Page 2 of 2 FirstFirst 12
Results 41 to 62 of 62
  1. #41
    Senior Member Four Rings fly300kts's Avatar
    Oct 16 2008
    South Florida
    Re: New Surgery: Fog Lights with DTM Bumper
    I know
    Pictures are better than a 1000 words
    Here are the 2 different types
    and this (the one I used in the DIY)
    You can clearly see that the attach points are different
    Does it make more sense now?
    phil
  2. #42
    New Member Two Rings
    Jul 26 2008
    South Africa
    I know
    phil
    Cool.... But if you just "glue" the light to the grill, then it wouldn't rally matter which one of the two you use ? The fogs pretty much look the same except for the mountings (as you mentioned).
  3. #43
    Oct 16 2008
    South Florida
    Quote Originally Posted by SinWolf View Post
    Not really, the one on the second picture are the one you need because of the location of the level adjustment screw
    Phil
  4. #44
    Jul 26 2008
    South Africa
    Phil
    Ok...
    But I'm 99.9 % sure that the ones I removed from my OEM non S-Line bumper are the same as those in the second pic... I'll just have to re-check.
    Thanks for the info !!
  5. #45
    Veteran Member Four Rings jriddle11's Avatar
    Mar 26 2007
    B7 3.2Q and B6 1.8Q USP
    Byers Audi - OH
    Great write up Phil!
    Current: B7 OEM + and B6 USP OEM +
    Previous: B5 and B6, All OEM +
  6. #46
    Active Member Two Rings Eldritch's Avatar
    May 02 2007
    www.garaget.org/?car=27926
    Sweden
    Very nice job
  7. #47
    Oct 16 2008
    South Florida
    Thank you Guys
    Phil
  8. #48
    Registered Member Four Rings SEXICÄN's Avatar
    May 20 2004
    More cars
    Never Land Ranch
    Phil,
    when your ready please PM me.
    Nico (Barrier Audi)
    ~Barrier Audi Sales, We are also a Stasis Series Dealership~
    AMD/EPL Tial 605 01 Nogaro alcantara sport sedan MT6
    01 B5 S4 Avant sport MT6 -DD
    01 Pearl white S4 MT6-Wifes car
    01.5 Nogaro Stage 3 -Parting the car out
    WTB stock ECU
  9. #49
    Senior Member Four Rings onceover's Avatar
    Jun 08 2008
    Calgary AB Canada
    very well done!
    2004 Audi A4 1.8T // quattro // 6 Speed // Brilliant Red
    Built 1.8T || AEB || revo || GT3076R
    1991 BMW ///M5 3.6 // 5 Speed // Macao Blue Metallic
    BetaAlphaTau Member #111
  10. #50
    New Member One Ring
    Jan 10 2010
    CO
    RS4 OEM Bottom Grille
    8E0 807 681 E
    8E0 807 682 E
    sorry im a newb on here, but a friend told me to jump on and look at this. I was hoping i could get the correct part numbers, these don't seem to work? sweet DIY though...thanks
  11. #51
    Oct 16 2008
    South Florida
    Quote Originally Posted by 1hotavant View Post
    8E0 807 681 E
    8E0 807 682 E
    The Part numbers are good, you just need to add the color code at the end
    Phil
  12. #52
    New Member One Ring
    Jan 10 2010
    CO
    Phil
    much appreciated
  13. #53
    Senior Member Three Rings inNout's Avatar
    Jul 22 2009
    IL
    Looks amazing.
  14. #54
    Veteran Member Four Rings D0lphinGrey's Avatar
    May 31 2007
    B7 2.0TQ S_line
    Sydney
    Thumbs up
    That looks nice and neat!
    Has anyone tried this mod for the S-line fog grilles? OEM S-Line Bottom/Fog Grille + RS4 OEM Bottom Grille mesh?
    B7 A4 GT28
  15. #55
    Oct 16 2008
    South Florida
    As far as I know, only Members swapping to DTM did this DIY
    Phil
  16. #56
    Senior Member Three Rings A4Grocerygetter's Avatar
    May 08 2009
    Makakilo
    I was thinking the same, but I think Phil's way is a lot easier. Besides, using the Dremel on the S-line fog grille will probably require some time to cut. Thats a lot of plastic. I'm using the OEM s-line fogs on the RS4 grille.
    2006 B7 A4 2.0T AVANT S LINE QUATTRO - DTM front bumper w/CF lip, 19x8.5 Hartmann's, Carbonio intake, 034 HFC w/Milltek Catback, RS4 sways, Stasis coilovers, HR 10mm rear spacers, Revo Stage II, 034 Upper/Lower Control Arms, Fly300kt V3 LED's, Bi-xenon CC mod, RS4 Lower grille mod w/DDM 5000k fogs, Ziza LED, RNS-E w/bluetooth, RS4 front grille/RS4 fog grille, ECS Vent boost gauge, Votex side skirts, rear CF valance
  17. #57
    Veteran Member Four Rings B18b1ex's Avatar
    Jul 02 2004
    FL
    Phil
    I saw your car at 1st Class, my Moro B6 was hit in the back :(, I thought it looked very good, and was wondering how you got the fogs done. Turns out that I may be getting a Dtm car and was wondering if the fog light wiring is already present in the car and just not utilized for the cars with the dtm kit? Also would you mind helping me with mine should I actually get the car. Thanks in advance.
  18. #58
    Senior Member Four Rings beantown's Avatar
    Jul 27 2009
    '07 A4 2.0T Quartz
    Guess...
    Phil - Fiiiinally completed the fogs this past weekend. All I have to say is that you set the difficulty rating quite low lol. For the inexperienced (me), in order to get the fitment perfect, it took me around 20 hours to complete.
    All in all it was definitely worth the time, thanks again for your write-up.
  19. #59
    Oct 16 2008
    South Florida
    Quote Originally Posted by beantown View Post
    Sorry
    Phil
  20. #60
    Senior Member Four Rings Operator's Avatar
    Feb 06 2009
    Audi A4, Mit. Montero, Escort
    Wellington, CO/Cheyenne, WY
    I'm currently getting my owned by this fog mod. Between my sucky dremel and my poor cutting tools, this may not turn out to be too clean.....
    K0R-GT Maestro tuned
    Info:
    Build
    History
  21. #61
    Jul 27 2009
    '07 A4 2.0T Quartz
    Guess...
    Definitely a bear of a project. Patience is key to this mod, since it doesn't leave much room for error. Good luck.
  22. #62
    Feb 06 2009
    Which I've already had a few of.................
    Info:
    Build
    History
