Results 1 to 40 of 79
    Senior Member Two Rings eaniemeanie's Avatar
    Feb 22 2009
    MB C300,1971 911E Targa, 05 Pathfinder.
    Temecula, CA
    Front rotor and pad replacement DIY
    The jobs done and it was pretty easy. One clip, two bolts, (use a wire tied to the shocks to hold the caliper up). Be careful you dont pinch the brake line moving it around. Remove the brake sensor on the left wheel. The old pads are easy to get out. The rear one just pops out, the front one I tapped out with a socket extension through the hole in the caliper. Use a caliper spreader to push the pads back before taking out the rear pad. Pay attention to the brake fluid dispenser since when you push the calipers back you'll over fill the resevoir. The new pads just slip right in.
    Use a T-30 socket to remove the rotor screw. A couple big hammers on the old rotor to break it loose. Then lightly sand the axle wheel face smooth to remove the corrosion. Then put it all back together! Also make sure you bed the pads according to the manufacturer. Carbotech gives you details how to.
    Hopefully this will end the dreaded brake dust!
    Long gone ->(2009 Audi A4 Premium current odo 95,000)
    Service history 85K miles.:85K miles......
    Sep 14 2006
    05 A4 1.8T CVT, 09 A4 Avant
    Loma Linda (SoCal)
    Nice, have you done an oil change yet? If so, does the b8 just have a canister oil filter like in the b7's? BTW I just noticed that you live in Temecula, I'm actually down there almost every weekend.
    -Thomas
    USP CLUB MEMBER #16
    B6 A4 CVT-APR Stage1+/Forge TIP/neuspeed exhaust/Eibach springs/Hyperboost DV/Ecode FMIC/B5S4 brakes/vdo boost gauge/Podi/APR snub/rs4 rear sway/
    B8 A4 AVANT-REVO stage 2 (stock CAT)/DMH electric cutout/Stud conversion/Enkei 18x9.5 ET40/VMR 710 19X9.5 ET33/H&R OE Sports/
    Senior Member Three Rings ASU Daniel's Avatar
    Oct 03 2009
    2009 A4 2.0T
    Scottsdale, AZ. Vicenza, Italy
    cool
    Feb 22 2009
    Temecula, CA
    Got the rotors!
    New rotors. 30mm thick.
    Min for changing rotors....28mm
    2mm of wear and that's it? WOW
    Feb 22 2009
    Temecula, CA
    No I had the dealer do the oil through the Audi Care program. But I think I'll be the one doing them from now on since Audi care expired.
    Why is it you're down here so often?
    Veteran Member Three Rings dmg312's Avatar
    Dec 08 2005
    OH-IO
    this should be good. brake jobs are usually easy save for bleeding the brakes. Having a brake bleeder makes it a lot easier though. Way to help save $$$$
    08 A3 2.0T Sprint Blue Sline.
    Feb 22 2009
    Temecula, CA
    Quote Originally Posted by dmg312 View Post
    Got one that I use to do the Porsche... You have to bleed the brakes to change the pads?
    I forgot to mention that I bought Carbotech Bobcats for the pads.
    Sep 14 2006
    Loma Linda (SoCal)
    Quote Originally Posted by eaniemeanie View Post
    My girlfriend lives there. So did you feel like Audi Care was worth it? I know they'll ask me if I want it tomorrow when I go in, but I feel like I won't really need it.
    -Thomas
    USP CLUB MEMBER #16
    Feb 22 2009
    Temecula, CA
    It was worth it for the fact that al I had to do was go in and have the oil etc serviced and not have to pay then since the payment was in the financing I did for the car. It's nice that you take it to the dealer so that any updates or Technical Bulletins were taken care of. I asked for an estimate on how much the 55K service was going to be ($500) because of plugs etc. So it nicer to not have to pay that every three months (10K mi.).
    But I'm not sure you can get the package after the fact....
    Aug 27 2008
    League City, TX
    You can buy Audi Care up until the 45000mi/4 year service ** but the services before you buy it are not pro-rated i.e. you still have to pay full price. So, it really only makes sense to buy it before the first service interval you would have to pay for otherwise - 15k miles here in the US.
    Current : 2009 Quartz/Black A4 - 6MT/Sport Pkg/Prem+ : EC Intercooler, 034 turbo inlet hose, Interior LEDs, Lic Plate LEDs, A4L fog grills, B&O Tweeters, Vag-Com tweaks
    Gone : 2001 Ice Silver/Black A4 - 5MT FWD/Prem Pkg
    Senior Member Four Rings cory_can's Avatar
    Mar 05 2009
    (Very) Red B8 Avant, '11 Volvo XC70 T6
    Golden Horseshoe, ON, Canada
    Before you install the new rotors I would be curious to know the approx. weight.
    Feb 22 2009
    Temecula, CA
    Quote Originally Posted by cory_can View Post
    Can do.
    Senior Member Three Rings Kavan's Avatar
    Jun 12 2009
    Audi S4 2011 3.0T
    T.
    You are going to use the stock rotors and pads im guessing?
    I think the parts guys could give me one hell of a deal but my brake pads are wearing very unevenly. Inside of the pads are gone and theoutside still have about half the pad left if not a little bit more. I am guessing that is not right?
    Stage 3 Forum Advertiser Four Rings ECS Tuning-Audi's Avatar
    Oct 02 2006
    Wadsworth,OH
    Quote Originally Posted by Kavan View Post
    Sounds like a general lube issue. Fairly common. Grease everything up and you will probably notice better wear.
    Senior Member Four Rings DavidB8's Avatar
    Nov 06 2009
    Oakville, ON, Canada
    Oh that is so not right. I had a problem like that on B5 and had my brakes done4 times in under 2 years until they finally got it fixed right. If I were you I would get the dealer to fix that problem. It is most likely the slider which is what Chris is eluding to with the grease. Problem is your rotors are shot now due to the uneven wear. I hope you get this one figured out because it cost me a small fortune on my other Audi but if I had just gone to the dealer instead of trying to find a cheaper garage I probably would have saved in the long run for sure.
    Mods:Votex spoiler, tint, Clear Bra, S4 replicas, Audi winter and trunk mat,mud flaps, Dipstick, oil pan heater, KW V2's, AWE Dual Exhaust, Votex valance, AWE FMIC, Eurocode IC pipe, PIAA fog lights,Vag Com, APR Stage 2, E-Codes, trunk mount emergency triangle, LED plate bulbs, Audi compressor and tire repair kit, RS4 Pedal set, Power Folding Mirrors, S4 steering wheel, heated rear seats, ski pass through.......
    www.audienthusiasts.com
    Dec 29 2009
    Midwest
    The only time you should will have to bleed the brakes is if you take the brake line off and enable air to get in. You should not have to take the brake line off. Just remove the bolts that hold on the caliper and put it to the side to remove the rotors. You will need a big C clamp and a small board to push/compress the piston back into the caliper prior to reinstalling.
    Oct 02 2006
    Wadsworth,OH
    Quote Originally Posted by Quattrolover View Post
    Careful with that. Rear calipers require a push and twist. There are special tools required to compress the rear calipers. If you don't use them you WILL damage the internals of the caliper and you'll be buying new rear calipers. I know this thread is for front rotors/calipers but you can use the piston retracting tool for both, it really makes it easier than the cumbersome C-clamp and board method. The tools isn't costly though, and it is kind of slick IMO: Click here for the piston retracting tool.
    Dec 29 2009
    Midwest
    Thanks for chiming in on this. I have not done any on a Audi, just others cars. I was more addressing the bleeding the brakes issue. Thanks! I will look into the tool you speak of.
    Nov 06 2009
    Cool tool, pretty cheap too considering what you save doing the job yourself.
    Apr 18 2009
    Sweden
    "Since the VAG group introduced the ‘Electronic Parking Brake (53)’ system in 2003 it has become
    standard equipment on the A6 (4F), A8 (4E) and Passat (3C) models. This increased level of
    technology now demands the use of suitable diagnostic equipment to carry out routine service
    procedures such as brake pad replacement and caliper removal."
    Does this apply to our cars?
    Feb 22 2009
    Temecula, CA
    Quote Originally Posted by Kerwind View Post
    I fricken hope not.
    I bought Carbotech pads from PureMS. I talked to the Carbotech Rep and he said they are making them (should be made now) We'll see when they come in.
    Aug 27 2008
    League City, TX
    Probably - but likely just for the rear. The Electonic Parking Brake isn't on the front calipers AFAIK - only the rears. I'm assuming vag-com will put the EPB in "service" position?
    Mar 05 2009
    Can do.
    Thanks.....Besides the obvious braking benefit, I'm hoping that LW rotors can have significant impact on performance. My estimate is that it'll save approx. 5lbs/corner of rotating mass.
    This pig needs to keep dieting!
    Feb 22 2009
    Temecula, CA
    True but I couldn't find any after market rotors yet! And I looked!
    Feb 19 2010
    Newbury Park, CA
    Send me a PM, as I can get you several different types of aftermarket rotors... including drilled.
    Like someone else said, there is no need to bleed brakes when changing pads/rotors unless the pedal is soft (air in lines) or the fluid is old (flushing).
    2010 Audi A4 B8 / 2012 BMW X5 35d / 1986 Porsche 911 Turbo (Check me out on Autoblog.com)
    Feb 22 2009
    Temecula, CA
    21.4 lbs. each.
    Feb 22 2009
    Temecula, CA
    Quote Originally Posted by Emission View Post
    I already picked up the new rotors. All the after market rotor guys said they don't make them for the B8 yet, what ones can you get?
    Nov 06 2009
    I think Adam might get upset if he see's you saying that.
    http://www.audizine.com/forum/showth...ghlight=rotors
    Feb 22 2009
    Temecula, CA
    Picked up the Carbotech pads today from PureMS here in Temecula.
    Might change them out this week-end.
    Also ordered the intermediate shaft bearing for the 911 yesterday. I'm not happy about having to work on two cars at the same time...boohoo.
    Senior Member Four Rings B_Boy's Avatar
    Nov 24 2008
    2011 Infiniti G37S Coupe
    South FL, USA
    i got my new rotors from adams rotors today. Ill post some pics soon, they look sick!
    Marcus
    ‘12 Audi A4 Quattro: Premium+, Sport Package, S-Line, B-O, Advanced Key
    -Tint: 15% F/R, 50% Windshield
    -LED Color Match Fog Lights/Int/Ext, S4 Aluminum Paddles, Pedals & Shifter
    -VAG-COM, storage bins, H&R Sport Springs & Plasti-dip valance
    Coming Soon: 20x9 Vossen CV3 ET 32 , Osir Trunk Spoiler, Custom Blacked-OUT Grille
    Future: AHHA, Custom Exhaust, GIAC ECU, F/R Parking Assist
    4Sale: Spacers F15/R20, iPod AMI Cable, Gloss Black Grille
    Jun 12 2009
    Audi S4 2011 3.0T
    T.
    I heard changing the rotors is plain and simple it is the pads that need adjusting and such. Also 22lbs almost for a rotor?
    Are adams rotors light weight? I have the dealership replacing my 2 fronts because one may have warped. I may have them swap the pads at the same time I only had about 25k on them. Wonder how the rear pads and rotors wear compared to the front? I heard it is about 60/40 front to rear. How long would I have to wait to service the back? The dealership suggested doing them together but i am sure thats more of a money making scheme?
    Oct 02 2006
    Wadsworth,OH
    You can visually see the wear on brake pads. The worst you have to do it pull a tire off. In the many various cars I've owned I noticed that I can go through 2 sets of front pads for 1 set of rear pads. I'm not sure about the braking bias on the B8 A4, but I would be surprised if the rears wore as fast as the fronts.
    Jun 12 2009
    Audi S4 2011 3.0T
    T.
    Yea from what I have taken it sounds about right. I also heard you can go through about 2 sets of pads on the front on a pair of Rotors.
    I have Audi replacing my Rotors for me because one was warped so I think I may just swap the pads as well and wait to do the front and rears together in another 40kms or so, but only if I can get confirmation that the backs will last as long. I am not worried about the Rotors as I am the pads.
    Mar 05 2009
    Yup, stock rotors certainly aren't light. Most people completely overlook (or under estimate) how reducing unsprung rotational weight can have tremendous advantages to acceleration, braking and handling. It's not always about needing more power...making better use of existing power is just as beneficial.
    Jun 12 2009
    Audi S4 2011 3.0T
    T.
    ^^ Okay so how many 100's more are these LW rotors? I would love to ditch 30lbs all around if not more. I am already thinking about ditcihng the spare tire, why not I pay for CAA and if I got a flat i will use what I pay for.
    Mar 05 2009
    I've seen sets of LW 2-piece front rotors for B6/B7's in the 500-600 range but I'm still searching for LW 2-piece units for the B8.
    Nov 24 2008
    South FL, USA
    i wonder when the actually DIY will start...
    Marcus
    Mar 05 2009
    Quote Originally Posted by B_Boy View Post
    whenever you start I guess
    ...had to.
    Feb 22 2009
    Temecula, CA
    HEY! I work for a living. And to tell you the truth, the light hasn't gone on yet and I haven't checked the wear since the last time I looked. I have about 1000 miles to drive next Friday and was thinking if the breaks haven't worn out too much in the last 1000 I drove, I might wait till next week-end. OR depending on the check tomorrow, I'll be doing it this week end!!!!! you sound like my kids.
    Jun 12 2009
    Audi S4 2011 3.0T
    T.
    Are the brakes there yet??
    I want to see how to swap the pads, I dont feel like paying 400 for someone to put somthing that cost me 300 in :).
