same worries about getting it to the track and back. Despite living close to Laguna Seca, Thunderhill is my favorite track and its 5 hours away. I have always loved having a car that I drive everyday, but that destroys the track. Of course, this presents all kinds of problems and compromises in both departments, but that is part of the challenge. So far, the car drives wonderfully. There are S4 issues of course, but on the whole, I get 25-26mpg on the highway, its never left me stranded (even when the turbos blew I was able to drive the 30 miles home), and the car has kept a high level of comfort despite track mounts all around. Even with the 4" exhaust and Sparco seats and Tracksport suspension (before the Motorsports), I still made plenty of 4+ hour drives.
Here is a list of whats been installed so far (this is whats currently installed; lots of things have been preceded by other parts). Aside from these aftermarket parts, I have replaced every hose, gasket, etc in the engine, along with new oxygen sensors, new sensor this, new that, etc, etc.
- Stasis Ohlins Motorsports 700/800 suspension
- H-sport rear sway bar with CPP adjustable swaybar links
- Touareg 6 piston 330mm front BBK
- 034Motorsport B6/B7 S4 300mm rear BBK
- Carbotech XP10 custom front brake pads, XP8 rear pads and stainless lines all around
- Upper control arms and Tie Rod Ends
- 034Motorsport 3" downpipes, catless, and custom 4" exhaust
- K&N filter, darintake airbox, sidefire plugs
- 034Motorsport Track motor mounts, Track tranny mounts
- 034Motorsport poly snub mount
- 034Motorsport Billet Diff Crossmember and diff carrier mounts
- Apikol rear diff mount
- AWE DTS (finally got it to work with minimal vibration)
- 034Motorsport Power Steering cooler upgrade/relocation
- VAST meth injection kit
- VAST bi-pipes
- Samco diverter valves
- JHM SS shift knob
- Sparco Roadster seats / Recaro double sliders / Wedge Eng. brackets
- 17" Avus w/ Michelin PS2 for the street
- 17" Kosei T1S w/ Nitto NT01 R-compounds for the track
- ATP GT2560 Eliminators
- 034Motorsport Stage 3 GT tune (~23psi, 90m MAF, EV14 injectors)
- 034Motorsport Bosch 044 dropin fuel pump
- VAST ported/ceramic coated exhaust manifolds
- 2.8L semi-built V6 heads with Supertech Inconel exhaust valves
- 034Motorsport Phenolic intake manifold spacers (RS4 transition)
- Ported intake manifold
- 034Motorsport X34 Carbon Fiber cold air intake
- JHM solid shifter linkage upgrade and Delrin stabilizer bushing upgrade
- VAST Stage 4 clutch and OEM flywheel (hate flywheel chatter)
- 034Motorsport Billet subframe bushings
- RS4 OEM oil cooler
- SAMCO hose kit
I am very excited for the 034Motorsport tune, as it is relatively new and I am also local to their shop, and it is important for me to be there for the tuning and have a dialog going on between me and the tuner. The initial goal is over 400whp @ 20psi on 91 octane. Very confident I can make this considering my Stage 2+ did 306whp on 91 octane. My eventual goal is 450whp with meth, 91 octane, aggressively tuned, with the 2.8L heads and a 3.2L VR6 throttle body. This would be one of the highest powered K04 cars on 91 octane around.
After this work next week, there are very few things I have planned. JHM shifter (only doing the solid shifter linkage now), 4:1 diff, and 2 piece rotors for the brakes, and eventually a transmission rebuild. As time goes by, and the car receives less and less daily driver responsibilities, I will be adding a cage and widebody. This car will never be sold; it will be driven till its too rough to go on the street, then it will be full track duty. Not the most ideal track car as far as lap times, but its all about fun.
Here are some pictures throughout my ownership, chronologically.
The day she came home. Passed SMOG that week, despite turbos almost gone
My first visit to 034Motorsport
Success! Mid May
Up and running
Emergency timing belt replacement (don't drop a socket into your timing belt area)
Yes, about 5 seconds from bending valves
Touareg BBK
Engine pull #2 (K03 blew @ 6800rpm 4th or 5th gear shift)
Yummy
Back on the road with free K03's from Hawaii (THANKS Will175!!!)
Destroying WRX
meth install
Custom 4" exhaust
034Motorsport rear BBK
Goodies
Sparco
sorry for taking your thunder...
