Due to tons of pics, please don't quote this entire post in your reply.
Here's the turbo data:
http://www.turbobygarrett.com/turbob...R_707160_5.htm
Here's a pic of the car in Long Island, NY the day I bought it (Nov, 08). Here's the former owner sitting in it one last time.:( It had a 6k mile AWE stage 3 kit.
May 3, 2009; Started pulling the engine.
May 7, 2009; AWE stage 3 kit I sold to help finance new kit.
May 24, 2009; Very new AWE flywheel and clutch, replaced with clutchmaster twin FX850.
May 30, 2009; cleaning up the engine.
June 4, 2009; removed stock heads. Took them up to ASP for install of inconel exh valves, valve seat grind, slight porting, Ti retainers and stiffer springs. Also new valve guides and stem seals. I'm using new 2.8 intake cams.
July 14, 2009; Received new pistons from WMS.
August 13, 2009; Received pistons back from Calico coatings.
November 14, 2009; Tore block down getting it ready for the machine shop.
December 3, 2009; Received ASP downpipes back from Calico Coatings.
December 16, 2009; Brought block home from machine shop. They bored 0.060" over, balanced/installed crank, forged rods and new JE pistons.
December 17, 2009; Started to reassembled the block.
December 22, 2009; continued engine assembly.
December 24, 2009. Continued engine work. Installed newer style valley cover, does better job of keeping oil out of pvc system.
December 31, 2009; Received bunch of new parts.
January 1, 2010; Worked on installing heads and other parts.
January 2, 2010; Timing belt install.
January 3, 2010; Clutchmaster FX850 install.
January 4, 2010; Turbo install.
January 9, 2010; test fit inlet pipes. Yes, the pink STI coils will be replaced.:)
That's where I am right now..
I'll definitely post vids asap.
one question so far ... why did you opt to use only the intake cams?
