Results 1 to 28 of 28
    Veteran Member Three Rings mike's machine's Avatar
    Apr 01 2008
    Ducati M750 900SS Honda CBR600rr Ruckus
    Massachusetts
    help with timing. no compression in all cylinders.
    i need help with getting correct timing.
    everything's at TDC, used cam locking bar and crank locking pin, all cam 4 shafts are at TDC also.
    but i'm getting no compression at all.
    valves are not leaking, rings are not leaking, i checked it while heads were off the block, they didn't leak fluid through valves for a few days.
    what could i have done wrong?
    and engine's completely out of the car.
    C5, Giac, 2Bennet , UUC, snub, 034, piggies, RS6 SE catback, rear S4 BBK, RNS-E, JHM, darintakes, K&N, forge, samco, rs6 reps, OZ Ultraleggera, phat box, 4.2 blades, clear corners, LED tails, tinted - SOLD
    Rolling on AR 402, H-sports, Milltek Turboback, O.CT tune, LWFW w/RS4, Stoptech ST-40 332mm fitted in stock 17", hyperboost BPV, Quad-xenon
    Apr 18 2007
    b5 s4 nogaro , 1991 bmw 325is 5spd
    florida,wellington & hollywood
    Re: help with timing. no compression in all cylinders.
    forgot the plugs out?
    Veteran Member Four Rings gearhead1186's Avatar
    Mar 17 2009
    02 S4, 02 M3
    Queens, NY
    what is the compression reading?
    Apr 01 2008
    Massachusetts
    plugs are out :)
    the readings are Zero.
    Apr 18 2007
    lol idk why i had a feeling that could be it. lol
    Apr 01 2008
    Massachusetts
    i've never done this kinda engine work before, i really need help guys.
    my mechanic doesn't trust the TDC marks...
    i can't figure out what's not right.
    Mar 17 2009
    2001.5 S4 Pearl white with white interior 6 speed.
    Earth
    How are you turning the motor over to build compression while it is out of the car ?
    Apr 01 2008
    Massachusetts
    a ratchet and a socket
    Jun 01 2008
    Suffolk, VA
    Items for Sale
    Quote Originally Posted by mike's machine View Post
    you're not going to get an accurate reading with that. You need a hand-held starter. Plugs should be in except for the cylinder you're testing when doing a compression test.
    current; 2013 ATS, 89 Corvette, 15 Jeep Rubicon, 14 ZX6R
    Past; Ninja 650, Ninja 300, 2000 S4, 99 A6 Avant, 2012 CTS-V, 90 Miata, 11 CTS-V, 09 G8, 01 S4, 99.5 A4, 00 Protégé.
    Mar 17 2009
    Earth
    I am no Audi god, but I have a lot of experience working on other cars. I have found that you can not simply draw in enough air to build compression by just turning the motor over by hand that slowly. It has to be spun over faster than that using something with some cranking power .. like a starter. The same principals apply as to why you cannot start your car by hand (unless you have a model T).
    It sounds like you should be doing a leak down test using compressed air in the cylinder to see how fast the air escapes or holds.
    Sep 16 2005
    Asheville, NC
    Quote Originally Posted by blmlozz View Post
    This.
    At least that's what I did when I used to work on my motorcycle.
    2000 S4 - SSP tuned Stage 3
    CrtchRktRcr: You could turn it into a unicorn with a gigantic pink dildo and i'd still love a b5s4.
    Apr 01 2008
    Massachusetts
    i thought hand-turning gives some reading.
    i'll try to get the leak down test.
    if not leak down test, how would you test the compression when engine's completely out?
    put flywheel and starter motor back on and override the starter?
    Veteran Member Four Rings wdbdy2000s4's Avatar
    Oct 08 2008
    1998 pathfinder, 2000 s4
    MA
    If the cam marks and crank mark are lined up then your car should be timed. Turn it over by hand a few times and see if your pistons are tapping valves. If they're not then you're safe to crank your motor.
    edit: just saw motor is out. What is stopping you from putting it back in?
    Frimmel: i only speak when i have something negative to say.
    Grah4m: i lost to a giraffe. be careful out there.
    ThirdStrike:leave your feelings at the keyboard
    Apr 01 2008
    Massachusetts
    def. cylinders are not tapping valves.
    so put starter motor on and crank it?
    or could i use impact gun to crank it?
    i haven't put valve covers back on yet and has no oil in it.
    is it safe to do so or should put the cover back on and put some oil in it first?
    Jun 01 2008
    Suffolk, VA
    Items for Sale
    you'd need a powerfull impact gun. the starter on our cars are rated for 1.4KW.
    Mar 17 2009
    Earth
    Put the stock starter back on for compression test. I would put oil in it too.
    Or perhaps you can use on of those mythical 'hand held' starters that someone mentioned above. Only if you are talking about an RC car or a Model T. Maybe even an ultralight ?
    Jun 01 2008
    Suffolk, VA
    Items for Sale
    Quote Originally Posted by pearlwhite View Post
    Or perhaps you can use on of those mythical 'hand held' starters that someone mentioned above. Only if you are talking about an RC car or a Model T. Or maybe you are a member of a F1 team?
    something like this
    http://www.jegs.com/i/JEGS/555/10001/10002/-1
    that's the cheap one btw. If you build motors or do crankshaft dynos often it's nice to have.. otherwise try to rent one instead.
    Mar 17 2009
    Earth
    something like this
    That is not a 'hand held' starter. It is designed to be bolted in.
    You could probably hold it up to the fly wheel and give it juice, only too see it fly across the room or rip your arm off.
    Prehaps you were thinking of a hand held solenoid? If so, starters and solenoids are two completely different things.
    Jun 01 2008
    Suffolk, VA
    Items for Sale
    no, that's what I was thinking when I mentioned it, but after looking at it again it looks like I got confused at some point from something I saw on youtube or similar.
    Apr 01 2008
    Massachusetts
    hand turning should give SOME reading, right?
    Mar 17 2009
    02 S4, 02 M3
    Queens, NY
    very little if anything..
    Veteran Member Three Rings car's Avatar
    Feb 03 2009
    00 S4 06 A4 Avant 93 SLC 91 GTI
    Millersville, PA
    I'd say no reading at all. Starter turns the engine at a few hundred rpms if not more. You're going to get about 3 with a ratchet. As long as you have the timing marks lined up, or a cam lock bar in place and your crank marks are lined up you're fine. Turn it over by hand a few times and put it back in. If your that worried about your work get the trans and starter bolted up and give it a spin.
    16 S6 Prestige - Daytona Gray Pearl - Sport Package - Drivers Assistance - B&O - Black Optic - Comfort Seats - Cold Weather Package - Alcantara Headliner - Cargo Net
    Apr 01 2008
    Massachusetts
    thanks for all the help, but which one should i more trust...lol
    no reading or some reading?
    and when i looked at the pistons while heads were out, i just don't understand how it can be off by 180 degrees off as someone said.
    it's has to be 360 degrees off if it is cause crank locking pin has to go into that little knob on the crank and everything would be back to where they were before.
    so put tranny back, put some oil, and crank it...?
    Veteran Member Four Rings bigern45's Avatar
    Sep 28 2009
    B5 S4 stage 3, 01 subaru legacy outback
    ky
    im having a hard time understanding 1) why is the engine out in the first place 2) why are you trying to get a compression reading by cranking the engine by hand. if everything is at tdc (you know this for sure) and your cams are lined up properly (iirc the cam tool will only go in one way) then you should be good, and you're wasting time trying to get a legit reading as far as compression when turning engine by hand.. its like installing a super aggressive hotrod cam and then wanting the engine to idle smoothly.. not going to happen..
    Built 2.7 TiAL 770r in the works....
    Mar 17 2009
    02 S4, 02 M3
    Queens, NY
    yea listen to these guys... when i said "little if any compression".. i meant little as in the needle will barely move.
    Apr 01 2008
    Massachusetts
    put flywheel and starter motor, then overrode the starter motor.
    i finally got compression...
    now i know hand turning won't give any compression reading.
    and since i got 120+psi in all 6, now i also know normal valves does leak, and you can hear it leaking air through intake valves when turn crank with a wrench...
    thanks for help guys.
    Sep 28 2009
    ky
    awesome bro.. if thats your biggest problem is a misunderstanding, then you have no engine damage, and your ready to throw that bitch back in and DRIVE again..lol.
    Apr 01 2008
    Massachusetts
    yea i put the engine and tranny back together today!
