Results 1 to 10 of 10
    Senior Member Three Rings JoeM's Avatar
    Nov 01 2007
    Vancouver, Wa
    Coin/Ashtray Stuck
    Just as it says... any idea how to unstick it? Also the rear seat cup holders are stuck in, this is my first A6 so I'm not sure if these are real common issues.
    -Joe-
    '08 A4 2.0T Q
    '01 Land Rover Disco II
    '99 Porsche Boxster
    Veteran Member Three Rings spyder101's Avatar
    Jan 25 2009
    some where in the U.S.
    remove the ashtray and then remove the coins. Once this is done, don't put coins back in the ashtray.
    Veteran Member Three Rings allroadstomtl's Avatar
    May 25 2009
    '12 Avant P+, '00 328ci
    Montreal
    I have the same problem. In fact the cover in front of the ashtray has snapped off and will need to be replaced. I know whats wrong, the lighter in the tray tilts upward when you slide inwards. Pull it out and the lighter does not tilt down but stays up and blocks the tray from coming out. So is there a remedy.
    '12 A4 Avant P+, S-Line 3 Spoke, S-Line Stone Guards,
    Veteran Member Three Rings Coors's Avatar
    Aug 21 2008
    04 A4 USP 6MT
    Philly
    Are there coins holding it shut? The cup holders are probably gumed-up with soda or juice.
    The greatest trick the Devil ever pulled was convincing the world he didn't exist, then poof he is gone.
    __________________________________________________ ________________________________
    GIAC BI File/TT 225 Injectors/034 HFC/Forge007/ER FMIC/JHM Short Throw/B5 S4 Motor Mounts/podi/AFE Dry/...
    [Sold] '01.5 6MT C5 A6/RS4'd/GIAC Stage 3 Minus w/ alot of mods
    Aug 21 2008
    04 A4 USP 6MT
    Philly
    Quote Originally Posted by allroadstomtl View Post
    I have the same problem. In fact the cover in front of the ashtray has snapped off and will need to be replaced. I know whats wrong, the lighter in the tray tilts upward when you slides inwards. Pull it out and the lighter does not tilt down but stays up and blocks the tray from coming out. So is there a remedy.
    There is probably coins jammed underneath the lighter. Thats why the lighter does not fully collapse.
    Veteran Member Four Rings 2.slowT's Avatar
    Sep 24 2006
    2002 Audi A6 2.7T
    Minneapolis MN
    Items for Sale
    To remove the ashtray you need to remove the upper trim, then radio, then climate control, to get to the clips for the ashtray.
    2002 A6 2.7T Sport
    2000 A4 Avant Daily
    C5UNION | pictures & timeline
    Nov 01 2007
    Vancouver, Wa
    Sounds fun, it was stuck when I bought it 4 days ago so I'm slowly discovering minor things here and there.
    -Joe-
    '08 A4 2.0T Q
    '99 Porsche Boxster
    Feb 07 2008
    04 silverado V8, 06 Touareg V8, 03 S6 V8, 03 RS6 V8TT
    The boonies, near Seattle
    Mine does the same thing, even when empty. You can see if my fix works for you: push the right side of the ash tray all the way in, then with pressure still applied, slide your hand to the other end of the ash tray, then release.
    Works for me
    -dre
    Senior Member Three Rings Asicks's Avatar
    Apr 01 2009
    01 allroad 2.7T 6MT/00 A6 2.7T
    Minneapolis
    I had coins stuck under my ashtray, I fished them out with a paper clip.
    As for the rear cupholders not opening.....i have one that does not. I broke it though. If yours are stuck....they were probably extended when the rear seat was folded down. Thats how i bent mine up.
    -Scott-
    Mods - Far from stock
    C5UNION
    Reppin' the Midwest
    http://www.audizine.com/gallery/data...fitti_wall.jpg
    Senior Member Two Rings bigdadi's Avatar
    Oct 07 2010
    2012 A4 Quattro Tiptronic 2.0T
    Boston MA USA
    PepBoy sells the mirror and magnet set & handle with extension ... I think you can use the mirror w/flashlight to locate the stuffs and use the ext rod magnet to fish it out.
    Also very useful if you drop a screw or nuts into tight space.
    12 A4 Quat 2.0T,
    02 A6 AvtQtr 3.0 (Sold),
    07 Subaru Outback LTD (Sold)
