Page 5 of 11 FirstFirst ... 345 67 ... LastLast
Results 161 to 200 of 406
  1. #161
    Registered User Three Rings
    Jul 16 2009
    Ferndale, MI
    Quote Originally Posted by Evilevo View Post
    8.27 in 90*F heat the other day. I really need to start in 2nd for these runs because i dont hit full boost till past 60mph in 3rd. Sent the logs in.
    That's still really fast considering your car is on pump gas and over 4k lbs with the way you made the run with passenger, wheels, amplifiers etc on low boost.
  2. #162
    Senior Member Three Rings Jason:addict's Avatar
    Oct 14 2007
    01.5 S4, 86 4KQ, 83 UrQ, 04 Cayenne S
    Woodinville,WA
    Our TiAL 605 car just did 8.7 at 25psi in high heat, verification to follow.
    Audi Tuning Hatemonger
    Tune your car, not your log.
    World's Most Powerful 2.7L.
    "The Bill Gates of selling dyno sheets..."
  3. #163
    Senior Member Four Rings gearhead1186's Avatar
    Mar 17 2009
    02 S4, 06 GTO, 69 Camaro, 73 Cuda, 68 Torino
    Queens, NY
    Quote Originally Posted by AMD View Post
    nice!
  4. #164
    Senior Member Four Rings AudiSportB5S4's Avatar
    Jun 14 2007
    Connecticut
    Impressive
    VAST Performance Stage 3 B5 S4 | Videos
  5. #165
    Active Member Two Rings Espen W's Avatar
    Jul 08 2010
    Oslo/Norway
    Have any of you guys tried to do a no shift pull in 4th only?
    Running 31psi, on the 2.2L I5 in the RS2, I've I've got peak torque from 67mph in 4th gear (same ratios as B5 RS4 with 4.11FD and 1.03 4th).
    60-90mph takes 2.61s in 3rd and 3.08s in 4th, the less than 0.5s advantage that 3rd gear would have is more than made up for by not having to shift. Not only does the shift itself take time, but with having to build boost again, a large chunk of time passes before the G's are back up. (No wonder the 997.2TT with PDK pulls such amazing times)
    I would imagine the 2.7TT's being even better suited for a no shift pull, even though 4th is somewhat taller geared in the S4)
    100-200km/h is where it's at over here, and I hit the limiter hard at 128mph or so, so I haven't gotten to time a 60-130. 100-200km/h (approx 62-125mph) is 7.62s, with 60-125 in 7.98s
    95' Audi/Porsche RS2 on E85 (7.2s 100-200km/h & 2.7s FATS)
  6. #166
    Oct 14 2007
    Woodinville,WA
    Quote Originally Posted by Espen W View Post
    Greetings to Norway and thanks for posting. It's nice to get some info from an RS2 owner! What turbo are you running? From what I've seen even with the 'quicker' spool of our 770 car it's still hard to get 4th gear to come on early enough. We have an RS4 trans and 4th gear makes it to about 143mph at just under 8500 rpm, and 3rd gear provides peak acceleration (according to the GPS) exactly at 60mph. I'm planning on attempting to limit the actual shift time and boost recovery (flat shift) instead of getting the system to handle huge amounts of torque delivered from a 4th gear 30+ psi boost spike.
    It's worth trying though, as it has become the fastest way for many higher displacement turbo cars.
  7. #167
    Jun 14 2007
    Connecticut
    That RS2 is hauling some ass.. Wow those are great numbers..
  8. #168
    Senior Member Three Rings Audi_S4's Avatar
    Feb 20 2008
    belgium
    Not that it's an Audi but it's a good friend of mine who has the fastest car I've been in (except for maybe the Z06) He has a fully built gutted Volvo R with a GT2871R @ 1.8bar boost (26psi)
    http://www.youtube.com/watch?v=To23O...eature=related
    FOR SALE : RS4 FUEL RAIL !
    MRC S4 Avant 386whp
    Sold: M3 E46 SMGII ESS Stage 1 S/C 380whp
  9. #169
    Jul 08 2010
    Oslo/Norway
    Quote Originally Posted by Jason:addict View Post
    I'm running a Turbonetics T04 E50 with a KKK #8 hotside. Runs on E85 and that made a night and day difference, even at the same boost.
  10. #170
    Oct 14 2007
    Woodinville,WA
    Well it was actually an 8.68!
    TiAL 605 Kit
    AMD IC's
    AMD 3" DP's
    AMD 3.5" Exhaust
    AMD 044 Fuel Pump Kit
    Aquamist HFS-1 50/50 Meth
    27psi spike to 25psi Flat Through Redline
    Full 2.7 Small Port Stock Top & Bottom End
  11. #171
    Mar 17 2009
    Queens, NY
    ^ thats awesome!
  12. #172
    Feb 04 2010
    Bush
    Stock Block/Rods plus fuel pump upgrade ?
    Impressive results.
  13. #173
    Jul 08 2010
    Oslo/Norway
    Jason: does the 605 car have the RS4 tranny as well?
    What is the weight?
  14. #174
    Oct 14 2007
    Woodinville,WA
    Quote Originally Posted by sektor M7 View Post
    Impressive results.
    Yup - drop-in 044 pump and completely stock engine.
    What is the weight?
    This is full interior with stock S4 trans - should tip scales around 3700lbs with A/C removed (without driver).
  15. #175
    Senior Member Four Rings Evilevo's Avatar
    May 26 2008
    2001.5 S4 2.8L
    Towson, Maryland
    How is it 3700 without AC?
    My car was 3650 with AC and a Spare CH and sub and amps with the heavy CHs on the car.
  16. #176
    Feb 04 2010
    Bush
    Unless you cornerbalance the car and read the weight off the scales weight estimates are going to be all over the place.
  17. #177
    May 26 2008
    2001.5 S4 2.8L
    Towson, Maryland
    I put my car on calibrated scales at Maryland International Rceway
  18. #178
    Senior Member Four Rings TweetsS4Estate's Avatar
    Mar 30 2008
    02 S4 GT'd, Early 01 S4 Stage 3+, 02 Pontiac Firehawk will have boltons soon
    Rochester/Grand Rapids, MI
    Awesome work Jason. We need to get some solid RS6 cars in the mix here.
    Big thanks to jason@AMD.
    It's not about what you have, it's about what you give to the community. Let's take on the AZ attitude stereotype, and put it to bed.
  19. #179
    Veteran Member Three Rings michael66899's Avatar
    Oct 26 2006
    00 S4, 01.5 S4
    WA
    Quote Originally Posted by TweetsS4Estate View Post
    2nd, would be interested to see what an RS6 car does even though I think 605s are much better in every aspect. Great work Jason keep it up man.
    - 00 Nogaro S4 - Single Turbo Project / 01.5 - Silver S4 - Stg. 3 / Five other B5s that have all been sold
    -BW EFR-Fikse-AMD-Stoptech-AWE-Stasis-034-JHM-Stern-Neuspeed-Dahlback-Eurogear-CPP-Group 2-
    WWU Formula SAE - 600cc's and 450lbs = Lots of fun
  20. #180
    May 26 2008
    2001.5 S4 2.8L
    Towson, Maryland
    Do a 60-130 with your car!
  21. #181
    Jul 08 2010
    Oslo/Norway
    We can see from the 605 graph that there is a gap of a little more than one second that passes from the shift is initiated until the G-Force is at the same level in the next gear. The shift itself takes much less time, but spool, inertia, etc plays a role.
    With the RS4 box, it would most likely be quicker with a 4th only pull, but with the 6.5% longer 4th in the S4 box, it is probably faster using 3rd and 4th.
  22. #182
    Dec 23 2009
    Brazil
    Just AMAZING!!!
    How much timing the car was pushing at redline with 25psi + Meth?
  23. #183
    Veteran Member Four Rings DLSJ5's Avatar
    Feb 12 2004
    2005 M3 ZCP
    LA, CA
    Here's "Bondoc's" Stage 3 S4, 60-130 time, with some lackluster shifts ;)
    9.45s (2 shifts) 1.26 decline, 60-130MPH.
    Here's his setup at the time -
    K04's, HB Tune
    AWE IC's, DP's, Twin 1 Exhaust
    100/110 octane
    His 2nd shift really hurt his time, if we measured 100-200kph (62-124mph) he hit 7.71s!
    From 100-200kph here's how he compares with others -
    6.7 - Enzo
    6.8 - GTB 599
    6.8 – CBR 1100XX
    7.2 - SLR
    7.7 - Stage 3 B5 S4
    7.8 - Murci LP640
    7.9 - C6 Z06
    8.0 - Ford GT
    8.4 - 997TT
    8.4 - F430
    8.4 - 996 GT2
    8.6 - M6
    8.7 - SL65 AMG
    8.8 - Gallardo Superleggera
    8.8 - E60 M5
    8.9 - S65 AMG
    9.0 - 996TT X50/Turbo 'S'
    9.1 - Gallardo SE
    9.7 - 996TT- 9.7
    10.0 - E55 AMG
    Current Ride
    E92 M3, DCT EI X pipe w/HFC's - GIAC ECU Flash - Rogue Pulley - VFE Filter = 363whp on a Mustang - 60-130(3 shifts) 10.71 ET 11.88 @ 118.76 Best Trap 119.8
    Gintani Stage 2+ Supecharger 60-130MPH (3 shifts) 7.3s
    Former Rides
    2005 BMW ///M3 SMG ZCP Best Naturally Aspirated ET 12.89 @ 108 MPH
    VF-Engineering Stage 2 Supercharger
    11.58 @ 122MPH Best trap 124.8MPH
    60-130MPH, 2 shifts, 8.67
  24. #184
    Jan 16 2007
    2001 Audi S4, HB Stg 3
    SOCAL
    thanks for posting the graph bro!
    So far the fastest PJ k04, full weight car in Socal and maybe the US......hahaha. And that was some crappy shifting
  25. #185
    Veteran Member Three Rings rouellettea4's Avatar
    Apr 07 2005
    00S4STG3, 1995 Subaru Impreza, 96 A6 (blown HG)
    Holden/Worcester, MA
    Quote Originally Posted by bone_doc S4 View Post
    What's your car trap around? thats pretty darn impressive!
  26. #186
    Feb 20 2008
    belgium
    Holy shizzles Bone_doc's car is so sick!
    What power is it making ?
    Gotta measure mine soon with the new tune!
    MRC S4 Avant 386whp
  27. #187
    Jan 16 2007
    SOCAL
    rouellettea4: only took the car to the track once on that setup, unfortunately managed to blow my tranny, but still trapped 117 limping down...
    Audi_S4: car dynoed 410whp/445tq on a mustang
    thanks for the props guys
  28. #188
    Feb 20 2008
    belgium
    Nice one! What setup are you running now then ?
    Do you shift past 7k rpm in 4th ?
    MRC S4 Avant 386whp
  29. #189
    Jul 08 2010
    Oslo/Norway
    100-200kmh in 7.7 is most excellent :)
    What was the ambient temp?
    Weight of the car including driver?
    With stock sized tires a B5 S4 should reach 130mph at approx 6950rpm (not considering possible tire deformation which should be close to zero at that speed anyway), so try to stay in 4th until 130mph.
    Try a no shift 4th gear pull as well. Might be quicker.
  30. #190
    Feb 20 2008
    belgium
    How would a 250lbs passenger affect a 100-200 pull for someone who runs this time on it's own?
    MRC S4 Avant 386whp
  31. #191
    Jul 08 2010
    Oslo/Norway
    Quote Originally Posted by Audi_S4 View Post
    Would probably add around say 0.5 or 0.6s.
    NA would suffer more than FI since the added weight would make the turbo spool at a slightly lower rpm, offsetting some of the weight gain
  32. #192
    May 26 2008
    2001.5 S4 2.8L
    Towson, Maryland
    With stock sized tires a B5 S4 should reach 130mph at approx 6950rpm (not considering tire possible tire deformation which should be close to zero at that speed anyway), so try to stay in 4th until 130mph.
    I looked back at my fastest 60-130 so far. My car did a 7.2 100-200kmh. I found a meth leak that was causing my IATs to go too high. Also looking into trying to free up the intake tract with either a RS4 Intake Manifold or modifying the stock and doing a 80mm TB.
  33. #193
    Registered Member Four Rings nthusiastt's Avatar
    Oct 27 2008
    B5 S4 Avant
    Would really love to see what some of the VR6's do
  34. #194
    Veteran Member Three Rings Spooled1.8's Avatar
    Jan 26 2006
    York, PA
    Quote Originally Posted by nthusiastt View Post
    x2, I'd love to see USP's 60-130 time
    -Pete
    2001 Imola Yellow S4 EPL/TiAL S605
    -Evolution Racewerks Intercoolers with Carbon fiber shrouds.-EBC Redstuff Pads-EBC Rotors-RAI Motorsport 3" Downpipes-AWE Twin 1 Exhaust-AWE DV1 DV's-AWE Center Vent Boost Guage-AWE DTS Bar-Advanced Automotion Rebuilt Trans-Southbend Stage 4 Clutch-Fidanza LWFW-ASP Engine Mounts-034 Motorsport Trans Mounts-Apikol Rear Diff Mount-KW Variant 3 Coilovers-
  35. #195
    Jan 16 2007
    SOCAL
    Audi_S4: currently running AWE with EBC, i didnt shift past 7k
    Espen W: thanks, temps were mid-upp 60s, i weigh 160, car is about 3600
    Evilevo: whats your 60-130? GTs should be hitting low 6s. Which GTs are you running from Mike/Vast?
  36. #196
    Feb 20 2008
    belgium
    What kinda of mixture do you run with the 109? Cause I read on the Sunoco site that 109 is not supposed to be in the tank for more then 24hrs , I'm gonna get some 109 soon but was wondering how much to put in!
    What wheels are you running Bone_Doc?
    MRC S4 Avant 386whp
  37. #197
    Jan 16 2007
    SOCAL
    i ran a mix of 100/110, wheels are SSR Comps (18in)
  38. #198
    May 26 2008
    2001.5 S4 2.8L
    Towson, Maryland
    My car did a 8.2 60-130 at like 26-27psi on pump/meth.
    I am still trying to figure out some stuff with my car. Mike@VAST says it isnt making the power it should be, so we are looking into changing some stuff like the intake manifold and throttle body and see if that helps.
    I am on 2871R/Agtronic kit.
  39. #199
    Jul 08 2010
    Oslo/Norway
    I would have expected a better time for your car, but remember that ditching the passenger will save approx 0.5s.
    Do you have Mustang dyno #'s for your car.
    What is your 60-90, 60-100, 60-120mph and 100-200km/h times?
    Also, did you stay in 4th until 130mph or did you shift into 5th?
  40. #200
    May 26 2008
    2001.5 S4 2.8L
    Towson, Maryland
    For some reason my car isnt making the power it should be. We think there is a restriction in either my intake or exhaust setup that is holding it back. We are looking into that now.
    The best FATS my car has done is a 2.8 with 1 passenger. Not sure about the 60-100 or 60-120, and right now I am too lazy to open up my logs, lol. my 100-200kmh i posted above, i think it was a 7.2
    I also found that my meth injection was leaking somewhat, so that might have been affecting it too.
