Four Rings
2011 S4,6MT,phantom black,panda leather,carbon trim,prestige,B&O,sport diff,titanium package,alu-optics,MMI 3G+.5,APR 93 flash,APR pulley,APR CPS,APR intake stg1+2,Miltek Valved full res,Eurocode headers,Eurocode shifter,Eurocode stabilizer bar,Eurocode sways+end links,clutchmaster fx400,KW V3 coilovers,ST-60's 380mm,P3 boost gauge,E-code's,TT-RS wheel,ETMS piano black trim,VNSmedia tv simulator,RS4 pedals,Deval CF lip,deval rear CF diffuser,HRE P43SC 19x9.5 tinted clear finish,RS4 grill
Four Rings
Re: occ is up and running
hrrmmm pics not showing up
Four Rings
Very good!! How does the car run, notice anything different ? (as in not running smooth due to the integration of an OCC)
Four Rings
nope, no turbulence in the motor at all, everything seems like its running like normal.
Registered Member
Three Rings
l2photobucket
Four Rings
what am i doing wrong here ha
Registered Member
Three Rings
gotta copy the link that pb gives you then throw it between [img][/img]
Three Rings
LOL, good news man car should be running sick or i mean healthy now
2008 AVUS RS4
Stock and Slow ;)
2004 IMOLA S4
Dead
Four Rings
thanks tylers was copying the wrong link
Registered Member
Four Rings
damn your cf is discolored.. every rs4 hav that prob eventually?
-Grant
B8 S4 APR Tuned
TD1 Club
Four Rings
Oh yes. It's horrible.
Senior Member
Four Rings
I thought it was from the heat cycles as well but I saw a left over 08' last year in a show room and CF looked identical to the one in the pic...and mine on my car. I think it's a different hue they chose when manufacturing it? Who knows, I could be wrong but iirc the brand new RS4 CF covers matched mine in color.
Back on topic: Sweet!! It doesn't look out of place in the bay AND i'm looking forward to more reviews and feedback from you once you have racked some miles.
2007 RS4 : K&N : HPS & Stop Tech : DTH Cover : 30% Tint : Tubi Rumore (SOLD!) : Audi Sport Rubber Mats : H-Sport Sways F/R : Stern Links & UCA's : JHM L/W FR & RR : JHM I/M Spacers : JHM LWCP : JHM FULL 2.75" : JHM Stage IV & LWFW : JHM Tune : JHM Cross Rod : JHM SS : 034 MAF & USM's : 034 Trans Mount : USP Slave & SS Line / Ohlins SL C/O : Stop Tech SS : Apikol Red Diff Mount : HOEN H11 Fogs : LED : MTM 10MM : Front Plate Delete : CC Mod
Senior Member
Two Rings
I cant pinpoint where does the other hose from cc go? I see the top one, but the bottom one?
Four Rings
the bottom hose is venting back into the motor through the valve cover
Senior Member
Two Rings
Why not just let that one vent outside? I used to have a little breather filter on my Rx7 when i installed a catch can... Unless you are actually looking to get the vacuum?
Active Member
Two Rings
Perhaps others can, but I can't quite make out all the plumbing changes; besides the addition of the catch can, what has changed? Also, if the basic crankcase ventilation system remains the same, where did you place the catch can - on the valve cover breather line upstream of the cyclonic oil separator?
Regardless, it looks good, I'll be very curious to see how it performs over the first 5k.
2008 Audi RS4 | 2007 VW GLI
Four Rings
Interested, please PM me details on parts and so on. Good work sir!
08' RS4 Ti/ Daytona  64K and counting!
~ECS H-pipe/deflapped~Apikol diff mount~034 trans mount~JHM IM spacers~034 MAF hose~PSS's~
~H&R sport springs~JHM LW rotors~Hawk ceramics~034 slave and SS line~MTM 10MM spacers~
~Stoptech SS lines~Front plate delete~Euro bumper~Ecodes~Black rings F&R~smoked side blinkers~
~Hoen matched fogs~Lamin-X'd front~20/35% 3M tint~CF trim~LED interior~Clear-Bra~SR7 concealed~
Senior Member
Four Rings
X2 - if this ends up being a resolution, I'll add this set-up as soon as I complete the cleaning.
Four Rings
Will you have to empty the can so often? Or does it dump itself?
Senior Member
Four Rings
I believe it is a manual process(meaning we have to empty it), not sure on the frequency either. Someone will chime in I'm sure, I had these same questions and was about to ask.
Four Rings
yea, it is emptied manually, but as far as frequency of emptying it, no1 really knows as this is the first one to my knowledge on a rs4 so i guess ill let you guys know about that one haha. this motor needs the vacuum, putting on a breather would result in extreme turbulence and most likely a stall out
Four Rings
So you will also have to monitor the oil levels more closely now as the CC will pull some? How hard is your setup to remove the can and empty it? A chore or as simple as popping the hood and unscrewing the can?
Four Rings
emptying the can is as simple as loosening a clamp and taking it out, childs play haha. ill take some better pics a little later of the cc close up but there is a clear vertical line that shows you the level of contents within the can, so just every now and then ill take a peak under the hood when i check oil levels in the car or something like that.
Four Rings
What about oil consuption? Will it increase? Sorry for the 50 questions....
Four Rings
Hmm that does sound like a possibility. We'll only know how much in X amount of miles once Rich has driven some more and starts to see the CC accumulate oil.
Good thing is that Rich uses his RS4 as a DD and will rack up miles fairly quickly to give us some good results. I on the other hand will take 1/2 a year to drive 5K miles lol.
Four Rings
jeez dave i put on 5k a month hahaha
Four Rings
Goodness man. Well fortunately for me I have a toyota pickup DD. 97 T100 with 320,000 original miles and still running strong with no problems, it's rediculous.
I noticed in your sig you have BBS CM wheels.... since when??? Did you ever post pics? I must see.
They are just sitting in his garage right now since he has his snow tires on. I think hes had them for a few months now, definitely from at least the early fall I think.
Four Rings
i got them on for waterfest this is the only crappy pic that i have and its from the iphone
Four Rings
Please post up a full list of parts/etc.. when you get everything squared away. Very exciting!
Four Rings
That looks awesome Rich. It actually looks really good on the RS4. I've seen them on other cars and they were iffy. Great choice, can't wait to see them in person once the weather gets better.
What were the specs on the btw? 19x9.5 ?
Senior Member
Three Rings
OCC looks very nice in there. Great spot for it (apparently the only spot too!). Looking forward to hearing the results.
Whats the planned time-frame of checking on the build-up? After 3k miles? 5k?
New - 2013 S4 Moonlight Blue Metallic
Gone But Never Forgotten - 2007 RS4 Phantom Black Pearl - Stasis MS, Hotchkis F/R Sways, Clutchmasters FX300, GMG Exhaust, Piggy Pipes, VMR V710 19x9.5, K&N Drop-in
Four Rings
yea dave, 19x9.5 i personally dont like the rims off the car haha they fit strangely well on my car with the color schemes and what not, the barrels and insides of the spokes are black, its hard to see in the pics. imm gunna remove the intake manifold at around 5k, but i will constantly be checking oil levels in the can. at 500 miles i will crack open the can to see what if anything is inside
Four Rings
+1 on parts list. Thanks!
Four Rings
Richie, what was the cost of parts/labor?
Four Rings
i dont know what the break down was as i had several things done at once, call kmd tuning(9082325777) and ask for danny,he can work something out with you
Active Member
Two Rings
Oil consumption shouldn't change with a catch can. Instead of the oil going through the intake and being burned in the compression chamber you are catching it in the can and dumping it out manually. The presence of the can isn't going to increase or decrease how much oil is coming up through the PCV lines.
Nice install BTW! I plan to install one soon on my S4. There was a lot of oil in my intake the last time I had it off so a catch can should help remedy that problem.
Four Rings
Richi, let me know when you take a look in the IM, I am very interested about this and spoke with Danny yesterday at KMD. It's riding on you bud! Thanks.
Four Rings
winterrunner, i walked into kmd as danny was on the phone with you hahaha.
VERY small update. because i was so impatient lol... we opened the catch can at kmd yesterday, i had put on 200 miles at that point. the catch can IS catching. we drained out a little bit so stay tuned
Four Rings
Ironic huh? Anyways, that is great news, hopefully it should catch all the oil buildup before it is recirculated.... I was talking to a buddy an d he suggested maybe removeing the EVAP canister, thinking that would probably help as well. Any insight?
- You may not post new threads
- You may not post replies
- You may not post attachments
- You may not edit your posts
Forum Rules
