Page 1 of 9 123 ... LastLast
Results 1 to 40 of 337
    Stage 2 Banner Advertiser Four Rings Adam@SPP's Avatar
    D4 A8l/Street Glide Special
    NEW prices on adam's rotors: $450 f&r to your door!
    BUILD YOUR CUSTOM ORDER | MACHINE PATTERN, ZINC FINISH, HUB COATING, METALLURGY, & BRAKE PAD/STAINLESS STEEL LINE/FLUID PKGS.
    WWW.ADAMSROTORS.COM
    adam's rotors inc. started out small and remains that way...a tight knit, self-owned & operated company established & going strong since 2006.
    the small outfit and one-on-one interaction creates only the best service w/quick response & even faster made-to-order set-ups. with top notch products, this lends hand to our success thus far.
    working 24/7 throughout the day, any and all questions are answered within the hour to the best of our ability, if not instantly.
    being an online company we do business direct via email, instant message, PM, and over the web in our ever growing threads...we're always here ready to reply!
    we are a fully made-to-order, replacement disc brake, rotor manufacturer...we offer only factory fit, OE spec, plug n' play discs.
    WE CATER TO THE CAR ENTHUSIAST WHO NOT ONLY NEEDS NEW BRAKE ROTORS, BUT WANTS SOMETHING DIFFERENT BEHIND A NICE SET OF WHEELS.
    be it looks or performance, adam's rotors is the only company to bring you over 17+ machine pattern variations (most of which are exclusive to AR), 3 zinc finish offerings, and 5 ceramic-silica hub coating options.
    YOU PICK, WHAT YOU WANT AT AN ALL-INCLUSIVE PRICE | COMPLIMENTARY CORROSION PREVENTION, FREE SHIPPING, CHOICE OF DRILLING, SLOTTING, AND/OR DIMPLING, ALL LOADED INTO OUR WEBSTORE.
    adam's rotors expertise is in the VW/audi market, but do set-ups for ANY make/models car/truck/van…check to our store!
    WHY ADAM’S ROTORS? WE’RE DIFFERENT!
    because we do what no one else does. AR is a customizable product, having managed to turn a boring replacement product into something different. it's a have-it-your-way, made-to-order modification item ideal for any enthusiast. now, instead of just picking 1 of 1-3 drilled or slotted rotor styles from off-the-shelf inventory, we offer over 17+ patterns for your choice/taste, how YOU want them. after that pick a zinc for corrosion prevention...silver? gold? maybe black? thereafter you can even add one of our coated hub colors in a satin ceramic finish to finalize your set and truly give them polished, unique look. we now even offer upgraded metallurgy, to a stronger premium grade high carbon iron if you so wish. we at AR believe a rotor ISN'T just a plain ol' service part...rather a fun, custom, cool way to not only enhance the look of your car, but add performance, protection, and something different to your build, with a ton of bang for your buck!
    oh yeh...and they actually perform!!!
    track tested, endurance race team approved; check it out HERE.
    QUALITY, IT'S ALL IN THE DETAILS...
    we chamfer each drill hole and pay extreme attention to how we lay down our machining…taking meticulous measures to avoid each and every vent rib; the internal cooling veins in most modern vented brake rotors. AR will not drill a rotor we are unable to do so with and thus unlike most, never have issues. this is another reason why unlike many, we also offer dimples and unique slot patterns, ways of avoiding this and offering better, longer lasting, quality products when we see possible issues with venting. lastly each set is made for YOU without the limitations of pattern & finish pre-made, “in stock”, off-the-shelf parts have. instead, we start each order upon payment & cater to your needs/wants for your car.
    HOW IT WORKS:these are customized by you & made per order; you'll have them in about 2-3 weeks...
    (this takes in account ordering raw material, ship time to the shop, pattern machining, zinc finishing, hub coating & curing, packaging, & shipment pick-up!)
    we hold NO inventory & are held to the same final sale terms as our policy.
    we make ONLY factory fit replacement rotors to OE spec. plug n' play original fitment.
    whatever one-off size you may be after other than what your car came with, will need to be based off another application's rotor that already exists.
    in some cases, we can open up hub bore and modify bolt-patterns (within reason) but we need to discuss via email, first.
    YOU TELL US HOW YOU WANT THEM!
    1. dimpled
    2. drilled
    3. slotted
    4. dimpled/slotted
    5. drilled/slotted
    6. dimple/dimple/slot
    7. drill/drill/slot
    8. AR race (exclusive double slot)
    9. AR street (exclusive double slot/drill)
    10. AR track (exclusive double slot/dimple)
    11. AR sport I (exclusive over-dimple)
    12. AR sport II (exclusive over-slot)
    13. AR speed (exclusive multi-slot)
    14. AR dift I (exclusive triple curve)
    15. AR drift II (exclusive triple curve/slot)
    16. AR drag I (exclusive cross-hatch/slot)
    17. AR drag II (exclusive cross-hatch/double slot)
    silver zinc, for brilliant rust-free finish is STANDARD on all orders, is a corrosion prevention process/measure, BUT...
    *COLORED ZINC FINISH:
    gold zinc or black zinc finishes are a subtle, unique, aesthetic touch for your rotors, very few offer!
    also...
    *HUBS COATINGS:
    this gives the rotor a nice clean, tailored, finished look.
    the rotor is still standard silver zinc dipped, with a high temp, satin, ceramic-silica finish.
    available in 5 colors…we can do some custom colors, so let us know what you need/want.
    or
    *G4000 HIGH CARBON IRON METTALURGY UPGRADE:
    we have started to offer a premium grade cast iron option, available for most all applications.
    standard grade G3000 is great and more than sufficient for most any use, but in some scenario's, a stronger iron is beneficial.
    reports of longer lasting rotors have been found, ideal for high mileage cars, haulers, or even heavy track goers who really beat up their brakes.
    it also greatly reduces the worry of pad squeal in cases of high friction with high performance brake pads.
    the harder iron is stronger and fights warping and cracking concerns, and higher carbon & chromium levels aid in oxidation resistance.
    another great benefit to the G4000 upgrade, is the price includes a premium black coating on the rotor at no charge.
    WWW.ADAMSROTORS.COM
    ONE (1) YEAR exchange warranty for:
    manufacture defects (cracking) per rotor...on all orders!!!
    EVERY ORDERS IS FINAL-SALE, ONCE PROCESSED | NO EXCEPTIONS.
    again, we hold NO inventory & are held to the same final sale terms as our policy.
    if there is EVER any issue with fitment/error on OUR end, we will ALWAYS make it right!
    AR EXCLUSIVES-
    AR drift I [triple curve] &
    AR drift II [triple curve/slot]:
    [must be ordered with coated hubs]
    AR drag I [cross-hatch/slot] &
    AR drag II [cross-hatch/double slot]:
    coated hubs]
    AR sport I [over-dimple] &
    AR sport II [over-slot]:
    coated hubs]
    AR race [double slot] &
    AR street [double slot/drill]:
    coated hubs]
    AR speed [multi-slot] & AR track [double slot/dimple]:
    coated hubs]
    adam | adam's rotors inc. | info@adamsrotors.com | est. 2006
    customizable factory-fit brake rotors, made-to-order | adamsrotors.com
    follow/like/@/tag @adamsrotors on twitter, instagram, & facebook | #adamsrotors
    Re: NEW prices on adam's rotors: $450 f&r to your door!
    the new numbers have been a hit. get your set now!
    Sep 16 2006
    SOLD: RS5
    Got any pics of these on an S5?
    __
    SOLD: []RS 5
    Suzuka Grey Pearl
    HRE|Bilstein|AccuAir|Capristo
    here you go...
    some S5 love with adam's rotors dimpled/slotted & black hubs:
    as seen in the march issue of eurotuner's featured product pages, tuner news!
    Senior Member Two Rings yellowc4s's Avatar
    Feb 03 2010
    2012 Volkswagen GTI Autobahn, 1996 Audi A4, 1996 Porsche Carrera 4s, 2006 Mazda3s
    michigan
    Can you get ceramic composite rotors for S5?
    you mean carbon composite? typically ceramic composite is used on pads.
    and no. these are OEM sized where as an expensive carbon disc would be at least 355mm and for serious track use. that's more of a BBK request.
    my units with machining and the s5 caliper using a high end pad is very capable.
    the AR cc will be showing with heavy hitters in SF this weekend at wekfest representing supreme, DPE, and singh autosport.
    come out to the bay for a dope show and some killer cars. crews are rolling deep to this from all over!
    come by and get a card from me...i'll take care of all attendees.
    Aug 09 2009
    SLC, UT
    Adam,
    The factory brakes on my TTS squeal terribly so I am changing my pads to Hawk ceramics. At the same time I would like to put a set of you rotors on. Please quote front and back rotors for an 09 TTS shipped to Utah 84040. Stand zinc coating with black painted hubs, drilled and slotted.
    Thanks Allen
    ^ should check out my TT thread then:
    Quote Originally Posted by Adam@SPP View Post
    the TTS is now $500 as well!
    *edit:
    hubs are +$50
    ...email me: adamsrotors@me.com
    thanks!
    -a
    Veteran Member Four Rings A4rce1's Avatar
    Jan 19 2005
    London
    Bump! These babies are awesome and Adam is the BEST to deal with!
    adam's rotor shook alot of hands and passed out alot of cards at the show this past weekend.
    big thanks to HH for having AR show with them:
    who's really not tweeting?
    adam's rotors is now on twitter!!!
    add @adamsrotors for updates, the life n times of AR, new deals/sponsorships/partnerships/etc. and alot of dope car related pic/video/links throughout the day.
    Feb 03 2010
    michigan
    I need 370mm x 32 front and OEM size rears for an S5 w/Stasis Alcons
    as posted I only build to OEM spec, so I'll need an OEM application using that size rotor and built those.
    as for your rears it's of course no problem.
    shoot me an email and we'll talk more!
    thanks...
    -a
    need pads & lines with your rotors?
    ask about pad & stainless steel braided line packages that ship out with your AR units!
    adamsrotors@me.com
    www.adamsrotors.com
    Veteran Member Three Rings ragazzi_07's Avatar
    Aug 07 2008
    Toronto, Ontario
    not sure if this makes sense, but on the A5/S5 there is like a plate looking part on the rears, where the Rotor sits in.
    If i get the bigger rotors that you sell. Would the new rotor still fit in this "plate looking shape"
    please advise.
    ^ it doesn't, as the rotors i sell are not "bigger rotors"
    that's called a dust shield and is not affected.
    these are OEM spec, replacement rotors...plug n play sizing...
    be sure to check out the two new AR exclusive machine styles just released, "race" & "street" in the OP above!
    you can now order your audi set-up directly online!
    visit www.adamsrotors.com >PLACE ORDER to select your application and make sure to consider a STOPTECH pads/line pkg. while your there.
    thanks for all the support and online orders already, feel free to email me with any questions you may have!
    -a
    some product photo of the AR classics in good ol' silver zinc w/black hubs:
    dimpled/slotted-
    slotted only-
    drilled only-
    record breaking month for AR...thank you all for the support!
    the AR garage is now offering local brake installation to northern california!
    based out of San Jose, CA, we offer great flat rate brake jobs and savings for having us install your adam's rotor order!
    take a look here and order now online!
    AR is back in audi land...get ready for a an oldschool euro project car coming to AZ soon!
    happy monda...er, tuesday!
    due to the complexity of the internal cooling veins of these vented rotors, we will not be able to drill this application, rather dimple and/or slot.
    AR has very strict guidelines when machining our rotors and pay very close attention to where we lay down the drill holes as not to interfere with the cooling, the rotors integrity, and to miss any ventilation ribs.
    this is something many manufacturers overlook and causes cracking making drilled rotors notorious for doing so...AR does not.
    we go even further and chamfer each drill holes and have some of the strongest, longest lasting, crack free rotors on the market!
    consider:
    -dimpled
    -dimpled/slotted
    -dimple/dimple/slotted
    -AR track (double slot/dimple)
    -AR race (double slot)
    any apple geeks excited about the big week?
    i'm dloading 4.0 right now and have a 4 waiting for me on thursday...
    ^ bumping from it now...the AR logo is lookn good thru the retina display! haha
    customer photos of AR pattern: race
    customer photos of AR pattern: street
    adam's rotors featured again in eurotuner this month as a featured product in tuner news!
    monday monday!
    customer photos of AR pattern: drill/drill/slot
    sorry for the radio silence...AR is back in the office!
    now we're having some fun:
    adam's rotors PSA:
    we've just LOWERED individual axle pricing for most every audi application AR offers from $50 to $150 a pair!!!
    log onto www.adamsrotors.com to see more if your interested in front or rears only...or always feel free to email me directly.
    @adamsrotors just hit 2000 tweets this week!!!
    follow us on twitter for the happenings at AR, along with some of the best auto photos/video/news around...even special offers!
    remember...AR decals are in stock!
    6.5" brushed aluminum vinyls available by request for your car...
    shoot me an EMAIL if you want one & title it STICKER with your mailing address in the message!
    thanks for all the support over the years and let me know when your read to order your set-up.
    -a
    a day off for our country's labor force today...thank the workers that keep it running!
