Page 5 of 17 FirstFirst ... 3456715 ... LastLast
Results 161 to 200 of 668
  1. #161
    Oct 26 2009
    Australia
    man I'm really grateful that you're doing it now nickg.. I will be in the same position as you in a months time and I hope I can manage alright.
    So everything is working fine now except for the highbeam?
    I wish I have all the equipment now so I can do it at the same time
  2. #162
    Senior Member Three Rings Cabal_san's Avatar
    Sep 06 2009
    TX
    Quote Originally Posted by nickg View Post
    well, I don't know, on byte 1 and 2...
    Nick,
    In an effort to be clear, please use the correct Byte numbering positions in your questions. All coding starts at Byte 0. When you say Byte 1 or 2, no one here has any idea what exactly you mean!!!
    I don't mean to sound terse, but we can not help you unless you use some specificity in your coding declarations on this forum.
    Thanks,
  3. #163
    Senior Member Four Rings NPuter's Avatar
    Oct 27 2009
    2007 MBZ CLK 350 Cabriolet
    Miami, FL
    the first two numbers in the coding are BYTE 0
    When I said byte 2 I meant byte 2 - the first byte in the coding is 0 - so you correctly changed byte 2 to 10
    byte 0 (originally 69) needs to be changed to 26 otherwise the xenon lights (the actually xenon bulbs) will not work properly. When my lights were installed, I ran them for about 10 mins without changing the coding
    Here is what I experienced
    - while the xenon lights seamed to work, one of them went out after about 10 mins and the other flickered
    - when you turn them on, they flash an unusual red color for about a second
    changing byte 0 from 69 to 26 fixes both of these issues...
    also, you need to change 14/15 from 5F5F to either 5D5D or 1D0D if you want your high beams to work...
    Nick (NPuter) ~ Brilliant Black 2010 B8 A4 2.0T | Build Thread | S-Line Front Bumper Conversion |
    Bi-Xenon Retrofit | LED Taillight Retrofit | S-Line Front & Rear Bumpers | S4 Alu Splitter | 19" Hartmann HTTRS MA:M | Vogtland Coilovers | APR/Carbonio Intake | Paddle Shifters | Gloss Black MMI surround | Yellow Fogs | LED Plate Lights | 20% Tint | VAG-Com
  4. #164
    Sep 06 2009
    TX
    heh, that actually sounds pretty damn cool, if you can get it to keep it a solid red! lol
  5. #165
    Active Member Two Rings nickg's Avatar
    Jun 06 2009
    Australia
    I'm pretty sure I have tried to just change the byte 0 from 69 to 26 but it kept giving out of range error, I'll try that again tonight, and actually I've noticed the same issues of flickering and flash as well
    Quote Originally Posted by Cabal_san
    Nice pick
    Quote Originally Posted by t0n13
    I didn't connected the high beam wires so I'm not expecting highbeams to work :D
    2010 Ibis White A4 B8, Xenons, Nav, Sunroof
    Mods: %35 tint, 19"x8.5 ET35, H&R Springs, 5mm spacers on rear, S-line exhaust tips, Vagged
    Planning: S4 mirrors & grill, APR Stage-1, Vortex/Caractere body kit, Rear Optical PDC
  6. #166
    Jul 10 2009
    northeast
    when changing byte 0, did you try to change it in the long code helper? you should try to just change the actual long code. hope this works
  7. #167
    Jun 06 2009
    Australia
    Quote Originally Posted by macuser View Post
    Thanks
    I noticed that in long code helper when you change the value of a byte and click on Exit while the changed byte is still selected, the long code turns up incorrect, but if after changing the byte value in helper and you select another byte and click on exit, the long code turns up fine, in any case now that I've actually used the software once last night, tonight things should be easier
  8. #168
    Oct 27 2009
    Miami, FL
    yea - it is kinda crucial to change byte 0 to 26 - otherwise your headlights (when turned on at night) will only be headlights for ~10 mins... not to mention the damage you are doing to the bulbs with the intense startup...
    where are you getting this "out of range error" error? - does it show up on the dis screen?
  9. #169
    Jun 06 2009
    Australia
    on the software (VCDS?) screen on the laptop when I press the DO IT button, I'll take screenshots when I get home, in probably 2-3 hours
  10. #170
    Jun 06 2009
    Australia
    the screenshot:
    Edit:
    Found this post, I'm not alone http://audiforum.us/b8-platform/9098...html#post73207
    He is from UK so an RHD version just like me
    I just retrofitted the bi-xenon lights to my car today, but despite all attempts to change byte 0 from 69 to 26, VAG COM returns an error message. As a result, I still don't have high beam/passing light for the car.
    Does anyone have a similar problem? Thanks.
  11. #171
    Oct 27 2009
    Miami, FL
    that is really strange... can you post your long coding of 09?
    also, if someone with RHD and stock LED bi-xenons is reading this, would you be able to post your coding too...
  12. #172
    Jun 06 2009
    Australia
    Hope these pictures cover the coding you want
    http://i41.tinypic.com/2efsyag.png
    http://i44.tinypic.com/15d9urn.jpg
    By the way, I randomly tested some numbers above and under 26, only 23 seem to be accessptable and actually lights work fine on this setting (I guess), thinking that a random number can harm the lights or the car I quickly changed everything back to default
  13. #173
    Active Member Two Rings carlsA4's Avatar
    Aug 21 2009
    Dirty South
    My lights arrived today, with no apparent damage. I feel very lucky. Now i have to wait for Kufatec to ship the harness's. they are still on back order. Also the lights came with two extra brackets in an L shape. I don't have time to take a photo, but if anyone can tell me what they might be I would appreciate it. I'll send a pic tonight to help out.
  14. #174
    Jul 10 2009
    northeast
    i believe the halogen brackets that came with the car are compatible with the xenon headlights, so you can just use the ones already on your car.
  15. #175
    Jul 10 2009
    northeast
    did you try to copy and paste the old code into the new code section, change the first 2 numbers from 69 to 26 and then click do it yet?
  16. #176
    Jun 06 2009
    Australia
    Yes and it didn't accept the code, I'm wondering if AU/UK models use a different code than 26, 23 worked for me and I'll be able to provide the AU model code within 2 weeks as soon as my new car arrives (I've sold my current one which didn't have xenons, the new one will have xenons)
  17. #177
    Oct 27 2009
    Miami, FL
    cool - I'm interested to see what byte 0 is for RHD xenon cars...
  18. #178
    Jun 06 2009
    Australia
    I think I found the problem, this post explains the issue http://www.a5oc.com/forums/showpost....8&postcount=23
    Apparently, J519 controller (power module?) has to be replaced in order to get the car to accept the first byte as 26, otherwise however, the xenons will work but without high beam support
    as mentioned in the link above, the part number for this module is 8K0 907 063 D and it has to be activated by an Audi service centre
    I wonder why we have 8K0 907 063 stock controllers while you guys have 8K0 907 063 D stock controllers...
  19. #179
    Senior Member Four Rings coolwater's Avatar
    Nov 06 2009
    NYC NY
    Good to hear they got there safely. What was the cost and delivery time?
    -cW
  20. #180
    Aug 21 2009
    Dirty South
    -cW
    It wound up being a little over a grand and took two weeks for delivery. But it took him three weeks to actually ship them so it took a month and a half to really get here. I got news yesterday from Kufatec that the harness came in but they did not have enough
    to fill all the orders. Mine being one of them. You don't want to sell me yours do you? LOL.
  21. #181
    New Member One Ring
    Mar 17 2010
    Spain
    codificacion
    The gray cables of the adapter kufatec, they are placed of the following form:
    1. Net of on board (under the steering wheel) conector brown color of 17 poles to the pin 9 2. Net of on board (under the steering wheel) conector red color of 17 poles to the pin 3
    Go into 09 Central Electronics
    Click on Coding-07
    Select Long Coding Helper
    1) Change the first byte to 26 (Xenons will turn on properly after this)
    2) Check Byte 02 Bit 4 (LED strip as DRL)
    3) Change byte 14 and 15 to 5D (For the hi-beam to work)
    ONLY, this conversion works if the net of I approach, is the version ended in "D" For example, in this photo the tests(proofs) have been realized by the net of I approach ended in 063 "A", since IT IS NOT COMPATIBLE, the long light does not work. And have fis error.
    Only works 063 "D" revision, and no have fis errors
    http://img121.imageshack.us/img121/7330/a55h.jpg
    http://img266.imageshack.us/img266/7...1257456192.jpg
    I hope that it you is of help, a greeting from españa
  22. #182
    Jun 06 2009
    Australia
    just to give an update, I've been given a loan car till the one I ordered arrives here,
    the loan car is an A4 B8 2010 1.8T without any package not even comfort and of course with halogens, surprisingly enough it does accept 26 for byte 0
    part number of J519 controller on this car is 8K0 907 063 K, on my previous car it was 8K0 907 063 without the K at the end
    that's a good news for me, I can install the Xenons retrofit kit I've ordered on someone's car and at least cover my loss
  23. #183
    Sep 06 2009
    TX
    swap Controllers with the loaner?
  24. #184
    Jun 06 2009
    Australia
    Quote Originally Posted by Cabal_san View Post
    I sold my car and the new one I ordered comes with Xenons (and Navigation which are the only reasons why I changed my car), even if I were to swap controllers it had to be activated on both cars by Audi service centre using their online portal so they would obviously know what I've done
  25. #185
    Aug 21 2009
    Dirty South
    Quote Originally Posted by xdeymos View Post
    Click on Coding-07
    Greetings Espania. I've been there many times. My mother is from San Lucar de Baramedos. I love that country, and the food.
  26. #186
    Oct 27 2009
    Miami, FL
    this is very interesting - so there are different "Versions" controllers for headlights in our cars... I wonder if my successful conversion is due partly to luck..
    I'm out of town right now, but I'll check which controller I have when I get home...
  27. #187
    Aug 21 2009
    Dirty South
    Click on Coding-07
    I got my adaptor today :) i have a questions. the two high beam wires are different colors. witch wire goes to witch connector? do i match them to the color of the conector?
  28. #188
    Oct 27 2009
    Miami, FL
    Quote Originally Posted by carlsA4 View Post
    the ends of the wires are labeled with Pin ** (the instructions tell you which pin goes to which connector)
  29. #189
    Nov 06 2009
    NYC NY
    Carl, good luck with the install. Post some pics of the install if you can.
    I am still waiting for my replacements e-codes from Germany. I paid extra for premium delivery service, whatever that means...
    6-8 days delivery according to DHL.
    -cW
  30. #190
    Aug 21 2009
    Dirty South
    lowest a4 sent them to me. thank you LA4. no instructions.. CW can you help me wit this
  31. #191
    Aug 21 2009
    Dirty South
    They are in. still need to hook up the high beams i forgot i need a metric socket set. oops. i'll send a pic tomorrow its crappy from my BB.
  32. #192
    Oct 27 2009
    Miami, FL
    Here are the instructions for the kufatec adapters - the link will be active for 2 weeks after this post...
    http://tinyurl.com/y9n8rrs
  33. #193
    Aug 21 2009
    Dirty South
    Awsome. Ill print it.
  34. #194
    Oct 27 2009
    Miami, FL
    cool... now that I read it again - the wire the says Pin 3 goes to the brown connector and the wire that says pin 9 goes to the red connector...
  35. #195
    Aug 21 2009
    Dirty South
    How do you remove that little magenta clip that holds the wires in the brown and magenta 17 pin connecter?
  36. #196
    Senior Member Three Rings ASU Daniel's Avatar
    Oct 03 2009
    2009 A4 2.0T
    Scottsdale, AZ. Vicenza, Italy
    very carefully
    if i remember right, it slides out a little one way, and then you can pop it out
    another update too: after i got my car back from the dealership (was in a slight accident and the body shop sent it to them to do some stuff) they had recoded my ecu and changed a bunch of shit. Basically i got lucky my friend was home with his vag-com or else i wouldnt have had headlights that night hahaha...pain in the ass!
  37. #197
    Sep 06 2009
    TX
    Did you ever get your hi-beams working??
    And the dealership just hooks you up to their VAS and wipes out everything to nice default settings!!! If you mod, you need your own cable, or lots of 12 paks kept chillin' in a small cooler in the trunk ready for those who come turn on your headlights in the middle of the night with a re-code! heh
  38. #198
    Oct 27 2009
    Miami, FL
    yep - that is partly why I bought mine... - I'm still contemplating if I should tell the dealer not to touch the coding during my 5,000... I mean, if they did, they would probably get some errors and maybe even damage my lights...
  39. #199
    Aug 21 2009
    Dirty South
    I would ask them not to re flash it.
  40. #200
    Jul 10 2009
    northeast
    just tell them you changed some of the vag settings and to only update the ecu if necessary.
