Page 8 of 8 FirstFirst ... 678
Results 281 to 305 of 305
  1. #281
    Senior Member Four Rings TweetsS4Estate's Avatar
    Mar 30 2008
    Rocheste MI -> NYC April 1st
    I was saying 20MPG on the highway isn't good. Technically, you should be getting better MPG than EvilEvo as per my explanation above. My wideband said good things, my pistons didn't. Don't ask me why but for some reason VAST Ev14 tunes get 5-8MPG less than their Deka tunes, and everyone elses EV14tunes that I've logged. Do you have the other bugs worked out that you had on the dyno?
    Quote Originally Posted by JDM EJ1 95 View Post
    20mpg is not good? i was getting 20 mixed when i was stage 3. and it definately wasnt running rich.. these cars are not good on gas in the first place... im around 20 mixed with 95 lb injectors and i really cant see it getting any better than that.. part throttle and cruising is always dead on according to zietronix.
    Big thanks to jason@AMD
  2. #282
    Active Member Two Rings Grayv3's Avatar
    Mar 02 2011
    2000 Jeep Grand Cherokee, 2001 Allroad 2.7t
    South Jersey
    Very nice build & very interesting info on the gt kit. I love the pull on the fenders. Hope things stay smooth
    anything worth doing right is never easy!
  3. #283
    Veteran Member Four Rings JDM EJ1 95's Avatar
    Feb 28 2007
    01 Nogaro S4 Stage 3
    chicagoland
    Quote Originally Posted by TweetsS4Estate View Post
    Got ya, as of now.. the car is fine on the street i dont know what is up on the dyno.. whatever.. itll go for a tune sometime during the winter and we will see what it actually does then.
    and youd have to be super rich to wash out the cylinder walls.. by that time you would end up fouling the plugs
    Nogaro 01 s43.0L GT28rsfinally pounding pavementVAST300/360 untuned 13psi
  4. #284
    Feb 28 2007
    chicagoland
    ok so since i wont be going standalone anytime soon.. you guys have talked me into putting a MAF back on the thing
    first step.. build a y pipe.
    2.25 inch inlets go into the Y which are obviously twin 2.25 into a 3.5inch. ordered some more piping.. will have an elbow and a single filter. not sure on the MAF yet..
  5. #285
    Senior Member Three Rings Cadiburns's Avatar
    Feb 17 2010
    Chicago
    Awesome. Is this going to cause a lot of tweaking? Still going to run the 2-to-1 FMIC?
    B5 Casa S4 Avant | Tial 605s | EPL | Aquamist
  6. #286
    Jan 26 2010
    Aurora, IL/ McHenry, IL
    Do it buddy those look good.
    J'S REPAIR AND PERFORMANCE
    PLAINFIELD,IL 815.556.0027
    VAG-COM EQUIPPED
  7. #287
    Feb 28 2007
    chicagoland
    Quote Originally Posted by Cadiburns View Post
    tune shouldnt be an issue. 2-1 should be fine too.. just going to switch from a tial q to a tial QR(recirculated)
  8. #288
    Senior Member Four Rings Evilevo's Avatar
    May 26 2008
    2001.5 S4 2.8L, 2012 Golf TDI w/Tech
    Potomac, MD
    What MAF are you going to use? For the power you want, you will need something like a 95mm or larger and then part throttle is going to suck. Don't let anyone tell you different, I maxed my 90mm out at like 25psi on the old VAST tune.
  9. #289
    Feb 28 2007
    chicagoland
    Quote Originally Posted by Evilevo View Post
    i contacted pro M to build me a maf.. but i have yet to talk to mike about it. still sort of undecided. i can live with a not perfect part throttle to be honest. im not 100% picky as long as the car runs hard its a weekend driver.
  10. #290
    May 26 2008
    Potomac, MD
    ProM is what EPL uses. When I talked to VAST about it before I switched, they weren't interested in rewriting their tunes to use it. To be honest I'm not sure if they are capable of it, it requires a lot more than just scaling for a larger MAF.
  11. #291
    Feb 28 2007
    chicagoland
    i assumed they(epl) did.... i dunno we will see what mike says.. if im going back id like to have it right at WOT at least.
  12. #292
    Mar 30 2008
    I would be careful my friend.
  13. #293
    Feb 28 2007
    chicagoland
    With?
  14. #294
    Feb 28 2007
    chicagoland
    Finished up the Y pipe, waiting on getting abottom half for my tial Q to convert it to recirculated, then weld a bung on the Y pipe to accept it.
    By jdmej195 at 2012-02-05
    and i removed the spare tire hump in the trunkspace.. need to run a bigger battery, the cap is going down there for the audio and i wanted to clean up the wiring.. Needed more room for all of that so i spot welded in a filler(dont mind the ugly) i made it out of 16 ga steel and a hammer haha, welded it and seam sealed it.. its now painted with sprayable undercoating but i do not have a pic of that.
    By jdmej195 at 2012-02-14
  15. #295
    Mar 30 2008
    Awesome stuff! Makes me want to do the spare-delete on mine! Y-pipe is HOT!
  16. #296
    Mar 30 2008
    With?
    Everything. It's a beautiful car and build.
  17. #297
    Feb 28 2007
    chicagoland
    Thanks! deleting the spare hump isnt that hard.. i honestly was using a claw hammer and a vice.. once you start tacking its easy to shape from there.
  18. #298
    Stage 3 Forum Advertiser Four Rings Max@034's Avatar
    Jan 13 2009
    Fremont, CA
    Dimensions on the y-pipe? Looks like 2.5"?
    Glad you are going with a MAF again. =)
    However, I believe it was mentioned above, but the 85mm or 90mm Hitachi is going to max out at 500whp. Moving to a 95mm is going to give terrible idle and be tough to tune down low. And yes, last I heard, your tuner wasn't interested in using a better MAF element. Any idea what they are going to do about that?
  19. #299
    Feb 28 2007
    chicagoland
    Quote Originally Posted by Max@034 View Post
    yea 2.5 inch to 3.5 inch.. Currently going to run the 90mm hitachi. we will see what happens..
    tuning/fueling these cars is kinda a pain in the ass. Need more aftermarket support.
  20. #300
    Mar 02 2011
    South Jersey
    why not talk to mark @ autospeed? it is his kit after all
  21. #301
    Feb 28 2007
    chicagoland
    Quote Originally Posted by Grayv3 View Post
    i havent heard anything about autospeed in years... it doesnt seem like they are moving forward? i could be wrong. ant it doesnt matter who made the hardware. the only thing autospeed about my kit anymore is the manifolds.. and even so, a tune is really a whole different story..
  22. #302
    Mar 02 2011
    South Jersey
    Didn't realize how much you changed the kit. As for AutoSpeed, they are very alive. The shop is a couple miles from my house & I had him chip my allroad. He just doesn't have the time to advertise like some other companies.
  23. #303
    Active Member Four Rings CorneliusRox's Avatar
    Jul 19 2011
    Warrenville, Chicago, IL
    your exhaust valves are inconel. not iconel ;-)
    Crazy stuff. We used it when designing the wastegates setup for the Cummins QSK19. I bet those valves werent cheap!
    I really hope I get the chance to drive by you and hear/see this thing in real life at some point!
    How's it feel for daily driving? Pretty solid or are you getting to misfires?
    2008 A4 6MT, Quattro, VAST Stage1 Tune, Cupra R Lip, VAGCOMed, Hawk Pads, RNS-E, 10f/15r Spacers, Eyelids, Black Vinyl, RevD DV, JOM C/O's - 24.75" FTG, 255/35-18 Ventus V12's, 80000miles+
    359awhp/K03-GT
    Thumper - 97 12V Cummins
    Lady Killer - 03 600rr
  24. #304
    Senior Member Three Rings 2380S4's Avatar
    Jul 16 2008
    01 S4 08 328XI 90 Turbo Grand Prix
    Windy City!!!!!!
    I know he poped his slave cylinder a couple weeks ago, I also read he may be doing a engine pull to re-work the trans. Not sure though.
    GT2868/RS 2.8 motor build in progress!
    PM for powder coating!
  25. #305
    Feb 28 2007
    chicagoland
    yea slave cylinder blew, fixed it. then two days later 3rd and 4th gear went out.. so ill be pulling the motor/trans here soon and rebuilding the trans.
