Results 1 to 35 of 35
    Dec 24 2008
    S4
    West of NY
    Tire Comments - Dunlop Direzza Z1 Star Spec, Conti Extreme Contact DW, Ventus V12 Evo
    Anyone have experience with these tires on their S4 or RS4:
    Dunlop Direzz Z1 Star Spec
    Continental Extreme Contact DW
    Ventus V12 Evo K110
    Kuhmo Ecasta XS
    Ventus R-S3
    Potenza RE-11
    I've got lightweight OZ Superlegga's and am getting 245 40 18's as replacements. Mainly for daily commute driving (10 minutes each way) and backroad driving, but no track, AX, DE. Northern California is a few weeks of rain, rarely below 40 degrees, and lots of dry weather.
    These are all summer tires, but the Conti Extreme Contact DW is new, is very light (22 lbs vs. 27 for Direzza Z1's) and treadwear rating is 340 AA A vs. 140 or 180 for the others. Some mag revies had Conti's doing very well in dry and wet (thus the name "DW"). Thanks for your feedback. (I understand some are "93Y" or "93W" vs. "95 XL" but even at only 18" is appears most are not "95" or "XL" and I do not drive with adults in the car, except wifey once in a while.) Plus, with all my lightweight JHM exhaust, rotors, flywheel, etc. (and wheel reduction to OZ's) I'm probably down around 3550 lbs vs. the stock 3800 lbs.
    Veteran Member Four Rings Retsujou's Avatar
    Dec 07 2008
    08 RS4 Tit/Exec/Prem/Carbon
    Mississauga
    Re: Tire Comments - Dunlop Direzza Z1 Star Spec, Conti Extreme Contact DW, Ventus V12
    ...and thus you risk blowing all four tires while going 160? Man, do not fuck around with the weight rating...
    08 B7 Cherry Black Pearl RS4 + JHM Lightweight Flywheel + JHM Stage III Clutch + VAST Piggie Pipes + K&N High Flow Airfilter + APR Stage II (Testpipe tune) + Hueper Optik 30% + Magnaflow X-Pipe + Centre Resonator Delete + Deflap + HAWK Ceramic front/rear + Stoptech Steel Brake lines + V4 LED Headlights (blackout/clear corner)
    Dec 31 2008
    PA
    Quote Originally Posted by Retsujou View Post
    +1 the ratings are at max pressure iirc
    and do not account for loading due to turns, hills, bumps, impacts, etc.
    say 3700 for your car with fluids
    1000 in passengers/luggage
    60% on the front or 1410 lb per wheel
    93 1433, too close imo
    95 1521, a good safety margin
    remember the rating goes down with tire pressure and is at a given temperature, it decreases with temp, either up or down
    Mar 07 2007
    04 S4, blown 91 Mustang GT
    Indianapolis, IN
    Items for Sale
    I have experience with the Continental ContiExtremeContact tire (this is the discontinued tire not the new DWS) and the Dunlop Direzza Star Specs.
    I drive the car daily on the ContiExtremes in a 235/40/18 and have had decent luck with them thus far. I will say that I had one of these tires fail due to low air pressure. It was a very cold winter day and I knew I had a small leak in the tire. Air pressure was probably around 30 psi when I struck a large pothole at about 40 mph. The impact blew a quarter sized hole in the sidewall. Thats not to say a tire with a higher load rating would not have suffered the same result given the cold temps and low pressure but it is what it is. Nonetheless these tires are a decent compromise of all season performance. Not great at anything but pretty good at everything. Yes the load rating is not XL (they are a 91 I believe) but at 40 psi front 37 psi rear they have served their purpose. I've pushed them up past 140 a few times which I do not advise.
    In regards to the Direzzas . . . . I have them in a 235/45/17 on a set of B5 S4 wheels for autocross and open track events. The grip of these tires is very impressive but ultimately the weight of the car overheated the fronts and caused some pretty serious chunking after several 30 minute track sessions. For autocross they were fine. Just not up to task of pushing them to the limit for 30 minutes. If you are not planning to autocross or open track this tire you will be very happy with the raw grip they provide as you carve up some backroads. You may not be happy with how quickly they wear (200 tread wear) and how noisy they are at highway speeds especially on concrete.
    I hope this sheds some light on your decision. Let me know if you have any other specific questions regarding my experiences with either tire.
    Veteran Member Four Rings dparm's Avatar
    Apr 24 2009
    Chicago, IL
    The Star Specs are unbeatable for the money. Look at any of the reviews...they're way ahead of the competition and are a bargain. I used to run them on my S2000 and loved them for auto-x and street use.
    now: 2011.5 BMW M3 sedan ZCP
    past: 2005 Audi S4 sedan, 2011 Audi S4 sedan
    Veteran Member Four Rings vintagespin's Avatar
    Sep 15 2008
    CO
    Quote Originally Posted by FarmerBob View Post
    I don't think you've shaved 250lbs with just those mods. maybe about 150lbs. and why risk cutting it close on the load rating?
    2005 Dolphin Grey A4 1.8T Quattro 6-speed Sedan
    Senior Member Three Rings dsq's Avatar
    Aug 10 2007
    B6 1.8TQM
    toronto
    treadwear cannot be compared across brands (only within the brand) as each manufacturer sets their own standards for treadwear rating.
    i'm also debating between similar tires, mainly the direzza z1's and the potenza re11, i'll most likely end up going with the dunlops since it's a bit cheaper and the reviews seem to be quite good.
    | bbs | vogtland | giac | racetec | alcon | and more |
    in the rare event of an erection lasting more than 4 hours, seek immediate medical help to avoid long-term injury.
    Veteran Member Four Rings CHECKERED's Avatar
    Aug 17 2008
    2005 B6 S4 DG, BMW 335i
    a canyon road in SoCal
    Stock weight: 3825lb
    Front rotors 10 less each 20lb total
    Rear rotors 3.5 less each 7lb total
    Flywheel 13lb less
    Exhaust, (assuming stainless steel ) 20lb less
    Wheels 12lb less per wheel 48lb
    108lb total.
    new weight: 3717lb
    BUT
    + driver you are at 3850lb
    So you need the highest load rating you can get, RE-11’s are your best bet.
    B6 S4 Garage Queen: JHM Supercharger, JHM IM Spacers, Carbonio-JHM hybrid Intake, Fast Intentions DP&CB, CF Vented Hood. Mounts:034 Engine, Trans, Apikol Rear Diff, Coolers: JHM Oil, Power Steering & Trans. Susp:PSS9 Coilovers, Hotchkis F&R sway bars, Brakes: B7 RS4 Front (w/JHM LW rings) & JHM BBK Rear, StopTech SS lines.
    Daily Driver: BMW E92 335i Coupe, JB4 Stage 3 Piggyback w/Flash, Meth Injection, Intercooler, Charge Pipe, Quaife LSD 12.1@117mph
    Veteran Member Four Rings Hyde's Avatar
    Sep 05 2008
    Northwest Florida
    Items for Sale
    c4racer should chime in ... I'm pretty sure I saw the Ventus V12 Evos on his Avant ...
    Established Member Two Rings Babyfoood!'s Avatar
    Sep 21 2008
    Southern California
    Ventus V12 Evo K110
    Kuhmo Ecasta XS
    Ventus R-S3
    Potenza RE-11
    Had the DW's for 3 weeks - they were horribly noisy and had the wrong load index molded on the sidewall (tire said they were 95Y, but they were really 93Y internally - long story). I ended up with Conti3's which are the best tires I have ever used - and I have tried many including PS2's. The Conti3's are well worth the money.
    Veteran Member Three Rings rzundel's Avatar
    Sep 20 2008
    Ferrari Challenge Stradale, Maserati GranTurismo S, Range Rover HSE, Porsche Panamera
    Westlake Village, CA
    I have the Hankook V12's and for the money I don't think you can beat them. Quiet, great traction, and great reviews! When I went to SEMA this year they were clearly the tire of the show.
    2005 Audi B6 Tip
    HRE M40 20x8.5 et34, HANKOOK Ventus V12 235/30/20, BREMBO 6pot Front BBK, BREMBO 4pot Rear BBK, KW VARIANT 3 Coilovers, LABREE Res Cat Back w/4" tips, GIAC ECU Flash, AE Corner Balance + Alignment, HOTCHKIS RS4 H-Sport F&R Anti Roll Bars, STERN Adjustable Control Arms, AE PERFORMANCE Black Optic Hood and Bumper Grilles, Clear Corner mod + Silver bulbs, Rear Valence Painted Satin Black, 30% Window Tint, Front Clear Bra, RS4 Pedals.
    Veteran Member Four Rings A4A4A4's Avatar
    Jun 02 2008
    Victoria, Canada
    I was choosing from a pretty similar list a couple weeks ago and went with the Hankook V12's. I've yet to try them (as they'll be going on in the spring), but all the reviews I've read on them have been really positive and they didn't hurt the wallet too bad either.
    EDIT: C&D did a pretty thorough test on all these tires, which you might want to check out. The star spec's came out on top, but the place I was buying from didn't have them in my size so I went with the second place V12's.
    http://www.caranddriver.com/reviews/...mparison_tests
    -Cam
    New: MK6 Volkswagen GTI
    Old: E92 BMW 335i
    Older: B7 Audi A4 2.0T Quattro
    Veteran Member Four Rings PESAPC's Avatar
    Aug 19 2007
    B7 RS4 + B8 A4 Avant + F150 Raptor
    Not on the list, but my only choice ... Michelin PS2s
    Got em on my A4 Avant S-Line
    Got em on my RS4
    Max good
    B7 RS4 - JHM R-Clutch/LWFW/CP/Short Shifter + Milltek Exhaust + JHM Piggies&Tune + F/R Brembo BBK + HRE
    B8 AVANT S-Line FMIC + F Brembo BBK + BBS + STaSIS Exhaust + GIAC Tune
    BOTH Ohlins Coilovers + Rear Sway Bars + Michelin PS2 + Tint
    Jun 02 2008
    Victoria, Canada
    Quote Originally Posted by PESAPC View Post
    Got em on my RS4
    Max good
    You might wanna check out that C&D test too, they pin all of the "affordable" tires up against the PS2's. Unfortunately, the PS2's don't really perform as well as their price might indicate.
    -Cam
    Old: E92 BMW 335i
    Aug 19 2007
    Quote Originally Posted by A4A4A4 View Post
    Appreciate the comment and it is valued from you ... however C/D has never, will not, guide my choice. The PS2s work well for me on and off the track.
    Perhaps noteworthy is that I don't leave any tires on my car for more than 10,000 miles ... given the way I drive, I am most interest in high quality rubber and traction.
    Jun 02 2008
    Victoria, Canada
    Appreciate the comment and it is valued from you ... however C/D has never, not will, guide my choice. The PS2s work well for me on and off the track.
    By all means if you like em', stick with em'. C&D absolutely isn't the end all, be all, and doesn't even come close to real life experience, but I've found some of their articles helpful in the past and just thought I could pass on some knowledge to you and maybe save you a couple bucks next time it comes time to purchase new tires.
    I apologize if I came off condescending in that first post, that really wasn't my intention. I just thought I might be able to help a fellow AZ'er out, but it seems you've definitely got it all figured out.
    -Cam
    Old: E92 BMW 335i
    Sep 15 2008
    CO
    more than C&D's review, I was most impressed with AZ user Jet Jockey's overwhelming support of the PS2s in this thread:
    http://www.audizine.com/forum/showthread.php?t=303578
    he's had a lot of dry/ wet track experience, and been through a lot of the top performance summer tires, and has some pretty valuable input.
    Dec 24 2008
    S4
    West of NY
    Quote Originally Posted by rzundel View Post
    What kind of driving have you done with the V12 Evo Hankooks? Dry or wet, twisty roads? Of the tires I referenced above, the V12's, RE-11's, Hankook RS3 have a 95 XL rating or above. All the others, including the Direzza Z1 Star Specs are 93 SL rated or below.
    I'll probably look at the RE-11's or V12 Evo's.
    I forgot to add that I took the (65 lb?) spare tire out and using can of fix a flat and AAA 100-mile tow if needed. And, I think the FI/JHM exhaust shaves 40 lbs off stock, by my estimate. All told, that's about 200 lbs. Nevertheless, I agree with the 95 XL minimum load rating, so many tires (i.e. almost all "Extreme" performance tires are out).
    Dec 24 2008
    S4
    West of NY
    Quote Originally Posted by Hyde View Post
    C4Racer, are you running on the Ventus V12 Evo's, and what's your impression in the dry and wet, twisty corners?
    The V12 Evo's 10/32" treadwear, 97Y XL rating, and 25 lbs (vs. 27 or 28 for most others) in 245 40 18's are appealing, as is the C/D review placing them behind the Direzza Z1 Star Specs (which are not 95 XL rated)
    Established Member Two Rings diablooffire03's Avatar
    Jun 21 2008
    N. New jersey
    Dont ge tthe direzzas. Ive had bad experience with them, not as grippy as they should be for the $$$
    05.5 Audi S4
    01 Lexus IS300 Turbo
    08 IS250AWD SOLD
    94 6spd single Supra SOLD
    Dec 24 2008
    S4
    West of NY
    If anyone else has run this new tire, you're review and comments would be appreciated:
    Hankook Ventus V12 Evo K110
    I think the couple people that posted above really liked them. Thanks.
    Registered Member Two Rings mickf29's Avatar
    Nov 06 2008
    Beaverton, OR
    Items for Sale
    I have a set of track tires on Direzza's, 275/35/18. Run them on my RS4, work very very nicely, in the dry. They do not perform nearly as well as say my PS2's in the wet, but they are much better than the PS2's in the dry. I have not had any chunking issues, wear seems to be quite even on them, even the shoulders, pushing really hard at the track or on a road course, do not show as much shoulder roll over as the PS2's.
    I don't have experience with the other tires, but in my opinion, I would use the Direzza's for summer or track only, and use PS2's for daily driving, wet, and get a set of Blizzaks for winter. I hear alot of god things about Re-11 as well, but have not used them to give any comparison.
    Veteran Member Four Rings two2's Avatar
    Jan 25 2009
    RS4
    Tri-state/CT
    i got the V12s in 275/30.. they're great and better than the Conti sport and overpriced PS2's at $375/ea.
    after spending $800 on these i don't think i'll be spending $1500 again anytime soon like i have in the past. these V12 practically outform them. they're quiet and grip.. of course that is just my opinion, but im usually the type to spend more money on something if it's better,... these tires aren't the case.
    Dec 24 2008
    S4
    West of NY
    Quote Originally Posted by two2 View Post
    Thanks for the review of the V12's. Car and Driver's review of the lower priced tires (compared to the PS2 benchmark) had Direzza Star Specs best overall, and V12's 2nd (above the PS2's). I know it's C/D, but it is a test nonetheless.
    Senior Member Two Rings 1.9TDI's Avatar
    Mar 03 2008
    Nogaro Blue B6 S4 6MT, Quartz Grey B7 A4 Quattro
    Orlando, FL
    I just picked up an E36 M3 and the car came with direzza Z1's on it. The tires are quite loud in comparison to the Dunlop DZ101's I have on my S4. The tires on the M are fairly new as well. Although they are loud, they are very sticky and run wide for their size.
    Nov 06 2008
    Beaverton, OR
    Items for Sale
    my buddy just did ThunderHilll on a set, will have to get a more detailed review of teh V12's.
    Dec 24 2008
    S4
    West of NY
    Quote Originally Posted by mickf29 View Post
    Thanks Mick. Was that this weekend, b/c Thunderhill was pretty wet.
    Nov 06 2008
    Beaverton, OR
    Items for Sale
    It was a week ago. He drove down from Portland, not sure how the weather was for him. But we met up yesterday for coffee and I saw he put on the V12's for the event. I will talk to him this week again, find out more.
    Jun 14 2005
    Anaheim, CA
    The tread wear on the Star Specs isn't great, but it's definitely a track worthy tire. I'm not sure if that's what you're looking for though.
    Tracy @ VMR Wheels - Shoot me a PM for a wheel or wheel & tire quote!
    Tracy@Velocitymotoring.com | 714.442.7916 Ext 110 | www.velocitymotoring.com| Instagram | | | Blog
    Apr 24 2009
    Chicago, IL
    Quote Originally Posted by VMRWheels View Post
    Agreed. But they're cheap enough that you can replace them without breaking the bank.
    Grassroots Motorsports was blown away by them and the Kumho Ecsta XS on their most recent autocross tire test.
    Senior Member Two Rings lig's Avatar
    Jun 25 2005
    seattle
    Currently running the Star Specs on my S2000. Excellent street/auto-x tire. Totally recommended.
    My 997 C2S came with PS2s. Overrated, IMO. Very spendy and not as much grip as the Star Specs.
    Dec 24 2008
    S4
    West of NY
    I'm not doing AX or DE or track with these set of tires, just hard backroad driving and daily commute in Norcal (dry and wet) weather.
    I like the Direzza Star Specs from the reviews and comments here, but they are 93 SL and not the standard 95 XL minimum that some people adamantly state we must use on our S4's. The PS2's, RE-11's and Ventus V12 Evo K110's are all 95XL or above, however.
    Established Member Two Rings SeanK313's Avatar
    Aug 12 2009
    Two Legs
    I currently have the Ventus v12's. I am amazed at the amount of grip they have and also with how quiet of a tire they are. In addition, they perform very well in the Seattle rain, granted they are brand new and have full tread. I will say they do feel a bit softer than the PS2, but do handle handle very well. For a DD with spirited driving every now and then, they are perfect. At their low price I'd take them over the PS2 anyday.
    Nov 06 2008
    Beaverton, OR
    Items for Sale
    Quote Originally Posted by SeanK313 View Post
    Review I got back from a friend who drove them last week (V12's) was that they were pretty good, sidewall was not as stiff as the PS2's, and hey rolled over the edges a bit more. I could definitely see the heavy rollover on the fronts. But again, this was tracking, not street.
    Veteran Member Four Rings littleredwagen's Avatar
    Jan 08 2008
    2017 Ara Blue S3
    Vero Beach, FL
    i run the direzza Z1 star spec on track and street. I find them to be fine on the S4 at speed and have tons of grip. Then for a short period of time I had bridgestones on the car and cornering speeds were lower and the car felt like it was loosing grip sooner.
    -Matt
    2017 S3 Ara Blue
    2011 S4 Prestige 6mt Black
    2001.5 S4 EPL Stage 3 Yellow
    2005 S4 Avant 6spd Red
