Page 2 of 2 FirstFirst 12
Results 41 to 49 of 49
  1. #41
    Forum Moderator Four Rings Blake P's Avatar
    Mar 02 2007
    Fresno, CA
    Quote Originally Posted by c-dubmobile View Post
    All,
    I have a Q5 and would like to perform the same mod.
    As mine is Automatic, RS4 does not apply to me.
    Question: Does both RS5 and RS6 gas/brake pedals fit my car? What is the difference? Thanks.
    It is my understanding that the RS5 pedals would be a direct fit.
    2009 A4 2.0T quattro sedan: quartz, prestige, S Line, nav
    APR - ADV.1 - A.W.E. - StopTech - Posi-Quiet - STaSIS - Rieger - DEVAL/EuroGear - Ingolstadt-Kunst - FormulaOne - Valentine One - KW - VCDS - OEM+
  2. #42
    Sep 04 2011
    Baton Rouge, LA
    Thanks for your help. Do you know if the RS5 pedal is also a direct fit? Does it require modding like shown earlier in this thread and this link?
    http://www.audienthusiasts.com/ProjectRS4PedalSwap.html
    Thanks.
  3. #43
    Mar 02 2007
    Fresno, CA
    RS5=direct fit
    RS4/6=requires modification aka not direct fit
  4. #44
    Sep 04 2011
    Baton Rouge, LA
    RS5=direct fit
    even for the Q5? thank you again
  5. #45
    Senior Member Two Rings Q-NIC's Avatar
    Jan 02 2007
    Golf GTI MK1 ,Harley 48
    Finland
    Yes,RS5 is direct fit on Q5
    Glacier white A4 2.0Tfsi Quattro S-tronic 2012 . H&R . 20" RS5 .
  6. #46
    May 31 2011
    moore
    I'm replacing the gas/brake pedals on my S4 tonight and just want to make sure i have all the steps right. For the brake pedal, remove the plastic cover and slip the new one on. For the gas pedal, slip the new one on top of what's on the pedal. No need to remove anything from the gas pedal?
  7. #47
    Mar 02 2007
    Fresno, CA
    Quote Originally Posted by hiwasss View Post
    You got it! Just make sure to have some hot water and/or lube handy to get that gas pedal on. It's a real PITA, honestly.
  8. #48
    Active Member Two Rings Midnight Storm's Avatar
    Jan 30 2012
    C5R Corvette, Avalanche, Trans Am, STS, Jetta
    Fox Island
    I wanted to add this little helper. It you have an Ipad or Iphone or smart device with a camera. Set it on the floor with the screen facing up so you can see what you are doing. Here are two photos I took while installing my new pedals. This really helped. I must have spent 40 minutes trying blind and 10 min to finish the job once I put the Ipad down. It is also great for making sure everything is correct & secure!
    2009 Aruba Blue Pearl A4 3.2 Tiptronic Sedan ► Premium Plus • Quattro • Underseat Storage Bins
    • Debadged • Front Filler Plate
  9. #49
    Active Member Three Rings maga4's Avatar
    Aug 12 2011
    Olathe, Kansas
    ^^^^good thinking!
    2011 A4 Premium+, Quattro, 6MT, 18" OEM 5-spokes, Nav, Black/Black
    APR Stage 1, 35% Tint, Eibach Pro-Kit, Vag-Com, Gloss Black 3.2 Grille, Hoen Endurance Fogs, LED Interior/License Plate Lights, Strat Short Shifter, BFI Catch Can, Eurocode TIP/TRUFit Kit/HFIP, Hardwired V1, Rieger Lip Replica
    '91 Audi 90s Quattro, 5MT, White, stock
    Past: '98 A4 1.8TQ, Tip, Red / '99 A4 1.8TQ, 5MT, Black, Sport
