Results 1 to 31 of 31
    Veteran Member Four Rings Rommulus's Avatar
    Aug 29 2007
    '03 1.8TQM
    Portland, OR
    POP!!! Goes the Door Handle Cable
    The cable (Bowden Cable?) for my drivers door handle has snapped. As a result I have to roll the window down and reach outside to let myself out of the car. I'm looking for the part # for the cable and whether replacing it is an easy DIY. Searching did not turn up any results for replacing the broken cable, so any info from others who have had this problem would be greatly appreciated. Thanks!
    Veteran Member Four Rings Molotov's Avatar
    Feb 24 2007
    2005 USP 1.8TQM Avant
    Burlington, Vermont
    Items for Sale
    Re: POP!!! Goes the Door Handle Cable
    off Vag cat 8H0837085B bowden cable is correct
    Getting to the cable isn't hard, and from the picture doesn't look too hard to replace. Check the part # against genuinevwaudiparts.com to see if it's correct
    - Scott
    Das Build Thread
    Performance parts for sale:
    MagnaFlow Race Muffler - Vibrant 4" Filter - MAF 4" Housing
    Oct 09 2008
    Its pretty straight forward. Take of the doorcard and you will see it. Fairly simple DIY
    The Awesome™
    Aug 29 2007
    '03 1.8TQM
    Portland, OR
    Thanks Molotov! That part # looks to be correct. +rep for you, sir!
    I've taken off the door panel and can see where the cable snapped. The door latch mechanism that the cable connects to is partially behind the interior metal door skin and doesn't look to be easily accessible without removing the skin. I'm hoping this is not the case...
    Oct 09 2008
    I think you can stick you hand back there. Unless you dont have small hands. In that case, higher the neighbor girl, she doesnt have school today.
    The Awesome™
    Aug 29 2007
    '03 1.8TQM
    Portland, OR
    Quote Originally Posted by JoshDub View Post
    Have you done the DIY? Do I have to remove the metal door skin to make the connection to the latch?
    Oct 03 2007
    New York
    Check this link. It is for the window regulator DIY, but it shows you how to take off the door panel.
    http://www.audizine.com/forum/showth...ndow+regulator
    Veteran Member Four Rings forevraudi's Avatar
    Sep 01 2008
    San Diego, CA
    taking the door panel off is easy and you'll see that it is simple overall once you are looking at it, so don't worry its an easy fix
    Oct 09 2008
    Quote Originally Posted by Rommulus View Post
    No I have not done the DIY. But I have taken the Doorcard off plenty of times and its really not that complicated back there. If you popped off the doorcard you can probably figure it out fairly quickly.
    The Awesome™
    Aug 29 2007
    '03 1.8TQM
    Portland, OR
    Thanks all! I got the part ordered and the doorcard off. Hopefully the install goes smoothly. I'll update once it's been done.
    May 28 2010
    Georgia
    8e0837085c
    Is now the part number for this
    2012 A4Q 2.0T S-Line Premium Plus - Black on Black
    GONE 2003 Audi A4Q 1.8T Sport - Black on Black 5speed
    Stage 3 Forum Advertiser Four Rings ECS Tuning-Audi's Avatar
    Oct 02 2006
    Wadsworth,OH
    We have them available below!
    Jason
    sales@ecstuning.com | customerservice@ecstuning.com
    Customer Service Hours: 8:00AM to 8:00PM EST
    Sales Team Hours: 8:00AM to 11:00PM EST
    800.924.5172
    OEM Audi Part Number Search with Pricing<--- Click me!
    Veteran Member Three Rings cjonesgo's Avatar
    May 22 2007
    02 A4 Avant 1.8t qm, '74 Vespa
    oakland ca
    I did mine last spring. Simple DIY. Everything is accessible once you remove the door card.
    [CENTER]02 A4 Avant 1.8tqm Dolphin Gray
    Blackout Grills | S4 Bi-Xenons | 3.0 Brakes | RS4 Rear Swaybar | Bilstein Sport Shocks
    K04 | REVO | TT225 Injectors | Apikol SMIC | 034 HFC |
    May 28 2010
    Georgia
    How does the cable release from the door latch mech, not the door handle?
    Veteran Member Four Rings Elliott's Avatar
    Oct 28 2007
    Ocean Beach, CA
    Items for Sale
    OP is still doing the install.... 3.5 years later.
    Established Member Two Rings crowncitycorey's Avatar
    Dec 24 2007
    Pasadena, Ca
    I am curious to how this works out, as I have the same issue.
    I've removed the door panel; however my door has been covered in Dynamat, so I really cannot see what work needs to be done. I hate to just start pulling Dynamat without some plan/idea of the action course.
    Has any one completed this job that is willing to talk about it?
    '03 A4 1.8t 5spd FWD - Sport Package - Revo Stage II - Audi TT Injectors - ATP 3" Testpipe - GReddy Global Sport G2S Cat-Back Exhaust System - Forge 007p DV - Podi w/VEI Boost Gauge - Debadged - M3 Lip Spoiler - K & N Filtercharger
    Dec 24 2007
    Pasadena, Ca
    Anyone?..................
    Oct 09 2008
    It unhooks on one end and pops out of a cradle on another. It is pretty straight forward. You just need to pull back the dynamat.
    The Awesome™
    Dec 24 2007
    Pasadena, Ca
    Pulled back the Dynamat and the cable does pop in/out; however to detach/attach it to the door lock mechanism, it appears that I must remove the mechanism from the actual door (am I wrong?). There are two bolts holding it marked "ESKA 8.8" and my Torx wont work on it. I think it is a 12pt or Spline bolt.
    Two questions, is it a must that I remove the lock mechanism? and if so, which is it - 12pt or Spline?
    Read somewhere it was an M8 size, which I think is 12pt, but I'm not sure.
    Still stuck...
    May 28 2010
    Georgia
    You dont have to remove anything other than the cable. Sorry didn't update the thread. You have to get a flat head screwdriver and lift the cable out of the mechanism. It only comes out in one way, so you may have to rotate the cable to make it line up.
    Dec 24 2007
    Pasadena, Ca
    My cable snapped within a couple inches of the door mech. No way to get in the door to rotate and such. Oh well. Ordered some 12pt tools to get the lock mech. out so I can access the connection point.
    Dec 24 2007
    Pasadena, Ca
    I had to remove those two 12pt screws and move the lock mechanism to access the cable connection point. Broken piece removed and new cable installed. It really is a simple job if you have all the tools and no Dyanamat!
    Mar 05 2013
    Earth
    Items for Sale
    I'm about to do mine. It's bent, the plastic is broken, and it's not unlocking the door from the inside. Before it got this bad, I could still open the door from the inside but the handle was loose/floppy, rattled on bumps, and didn't retract all the way. The spring mechanism within the handle itself still works, and if I unhook the cable from the door handle, it retracts and stays put - just not when everything is attached how its supposed to be. Maybe the cable is streched?
    For those of you who successfully replaced the cable, how is the door handle play? Does it stay put within the door or rattle/hang loosely?
    Mar 05 2013
    Earth
    Items for Sale
    Done!
    I did it with a wire coat hanger. I cut the existing cable in half at the middle, trimmed it to length, and fit a coat hanger in between by bending the ends into hooks. Works perfectly. It took me a few adjustments to get the door handle to return to its original position
    Veteran Member Four Rings coowhip's Avatar
    May 11 2008
    Columbus, OH
    Items for Sale
    Jason
    FYI this cable is about 8 inches too long Jason. Mine is a white cable and a ton shorter. Now its broken trying to remove it and I have this piece of crap that won't come close to being tight.
    EDIT: Well dang it if I didn't order the wrong cable. Now I need an interior door handle cable. Didn't even see it when I ordered the other one. This sucks...
    And the installation is not easy at all. Very very tight space to do anything and no way people are getting their fingers back there.
    RAI Test pipe / TT DP / S4 rear sway / Motoza stage 1 / SAI delete / IE Blockoff plate / S4 Front Recaros / B7 Center Console
    http://www.flickr.com/photos/27286038@N03/
    Oct 02 2006
    Wadsworth,OH
    Quote Originally Posted by coowhip View Post
    The part I linked is directly from the parts diagram for interior door handle.
    Jason
    800.924.5172
    May 11 2008
    Columbus, OH
    Items for Sale
    This is the one I actually needed...It's for the interior door handle. That Bowd cable is way too long for interior door.
    http://www.ecstuning.com/Audi-B6_A4-...able/ES438292/
    Oct 02 2006
    Wadsworth,OH
    Apparently the one that I posted is for a cabrio. Looks like my parts guy messed up and gave me the wrong part number.
    Jason
    800.924.5172
    May 11 2008
    Columbus, OH
    Items for Sale
    Sent you a pm.
    Oct 02 2006
    Wadsworth,OH
    Sent you a pm.
    PM replied.
    Jason
    800.924.5172
    Active Member One Ring mishkind's Avatar
    May 05 2014
    United States
    Just wanted to give kudos for this thread as it helped me when my cable snapped about 10 months ago. I ran into problems putting everything back together, but posted the solution here:
    http://www.audizine.com/forum/showthread.php/603255-Help-can-t-install-exterior-door-handle-on-Q5
    Hopefully others find that useful.
    Why am I posting this almost a year later you ask? Because the god damn piece of sh*t cable snapped again. seriously audi, wtf?
    2009 Q5 3.2
