Page 4 of 5 FirstFirst ... 2345 LastLast
Results 121 to 160 of 182
  1. #121
    Senior Member Four Rings *Blue-Angel*'s Avatar
    Sep 11 2007
    2000 S4 TT RaceCar & 2007 IS350 ;2007 Mazdaspeed6
    Tampa,FL
    yeah man im deff not rushing anything with this car. Did that with my last two cars and it just leads to problems. Between the three cars of mine right now and work I really dont have time to finish anything lately. The car is honestly as close as possible to being finished but I am dragging it on because I am still looking to see if any fluid is dripping from the slave cylinder I installed. The other night it looked like some fluid was around the edges of the slave and that just doesnt cut it. I need a perfect seal on that thing. I really dont want to have to yank it yet another time.
    Im also sitting here patiently waiting on my driveshaft but things do not look so great with that at the moment.
  2. #122
    Sep 11 2007
    Tampa,FL
    Having trouble aligning shifter. Can get reverse, 1st, 2nd, 3rd but locked out of 4th-6th
    That's using Audis suggested 3degrees to right and 7degrees back.
  3. #123
    Sep 11 2007
    Tampa,FL
    Debate right now is whether to go with a carbon fiber DS or stick with a one piece steel shaft.
  4. #124
    Senior Member Four Rings gearhead1186's Avatar
    Mar 17 2009
    02 S4, 06 GTO, 69 Camaro, 73 Cuda, 68 Torino
    Queens, NY
    Quote Originally Posted by *Blue-Angel* View Post
    did you shave down metal where the bushing sits?
  5. #125
    Sep 11 2007
    Tampa,FL
    yessir. I will get in there with a flashlight and my fingers and see what I feel tho. I can access Reverse. 1st-4th at the moment but not 5th and 6th. Im hoping/thinking its just because the gearbox was freshly rebuilt and the input shaft needs to be spinning. But I dont know bout that. I think I should still be able to nail all the gears.
  6. #126
    Sep 11 2007
    Tampa,FL
    Actually looks like I can get in every gear. Not very easily but it appears the biggest problem is that there is no reverse. May have to redo the shifter. SIgh.
  7. #127
    Sep 11 2007
    Tampa,FL
    Carbon shaft should be ready by next week. Had a driveshaft made for both my speed6 and s4. Soon to come out is a shaft for evox and sti :)
  8. #128
    Sep 11 2007
    Tampa,FL
  9. #129
    Sep 11 2007
    Tampa,FL
    Just a couple hours away from finally being able to drive my car for the first time in 11 Months!!!
    So stoked.
  10. #130
    Mar 17 2009
    Queens, NY
    So stoked.
    hurry up slacker.
  11. #131
    Veteran Member Three Rings Spooled1.8's Avatar
    Jan 26 2006
    York, PA
    Congrats man
    -Pete
    2001 Imola Yellow S4 EPL/TiAL S605
    -Evolution Racewerks Intercoolers with Carbon fiber shrouds.-EBC Redstuff Pads-EBC Rotors-RAI Motorsport 3" Downpipes-AWE Twin 1 Exhaust-AWE DV1 DV's-AWE Center Vent Boost Guage-AWE DTS Bar-Advanced Automotion Rebuilt Trans-Southbend Stage 4 Clutch-Fidanza LWFW-ASP Engine Mounts-034 Motorsport Trans Mounts-Apikol Rear Diff Mount-KW Variant 3 Coilovers-
  12. #132
    Sep 11 2007
    Tampa,FL
    Got her out the garage!
    What a day its been. So many issues so many little things to wrap up. Only one major issue left and its the brakes. They mediate between extremely hard and very mushy practically not working. So I am guessing there is a pile of air in the system somewhere. I will try to bleed them out and see if that helps or not and then possibly take it out the garage for a song and dance later around 2am :)
  13. #133
    Senior Member Four Rings RolledMySTi's Avatar
    Jul 06 2007
    2001 S4 Sedan Laser Red
    San Jose, CA
    Good to hear she is alive, mostly anyway.
    01 Laser Red S4 Stage 3 | Vast Fueling | VAST Stage 3 clutch | APR Downpipes | Neuspeed Exhaust | Ebay Side Mounts | ECS Pulley Kit | Darintake | UUC Short Shifter | ST Coilovers| Samcos | AWE DTS Bar | JHM Center Diff | 034 Track Motor Mounts + Street Trans Mounts |Apikol blue rear diff mount and bushings | Hooked on Meth
    TEAM|AXION
  14. #134
    Sep 11 2007
    Tampa,FL
    Vids, Pics of my actual car and some of the other custom work ive done and things installed that havent had there pics yet as well as dynos and engine build to follow :)
  15. #135
    Sep 11 2007
    Tampa,FL
    Got the linkage figured out and fixed! car goes in every gear.
    Still waiting on master cylinder then that will get installed and hopefully the stop from triple digits :)
    Waiting on custom tune from VAST should be here Friday
    Then alignment from Reeves Motorsport Audi.
    Saturday = FixxFest.
  16. #136
    Sep 11 2007
    Tampa,FL
    Car is breaking in really nicely. Only put about 78miles on it so far. Car is running stupid rich right now. Getting about 17mpg. Back fires like crazy. The car also appears to have a faulty N75. Nothing new around here lol. Car boosts to ~21 and drops to around 15 and then boosts back to 20 or so and then back to 15. Still need to hook up the Meth controller and get this tune fine tuned a bit. In the process of getting a VAG cable that actually works and updating operating system on my laptop for car so I can run ECUx and send the logs off and get everything smoothed over a bit. Over all the car is a complete blast to drive. I can see everyones pashion for this car and I also understand how this has been a car I adored since 15. Well worth the 11 months it spent in the garage and the very large amount of money it drained from my bank account.
    It goes in for alignment tomorrow. And dyno tune next Tues. Stay tuned for more pics and vids and logs in near future.
  17. #137
    Sep 11 2007
    Tampa,FL
  18. #138
    Jun 14 2007
    Connecticut
    Looking good man, it must be great to be back in the car driving it again. I looked through the pages, this is with Tials right? Congrats, everything you did took time but certainly was a thorough job.
    VAST Performance Stage 3 B5 S4 | Videos
  19. #139
    Sep 11 2007
    Tampa,FL
    not yet it doesnt. The motor build will begin after I build my MS6 first. The S4 will be 3.0L 770 with built heads. But if I gut the car then I may just go with 605s instead since I will yeild the same acceleration with less weight.
  20. #140
    Sep 11 2007
    Tampa,FL
  21. #141
    Sep 11 2007
    Tampa,FL
    Looking forward to getting her back on the road in a couple days. Newest additions are a custom exhaust and Meth. Retune to come soon.
  22. #142
    Senior Member Three Rings FlaS4's Avatar
    May 05 2008
    2000 B5 S4
    Miami
    Nice man. Are you building the motor yet? Any parts collected?
  23. #143
    Sep 11 2007
    Tampa,FL
    Still being held back with my Mazdaspeed6. Hell the S4 has been sitting for awhile. Im going to start the process of gutting the car in the next week or two max. And then pulling the motor in july and doing some more work. Motor build and turbo build wont start till the end of the year at the latest.
  24. #144
    Sep 11 2007
    Tampa,FL
    Mazdaspeed finally finished. So Audi is starting to see some time.
    New tires, New ABS Module, Exhaust being fabbed new Headlights so I can actually drive at night so its not 96degrees out side. Looking forward to finally getting her back on the road again.
  25. #145
    Senior Member Three Rings FLYINGLEGGS's Avatar
    May 04 2009
    Clearwater, FL
    I think your biggest problem is not having a real driver that can handle the power of das audi. I'll be glad to fill that spot for you after all the work is done.
    Yah! You must make das Audi finished!!!!
  26. #146
    Sep 11 2007
    Tampa,FL
    Das Audi Is finally finished. I had to turn boost down a few psi because of knock because my tune calls for Race gas. At any rate it runs great. Just took bypassing the N75 and using a Perrin MBC to get a controlled and linear boost response.
    Im already in the process of gathering parts for my 3.0L 770R turbo engine swap.
  27. #147
    Sep 11 2007
    Tampa,FL
    Finalyzing:
    Custom Floating Rotors
    Cayenne Calipers
    Hotchkis Sways
    New Brake Lines front and rear
    New Carbon Fiber Driveshaft
    A/C System Delete
    Will Post Pics of Everything Soon When Done
  28. #148
    Sep 11 2007
    Tampa,FL
    Edit:
    Scraped the crappy cayenne brakes and heavy rotors for a custom Competition AP Racing front BBK with 2 piece rotors and lightweight forged aluminum racing calipers
    Calipers alone are 5 lbs lights than Cayenne calipers and the rotors are 15lbs lighter on each side!
    Hotchkis Rear sway bar and H&R front sway bar
  29. #149
    Oct 29 2005
    1988 Jetta, 1998 ZX7R
    Ft. Lauderdale, FL
    Edit:
    Nice keep us updated. Do you feel the difference?
    - Clint
    New Ride: White '04 S4 2.7T - Already Stage 2
  30. #150
    Sep 11 2007
    Tampa,FL
    I will be posting pics and threads shortly. Will be updating this thread as well.
  31. #151
    Sep 11 2007
    Tampa,FL
    Just finished gutting the entire car. Ready for roll cage and chasis reinforcements.
    Updated the first page.
    KW Coils, Carbon Trim And Sunroof etc...check it out.
  32. #152
    Sep 11 2007
    Tampa,FL
    Teaser
  33. #153
    Jun 14 2007
    Connecticut
    Rotors look awesome!!
  34. #154
    Sep 11 2007
    Tampa,FL
    Thanks, been a long time designing them. I personally believe they are of the nicest on the market and will look fantastic in the finsihed form, stay tuned for details.
  35. #155
    Jun 14 2007
    Connecticut
    Definitely.. Eventually I'll need replacements for my Cayenne calipers, I run a 350mm 2 Piece JHM rotor now.. Would they be making a set that would work with what I have?
    Looking forward to installed pics.
  36. #156
    Sep 11 2007
    Tampa,FL
    Nope sorry, stand alone system. 6 different models available for the B5 chassis and 2 available for the B7 and B8 chassis
  37. #157
    Sep 11 2007
    Tampa,FL
  38. #158
    Jan 11 2007
    SLC,UT
    What was the issue and solution with the linkage? Just aligning the shifter?
    ** GT2860R-7 S4 Build Log--
    FOR SALE (click me):
    --FIKSE FM10 - 3pc LIGHTWEIGHT WHEELS - 17x9 et55 & 17X8 et57 - 5x130 - WORK ON AUDI W/ ADAPTER**
    --JHM DELRIN SHIFTER STABILIZER BUSHING (LATE STYLE)**
    --RS4 AIRBOX--
    LOOKING FOR:
    --BROKEN SPIDER HOSES
  39. #159
    Sep 11 2007
    Tampa,FL
    Very small amount of material that was holding the OEM pieces in place was left to long so when you threw the shifter forward for reverse it was unable to make a complete travel to engage reverse. Took the dremel up to that area and carefully removed a little more material and it was now able to move forward far enough to engage reverse.
  40. #160
    Senior Member Three Rings 30vQuattro's Avatar
    Mar 09 2008
    B5 s4, B5 a4
    Lakeland
    subscrizzledddd.... Finish it sucka. I can't believe I hadn't seen your thread..
    Ohh the b5...
