Sorry if this was already asked/posted, but I did not find it. Is it possible to disable TPMS on a 2009 A4 Quattro? I have winter rims/tires that don't have the sensors, and just want to disable it all together. I have access to a vag-com
As well, for some reason the day time running lights are the high beams. (I brought the car from the US to Canada). How do I just get the regular lights on.
Thanks all.
If you check the vagcom thread I'm sure you'll find your answers fairly quick. There is information on turning on TPMS so I'm sure you can try and figure out how to turn them off (if possible) and there is tons of information on the DRL settings. Thats why it's a stick
Mods:Votex spoiler, tint, Clear Bra, S4 replicas, Audi winter and trunk mat,mud flaps, Dipstick, oil pan heater, KW V2's, AWE Dual Exhaust, Votex valance, AWE FMIC, Eurocode IC pipe, PIAA fog lights,Vag Com, APR Stage 2, E-Codes, trunk mount emergency triangle, LED plate bulbs, Audi compressor and tire repair kit, RS4 Pedal set, Power Folding Mirrors, S4 steering wheel, heated rear seats, ski pass through....... www.audienthusiasts.com
I don't think there's a way to disable TPMS. I had the same problem as well with my VMR's (no TPMS) and the TPMS error would always go off. My Audi tech friend looked through his VAG-Com and couldn't find anything to disable it or the error.
-Jeff
2009 Ibis White A4 2.0T Gloss Black Grille | CF Filler Plate | 19x8.5" Dark Gunmetal VMR v701's | Black Calipers | ST Coilovers
OSIR Trunk Spoiler| H&R 5mm Spacers | 5k DS3 HID's | Luminics Fogs | VAG-Com | Silver CF Interior | K&N Intake
Painted Front Splitter | Gloss Black Roof | Hardwired V1 | OSIR CF Rear Valence | AWE Quad Tip Exhaust
Try this
WITH A ROSS-TECH VAG-COM TOOL:
LOG on to [17] - Instrument Cluster Audi A4 (8E) Instrument Cluster
(8EC/8ED/8HE)
GO TO: Adaptation
Channel 061: CAN-Databus Comfort (Installation List)
+00512 = Tire Pressure Control (Optional)
Subtract 512 from number given...Bam your done!!!! No more TPMS!!!
If your TPMS is the indirect ABS sensor type, try in reverse (as in 1/checked to 0/unchecked etc.) the codings here for "Enabling tyre pressure monitoring". It may require setting codes in three modules:
Try this
(8EC/8ED/8HE)
GO TO: Adaptation
It won't work - because the B8 model uses long coding
Rene Larsen
A4 Avant 3.0 TDI quattro tiptronic MY2009
VCDS 11.11.3 (HEX-USB+CAN)
I have a Canadian 2010 A4 S-Line quattro, which is claimed to have TPMS. I brought it to the tire place to get my snow tires mounted on my S-Line rims. There were no TPMS sensors on the wheels. So with the TPMS we have in Canada, you should be able to put on different rims and tires without worrying about TPMS or spending money on sensors.
Isn't it only so on the MY2010+ ??
I think the previous model (MY2008 and MY2009) do have the wheel sensors.
Bump^^ I need help on how to disable the TPMS i have searched the forums and havnt found any solid information. I have the individual wheel sensors (sensor in each tire) but i need to find a way on how to disable the TPMS light and tyre pressure malfunction reminder.
I tried searching for a few months with no luck. I finally ended up just buying additional sensors instead of having to switch back and forth. At $65 a piece I don't consider that cheap.
2009 A4 2.0T S-Line|GIAC chip|BBS CH|AWE quad tip exhaust|OSIR carbon fiber grille|OSIR carbon fiber fog light trim|
I hate the search on this forum, i can't figure it out. the vag-com thread has like 300 replies and most are just someone blabbing. I have a 2009 A4 with the sensors in the wheels. Can I diable them using VAG-COM? Other than the cable, do I have to buy anything else?
I disabled the unit in the gateway, and re-coded the TPMS (65) to 0202125, which DISABLES the TPMS.
So if this works, then it is:
1) "Go to [19 - CAN Gateway], and remove check mark at TPMS"
2) "Go to [65 - Tire Pressure Monitoring] and re-code to 0202125" - I don't know what your current coding is, but here you can see what the bits stands for: http://wiki.ross-tech.com/wiki/index...itoring#Coding
