Results 1 to 24 of 24
    Active Member Two Rings steveeo87's Avatar
    Aug 24 2009
    Socal, Glendale
    Fuel Filter Lines Stuck
    I was changing my fuel filter today when I ran into a problem, the 2 lines towards the engine side that connect to the fuel filter are stuck and I cant figure out how to take them off. Also the blue clips on the 2 lines leading to the rear of the fuel filter broke off... what is the easiest way to fix those? Would I need to buy the whole fuel line leading to the tank or does Audi sell just the ends(connecting clips)? Help will appreciated.
    Thanks in advance
    Engine Side Fuel Lines
    Rear Side Fuel Lines
    Veteran Member Four Rings mrbacardi35's Avatar
    Sep 18 2006
    2002 a4 1.8t quattro
    Los Angeles, CA
    Re: Fuel Filter Lines Stuck
    Holy shit batman. If i remember right all it takes is just needle nose to pinch and pull. I would say you need the whole line because I never seen anyone replacing the tip on AZ thread nor sold.
    **MIKE**
    Senior Member Four Rings PDX04a4's Avatar
    Jun 22 2008
    04 1.8t quattro tip
    NoPo PDX
    holy shit, you really did a number on those lines. by the way, the secret is to push the lines toward the filter, pinch the clips and then give it a good pull. comes off clean every time. you should not be using any pliers, screwdrivers or any other prying device to get the lines off, FAIL.
    you will probably have to replace the lines.
    Aug 24 2009
    Socal, Glendale
    i tried pinch the clips n it wasnt working so got a screw driver and tryed pushing the clips in and thats when they just broke off ... ya im just going to have to replace the lines.
    thanks for the help you guys
    Senior Member Three Rings Agro's Avatar
    Dec 10 2006
    04 A4 1.8T USP FWD 5sp
    San Diego, CA
    it isnt like those lines go firing off from huge amounts of pressure. You could rig it for a while with some hose clamps. It'll hold fine. Sure it isnt ideal, sure it isnt OEM, but they wont go anywhere.
    The rear you can swap the plugs on, but the front its molded. One is short, and easy to swap as you can see where it bends in a U and then plugs in to another port (about 8" or so in length maybe), the other leads all the way up I think.. Been a while. Good luck
    APR K04 | APR Turbo Inlet Hose | ER Sport FMIC | TT225 386cc | Neuspeed Snubmount | VMR B7 RS4 Replica's | Forge 007PA DV | Podi Electric Stepper Boost Gauage | Stern Adjustable Front Upper Control Arms | Valentine 1 Radar Detector | Pioneer AVIC-Z140BH Navigation
    Dec 03 2005
    audi, chevy, jeep, lots and lots of bicycles
    connecticut
    pliers:
    looks like those lines are fucked. you can try to put new connectors on but I don't think that will happen. gonna have to buy the whole line.
    -Doug
    2002 A4 2008cc GT-3076R turbocharged Avant
    397awhp/371awtq on straight 93oct and 96*F ambient
    Tuned by Autospeed Performance
    I am selling an Authentic B6 Sportec Front Bumper. PM me for info.
    Senior Member Four Rings Undisputed's Avatar
    Jun 28 2008
    05' A4 USP, 00' Suburban, 07' Tahoe
    Yup. I did the same thing to mine and ended up having to take it to the dealer. They had to order the line I needed. It's expensive. $100 or something stupid like that. Once those clips break, you're outta luck.
    05' USP 6MT-REVO Stage II- Racetec- Stoptech 332- OCarbon Fiber Interior Trim- B7 RS4 Steering Wheel- VMR Boost Gauge- Siemens 380's- Bailey Motorsport DV- NGK Copper Plugs- LED tails- and a few other things
    -Damon-
    USP CLUB MEMBER #927
    Senior Member Two Rings Peoples-2's Avatar
    Oct 24 2008
    Florida
    Quote Originally Posted by Undisputed View Post
    How much did the dealer charge you for labor? What year are you and quattro/fwd?
    Jun 28 2008
    I'll have to find my reciepts when I get home. I know I still have them all. I'll tell you exactly what it was. I'm 05' quattro.
    -Damon-
    Oct 24 2008
    Florida
    any chance they gave you the part #s too?
    thanks!
    Veteran Member Four Rings manhertm's Avatar
    Jan 21 2007
    "Old Yella"
    san antonio tx
    I did that to one of my lines, 2 years later nothing has happened. Like someone said, the pressure is minimal, and those lines have no reason to move, so it will stay put. Maybe if I feel like doing something for the summer, I might tackle it, but probably not. It has affected anything. Just my 2 cents.
    ThetaAlphaThetaMember#1
    MY CAR IS ON AN EBAY BUDGET!! DEUTSCH REIS!
    Magnum Cross-drilled rotors $85 shipped. Ebay!/// 034 Street Density($75 shipped AZ)
    Apr Snub Mount $42 Local
    GFB Hybrid Valve $110 AZ
    Southbend OFE HD $450 shipped :(
    Hayden Steering Cooler $25 Autozone
    "America, people who'd rather be killed by lies, than saved by the truth." -me
    Senior Member Three Rings KFizz's Avatar
    Dec 27 2009
    Edmonton/Alberta
    So I've done this same thing. Destroyed my rear clips. What all is involved in changing these lines? Ideally I'd like something flexible, as the oem ones seem prone to kinking. Braided even. Any help would be appreciated. I can hear my pump starting to struggle now with one of the lines being partially bent.
    Kyle
    2004 a4 1.8tq 6MT > I got a turbo, and a bunch of other shit.
    Stage 3 Forum Advertiser Four Rings ECS Tuning-Audi's Avatar
    Oct 02 2006
    Wadsworth,OH
    Get yourself a set of fuel line pliers, we have them available below.
    Click HERE to order or for more information.
    Jason
    Active Member Four Rings Charles.waite's Avatar
    Jun 27 2011
    2004 A4 1.8TQ 6MT USP • 2006 A4 Avant 2.0T tip
    Man, sounds like a bunch of ham fisted neandethals here. I've changed my fuel filter twice and never needed pliers or tools. You've got to finesse it out. Its not that hard...
    -CP
    2004 A4 1.8TQ 6MT USP APR Stage 1 - Achtuning Snub - FSI Coils - BKR7EIX-11 (.04" gap) - 710N
    Maintenance: 034 Silicon Breather - US Plastics Check Valves - Rev. D SJP - Rev. F PRV - Injector Seats - Coolant Flange
    Issues: All control arms are shot - Shitty, poorly worn YK520s - Sloppy TREs - Godawful stock brakes
    2006 A4 2.0TQ Avant Tiptronic stocker - Failing TC Mod
    Senior Member Four Rings boy412's Avatar
    Jul 15 2007
    2003 A4 Avant 1.8TQM Sport
    Mount Rainier, MD
    Well I know that NOW!
    I did this too when I first changed my fuel filter...and for the moment I just have some hose clamps securing the clips I broke. Someday I'll replace the lines but thankfully this isn't something I have to look at every day.
    @Jason...the fuel line pliers won't do him much good now.
    RAI | MTM Stage II | DSMIC | Fluidampr | FX400 | Vogtlant GT coilovers | B6 S4 brakes | ER TIP | Forge 007 | STaSIS | Stėrn | Apikol | JHM trio | Podi | OEM+
    2.0L stroker build in progress...
    Dec 27 2009
    Edmonton/Alberta
    Yea the pliers are no good now, there are no clips left to depress. And they look like they're only good for the one hose type (engine side). The other ones require something skinnier. Honestly though, I didn't emediatly resort to trying to force them off. I read the DIY and I tried on 2 seperate ocasions on the same weekend. My clips were not easily removed. Maybe it's weather related, I'm not sure. But lots of people have this issue it seems. I'm tempted to fabricate something out of AN fittings now. I'm just worried about clearance near the pump access. I also found these that look kinda cool. http://www.summitracing.com/parts/RUS-641300/
    Kyle
    Oct 02 2006
    Wadsworth,OH
    We have a supply hose on clearance currently if you need a replacement!
    Click HERE
    Jason
    Jun 27 2011
    Quote Originally Posted by KFizz View Post
    That actually wouldn't be a bad idea.
    I mostly kid, mine were a major pain in the ass to remove. Incidentally, keeping the fuel tank pressurized (not taking the gas cap off) helps "shoot" the lines off, though you make a much bigger mess and waste much more gas. I know because I forgot to unscrew said gas cap last time.
    At least I know my fuel filter isn't a shitty Hengst one. Of course the damage has already been done to my Fuel Pump. Its starting to make noise while driving. So pissed...
    -CP
    Active Member Two Rings 69clark's Avatar
    Jul 20 2011
    Ravena, NY
    Looking at this lines, it just looks like regular plastic fuel injection line. If so, buy a new plastic fitting, cut the old one off, heat up the plastic line (I think they recommend boiling water but I have used a lighter and a heat gun and both have worked), and slide the new fitting on before it cools. Your done....
    Or is the problem that you can't just buy the plastic fittings? Because if you can you guys are making a simple issue way bigger than in needs to be. Am I missing something?
    Dec 27 2009
    Edmonton/Alberta
    I'm thinking I'll keep the lighter away from the fuel lines. Especially while I'm laying on my back under the car, with it 4 inches in front of my nose. You can buy new plactic connectors. My issues with this are: I'm putting back in the same connectors that I was unable to disconnect the last time. This is what got me into this whole mess in the first place. Secondly, I'll have to splice into the existing line. I personally would just rather not have splices, just another place to leak. However I may end up using rubber line instead of braided. The cost of braided is high, they are a pain in the ass to make, and nobody will ever see them.
    Kyle
    Jul 20 2011
    Ravena, NY
    Well yes obviously you don't want to use a lighter on the car, that's more of an on the work bench solution. As for putting in the new plastic piece, it's not really a splice, it is the same sort of connection that the factory uses. Just cut the line back enough from where the original conector was and the heat it up and insert the new connect, thats how the OEMline is done. if you look at the picture of the line that ECS posted you see where the barbs of the connector are bulging the plastic line. That's why you want to heat the plastic to make it soft, push the new one in and let cool.
    However, if you are looking for a solution that you won't have the same type of connector as you have now, then yes you'll have to come up with something else.
    Jul 20 2011
    Ravena, NY
    The only other issue is that you will be cutting the plastic line back about an inch, you'll just need to make sure there is enough slack in the line to not be too short to connect it again.
    Just trying to save some guys a bunch of time and money. This is a standard repair to these types of lines.
    Dec 27 2009
    Edmonton/Alberta
    I agree that may be a more simple solution. I feel like the existing lines are are a little too stiff though and are therefore prone to kinking as they did. I think I'd just prefer to have a more flexable line. We'll see though. I'll have to crawl back under there in the next couple days and have a good look. Last time I was so angry I couldn't think straight.
    Sent from my HTC EVO, using Tapatalk
    Kyle
    Active Member Three Rings CrazyCal's Avatar
    Sep 10 2011
    Oregon
    I'll soon be changing my fuel filter for the first time. Glad I can learn from all your mistakes!
    ~Calvin
    RogueEuro
    2004 Audi A4 1.8T /// 6-Speed /// quattro ///Moro Blue Pearl
    || forge splitter || symphony ii+ || podi ||
