So I finally got my s5 wheel installed on my b8. At first the car didn't read the steering wheel but after taking it back apart the wiring was all fucked up. Big thanks to SIMMS@ RAI MOTORSPORT for correcting the issue and enabling my paddle shifters!!
2009 Audi A4 b8 2.0. TOTAL LOSS
2010 Audi A4 B8 2.0 Ibis White - Custom FMIC, Borg Warner EFR, RAI MOTORSPORT Custom Tubular Turbo Manifold(wrapped), Custom RAI MOTORSPORT 3" FULL turbo back exhaust, RAI MOTORSPORT Downpipe, RAI MOTORSPORT Midpipe, UNITRONIC STAGE 3 ECU, HOTCHKIS Sway Bars ( f&r), Audi S5 Steering w/DSG Paddle Shifters, Lusch CF fog light grilles, H&R Coilovers, Stage 3 Water/Meth SNOW, 19" Stasis w/ Yokohama Advan 255/40/19 -
Are you asking if the two wires circled in red are connected? Are you asking if the two wires are identical? Please provide more detail.
it is two different car and picture
I wonder if this is the identical cable
one has a green that is not the other has
I will switch to multifunction steering wheel
wonder if i should replace the cable also
or if it is enough just to change 8K0953568E 6-pin to 8K0953568G 12-pin "Steering Angle Sensor Slip Ring"
I need to resolve this same plug mis-match situation. If there's an alternative, I'd rather not salvage the green plug on the 4 spoke airbag to remove the orange plug from the 3 spoke airbag and repin the 4 plug on the 3 bag to make it work because eventually when I sell the car, I may want to keep the better 3 spoke steering wheel and put back the original 4 spoke and 4 spoke airbag. Do you know if it's possible to either get a new receiver part on the steering column that matches the 3 spoke wheel or get a second green harness plug so I can keep the 4 spoke airbag "as is" for the option to put it back? Appreciate the help so I can make this a success DIY upgrade...
2008 A4 3.2L S-Line Quartz Grey | (Triple) XXXL AUDI OEM FACTORY LIFT KIT!!! | 19x8.5 Audi 7 Spoke Wheels | Good Year F1 Asymetrical 245/35/19s | Extra Wheel Set 18" Audi S-Line | 3 Spoke Air Leather Contoured S-Line Steering Wheel | 15% LLUMAR Tint | SiriusXM Satellite Module | Passport 9500ix | Nitrogen Filled Tires | Billet Blue Tire Valve Caps | Remote Gate/Garage Opener | Maglite 2D Incandescent Flash Light | Loose Change | Extra Plastic Lug Bolt Caps | Lint | AAA Card
fka : Vergnügen
> 2008 Audi A4 3.2 FWD
> 4 Spoke Steering Wheel (Purple Airbag Plug)
> 3 Spoke Audi A3 Steering Wheel and 3 Spoke Airbag (Orange Airbag Plug)
I called my local Audi Parts Tech and he said he grabbed the clock spring for the 4 spoke wheel and clock spring for the 3 spoke wheel and they are not compatible. So it seems the only option left is to use a "Purple Plug Re-Pinned in place of the Orange 3 Spoke Airbag Plug".
Does anyone know the part number for the "Purple Plug" (I didn't think to find it and write it down before putting the original wheel back on) Otherwise I need to take it apart again.
And can anyone provide help with how to "Re-Pin a Purple Plug instead of a Green Plug"?
fka : Vergnügen
You may have to replace the whole wiring harness and not just the plug. The wiring harness has two variants: 8K0971589 and 8K0971589A. I do not see a part number for just the plug. If you look at the options sticker in your trunk, you can determine which harness you currently have. If your sticker has either the 1ML or 2PV PR-numbers , your car came with the non-A harness. If your sticker has 1XD, 1XW, 1XX, 2PD, 2ZC, 2FQ, 2PU, 2ZQ, or 2ZS it as the 'A' harness.
Installed: Grocery Hooks, BLESK Plate bulbs, iPhone Extension, VAG-Com, Luminics JDM Yellow Fogs, Chrome Grille Inserts, Rear 12v power, Underseat Storage, Folding Side Mirrors, B&O Tweeters, E-Codes with BLESK 5000K, Audi Hill Hold, S-Line Rear Bumper, Warning Triangle, DIS Stalk, Full-Function Rear Power Locks, 10/17.5mm Spacers, ADS, Mirror with Compass Next Up: 4-Spoke Paddled Steering Wheel, Auto-On Headlights
