Forge Blow Off Valve Kit for VAG 1.4T 1.8T 2.0T Engines
PLEASE ORDER HERE
NEW ITEM!!
Forge Recirculation Valve for VAG 1.4 TSi Twincharged Engines
PLEASE ORDER HERE
NEW ITEM!!
Actuator for MK5 Golf 2.0L FSiT
PLEASE ORDER HERE
Replacement Valve for 2.0litre FSIiT TFSi Engines
FREE SHIPPING WORLD WIDE!!
PLEASE ORDER HERE IN STOCK READY TO GO!!
We’re proud to announce another industry first for the Volkswagen and Audi tuning market from Forge Motorsport!
For owners of VAG vehicle equipped with the all new 2.0T FSI engine that have the electronically controlled bypass valves, situated at the front of the engine (as shown in the photo below), we can now offer an alternative.
If you are running increased boost pressures, after a software remap (chip), or the OEM valve is being subjected to high temperatures, the lifespan of the unit is significantly reduced.
Even without any modifications taking place to the vehicle at all, this OEM valve has been shown to fail over time and it’s boost holding capacity also leaves some room for improvement. Our alternative is a fully engineered solution offering both significantly improved reliability as well as valve related boost response. Our valve and installation kit replaces the original unit with a pressure/vacuum operated piston valve that still also retains the desirable OEM ECU control over valve actuation. This product has been thoroughly designed and tested with the expressed intent of offering improved valve response and maintaining ECU control while resulting in absolutely NO fault codes, NO check engine lights, and no adverse effects of any kind. All of the necessary components and detailed instructions are included and everything is designed to make installation as simple as possible.
As of May 2009 this kit is supplied with an additional uprated spring (coded Yellow) that may be required if the vehicle has had a significant boost increase.
Blow Off Adaptor for VAG Turbo Engines
Yet another first for the Volkswagen and Audi Tuning Market from Forge ! With the introduction of the VAG TSi Turbo Engine, we have developed a Patented Atmospheric Blow-Off adapter specifically designed to fit this application. Simple in execution, yet offering the desirable atmospheric blow-off valve sound, this product has been designed to be fully compatible with the Bosch engine management systems employed. This is a replacement for vehicles fitted with the OEM solenoid valve part number 06F 145 710 D. As found in the 2009 onwards 1.4 and 2.0 liter vehicles fitted with the "D" version of the solenoid.
Please note: For the twin charged 1.4 engine (Turbo and Supercharger) please see FMDV14TSi
Replacement Vacuum operated Valve for VAG 1.8 and 2.0 FSiT
Please See below for more information from Forge Motorsport's Website
Many owners of any VAG vehicle equipped with the all new 2.0T FSI engine, have unfortunately discovered, that the OEM electronically controlled bypass valves, which bolts directly to the compressor cover of the turbocharger, have their limitations. If you are running increased boost pressures, after a software remap (chip), or the OEM valve is being subjected to high temperatures, the lifespan of the unit is significantly reduced. Even without any modifications taking place to the vehicle at all, this OEM valve has been shown to fail over time and it’s boost holding capacity also leaves some room for improvement.
We now have the world’s first fully engineered solution offering both significantly improved reliability as well as valve related boost response. Our valve and installation kit replaces the original unit with a pressure/vacuum operated piston valve that still also retains the desirable OEM ECU control over valve actuation. This product has been thoroughly designed and tested with the expressed intent of offering improved valve response and maintaining ECU control while resulting in absolutely NO fault codes, NO check engine lights, and no adverse effects of any kind. All of the necessary components and detailed instructions are included and everything is designed to make installation as simple as possible.
This product is applicable for all of the following 2.0 FSiT applications:
VW Golf MK5 GTI/Jetta GLI, VW Eos, VW Passat (B6)
Audi A3, Audi TT Audi A4 (B7)
SEAT Leon
Skoda Octavia
For all vehicles where the OEM valve is mounted remotely (8P Audi S3, MK5 Golf Edition 30 and the Seat Leon Cupra), please see product reference FMFSITVR. )
