Results 1 to 40 of 48
    Senior Member Four Rings DavidB8's Avatar
    Nov 06 2009
    Oakville, ON, Canada
    DIY Steering wheel and Stalk swap
    I've redone the write up and pictures and moved everything to my website here: http://www.audienthusiasts.com/ProjectSteeringSwap.html
    Mods:Votex spoiler, tint, Clear Bra, S4 replicas, Audi winter and trunk mat,mud flaps, Dipstick, oil pan heater, KW V2's, AWE Dual Exhaust, Votex valance, AWE FMIC, Eurocode IC pipe, PIAA fog lights,Vag Com, APR Stage 2, E-Codes, trunk mount emergency triangle, LED plate bulbs, Audi compressor and tire repair kit, RS4 Pedal set, Power Folding Mirrors, S4 steering wheel, heated rear seats, ski pass through.......
    Senior Member Four Rings ItsDubC's Avatar
    May 26 2009
    Houston, TX
    Once again David, thx for taking the time to write this up and take pics during the process, especially given your climate conditions.
    When you reconnect the battery, is there anything special that has to be done to get everything working the way it used to (ie entering a security code for the radio, re-VAG-COMing previous settings, etc)? TIA
    OEM+ 2009 Meteor Gray - Light Gray A4 2.0T Tip Quattro Prem+ Sport Saloon
    All-Weather Mats • Hüper Optik Stark 30 • APR Stage I • A5 S-line Y-spokes • Hankook Ventus V12 evos • S-line Stone Guards
    VAG-COM'd • H&R OE Sports • Eurocode IC Pipe • OEM Avant Dual Exhaust • Lamin-X'd • Smoked Ambers
    Senior Member Three Rings Cabal_san's Avatar
    Sep 06 2009
    TX
    Nice as always and in sub zero temps! You are the mod god!
    Active Member Two Rings rtc5250's Avatar
    Jun 29 2009
    Louisiana
    Nice write up!! Thanks again David!
    Nov 06 2009
    Quote Originally Posted by ItsDubC View Post
    No special codes needed.
    I believe if you take out the errors I got because of the non existent options the only one I would have had to deal with was the steering angle sensor. I think that will happen if you put new stalks on because the car recognizes you swapped it.
    Veteran Member Four Rings JetBlue's Avatar
    May 03 2004
    Carlsbad
    I am always amazed by the amount of work you are doing on your car. Fantastic writeup.
    "The American Republic will endure until the day Congress discovers that it can bribe the public with the public's money." Alexis de Tocqueville
    Senior Member Two Rings jabicho's Avatar
    Feb 02 2010
    Muchos Bandidos, Spain
    Great work, David... ´just thinking about the disconnecting battery issue.Here on my owner´s manual it says it ´s necessary to reset it or something like tahtt at the dealers, is it just to clear error messages???
    Nov 06 2009
    Yeah if you don't have a vag com you could end up with some errors you can't clear. With my Vag I cleared everything no problem.
    Oct 28 2009
    2010 A4 2.0T; 2010 Jetta Wolfsburg
    San Antonio, TX
    my next mod
    To Do: Drop
    Done: Bi-Xenons, StaSIS Exhaust, 19x9.5 Avant Garde M310s, tint
    Feb 02 2010
    Do you know if it´s possible to adapt the original 4-spoke wheel air-bag to this 3 spoke wheel? It´s cheaper to buy just the wheel without it...
    Nov 06 2009
    They are different unfortunately.
    Senior Member Four Rings ThePiombino's Avatar
    Dec 01 2008
    North JerZ
    The Mod Man strikes again! Great work as usual.
    09 A4 2.0T Quattro - Tip - Black/Black /// MODS: APR Stage II+ l AWE CB Exhaust l 034 HFC l EC HFIC Pipe l Forge DV Spacer l 3M Di-NOC Carbon Fiber Interior Trim l 3M Chrome Grille Trim l SG Supreme 28 l Debadged l Fly Eyes Kit (f&r) l Needle Sweep l Window/Moonroof control w/Keyfob l Seat Belt Chime Disabled l "Wink" Disabled l Double Unlock "Beep"
    New Member One Ring
    Nov 08 2010
    de gregorio
    Hello,
    I'm Pino from Italy and excuse me for writing in pm and for my English.
    I'd like to install MF taste in my 2008 A4B8 and I'm a little bit confused.I buy this :http://cgi.ebay.de/AUDI-A4-A5-A6-S-L...item2a0bb1dbdd
    but now I need wiring arness for airbag and maybe another cable to joint the 2 tastes?
    Please can you tell me more about it and audi part number ?
    Thank you very much,Pino.
    Jan 03 2011
    Kids Bikes, Mountain Bike, Lizards
    Central Coast NSW Australia
    Airbag connectors
    Hi, thanks for this excellent writeup and tutorial. Unfortunately, I've hit a snag. The airbag connector on the 3 spoke steering wheel is different from the one on my original 4 spoke wheel.
    The green/yellow connector is the 4 spoke wheel and the orange/yellow connector is the 3 spoke. Note the tabs on the side; 4 spoke have them at the bottom, 3 spoke; halfway up.
    I read the notes at the bottom of David's article; would it be best to buy the right connector from Audi and have that installed onto the 3 spoke steering wheel? Would it then work? I actually did shave the tabs of the 3 spoke connector down a tad so it could plug in, but there was no communication with the wheel (no lights, horn etc) and Vag Com reported the error as such.
    Thanks,
    Scott.
    Active Member Two Rings autobahnaudi's Avatar
    Oct 01 2010
    06 Audi A6 4F Avant
    Ansbach/Illeshiem Germany
    Looking at the back of the harness with the cover off and with the orange/green tab UP label the pins as follows.
    1-2-3-4-5-6 (FISRT ROW TOP)
    7-8-9-10-11-12 (SECOND ROW BOTTOM)
    Completly de-pin the orange connector so you can put the green one in its place so you don't have to trim the tabs like you said you did. (Optional of course)
    Here are the pin re-locations as I said to label them above. The other pins remain in the same place. Pin 3 4 5 and 6 leave in same location.
    There is a purple pin lock on the side of the harness that will need to be removed so you can de pin the pins. This just push out with enough force. FYI the pins are a PITA to get out of the harness I used a sewing needle to unlock there clips. Insert sewing needle into the small aquare holes on the front to disengage the pin locks like I said its a PITA.
    Pin relocation.
    7 to 1 / Brown
    8 to 2 / Yellow
    10 to 8 / Red
    Here some pics of before and after sorry they are old.
    BEFORE I depinned the 3 spoke round airbag
    AFTER I re-pinned the 4 spoke green harness onto the airbag.
    I don't think you can take the wire harness from your old airbag because the mounting points are different to include the grounds. I might be wrong about that though, I did the pin-reloaction and swaped the orange for the green so I didn't have trim tabs. Been working for me for the last 4 months and all is still good. Make sure you disconnec battery, before you play around with airbag!!
    Now your steering wheel contols and lights should work.
    Great success!
    Jan 03 2011
    Mate, thank you SO much for this information! I think I'll just rearrange the pins on the orange connector, as per your instructions, since ive shaved it to fit already. (it still clicks in nice and solid)
    Ill leave the green connector on my 4 spoke steering wheel so that I can sell it.
    Cheers,
    Scott.
    Jan 03 2011
    I think i may have a slightly different wiring config? Looking at the connector with the orange tab UP I have;
    ROW ONE: 1/empty, 2/empty, 3/empty, 4/green, 5/white, 6/blue, 7/orange
    ROW TWO: 7/black, 8/brown, 9/dark blue, 10/red, 11/empty, 12/empty
    So for example, if I moved the wire in pin 7 to 1, I would be moving the black wire..
    Oct 01 2010
    06 Audi A6 4F Avant
    Ya thats wierd. What airbag are you trying to install the round one like the audi TT / S3?
    I installed my audi S3 wheel with round airbag / replacing the audi a4 squarish airbag.
    See if this link can help you
    http://www.audizine.com/forum/showth...ing-wheel-fits
    Jan 03 2011
    Thanks for the link, I'll have a look and see if it helps. At the moment, the 4 spoke wheel is back on the car, but I seem to remember all of the wires going into its green connector being black which is weird. My car is a 2008 Audi A4 B8 1.8T, I bought this off a guy who says he has a Audi B8 1.8T (i think 2010 or 2011, he just bought it) he was selling his 3 spoke wheel cause he bought the TT style flat bottom steering wheel.
    I guess I have to work out on my car, which pin is the horn, which is the lights, etc.
    Oct 01 2010
    06 Audi A6 4F Avant
    That's what I thought it looked liked it your pics all the wires where black this is normal. The colors don't matter just there locations. My new harness for my old 4 spoke airbag has all black wires.
    However I am only telling what worked for me. I wouldnt want you to blow your airbag or something crazy. :)
    Jan 03 2011
    Thanks for that. I guess i'll need to find out the pin assignments for my specific model car.
    Senior Member Three Rings Kandiru's Avatar
    Mar 28 2010
    Isolation, OH
    I did Autobahnaudi's mod when i installed the R8 V10 wheel in my S4 and have horn
    and backlights but nothing else and a "Parking Brake Failure" alarm.
    Autobahnaudi can you help?
    2012 S4 6MT Monsoon/Silver-Alc./Diff+B&O+airbags, Mods:R8 V10 St.Wheel, JHM Shifter, Summer: S5 Double Spokes 8T0601025H - Dunlop 245/35R19 (ET32), Winter: Hollow Spokes 8K00714994EE - Dunlop 255/35R19 with BFI 10mm & RAD 35mm bolts/locks, Customcargrills upper/lower/L-fog radiators protection, Oil Dipstick, RS4 pedals x4 & Autovation Heel Guard, JHM Shifter, Underseat Bins, Trunk Triangle, Bosch 0263009565 ParkPilot, Laminx fronts+fogs+edges+bumper, Windesa Sonniboy 8K Curtains
    Sep 07 2008
    Sydney, Australia
    Just wondering, if I have a B8 A4 with manual transmission and 3 spoke steering wheel, am I able to buy a flat bottom RS6 or RS5 steering wheel with DSG paddles and fit it without any problems? I assume the only thing is that the paddles will not work, but everything else would. Am I correct in thinking this, or are the plugs totally different?
    It seems all flat bottom steering wheels all have DSG paddles
    Jul 21 2011
    Aalborg
    What can bed added in the DIS by adding a new wheel?
    New Member One Ring
    Jan 11 2012
    Trier/Germany
    Exclamation different airbag systems!
    Quote Originally Posted by autobahnaudi View Post
    Great success!
    I hope you know what you do?!
    You can't use the TT or RS6 steering wheel by changing the airbag-connector! There are two different airbag systems (adaptive in the B8 and non adaptive in TT,A6). There will be no error in the ECU, but in case of an accident the system will not work properly!!!
    If there are different airbag-connectors ->there are different airbag-systems!
    New Member One Ring
    Jan 11 2012
    Trier/Germany
    new steering wheel A4/A5
    The steering wheel from the facelift A5 (and fl A4) can be used in the "old" A4 B8! They have the same connectors and the same airbag-systems. with or without paddles.
    without paddles:
    8K0 419 091 CE INU
    8K0 419 091 CN IXB (S-Line
    8K0 419 091 CJ IWQ (S5)
    with paddles:
    8K0 419 091 CF INU
    8K0 419 091 CP IXB (S-Line)
    8K0 419 091 CK IWQ (S5)
    Airbag:
    8F0 880 201 H 6PS
    Airbag-cable:
    8U0 971 589 J (included in 8F0 880 201 H)
    Registered Member Two Rings jrod80's Avatar
    Dec 18 2011
    '11 HD Dyna Street Bob - Highly Modified
    SLC, UT
    Quote Originally Posted by spuerer View Post
    without paddles:
    8K0 419 091 CE INU
    with paddles:
    8K0 419 091 CF INU
    Airbag:
    8F0 880 201 H 6PS
    Airbag-cable:
    Do any of the facelift wheels not have the "i/NAV" button? If not, what is this button used for on those new facelift vehicles without NAV? I would love a new facelift wheel to replace my non-sport '12 Avant 4 spoke wheel but don't really want a "dead" button that doesn't do anything since I don't have NAV.
    Nov 06 2009
    I don't think the iNav button does anything on cars with Nav. That's a new button for these wheels and not compatible with current system. The MFC buttons have their own bus system in the wheel so It's not like you can wire them directly for something else. I don't think a dead button is such a big deal though
    Dec 18 2011
    SLC, UT
    Agreed, not a huge deal and I can most likely live with it. I'm just curious what that iNAV button does on the new facelift vehicles without NAV if there isn't two different facelift wheels, one without the button and one with.
    Dec 18 2011
    SLC, UT
    Also, if you do an eBay search for S-Line steering wheel quite a few of the new style wheels show up (without airbags). The one I'm currently looking at has a different button configuration than the wheel posted by spuerer. The one I'm currently looking at has a < > button on the right side and the iNAV button and Speak button are in the same button on the right side with a * button below. Will these wheels work with our platform? Is the < > a skip button? If so, it would be great if it worked with our platform to skip tracks. What is the * button for?
    http://www.ebay.com/itm/Multifunctio...r#ht_500wt_922
    And this wheel has the same configuration as the wheel spuerer posted...a bit confusing.
    Nov 06 2009
    Don't know but I looked at the Audi Configurator on UK website and the car has that button even without NAV.
    Dec 18 2011
    SLC, UT
    Great thanks. I would really like the < > capability of the first wheel if it is indeed skip track. I posted a new thread so maybe Alex or someone can provide insight. Thanks David!
    Active Member Two Rings mishonio's Avatar
    Nov 10 2011
    VW jetta GLX
    san fran
    Thanks DavidB8 for the detailed DIY!
    I will be replacing just the steering wheel and not the stalks. A B8 A4 wheel for a B8 S4 one. Will re-programming be necessary?
    Thanks,
    Michael
    Nov 10 2011
    VW jetta GLX
    san fran
    Also dimensions-wise and feel-wise how does the B8 S4 3 spoke steering wheel compare to the B8 A4 4 spoke one?
    The S4 one looks thicker, so grip must be better. Is it made of better materials to even further improve the grip? Also how much smaller is it than the A4 one in diameter?
    Cheers,
    Michael
    Active Member Two Rings dame drizzo's Avatar
    Sep 15 2009
    2011 Infiniti G37x
    Staten Island, NY
    Sorry for this annoying question, but if I have s5 steering wheel and want to put on my b8, would I need to change th stalk as well? Had steering wheel and airbag sitting in my house for months and would be disappointed if I didn't purchase all the parts necessary . :(
    2009 Audi A4 b8 2.0. TOTAL LOSS
    2010 Audi A4 B8 2.0 Ibis White - Custom FMIC, Borg Warner EFR, RAI MOTORSPORT Custom Tubular Turbo Manifold(wrapped), Custom RAI MOTORSPORT 3" FULL turbo back exhaust, RAI MOTORSPORT Downpipe, RAI MOTORSPORT Midpipe, UNITRONIC STAGE 3 ECU, HOTCHKIS Sway Bars ( f&r), Audi S5 Steering w/DSG Paddle Shifters, Lusch CF fog light grilles, H&R Coilovers, Stage 3 Water/Meth SNOW, 19" Stasis w/ Yokohama Advan 255/40/19 -
    FIRST (only) AUDI B8 WITH EFR
    Nov 06 2009
    Quote Originally Posted by mishonio View Post
    Cheers,
    Michael
    Thanks,
    Michael
    No reprogramming was needed when I swapped mine. As long as you don't so something silly like alter the clock ring on the stalks when you pull the wheel off you should be plug and play. The S4 wheel is slightly larger and does have a nicer feel to it.
    Quote Originally Posted by dame drizzo View Post
    That stalks are the same. They only change for different options not based on the wheel you have.
    Nov 10 2011
    VW jetta GLX
    san fran
    Thanks DavidB8.
    If reprogramming is indeed needed, will it be trivial? Just force a re-check of installed components. On the dimensions aspect, in the photos the S4 wheel looks thicker but with smaller diameter. Are you saying it has larger diameter?
    Cheers,
    Michael
    Active Member Two Rings r8ders's Avatar
    Feb 15 2004
    2011 B8 A4, 01 Yamaha R1, 95 M3, 98 Ford F150
    SF Bay Area
    Can anyone tell me if I can use the airbag off my 2011 B8 A4 w/ sport package 3-spoke steering wheel on a S5 steering wheel?
    Thank you
    Active Member Two Rings D-Love's Avatar
    Jan 18 2012
    Springfield, NJ
    Excellent Write up. Question My car did not come with The Paddle Shifter Option if i were to Purchase the R8 wheel w/ Paddles is there a way to make it work? Thanks!
    New Member One Ring
    Jan 09 2012
    Chicago
    Quote Originally Posted by D-Love View Post
    I second this. I'm very new to the scene, but I'd love to get some paddle shifters going. Any advice on fitment?
