Results 1 to 11 of 11
Thread: P2293 Code
    New Member One Ring
    Dec 18 2009
    2006 Chevrolet 2500 HD Duramax 2006 Outback 5er 30 Ft 2001 Yamaha ATV
    Elkview WV
    P2293 Code
    Would it be the high pressure pump or the cam follower or what would be the fix?
    Senior Member Four Rings ryannorthcott's Avatar
    Jul 10 2008
    2002 A4 1.8T Quattro
    Kelowna BC
    Possible Symptoms
    Power Loss
    Possible Causes
    Fuel Pressure too Low
    Possible Solutions
    Check Measuring Values for Fuel Pressure
    Check for bent/squeezed Fuel Lines
    Check Low Fuel Pressure System for Leaks
    Check Fuel Filter & Filter in Fuel Pump
    Check the Fuel Quantity supplied by the Fuel Pump
    two thousand two audi a-four quattro five speed
    Stage 3 Forum Advertiser Four Rings ECS Tuning-Audi's Avatar
    Oct 02 2006
    Wadsworth,OH
    Hm, this is the nightmare code to chase. What are your mods? If you are encroaching on a proper Stage 2+ I'd suggest checking the gap on your plugs. If you are less than that, you might as well check your gap but this code typically leans to a new fuel filter or HPFP.
    So, what is your current setup?
    Senior Member Three Rings psiaddict85's Avatar
    Dec 16 2008
    Cleveland OH
    I started getting fuel cut on the highway at WOT a few weeks ago and sometimes I would throw the same code. Only 22k miles on the car and Stage 2
    B8 S5 V8 6MT IBIS/MAGMA
    SOLD: B7 A4 2.0TQ StgII DTM MORO
    Oct 02 2006
    Wadsworth,OH
    What was your solution psiaddict?
    New Member One Ring
    Dec 18 2009
    Elkview WV
    Quote Originally Posted by Chris@ECSTuning View Post
    I have a stock no mods 2006 A4 Sline with a 2.0 engine.
    Dec 16 2008
    Cleveland OH
    Just started doing it, trying to figure it out. Talked to the service manager at Stoddart and they can't figure it out. :/
    Senior Member Three Rings illegitimus's Avatar
    Mar 17 2009
    2006 B7 A4 Quattro Tip S-line
    Boston, MA
    Here you go:
    "Symptom:
    -Fuel cut-out when driving, esp. under WOT.
    -Fuel cut-out symptoms range from soft pulsations of power to long-pulse bucking while in high-gear high-load situations (high gear at WOT, or up a grade). MIL may flash if cut-out is severe. Car will also go into hard-limp (no boost, 4500RPM limit) if severe enough.
    -MIL ON
    -P0087 Fuel Rail / System Pressure - Too Low
    -P1093 Fuel Trim 2, Bank 1 Malfunction
    -P2293 Fuel Pressure Regulator 2 Performance
    Solution:
    Increase surface hardening of camshaft lobe for the high pressure fuel pump. Improved intake camshafts
    straight from the Sticky, "Common problems..." I'd pull the fuel pressure pump and check the condition of the cam follower and the cam shaft lobe.
    New Member One Ring
    Dec 18 2009
    Elkview WV
    Thanks for all your info I will tear into it tomorrow
    Wes
    New Member One Ring
    May 14 2010
    Elk River, MN
    Quote Originally Posted by wk55 View Post
    Wes
    Curious as to what you found? I have an 06 A4 S-Line 2.0 as well and am experiencing the exact same problem.
    Senior Member Four Rings vbrad26's Avatar
    Oct 17 2009
    nothing
    NY NY
    i just replaced my cam follower and after i started the car i noticed fuel spraying out of one of the hard lines going to the pump
    so i tightened it and fixed that up
    when i got in the car i noticed i had a cel which turns out to be p2293
    so i figured it was because of the fuel spraying out and went ahead and cleared it
    drove around for about 20 min and the light did not come back on
    i didnt drive the car very hard but i also didnt notice any sort of power loss or anything like that...
    so was i correct in thinking i got the code from having one of the fuel lines spraying fuel out of it?
