Results 1 to 16 of 16
    Veteran Member Four Rings drew's Avatar
    Jul 27 2004
    Gone: 996TT stage 3, E46 M3
    so cal
    ferodo ds2500 brake pads
    anyone have a good review on these? they cost about twice the hawk hps. i am wondering if it is worth it.
    anybody know the best place to pick up a front set?
    05 S4 6MT Light Silver/Black-Silver Alcantara
    13 VW Tiguan SEL 4MOTION
    Veteran Member Four Rings EBG 18T's Avatar
    Mar 27 2005
    Toyota 4Runner 4x4
    Here & There
    Re: ferodo ds2500 brake pads
    i have used them on and off over the years. The DS2500 is one of the best pads i have used for street and light track use. They have a very broad temp range and handle heat very well. The biggest quam people have with them is the dust output. They are a little dusty when compared to the hawk hps, but they are much better than the hps at higher temps. if you like clean wheels, skip the ds2500.
    IMHO they are best suited for a situation where you need a single brake pad to use for dd, auto-x and light brake hdpe's (some courses are harder on pads than others).
    if you want a set, call or visit www.raceshopper.com . they have very good pricing and a large inventory.
    2004 A4 1.8TQ6MT - Dolphin Grey
    -Maestro Stage III with a built block
    -STaSIS/Ohlin Dampers with Swift Springs
    -STaSIS/Alcon 355mm Mono4 BBK & 310mm Rear
    -STaSIS 4:1 Center Diff
    -19" RS10 Forged wheels w/ Nitto NT-05
    -Laser Intercepter Dual + Bel STI Magnum
    301hp & 331 ft/lb uncorrected
    on 93 oct
    Sep 23 2006
    Central Illinois
    Agreed, I'll be replacing mine with another set of DS2500s. They will dust a bit more than HPS as mentioned and I have a comparison of how brake dust looks with Carbotech Bobcat ceramics in the rear. I'll try to dig that up. They should be slightly better on dust than OEM pads though. But once bedded in properly, great bite even when cold.
    Jul 27 2004
    so cal
    these will still dust less then oem right?
    i won't be tracking this car but i do a bunch of canyon runs and such and want a firm bite on the brakes...
    i am thinking these pads plus stoptech brake lines and motul rbf600 should have me all set right?
    Sep 23 2006
    Central Illinois
    yup, should work well for that. For canyon runs, RBF600 is probably overkill, but I'm not sure. I'd guess Motul 5.1 would be fine but might as well ask around from people who regularly go on canyon runs to see if the higher bp is really necessary since RBF600 is fairly expensive.
    Sep 23 2006
    Central Illinois
    About dust, this is after 3 or so weeks of not washing my wheels and shows DS2500 in front and ceramics in the back. So they should dust less than OEM, and keep in mind slotted rotors will contribute more dust than blank rotors.
    Veteran Member Four Rings Papachristou's Avatar
    04 Audi A4 USP,05 S4 Cabriolet
    Memphis, TN
    i wouldnt get the RBF, just 5.1... rbf needs a yearly flush. its a straight track fluid so it has a higher boiling point but absorbs a lot more water...
    but you will like the ferodos a lot once bedded in
    2004 A4 UltraSport
    APR 2+, Racetech FMIC, APR TIP, Southbend FE SS, Stasis 4:1 Center Diff, Neuspeed Exhaust/test pipe, Podi/VEI boost gauge, Stasis StreetSports, JHM Solid Short Shifter -1" Stern ACAs
    2005 S4 Sprint Blue Cabriolet
    Stock but 1 of 150
    Mar 27 2005
    Toyota 4Runner 4x4
    Here & There
    Quote Originally Posted by Ill 3.0 View Post
    you had a lot less dust then i did. Mine looked worse than that in less than a week.
    Quote Originally Posted by drew View Post
    RBF600 is definitly overkill. If you use that fluid remember you are suppose to flush and bleed it every year or so. If you want something lower maintnance the Pentosin Racing fluid is a great fluid. I used it on the track without issue. Plus you don't have to flush it every year & you get a full liter for the price of 0.5 liters of motul 600. The other excellent option is the ATE Gold which is what i had put in my car back in the spring, it has been very good at the track and is easy to find.
    Motul RBF 600 Temps: Dry 594F / Wet 421F ($17.99/ 0.5L)
    Pentosin Racing Temps: Dry 572F / Wet 392F ( $16.99/ 1L)
    ATE Super Gold Temps: Dry 536F/ Wet 396F ($14.99/ 1L)
    Here's a nice link to the temp charts: Brake Fluid Temp Charts
    on 93 oct
    Registered Member Three Rings
    Nov 21 2008
    Audi RS4|BMW 330d cabrio|ML420CDI|2L TDI Q5
    Romania
    I have the ds2500 on my rs4. Great pad. They do dust a bit. I also have rbf 660 fluid. Never had a problem with it .Remember dot 5.1 only refers to what the thing is made up of not how much heat it will absorb before boiling.
    NAZI MOD FAIL!
    Jul 27 2004
    so cal
    so i'd need two liters to do a full flush?
    Mar 27 2005
    Toyota 4Runner 4x4
    Here & There
    That might be more than you need. I used about 1 liter last time.
    on 93 oct
    Sep 23 2006
    Central Illinois
    I'd have at least 1.5L on hand if you're flushing, took me a tad over 1L but I bleed manually. 2L wouldn't hurt since unopened bottles have a good shelf life. A good idea to bleed slave cylinder as well since you're changing fluids, but that doesn't hold much, 100cc IIRC.
    Jul 27 2004
    so cal
    thanks guys
    Jul 27 2004
    so cal
    i am skipping the ferodos. i want less dust...
    i got the hawk hps, goodrige ss lines, and motul 5.1
    got the hps for $100, goodrige front and rear for $130, and motul for $3 per bottle....not bad at all
    Veteran Member Three Rings NoTec's Avatar
    Dec 24 2007
    Ducati is KING!!!
    Not sure if the compounds are the same but the ds2500's for my Evo dust like a mofo. I guess that also depends on how hard you drive the car. The brake dust is greater than what I'm willing to accept and also the dust was rust colored. A possible indication of iron content.... The pads have never faded and only perform better with heat. They also cause rotor glow if that's your thing.
    Very impressed with the performance and ultra low noise. Not so much impressed with the dust. Tifwiw
    Sep 23 2006
    Central Illinois
    Good deal, that should suit you well. Mind PMing where you got the fluid so cheap, or did you just buy it from someone local? Actually, also curious where you got the Goodridge lines.
