Page 1 of 9 123 ... LastLast
Results 1 to 40 of 346
    Stage 2 Banner Advertiser Four Rings Adam@SPP's Avatar
    D4 A8l/Street Glide Special
    NEW prices on adam's rotors: $500 f&r to your door!
    BUILD YOUR CUSTOM ORDER | MACHINE PATTERN, ZINC FINISH, HUB COATING, METALLURGY, & BRAKE PAD/STAINLESS STEEL LINE/FLUID PKGS.
    WWW.ADAMSROTORS.COM
    adam's rotors inc. started out small and remains that way...a tight knit, self-owned & operated company established & going strong since 2006.
    the small outfit and one-on-one interaction creates only the best service w/quick response & even faster made-to-order set-ups. with top notch products, this lends hand to our success thus far.
    working 24/7 throughout the day, any and all questions are answered within the hour to the best of our ability, if not instantly.
    being an online company we do business direct via email, instant message, PM, and over the web in our ever growing threads...we're always here ready to reply!
    we are a fully made-to-order, replacement disc brake, rotor manufacturer...we offer only factory fit, OE spec, plug n' play discs.
    WE CATER TO THE CAR ENTHUSIAST WHO NOT ONLY NEEDS NEW BRAKE ROTORS, BUT WANTS SOMETHING DIFFERENT BEHIND A NICE SET OF WHEELS.
    be it looks or performance, adam's rotors is the only company to bring you over 17+ machine pattern variations (most of which are exclusive to AR), 3 zinc finish offerings, and 5 ceramic-silica hub coating options.
    YOU PICK, WHAT YOU WANT AT AN ALL-INCLUSIVE PRICE | COMPLIMENTARY CORROSION PREVENTION, FREE SHIPPING, CHOICE OF DRILLING, SLOTTING, AND/OR DIMPLING, ALL LOADED INTO OUR WEBSTORE.
    adam's rotors expertise is in the VW/audi market, but do set-ups for ANY make/models car/truck/van…check to our store!
    WHY ADAM’S ROTORS? WE’RE DIFFERENT!
    because we do what no one else does. AR is a customizable product, having managed to turn a boring replacement product into something different. it's a have-it-your-way, made-to-order modification item ideal for any enthusiast. now, instead of just picking 1 of 1-3 drilled or slotted rotor styles from off-the-shelf inventory, we offer over 17+ patterns for your choice/taste, how YOU want them. after that pick a zinc for corrosion prevention...silver? gold? maybe black? thereafter you can even add one of our coated hub colors in a satin ceramic finish to finalize your set and truly give them polished, unique look. we now even offer upgraded metallurgy, to a stronger premium grade high carbon iron if you so wish. we at AR believe a rotor ISN'T just a plain ol' service part...rather a fun, custom, cool way to not only enhance the look of your car, but add performance, protection, and something different to your build, with a ton of bang for your buck!
    oh yeh...and they actually perform!!!
    track tested, endurance race team approved; check it out HERE.
    QUALITY, IT'S ALL IN THE DETAILS...
    we chamfer each drill hole and pay extreme attention to how we lay down our machining…taking meticulous measures to avoid each and every vent rib; the internal cooling veins in most modern vented brake rotors. AR will not drill a rotor we are unable to do so with and thus unlike most, never have issues. this is another reason why unlike many, we also offer dimples and unique slot patterns, ways of avoiding this and offering better, longer lasting, quality products when we see possible issues with venting. lastly each set is made for YOU without the limitations of pattern & finish pre-made, “in stock”, off-the-shelf parts have. instead, we start each order upon payment & cater to your needs/wants for your car.
    HOW IT WORKS:these are customized by you & made per order; you'll have them in about 2-3 weeks...
    (this takes in account ordering raw material, ship time to the shop, pattern machining, zinc finishing, hub coating & curing, packaging, & shipment pick-up!)
    we hold NO inventory & are held to the same final sale terms as our policy.
    we make ONLY factory fit replacement rotors to OE spec. plug n' play original fitment.
    whatever one-off size you may be after other than what your car came with, will need to be based off another application's rotor that already exists.
    in some cases, we can open up hub bore and modify bolt-patterns (within reason) but we need to discuss via email, first.
    YOU TELL US HOW YOU WANT THEM!
    1. dimpled
    2. drilled
    3. slotted
    4. dimpled/slotted
    5. drilled/slotted
    6. dimple/dimple/slot
    7. drill/drill/slot
    8. AR race (exclusive double slot)
    9. AR street (exclusive double slot/drill)
    10. AR track (exclusive double slot/dimple)
    11. AR sport I (exclusive over-dimple)
    12. AR sport II (exclusive over-slot)
    13. AR speed (exclusive multi-slot)
    14. AR dift I (exclusive triple curve)
    15. AR drift II (exclusive triple curve/slot)
    16. AR drag I (exclusive cross-hatch/slot)
    17. AR drag II (exclusive cross-hatch/double slot)
    silver zinc, for brilliant rust-free finish is STANDARD on all orders, is a corrosion prevention process/measure, BUT...
    *COLORED ZINC FINISH:
    gold zinc or black zinc finishes are a subtle, unique, aesthetic touch for your rotors, very few offer!
    also...
    *HUBS COATINGS:
    this gives the rotor a nice clean, tailored, finished look.
    the rotor is still standard silver zinc dipped, with a high temp, satin, ceramic-silica finish.
    available in 5 colors…we can do some custom colors, so let us know what you need/want.
    or
    *G4000 HIGH CARBON IRON METTALURGY UPGRADE:
    we have started to offer a premium grade cast iron option, available for most all applications.
    standard grade G3000 is great and more than sufficient for most any use, but in some scenario's, a stronger iron is beneficial.
    reports of longer lasting rotors have been found, ideal for high mileage cars, haulers, or even heavy track goers who really beat up their brakes.
    it also greatly reduces the worry of pad squeal in cases of high friction with high performance brake pads.
    the harder iron is stronger and fights warping and cracking concerns, and higher carbon & chromium levels aid in oxidation resistance.
    another great benefit to the G4000 upgrade, is the price includes a premium black coating on the rotor at no charge.
    WWW.ADAMSROTORS.COM
    ONE (1) YEAR exchange warranty for:
    manufacture defects (cracking) per rotor...on all orders!!!
    EVERY ORDERS IS FINAL-SALE, ONCE PROCESSED | NO EXCEPTIONS.
    again, we hold NO inventory & are held to the same final sale terms as our policy.
    if there is EVER any issue with fitment/error on OUR end, we will ALWAYS make it right!
    AR EXCLUSIVES-
    AR drift I [triple curve] &
    AR drift II [triple curve/slot]:
    [must be ordered with coated hubs]
    AR drag I [cross-hatch/slot] &
    AR drag II [cross-hatch/double slot]:
    coated hubs]
    AR sport I [over-dimple] &
    AR sport II [over-slot]:
    coated hubs]
    AR race [double slot] &
    AR street [double slot/drill]:
    coated hubs]
    AR speed [multi-slot] & AR track [double slot/dimple]:
    coated hubs]
    adam | adam's rotors inc. | info@adamsrotors.com | est. 2006
    customizable factory-fit brake rotors, made-to-order | adamsrotors.com
    follow/like/@/tag @adamsrotors on twitter, instagram, & facebook | #adamsrotors
    Veteran Member Four Rings jdmnomore's Avatar
    Mar 13 2008
    Orlando
    Re: NEW prices on adam's rotors: $450 f&r to your door!
    Wow that is an incredible deal. These rotors are awesome people and Ive put them to the test, they are proven.
    2013 SUZUKA GREY RS5
    Eventuri intake + Slam Panel / Milltek non res / 034 Rear Sway and diff inserts / H&R Springs/ 20x10 Volk TE37 in Michelin PS4s
    2015 MYTHOS S4 (Black Optic)
    2008 AVUS RS4
    2004 IMOLA S4
    Dead
    the new numbers have been a hit. get your set now!
    Senior Member Two Rings Naudi04's Avatar
    Dec 02 2009
    2004 S4 6MT
    Oregon
    Hmm this is getting very tempting!
    2004 Audi S4 6MT 40k miles, Light Silver (Metallic) w/Black-Silver Alcantara
    For Sale <- click link
    Established Member Two Rings mpunklil's Avatar
    Jan 22 2010
    04 S4 Imola
    San Juan Capistrano, CA
    are these just modified OEM rotors?
    *NOTE: this application utilizes OEM audi brand and/or PREMIUM grade units
    what do you mean just?
    as posted we custom machine units to order, per order.
    units are then zinc dipped for corrosion prevention and are available in gold or black zinc as well.
    finally we offer black painted hubs as a brilliant finish option.
    my prices are also f&r set-ups, shipped to your door.
    everyone join the adam's rotors facebook fan page?
    as seen in the march issue of eurotuner's featured product pages, tuner news!
    Veteran Member Four Rings BUD-S4's Avatar
    Jul 01 2009
    B8.5 S4 6MT & Q5 3.0t
    Brentwood, CA
    a little help here...
    So any rotor black, gold or silver shipped to my door for $450 unless i want the center painted black then it's and extra $50?
    how much lighter are these than stock? they are drilled slotted and zinc dipped stock rotors if i am not mistaken, correct?
    just trying to get a hold on what you're offering. I am super intersted in a set of these.
    .:B8.5 ///S4:.
    .:Current: Monsoon Grey B8.5 S4 6MT (Luda):.
    .:Past: Silver B6 S4 6MT (Rita), Silver/Matte Blue B7 S4 6MT (Rocco), White B7 S4 6MT (Clancy):.
    Exhaust
    IG: RockAndRollRita
    $450 includes custom machining to your liking, silver zinc, and shipping to your door.
    +$25 for gold or black zinc, +$50 for black hubs.
    the machining includes drilled/slotted/dimpled or combos. it's however you want them.
    these aren't to be thought of as light weight alternatives, but are lighter than stock units, and even less once machined. nothing crazy tho.
    adam's rotor shook alot of hands and passed out alot of cards at the show this past weekend.
    big thanks to HH for having AR show with them:
    who's really not tweeting?
    adam's rotors is now on twitter!!!
    add @adamsrotors for updates, the life n times of AR, new deals/sponsorships/partnerships/etc. and alot of dope car related pic/video/links throughout the day.
    Senior Member Two Rings the700level's Avatar
    Feb 13 2010
    Philadelphia, PA
    typically how many miles do the audi rotors usually last? i just picked up a b7 s4 with 54k miles on it, should i pick up a set of these to keep in the closet when the time comes? i can only imagine going to an audi service and them claiming the parts are $1,500
    you can look for yourself...put your hand thru the spokes and feel the lip on the outer edge of the rotor face.
    i'd imagine at about 60k you could use a fresh set-up...not only for maintenance reasons, but performance and look.
    these are machined, and zinc dipped for corrosion prevention...and have a killer finish & options.
    also, take in account build time...so 2-3 weeks to make these custom made to order units!
    let me know...
    thanks
    -a
    need pads & lines with your rotors?
    ask about pad & stainless steel braided line packages that ship out with your AR units!
    adamsrotors@me.com
    www.adamsrotors.com
    Veteran Member Four Rings Fade2Black's Avatar
    Nov 27 2008
    Black B6 S4
    Springfield NJ
    What pads do you offer?
    The democracy will cease to exist when you take away from those who are willing to work and give to those who would not.
    – Thomas Jefferson
    STOPTECH pads & ss lines...email me!
    Apr 23 2008
    05 B6 S4
    As I just purchased new OEM rotors from JHM this morning this now appears! Well I only really needed the fronts.
    i've been around alot longer than JHM rotors and the special was posted a week ago bud...just a bump today!
    i sell fronts only as well of course...email me if your still interested.
    thanks
    -a
    SPECIAL IS HALF WAY OVER!!!
    ...shoot me an email and take advantage before the 15th...
    adamsrotors@me.com
    www.adamsrotors.com
    Veteran Member Four Rings 0000 V8's Avatar
    Feb 19 2010
    Porsche Cayenne Turbo, B6 S4, C5 Allroad, B5 A4, Prius C
    Sacramento, CA
    Quote Originally Posted by Adam@SPP View Post
    Why is this OF COURSE? I thought you could do rears, as I was going to order a full set... :-/
    Oct 09 2006
    STL
    Quote Originally Posted by 0000 V8 View Post
    He can do FRONTS and REARS....additionally he offers fronts alone. I think that's what he was getting at..
    Feb 19 2010
    Sacramento, CA
    Got it. Thanks.
    Oct 26 2009
    S4, TR6, J10, X5
    va
    can you change your title please.
    every time you bump it I get excited... but when I open up I see you not only bumped the thread, but bumped the pricing too.
    no that's not what you mentioned...you stated u only needed fronts which i took as you assuming i only sell f&r packages.
    if you only need fronts, or you only needed rears, i can accommodate that too, no problem.
    Quote Originally Posted by Faster444 View Post
    exactly, thanks bud
    Quote Originally Posted by slackin at work View Post
    it is changed, in the threads message...hence the edit.
    unfortunately, AZ does not allow the thread title to be edited once published, just the rules of the land, sorry for the confusion.
    Quote Originally Posted by Brian@rotiform View Post
    Great product
    can't wait to seem em on the avant my man!
    Established Member Two Rings cyberwire2000's Avatar
    Jul 31 2009
    94 Mazda FD3S, 06 B7 S4, 11 4Runner
    Brooklyn NY
    So they are $450 or $500?
    Bump for the great price anyway!
    this was addressed:
    the post is correct...thus the edit with message "pricing error"
    $500 f&r shipped for a B6/7 S4
    Jul 31 2009
    Brooklyn NY
    I'm in for the set!
    Registered Member Three Rings somethingcorp's Avatar
    Oct 07 2008
    New Jersey
    i been needing brakes so bad for the past month.. i just cant afford them with 600 dollars in tickets =[... please keep this price for 450 just a little longer!
    Jhm tune, Piggie pipes, Awe Non-res cat-back, Intake spacer, clear corner mod, custom suede trim.. more to come
    "speaking my mind isn't an act. nor is it a product of me allowing myself to be a con artist, but it is simply to express something that i suppose shouldn't be held in."
    be sure to check out the two new AR exclusive machine styles just released, "race" & "street" in the OP above!
    you can now order your audi set-up directly online!
    visit www.adamsrotors.com >PLACE ORDER to select your application and make sure to consider a STOPTECH pads/line pkg. while your there.
    thanks for all the support and online orders already, feel free to email me with any questions you may have!
    -a
    record breaking month for AR...thank you all for the support!
    the AR garage is now offering local brake installation to northern california!
    based out of San Jose, CA, we offer great flat rate brake jobs and savings for having us install your adam's rotor order!
    take a look here and order now online!
    Active Member Three Rings
    Mar 17 2010
    wa
    So, the way I'm reading it, if I go zinc dipped in black for +25 then the whole rotor is black thus wouldn't need to pay +50 for black hub? Or is the finish on the black hub stronger than just the zinc dip? Just seemed strange, trying to figure out what I need.
    Any plans for doing dimpled?
    1. yes you're correct on black zinc coating the whole rotor for +$25
    2. yes its the same overall look as black hubs once installed, but black zinc is just that...zinc. black hubs for $50 is a painted hub only, clear coated, and a cleaner finish which ALSO utilizes the standard silver zinc for protection all over.
    3. what do you mean plans? i already offer dimpling.
    Mar 17 2010
    wa
    Sorry, realized dimple wasn't the right term .... the C shaped like on Alcons (stolen pic from classifieds)
    thats just a slot.
    we can do it...
    we also have an exclusive pattern coming out this summer called AR "show" which is a take on that...
    email me me: adamsrotors@me.com
    workn on stickers...anyone want some?
