Page 1 of 8 123 ... LastLast
Results 1 to 40 of 305
    Veteran Member Four Rings JDM EJ1 95's Avatar
    Feb 28 2007
    01 Nogaro S4 Stage 3
    chicagoland
    Midwest GT28 3.0L build.
    EDiT!!!!!!!!!!!!!!Some pictures and videos as of recent
    pic from a shoot we did a month or two back more to come. Jeremy Cliff is the man check his flickr http://www.flickr.com/photos/jeremycliff/
    By jdmej195 at 2011-10-23
    By jdmej195 at 2011-09-24
    this is a 2nd revision base file.. pull. half throttle 10 or so psi
    here is the latest 3rd revision 15psi pull (not enough room to really pull.. but got it up to about 5k)
    Here is the updated mod list as of right now
    ENGINE
    Brand new audi 3.0L crank
    Vast performance 3.0L stroker pistons and rods
    82.5mm
    Factory rod/main bearings/seals/gaskets all brand new.
    Raceware headstuds
    Raceware main studs
    factory 2.8 headgasket
    brand new 2.8L heads
    2.8 cams.
    slight intake porting and smoothing
    Valve bowls ported.
    supertech 1mm OS stainless intake valves
    supertech iconel exhaust valves
    Supertech valvesprings/retainers
    all new seals
    RS4 intake manifold
    Turbo
    ASP GT28rs setup(GT28rs, 3 inch dps, tial wastegates)
    Downpipes modified divorced and dumped wastegates.
    vibrant intercooler core with modified end tank (2 to 1)
    Tial Q blowoff valve.
    Custom TRUE 3 inch dual exhaust 2 resonators no muffler.
    Fueling/tune
    VAST Mafless tune.. currently at 15psi.
    Hemi Throttle body
    VAST EV14 95lb injectors(awesome)
    Custom swirl pot
    Aeromotive A1000 pump
    aeromotive pump controller
    Magnafuel FPR, magnafuel/russel fittings. russel braided lines(-8 feed -6 return)
    Misc
    -12an breather setup for valvecovers
    -inlet piping vac assisted WOR brand catch can for valley pan(12an fitting)
    Suspension/brakes
    Ksport version RR 14k rear springs 13k fronts
    Full control arm kit up front
    Porsche 993T front calipers/rotors
    drilled/slotted rotors
    HAWK HPS pads
    braided hoses
    ABS delete
    Willwood adjustable prop valve
    Stainless lines from prop to 4 corners.
    Wheels/tires
    My old setup, CCW classics 18x9F 18x9.5R
    probably run some toyo r888s as big as i can fit, probably 245 or bigger up front and 265 or bigger in the rear
    Interior went from All black leather to the sport package suede with aluminum trim.
    AVIC D3 Nav radio
    carbon blockoffs.
    exterior
    fenders and quarters got pulled pretty good and body worked to fit bigger rubbers
    RS4 front bumper
    Shaved engine bay with fabbed cover panels for in front of the strut towers.
    Custom nogaro blue paint mix
    black roof
    Audio
    Hertz HDP 1
    Hertz HDP 4
    audison av6.5 door speakers
    audison av 1.1 tweeters
    audison av12 sub
    custom fiberglass box
    black pergo wood flooring in the trunk
    connection cap.
    Pioneer avic d3
    Nogaro 01 s43.0L GT28rsfinally pounding pavementVAST300/360 untuned 13psi
    Aug 09 2009
    suburbs,IL
    Re: Midwest GT28 3.0L build.
    Nick was telling me that you bought it! Nice cant wait to see your build.
    Veteran Member Four Rings W1CK3D's Avatar
    Sep 19 2006
    Just my S
    North 'burbs (Chicago)
    Should be a beast.
    Going into the nogaro, or are you still looking to go with an avant?
    2006 B7 S4 | alcantara | nav | 35% tint | ECS slotted | HPS pads | SS lines | STaSIS catback
    RIP 2000 Nogaro
    Feb 28 2007
    chicagoland
    sorry im just too far into this car to let it go now :P
    just got everything i wanted
    full sport interior, a lot of power, new suspension, new brakes.. and a fresh body
    itll be enjoyable again.
    Senior Member Two Rings slammed_nogaro's Avatar
    May 10 2007
    95 supra, 2001 type r 2000 s4
    CHICAGO BURBS
    cheap huh a finders fee would be nice haha
    Feb 28 2007
    chicagoland
    i got you. dont worry.. let me recoupe a little haha
    Senior Member Three Rings NYEuroTuner's Avatar
    Oct 24 2008
    B5 S4, Nissan 350z
    7-ONE-8, NY | SoCal
    Nice!!!! Goodluck with the build!!!!
    -George
    SEMPER FI
    AbsolutEuro.com
    Airframer's Motto: We Screw, We Nut, We Bolt
    I.N.A ENGINEERING
    Senior Member Three Rings ZMEY's Avatar
    Feb 08 2009
    B5 S4 Avant A.W.E stg3
    Chicago, IL
    wow man thats nice. ill be stopping by in a future see how the progress goes. maybe give you a hand. not that i know much :)
    Feb 28 2007
    chicagoland
    definately.. hows the car doin?
    Feb 08 2009
    Chicago, IL
    still running strong.lol. knock on wood...havent tried race gas yet been busy with work, and btw i didnt find the little extension you were asking me about, sorry. all this a side, your build sounds very intresting, you doing what im dreaming of doing.
    Feb 28 2007
    chicagoland
    when i get it done ull def get a ride. maybe ill let u take it for a pull or 2 :P
    Veteran Member Four Rings GURUMAN's Avatar
    Mar 13 2007
    2.9L PTE 6766 1000 Bhp single Monster !
    Montreal
    Buy my FMIC ...
    Send me a PM, I will hook you up...
    If you want the bumper, I could sell it too.
    GURU energy drinks
    www.guruenergy.com
    10.58 @ 140.17 mph
    10.51 @ 137.56 mph
    http://www.youtube.com/watch?v=1kG98vSWkT4
    WATERFEST 15 RUN 10.92 @ 133.55 mph
    Feb 28 2007
    chicagoland
    i would, but to be honest i shouldnt spend the money right nowhaha.. i need to sell my stage3 kit then id snag it up from ya
    Jan 11 2007
    SLC,UT
    So you picked up that kit, nice!
    ** GT2860R-7 S4 Build Log--
    FOR SALE (click me):
    --FIKSE FM10 - 3pc LIGHTWEIGHT WHEELS - 17x9 et55 & 17X8 et57 - 5x130 - WORK ON AUDI W/ ADAPTER**
    --JHM DELRIN SHIFTER STABILIZER BUSHING (LATE STYLE)**
    --RS4 AIRBOX--
    LOOKING FOR:
    --BROKEN SPIDER HOSES
    Dec 03 2005
    audi, chevy, jeep, lots and lots of bicycles
    connecticut
    What car did this come out of? I hope not the white widebody Avant.
    EDIT: Nevermind. Found the FS ad. Looks like it was a silver car. Damn. those are amazing prices.
    How was the motor running prior to the accident? I heard those CP pistons have been hit or miss with oil consumption in the 2.7 block.
    -Doug
    2002 A4 2008cc GT-3076R turbocharged Avant
    397awhp/371awtq on straight 93oct and 96*F ambient
    Tuned by Autospeed Performance
    I am selling an Authentic B6 Sportec Front Bumper. PM me for info.
    Mar 13 2007
    Montreal
    Quote Originally Posted by JDM EJ1 95 View Post
    If you tell me you want it, I'll keep it aside for ya so you can save 50% of what it have cost me to build it...
    Too big for my turbo LQ4 motor, I need space up front.
    GURU energy drinks
    www.guruenergy.com
    10.58 @ 140.17 mph
    10.51 @ 137.56 mph
    Aug 20 2008
    2000 Audi S4 Sold :(, E90 335i
    Niles, IL
    Damn dude,
    Gonna be a sick build for sure!
    Can i has a ride?
    Wish i had cash for your stgIII setup but im broke as hell.
    Good luck with the build!
    Feb 28 2007
    chicagoland
    Quote Originally Posted by GURUMAN View Post
    Pm me a price and we will talk.
    also if you can get back to me on the PM i sent to you before.
    Registered Member Four Rings
    Dec 11 2006
    QuattroWorld
    What are you doing with the single setup?
    For sale:
    Silver Trunk (Great condition)
    Pass. side timing belt cover (2.8 Brand New)
    AC Lines and Condesor
    Stock Fuel Rail with FPR
    034 Lower Compression Headgaskets
    Misc. oil and coolant lines
    Misc. brackets
    Misc. AN Fittings and braided lines.
    Feb 28 2007
    chicagoland
    workin on it.. slowly.. at my leisure maybe put it in our spare b5 chassis
    Mar 13 2007
    Montreal
    oh sorry I will
    GURU energy drinks
    www.guruenergy.com
    10.58 @ 140.17 mph
    10.51 @ 137.56 mph
    Senior Member Four Rings washyourrhands's Avatar
    Mar 12 2008
    06 350z, 01 Tahoe
    Saratoga, CA
    i wish we could run when im done too
    2006 350Z
    Instagram: @washyourrhands
    Crawl Apparel
    Feb 08 2009
    Chicago, IL
    mine is spare
    Feb 28 2007
    chicagoland
    :P
    some pics to come tomorrow guys.. gonna get everything apart and start cleaning up the turbo kit to make it shiny and new
    Veteran Member Four Rings DxC's Avatar
    Nov 16 2006
    Boston
    arghhhh so youre who sniped this deal!! <bitter> congrats though! it was a sickkk deal and i immediately hopped on it the second i heard about it trying to paypal a deposit, but looks like your localness paid off :)
    lemme know if you wanna get rid of it :-)
    1999 Black A4 Avant
    2000 Nogaro S4 Stage 3
    2001 Nogaro S4 Stage 3
    2000 Black S4 - under construction Stage 5?
    2001.5 Santorin S4 Stage 3
    2001 Black S4 - parting out/scrap
    2001 Black Burnt S4 - shell gone, drivetrain remains
    i know, i got problems. and the cure is more B5s!!!
    going to start selling 3 Stage 3 S4s pretty soon ...
    Senior Member Four Rings BEESIX's Avatar
    Nov 06 2007
    B6 A4
    The Windy City
    damn bro you are crazy, i cant wait to c it in person when its done!. goodluck with the build lemmie know if u ever need a hand or extra tools. SUBSCRIBED!
    2002 White A4 1.8T 5MT Fronttrash with a few goodies
    Premier MotorWerks,
    2494 Oakton St, Evanston, IL
    http://www.facebook.com/profile.php?id=100001076103808
    ^ This is what i do^
    Adil
    Feb 28 2007
    chicagoland
    Quote Originally Posted by DxC View Post
    neener neener neeeeener
    no jk, nick(slammed_nogaro) really helped me out on this one.
    Feb 28 2007
    chicagoland
    Quote Originally Posted by BEESIX View Post
    For sure.. hows the b6?
    Nov 06 2007
    B6 A4
    The Windy City
    b6 is great, im pulling it into my shop so i can tear it all apart and finish it right for spring lol. btw congrats on the shop bro
    Premier MotorWerks,
    Adil
    Feb 28 2007
    chicagoland
    Thank you sir ill have to stop by and see yours.
    for now heres a few pics of some minor progress
    got the turbos and the downpipes apart.. and got the motor out of the trunk of my corollla :P
    next step.. pull the built motor apart.. and get all the internals set to go in my spare block
    Shot with Canon EOS DIGITAL REBEL XT at 2009-12-27
    Sep 01 2008
    Illinois
    hell yah rick, im pumped to see this car together and running. dont forget you promised i could drive it ;)
    haha you need to hit me up when you in mchenry man..
    2000 Silver S4 - RIP
    2001.5 Brilliant S4 - SLOW
    Sep 01 2008
    Illinois
    also, you should show the aftermath of hauling that motor in your corolla trunk...
    Feb 28 2007
    chicagoland
    they dont want to see that :P
    Feb 28 2007
    chicagoland
    motor is out of my car, gotta get my engine stand over to my shop so i can get her torn down.
    Feb 28 2007
    chicagoland
    minor progress, just working on organizing the shop lately
    but i got the oil pans off, and should have the crank out by tomorrow.
    By null at 2010-01-09
    Feb 28 2007
    chicagoland
    Progress,, built but broken motor is torn down and everything has checked out and has no damage..
    now gotta get my spare motor and eveyrthing to the machine shop.
    Senior Member Three Rings diabolical1's Avatar
    Mar 24 2009
    New York and Toronto
    what's the deal with that Rx-7?
    The dude that loves cars with character: raw, rambunctious road manners, angry triangles and four devilish rings ...
    Feb 28 2007
    chicagoland
    just a car we are working on, doing all the blockoffs and removals of stuff he doesnt need and doin some maintnence
    Feb 28 2007
    chicagoland
    Ok guys, little update.. motor is at the machine shop, getting everything setup, cunningham rods/cp pistons/034 coated bearings
    Manifolds are at ASP, just waiting to hear from them on how much it will cost me to repair the drivers side.
    Currently i need to sell my ASP fueling, i know its a longshot but its for a 3.0L with 2.8heads. made 560whp.
    plans are to go 034 standalone, 72lbers basically full custom fueling.
    reason being is i will push these 28's to the limits or whatever else breaks first. and if they run out of steam ill either be going bigger in the future or throwing another power adder at it..
    with that being said, no real pictures to post as of now that you guys havent seen yet.. ill post pics when i get some things back.
    Dec 11 2006
    QuattroWorld
    What is wrong with ASP manifold?
    For sale:
    Misc. brackets
