Results 1 to 23 of 23
    Senior Member Four Rings fly300kts's Avatar
    Oct 16 2008
    South Florida
    A4 B7 - Inner CV Boot Replacement
    For information only, I will not endorse any responsibility.
    Hi,
    I finally found time to tackle this issue: Inner Boot Shaft replacement.
    The outer side is pretty straightforward and I will talk about it a bit later but I could not find anything about the inner boot, and it’s the trickier one. So here we go:
    Time: 2 Hrs
    Difficulty: 4
    Tools:
    Generic
    Triple Square 10mm
    Allen socket 17mm
    So here is your problem
    Remove the rim center cap and parking brake ON. This will allow you to remove the big Allen screw.
    Then, jack up the car and remove the wheel.
    Remove the cross bolt securing the upper arms as well as the direction control arm.
    You can use a small chisel to expand the arm
    Slide the assembly on the side and you will be able to disengage the axle outer side.
    Then, using the 10mm triple square, remove the 6 screws engine side and slide out the axle.
    After securing the axle, using a razor blade (or other) cut the remaining on the boot as well as the old clamps. Clean any excess of grease. Not like this outer CV Joint where at this stage, you will be able to remove outside clip and slide out the tripod, for the inner joint, you don’t have access to the outer clip. With a hammer, hit the flange where the 6 screws were, until she slides off the tripod and you should end up with something like this:
    Now you have access to the outer clip. Remove it and slide out the tripod
    After a good cleaning of the different components, slide the part in this order:
    Small Clamp
    New Boot
    Inner clip
    Slide the tripod and come in contact to the inner clip. Then install the outer clip
    Slide the boot in his final position and tight the inner clamp.
    Empty the entire tube of grease inside the boot, install the outer clamp and secure.
    Reinstall the axle on the car.
    Let me know if any question
    Phil
    Senior Member Three Rings illegitimus's Avatar
    Mar 17 2009
    2006 B7 A4 Quattro Tip S-line
    Boston, MA
    As always, best DIY! Saved and subscribed. Thanks!
    Active Member Four Rings Tusin's Avatar
    Mar 16 2009
    Anchorage, AK
    haha freaking awesome DIY. If it was me I would just replace entire axle. But I am kind of lazy:)
    Senior Member Four Rings Hyphy's Avatar
    Jan 09 2009
    Ft. Lauderdale
    i love my CPO :)
    Nick
    PM me if you need any B5 work done in south Florida.
    I'd rather be flying
    Active Member Two Rings FASTONE's Avatar
    Feb 13 2006
    04 I35, 05.5 A4
    Harker Heights, Texas
    Very nicely done Phil. A must keep for the DYI archives.
    Senior Member Four Rings Doctor's Avatar
    Jun 02 2008
    A4 B7 20vt Quattro,Golf MKV GT
    Greece
    Excellent and really helpful...Thumbs up Phil, as always
    A4 B7 1.8T 20v Quattro Project
    powered by ToM's Garage and Etuners
    Mike
    Senior Member Four Rings B72.0T's Avatar
    Dec 18 2009
    2003 Audi A4 1.8TQM
    Pennsylvania
    Nice write-up as always :)
    B7 A4
    APR Stage II
    Mar 16 2009
    Anchorage, AK
    Quote Originally Posted by Hyphy View Post
    i love my CPO :)
    As long as you keep it stock (which by your sig, looks like you are). But CPO doesn't matter two-bits once you do ANYTHING to the suspension, in regards to your CV Axel's.
    Nov 04 2009
    Norcal
    Great write up.
    Do you use new bolts on the CV and a new Allen on the hub end? What size is that allen?
    Might also be a great time to change the front bearing, since the shaft is out.
    S4 BBS, KW v3, JHM SSshifter.
    Oct 16 2008
    South Florida
    Same bolts were used
    As noted in the beginning of the DIY = Allen 17 mm
    In reference to the bearings, my dad always told me: if ain't broken, don't touch it
    Phil
    Senior Member Two Rings dynamic's Avatar
    Apr 22 2007
    2004 A4 3.0 Quattro
    Tempe, AZ - Maple/Ash
    It is also helpful to have some dowel pins and a mallet for removing the bearing set from the spline shaft. Mine was on there pretty good. When getting the arms to fit back on, some c-clamps were helpful as well. And I borrowed the crimping tool from Pep Boys. Thanks for the DIY. Helped a lot today!
    Senior Member Two Rings rs6's Avatar
    Mar 23 2005
    2008 Cayenne,2006 A4
    San Francisco
    For the lazy, you can just get reman'd axles from Napa for (typically) less than $80 w/ lifetime warranty. They are original Audi axles. Beats spending the time and all that nasty grease.
    Active Member Two Rings Nail Nutter's Avatar
    May 07 2008
    2008 A4 2.0TQM
    PDX
    Hey Phil,
    Axel bolts are commonly stretch bolts. You might want to take a look at those bolts from time to time to make sure they aren't backing off. I replaced an axel on my old VW and wasn't able to buy new axel bolts at the same time. I appropriately torqued the bolts when I reinstalled them, but was surprised to find several had worked themselves loose when I checked on them a year later.
    Oct 16 2008
    South Florida
    Not mentioned in the DIY but I replaced them
    Phil
    May 07 2008
    2008 A4 2.0TQM
    PDX
    Glad to hear it. Great DIY!
    Veteran Member Three Rings audidrver's Avatar
    Mar 31 2007
    CA
    Hey Fly where can i pick up those specific clamps and clampers at? Also will those work for the smaller ones, : for power steering lines.
    ooooO..................Ooooo
    ...............oooo
    .........o.............o
    Senior Member Three Rings pape's Avatar
    Nov 30 2008
    MIA
    just did this to my b6 without removing the axel from the car (pasengers side inner boot)
    Oct 16 2008
    South Florida
    Quote Originally Posted by audidrver View Post
    Yes they should work and the clamps came with the repair kit
    Phil
    Active Member Two Rings derrek's Avatar
    Jul 23 2010
    arizona
    Anyone have problems removing the 6 triple square bolts? Got 3 out but the other 3 wont budge with a 1/2 inch impact gun. I've already snapped one triple square socket.
    Oct 16 2008
    South Florida
    Get a good bit Like Snap-on and try with an impact wrench
    Phil
    Jul 23 2010
    arizona
    Phil
    It was a Matco bit, lifetime replacements are awesome btw. Ended up heating it with a torch for 30 sec, then it came right out.
    Senior Member Four Rings shiro1745's Avatar
    Jul 26 2009
    dishwasher
    South Jersey
    Thanks for this nice DIY Phil
    Full Apr tune stage 2+ - K&N custom CAI - Treadstone TR6 FMIC (Greddy piping) - APR HPFP - VMR TP - Milltek Exhaust - H&R/Bilstein suspension - VMR v701 19" - RS4 sway bar - Apikol snub mount - Revised piston DV - Short shifter - AWE boost gauge - Votex 3 piece trunk lip - Cupra lip - LED interior - De-badged
