Stage 2 Banner Advertiser
Three Rings
Re: FCP Groton Control Arm Kit (UPDATED PRICING!!)
Option 1: (SEE PICTURE BELOW)
13 Piece Control Arm Kit Contains:
4 Lower Control Arms
4 Upper S4 Upgrade Control Arms
2 Tie Rod Ends (Rubber Dampening Shaft)
2 Updated Sway Bar Links
Hardware Kit
Audizine Group Buy Cost $194.95 (Shipped Free to US Lower 48)
Option 2: (SEE PICTURE BELOW)
2 Complete Tie Rod Assemblies (Rubber Dampening Shaft)
Hardware Kit
Audizine Group Buy Cost $224.95 (Shipped Free to US Lower 48)
Option 3: (SEE PICTURE BELOW)
2 Complete Tie Rod Assemblies (Updated Full Metal Version)
Hardware Kit
Audizine Group Buy Cost $239.95 (Shipped Free to US Lower 48)
Shipping to Canada flat rate of $50.00 via USPS Priority International (Taxes and duties would need to be paid by you upon arrival)
To purchase: send paypal to sales@fcpgroton.com with your Audizine user ID,Vehicle, Vin, Option # you would like to purchase, and obviously the correct amount OR call Joe Coppola directly at 877-634-0063 ext 221
Reason: PRICE CHANGE!
FCP Groton
European Auto Part Specialists
(877) 634-0063 ext. 221
FCP Groton
877-634-0063 | joec@fcpgroton.com
FCP Euro - European Car Parts Specialists
FCP Import - Import Replacement Car Parts
Senior Member
Four Rings
You have a PM
Excited about this
Three Rings
Question: Which option is Aluminum or Steel?
Answer: Just pick an option and give us your make model and Vin and we will put the appropriate lower arms in the kit!
FCP Groton
FCP Groton
Four Rings
Re: Official: FCP Groton Control Arm Kit
sweet, i'll be placing an order shortly.
how long will this group buy be going for?
PM sent. Very interested.
Audi S4. Noggy Blue. MRC remap. FK Coilovers. 18" Compomotive MO's. Vredestein Ultracs. Labree downpipes. Vibrant cat-back. Carbon goodies. Cayenne BBK. Hotchkis ARBs. Dietrich RS4 front end. Recaro Pole positions. R8 steering wheel.
Four Rings
Am in on this for sure, too. Will email or call soon.
I have mint B6/7 S4 Recaro seats with blue alcantara for trade -- looking for black/black alcantara
Senior Member
Three Rings
WOOT! Glad to finally see this. Will be ordering soon.
Question: Am I going to get more road noise/vibration by going with option #3 with the full metal tierods vs. #2 with the rubber dampening ones?
This is my daily driver, but I'm not hyper sensitive. Just curious.
2000 S4 6MT Brilliant Black ~ Low Flyer~ Stage 3- stuff
Three Rings
No, you will not notice any difference in road noise or vibration
FCP Groton
FCP Groton
Senior Member
Four Rings
Ok, so if I'm understanding this correctly, the only difference between the 3 options are in the Tie Rods.
1. Partial replacement
2. Full replacement
3. Full replacement and metal
Is the correct? Would you recommend #2 over #3?
Also, could you give me some info on the motor mounts you carry? Are they OEM standard, better/stiffer than OEM?
Thanks, can't wait to make the order.
Three Rings
2. Full replacement
Yes, that is essentially the different between the three kits. You really can't go wrong with either 2 or 3. You will not notice any difference in road vibration or steering sensitivity. Check out this tech sheet explaining the difference between OE and Full Metal. http://images.imcparts.net/shared/do...W_06.03_en.pdf
What is your year make and model for the engine mounts? We deal with over 30 suppliers in and outside of the United states and have access to nearly every Audi/VW replacement part (we can even quote you dealer items) - so I will provide you with a bunch of brands and options.
FCP Groton
FCP Groton
Four Rings
just to confirm, this is for b5 only, correct? Anything for b7?
2006 Audi S4 | Brilliant Red on Platinum Silver | STaSIS Ohlins SL, Swift Metric Springs, Stern UCAs, 19" BBS CH, 370mm Alcon BBK, Aerofunction hood, flat bottom steering wheel, RS4 Grilles, Milltek Catback, Piggie Pipes, oCarbon trim + B&C pillars, JHM tune, etc
NicksCarBlog.com | FRRG Southern Ring
Account Terminated
Four Rings
Is this similar to Stern's adjustable front control arm? (even though I have a b7 as well)
Three Rings
I believe the only difference between the B5 and the B7 kits are the front lower (straight) control arms <--correct me if I am wrong
B5 chassis takes either 4d0407151p or 4b3407151c front lower control arms (depending on steel or aluminum uprights)
B7 chassis takes 8e0407151M front lower control arms
So, if you are looking for a B7 kit, just add $40 to the price of the three options.
Please, just double check with me by giving me your make model and year so I can verify the pieces
FCP Groton
FCP Groton
Three Rings
No, these are stock replacements (actually an upgrade for some A4 and S4 models) and they are not adjustable. Stern has a phenomenal product but a huge price tag.
FCP Groton
FCP Groton
Senior Member
Four Rings
Thanks for the clarification. I meant to say do you recommend #2 over #1 as in is the full replacement easier to install than the partial?
I have a 2000 Audi S4, 6spd as far as the motor mounts go. I'd be happy with a marginal performance upgrade over OEM.
Thanks.
Three Rings
I will be installing these myself and I'm wondering if I need to add 10% from the purchase price to "buy" the lifetime warranty? Do I have to email warranty@fcpgroton.com or do I just automatically add it from the paypal or maybe you throw in the lifetime warranty for GB purchasers?
Three Rings
Once you have finished completing your purchase, simply email warranty@fcpgroton.com with a lifetime warranty request and they will lead you through the steps. Unfortunatley because we are giving away the control arm kits at such a low price, I can't throw in the lifetime warranty for free (however all kits come standard with a 1 year warranty).
Regards,
FCP Groton
FCP Groton
Three Rings
Thanks.
Either one will be fine. Both are a fairly easy install, so there will be no benefit (as far as ease of install) to go with one over the other)
2000 S4 Engine Mounts:
8D0 199 379 K
Brands Available
FEQ (Chinese) 29.50 each
Febi/Bilstein (Germany?) 37.50 each
Meyle (Turkey/Germany) 45.00 each
GLM Global (No country of origin - but GLM provides great quality) 25.00 each
FCP Groton
FCP Groton
Three Rings
Four Rings
how long will this price be good for?
Three Rings
Price will be good until you need to buy it , or we run out LOL
FCP Groton
FCP Groton
Senior Member
Three Rings
I already bought the Upper control arm kit. How much would it be if I just get the rest of the #3 setup?
-Mike
2000 S4 SSP Tuned Stage III ,K04's,SSAC Downpies, Scorpion Exhaust, RS4 Clutch, APR Bi-Pipes, APR Snub mount, VAST MBC & TCD running 20-22 Psi., APR SMIC, Bosch 710N DV's
2008 VW Touareg
Senior Member
Four Rings
8D0 199 379 K
Brands Available
Excellent, thank you. Any personal recommendation of 1 over the other?
Senior Member
Two Rings
Awesome group buy, excited to see FCP as an official advertiser now.
What kind of pricing could you guys do for the full metal tie rod ends alone for my 01 S4?
2001 S4 6spd black on black- GIAC, Borla, BBS CH, CarPC, rattle can white trim, 034 snub w/ cage, ebay silicone hoses, AWE DTS, obligatory RS4 grill... dreams of Stage 3...
2000 Audi A4 1.8TQM - RIP March 9/08
Senior Member
Four Rings
I have these on my B5 A4 (aluminum) version. I love them, but my outer tie rod on my driver side has started to slightly leak. If you can do anything for me about a replacement or something please let me know by pm.
They currently have 7k miles on them.
2001 Allroad 2.7T 6spd - Stage 3
SMIC | Jfonz'd | k04's | Bosch 710N (x2) | SSAC 3" DP | Podi Gauge | Skid Plate | ST Coilovers | RS4 Clutch | OEM RS4 Inlets | Custom Paint Matched Lowers
Senior Member
Four Rings
Would it have made a difference if you had full metal version?
Three Rings
Can you explain leak? Is it leaking at the boot? Did the boot tear?
FCP Groton
FCP Groton
Three Rings
-Mike
Did you buy the uppers from us?
FCP Groton
FCP Groton
Three Rings
30 each (60 for the pair) but I can't sell them individually right now. I only have 12 left and need to save the inventory we have to fill the group buys. I will have some more in stock in a couple weeks.
FCP Groton
FCP Groton
Senior Member
Three Rings
you should do a sale for the c5 a6 :) im thinking about getting a kit to throw in this spring. my dad put a kit in my mom and sisters a6 and i seriously think this is one of the best deals around
Senior Member
Three Rings
Sure did!! You guys have the Best prices around....
2008 VW Touareg
Senior Member
Three Rings
I believe the part numbers are the same? Can you confirm FCP? 2001 A6 2.7T 6speed
heres my vin to check Mike
Vin # WAUED64B91N049126
I know at least some parts in the set are interchangeable
Stage 3 SSP Tuned RS4 K04'd
12.4 @ 115 on pump gas only
425AWHP/467AWTQ
ALL MY MODS DONT FIT IN SIG! DAMMNITTT!
95 Toyota Supra T51R 800hp
Three Rings
I would deduct the price you paid for the uppers out of the kit that you would like to purchase. You can email me scottd@fcpgroton.com.
FCP Groton
FCP Groton
Three Rings
Just checked, looks like the parts are all interchangeable indeed.
FCP Groton
FCP Groton
Three Rings
It would not make a difference - the rubber boot tore (thats why it is leaking grease - the actual joints or shaft did not fail or break)
FCP Groton
FCP Groton
Four Rings
Giggling like a school girl here. Tomorrow I can finally place my order.
TEAM| AXION
Vorsprung durch Technik
Advancement through Technology
GCC Rule #22 Enforcer
marty was here: id stay away from the womb that gave birth to fail
It's not rape if you yell surprise.
Funnel Game
Senior Member
Three Rings
i just bought these yesterday and paid $300....=[ shoudnt they be $205 or $250 at most? Anything you guys can do to correct that? even store credit would be helpfuil thankyou
Three Rings
Yep, I'll hook you up and adjust things. Just email me, scottd@fcpgroton.com
FCP Groton
FCP Groton
Three Rings
This is awsome, I've already purchased two complete sets from you guys in the past and have always been happy, especially with the customer service. I'll be ordering another package here shortly for my new S4.
- You may not post replies
- You may not edit your posts
Forum Rules
