Results 1 to 12 of 12
    Jun 30 2008
    Erie, Pennsylvania
    C6 - Electrics dead, steering locked, Need some assistance
    The car is 2005 Audi A6 3.2 Quattro automatic.
    The car will not start with the key. Turning the key to the "on" position also does nothing. The steering will not unlock, the electronic parking brake will not disengage, and it will not come out of Park. Battery is good (12 volts).
    I've checked the fuses on the side of the driver's kick panel and in the passenger side of the trunk. I found 1 blown 20 amp fuse at the top position int the trunk fuse panel, but replacing it did not change the behavior.
    It seems like it is not recognizing that the key has been turned to the "on" position. All of the power items that should operate without the key work fine: power seats, brake lights, etc. Items that should power up with the key "on" do not get power.
    I believe the problem may be either:
    - Ignition Switch
    - Power Supply Relay (Terminal 15)
    - Access/Start Control module
    1) Can someone tell me where the Power Supply Relay is located? I'd like to test for power/ground there. My diagram says "behind storage compartment, driver side", but I find no relays on the driver side of the trunk.
    2) How do I go about testing the ignition switch? I have a "power distribution" wiring diagram, but it only shows the Access/Start module, not the actual ignition switch. It seems that the ignition switch is just a low-current input to this module, which uses a couple power supply relays to actually switch power.
    3) Any other suggesstions or experience?
    TIA
    Veteran Member Three Rings Kemer1's Avatar
    Aug 26 2008
    Sin City
    Re: C6 - Electrics dead, steering locked, Need some assistance
    Ok when you put the key in the ignition does the radio turn on? power windows work?
    What I'm getting at is the issue you're having is going to be either the key has lost its coding and it will need to be recoded...try another key to test if it's just the key...
    If the other keys won't work then you have a more serious issue. The sensor in the steering column that reads the key coding is fried, and is not able to be replaced seperately. You will have to replace the entire steering column... This was the fix for mine when mine had your exact symptoms.
    Good luck my man.
    Audentes Fortuna Juvat...Fortune Favors the Bold
    I drive a wagon, so even if you were to outrun me, could you really brag about it?
    Jun 30 2008
    Erie, Pennsylvania
    No, turning the key to ON does not have any effect whatsoever. No radio, no dash lights, windows don't work, nothing at all. The "insertion" of the key will "wake up" the MMI and the date/miles display of the cluster, and make it "bong" if the door is open. Nothing else.
    I would think if it was the coding, then the cluster would blink a key/lock symbol or something, right? Also, I think the coding may prevent the vehicle from starting, but would not prevent the windows, etc from working. Or am I wrong here? What all does the transponder lock you out of?
    And the key is not inserted into the steering column. It is inserted into the dash, straight ahead, just to the left of the large LCD display. The steering lock appears to be actuated by a solenoid, not directly by the ignition cylinder.
    I'd really like to test at the Power Supply Relay location, anybody know where that is at? Actually I've found only 1 relay - in the trunk near the battery cable patch bay. Where are the rest of them? I looked behind the driver kick panel and didn't see any there. ECU box perhaps?
    Kemer - What miles did your car have these symptoms?
    Established Member Two Rings anpk05's Avatar
    Aug 29 2008
    2005 A6 4.2L S-Line/
    Long Beach, CA (562)
    I had the exact same problem with my car, i beleive it's the ignition switch, not sure, i have check on the paperwork i got from the dealer. Well it happened to me at maybe around 50k miles on my car. The batteries are good, called audi road side assitance, they showed up tried to jump start the car. Then he called a tow truck and towed the car to the dealer - no charge. It's covered under warranty...
    Jun 30 2008
    Erie, Pennsylvania
    Thats funny, this car has about 51k miles. If you could tell me what they did, that would be great.
    Thanks.
    Veteran Member Four Rings Kevin1's Avatar
    Oct 19 2008
    Long Island
    It sounds like it is your Access Starter Control Module. It is a common problem in the C6, here is the lik to the TSB issued by Audi regarding the fix.
    http://www.uberlame.com/a6_tsb/Ignit...ot%20start.pdf
    1 of 1 in the United States - 2015 A6 TDI Prestige with 19" Sports Package and Season Dedicated Tires - Oolong Gray Metalic, Nougat Brown Interior, Dark Brown Walnut Inlays, Black Headliner, Driver Assistance Package, Cold Weather Package, Night Vision Assistant with Pedestrian Detection. Summer - Michelin Pilot Super Sport. Winter - Yokohama Bluearth Winter V905. Eurocode Sway Bars and Links. XPEL Ultimate.
    RIP - 2005 A6 4.2 - (February 2005 - August 2014) (142,000 miles)
    Jun 30 2008
    Erie, Pennsylvania
    Quote Originally Posted by Kevin1 View Post
    Thanks Kevin, that sounds like exactly what it is.
    Does anybody know where this module is located or the price of the updated module? Part number?
    I'm guessing it is in the steering column area, but I suppose they could hide it anywhere.
    Jun 30 2008
    Erie, Pennsylvania
    Post
    OK, got some info from the dealer. The part (access/start control module) includes a large part of the steering column. The price they gave was $1,050 just for the part. It also needs to be "coded" after replacement. Dealer will do this for $100.
    Also, the car is definitely, completely out of warranty. Not due to mileage, but time.
    Questions:
    - Has anybody done immobilizer coding using Vag-com? I'm not trying to skirt the dealer's coding charge, but the TOWING to get it to the dealer...$$$. I've read the Ross-Tech procedure. I'm looking for experience here specifically regarding obtaining the "PIN"/Date/Workshop Code/etc for the old module.
    - What did your dealer charge (hours) for the replacement?
    TIA
    Aug 26 2008
    Sin City
    Sorry to hear about your issue....like I said...I had the same thing go out on mine. Tried to save you a wild goose chase with the ignition switch. Good luck in finding someone to recode your keys. Just remember you have to recode all of them at once...or they won't work.
    Jun 30 2008
    Erie, Pennsylvania
    It is not so much the key coding, but matching the new immobilizer to the ECU. I called Ross-Tech (vag-com company) and they told me that it can no longer be done by vag-com. Coding the new module is dealer-only. Pre-2005 the dealer could give you a PIN to do it in vag-com but they switched systems. It is now completely transparent at the dealer. There is no PIN, the ECU talks directly with Audi/VW corporate computer. So much for a DIY. We'll see how it goes.
    Thanks again.
    Any additional info is still welcome. In particular I'd still like to know where the "Power Supply Relay" is located.
    Jun 30 2008
    Erie, Pennsylvania
    Well, I've gotten some questions about this thread recently, so I thought I'd update with the results.
    I procured a newer VCDS cable that did "CAN" bus. It was the HEX+CAN usb cable to be specific. Traded in an older serial VCDS interface to get a discount. Anyway, with the cable in hand, I went out to the car. Held the brake pedal for half a minute or something (to wake up the CAN bus, supposedly), then I was able to connect to the "Authentication" module.
    In the Auth module it had a code stored for the steering wheel lock solenoid, so that's why nothing would power up. I checked all the other modules too. There were tons of code set it nearly every module. Shorted circuits, open circuits, all over the place. I printed the codes out of VCDS and it was 6 pages of codes as I recall. Lots of "no communication" codes between the various modules.
    Back in the Auth module I hit "Clear Codes" and the car magically lit up, almost like the car rebooted. Went through the rest of the modules and cleared all the codes and there was nothing really wrong with it. Just a complete electrical fluke across all modules. Very weird. Car never came back. We figured somebody tried to jump start the thing and reversed the terminals. There was a slight arc burn mark on the positive terminal. That's all we could come up with for a cause, but the car was super nice to drive. I'll tell you that!
    2001 Laser Red A4 1.8TQM, 5-Speed Swapped, 4.11 Final Drive, APR 93, R8 coil packs, Labree HFC & DP, 2.5" Exhaust, ST Coilovers, 034 RSB, A8 Brakes Front & Rear, 18" RS4 Reps
    "You need to know what you are doing...Its like a rainbow jungle in there." - Redline380
    Veteran Member Three Rings JediJoker7169's Avatar
    Dec 11 2009
    San Francisco Bay Area/CA/USA
    MODS: Move this thread to the new C6 forum? Thanks for the update, OP.
    - JediJoker
    "Das Boot" / 2001 Audi A6 2.7T quattro sedan:
    RS4 clutch / 710N DVs / 2Bennett Stage2 GT front 6-piston Brembo 350mm/rear 311mm / Bilstein PSS9s / Hotchkis Sport anti-roll bars / 034 Density adjustable front upper control arms/Track Density front shock mounts/spherical rear anti-roll bar end links / O.Z. Superturismo LM 18" x 8" / Falken Azenis RT615K 235/40ZR18 / Hella E-codes / LED tails (ATL-254-LED-CR-LT) / Facelift black rear license plate trim
