Page 5 of 13 FirstFirst ... 34567 ... LastLast
Results 161 to 200 of 487
  1. #161
    Jun 21 2005
    B6 Avant
    Milton, Ontario, Canada
    Any more pictures? Vinny can you do a write up of all the parts required to do this?
  2. #162
    Oct 22 2005
    04 A4-Marley / 11 STi-Nami / 93 Mercedes Benz 300SE-Cruiser / Specialized Enduro-lol
    Reppin the Mitten.
    Quote Originally Posted by SleeperAvant View Post
    Yea, I'll do a write up of all the parts I've accumulated and edit the first post. Most of the parts are listed in the initial post, but there are a few other things that I have acquired. I'm sure Doug or I can post up the ETKA plots of the necessary parts too if needed.
    -Vince
    Stockish 2004 Audi A4
  3. #163
    Senior Member Four Rings nein-reis's Avatar
    Feb 01 2008
    B6 A4 GT3076R
    Uintah, Utar
    Vinny, do you know for sure yet or not if the shop has the "1.8T transmission spacer" working? I have the same one and it does not line up on my block. I'm wondering if DoWerk figured out something we could not... very possible.
    -Tyler-
    IntegratedEngineering - Bulletproof your engine.
    /GT3076R/Eurodyne M7/6MTQ
    AEB/IE Cams/Supertech train/2.0 stroker
  4. #164
    Oct 22 2005
    Reppin the Mitten.
    Ray shipped it out last week, so my wild guess is it should arrive this monday or tuesday. I'll try to get Jake more involved on here about this topic. From the sounds of it, theres no reason why it shouldn't fit...since others have already done this before, without the spacer (i thought), I kind of just ordered the spacer "just in case" ordeal. We'll find out.
    -Vince
  5. #165
    Feb 01 2008
    B6 A4 GT3076R
    Uintah, Utar
    Yeah, that is what I keep hearing... I don't get it. My trans bolted right on no problems with out any spacer but the flywheel is stuck on the bellhousing (I have a nice scar inside the bellhousing to prove it). The spacer plate Ray sent me is the exact same plate that was already on the 3.0 trans so I have two now, should of asked for a part number first I guess.
    The spacer plate lines right up with the trans, Ray said it lines up with the 1.8T trans, but it does not even come close to lining up with my block. I hope I can find a solution before you run into it... or I'm dumb.
    -Tyler-
  6. #166
    Oct 22 2005
    Reppin the Mitten.
    Did you end up taking any pictures? I thought Ray lined up the spacer to an 1.8t engine block before he shipped it to you and me? I mean what are the chances of the blocks being different (maybe between b6 and b5), but then if they were, the 01A wouldn't bolt up... for Clint and and Dave. Or, there is something else we are missing that we don't know...
    I remember Doug telling me someone on here has done the same thing, I'll have to call Doug tomm and ask. Come to think of it, I think we are the only two that is/has attempt to put a 01e 3.0 trans in a 1.8t.
    -Vince
  7. #167
    Feb 01 2008
    B6 A4 GT3076R
    Uintah, Utar
    I'll take photos tomorrow, I was not able to make it back into the shop over the weekend. Ray told me he lined it up to a 1.8T transmission, this is where I'm confused, why would it line up with a 1.8T trans but not the block? I remember talking to Doug about someone else who has done it, but Doug was not able to contact him IIRC.
    Also the plates you and I are getting are different part numbers, but supposedly the same??? You are getting 01e103551a and mine is 01e103551c ..not sure if there is a difference or not, but Ray said they were the same.
    -Tyler-
  8. #168
    In Limbo Two Rings
    Jul 29 2009
    Michigan
    I wonder why the different pn...Same price on GAP. Somebody with ETKA should look into the difference.
  9. #169
    In Limbo Two Rings
    Jul 29 2009
    Michigan
    Google'd your PN. And found some pics.
  10. #170
    Feb 01 2008
    B6 A4 GT3076R
    Uintah, Utar
    Here is where I'm having problems, found this photo of one. All the green lines up on the block, red is not even close, and I can't remember yellow.
    I'll know more tomorrow.
    -Tyler-
  11. #171
    In Limbo Two Rings
    Jul 29 2009
    Michigan
    From the looks of it,
    heres the reason why its diff...from the site i found
    "The next piece that you will need is called a filler plate. It's found on the Audi 2.7 TT equipped cars. So far this has been the hardest part for me to locate due to the fact that noone knew what I was talking about and I didn't have a picture. Bullmoose did a good job of describing it to me and luckily had a p/n to. The part number for the piece he used is 01E103551C. A dealer ship looked it up for me and said it was superceded by the number 01E103551A."
  12. #172
    Feb 01 2008
    B6 A4 GT3076R
    Uintah, Utar
    Yeah I found the same site. So they should be the same I'm thinking.
    -Tyler-
  13. #173
    Senior Member Four Rings FORCE_FED_DUB's Avatar
    Aug 10 2008
    Denver, Colorado
    Part number 01E103551A was superseded by part number 01E103551C.
    BT/BAT build threads make me happy I have a stock turbo
    -Cam
  14. #174
    In Limbo Two Rings
    Jul 29 2009
    Michigan
    lol too funny Tyler.
    I guess without the physical engine block, and seeing the orientation of it. Its impossible to figure it out. Hopefully Tyler you figure it out, or Jake will. Because this down time is killing me, and I'm on a pretty tight schedule of needing the car back.
  15. #175
    Feb 01 2008
    B6 A4 GT3076R
    Uintah, Utar
    Agreed. I miss my car a lot, and this one problem has held it up by a couple weeks now and caused a fire.
    -Tyler-
  16. #176
    In Limbo Two Rings
    Jul 29 2009
    Michigan
    Quote Originally Posted by nein-reis View Post
    I'm trying to think if there are any outlying reasons that it doesn't bolt up... I think I'm going to pm bikesai, the gentleman that did a swap in his b5 to see if he ran into this problem. I can't think of any reason why it wouldn't fit, when it fits our trans, but not the block...granted the spacer/trans was made for a v6 motor.
  17. #177
    Feb 01 2008
    B6 A4 GT3076R
    Uintah, Utar
    Let me know what you find out and I'll do the same. PM'd you my number.
    -Tyler-
  18. #178
    Jun 21 2005
    B6 Avant
    Vinny, Jake, Doug:
    Would the swap have been any easier if Vinny went with the 5 speed GBT transmission instead of using a 3.0 6 speed?
  19. #179
    Stage 3 Forum Advertiser Four Rings Sales@RAI's Avatar
    Jun 22 2009
    Dundalk, MD
    Vinny, Jake, Doug:
    yea, he just wouldn't have to trim the bellhousing for the 240mm clutch. The 2 ways to make this easier are
    1. Don't get a 240mm setup
    2. Get a 5 speed setup
    3. Man up and grind the bellhousing
  20. #180
    Dec 03 2005
    audi, chevy, jeep, lots and lots of bicycles
    connecticut
    Vinny, Jake, Doug:
    Are you asking in regards to the bellhousing interfering with the clutch assembly? Clint answered that in the post above me.
    No matter which manual transmission he went with he would still have to swap the driveshaft, rear differential, shifter linkage, pedal assembly, front half shafts, etc..
    I was never worried about the bellhousing issue because I knew both Jeff and Brian successfully mated an 01E to the 1.8T block. I was not aware the 01E bellhousing did not have enough clearance (as is) for a 240mm clutch assembly. The FX700 fit fine (Brian) and the stock clutch assembly fit fine (Jeff).
    Vince has the FX850. I don't think the clutch assembly is 240mm so I don't think he'll have that problem.
    -Doug
    2002 A4 2008cc GT-3076R turbocharged Avant
    397awhp/371awtq on straight 93oct and 96*F ambient
    Tuned by Autospeed Performance
    I am selling an Authentic B6 Sportec Front Bumper. PM me for info.
  21. #181
    Jun 21 2005
    B6 Avant
    Ah ok. Yes I was asking in regards to bellhousings.
  22. #182
    Oct 22 2005
    Reppin the Mitten.
    That and Brian has a FX850 now from what I read on here, which fits fine on his setup. So there isn't any reason why it shouldn't fit. I'm looking forward to an update with Jake. I called him thurs and fri, and he never got back to me. So he must be chugging along on the car.
    -Vince
  23. #183
    Dec 03 2005
    connecticut
    Quote Originally Posted by vinny.dtw View Post
    Brian is also running a custom flywheel and bellhousing adapter for his VR6. His set-up can't be compared beyond what he ran with the 1.8T combo.
    -Doug
  24. #184
    Oct 22 2005
    Reppin the Mitten.
    Good to know, thanks Doug. Call me back when you get a chance.
    -Vince
  25. #185
    Senior Member Three Rings misterjj2u's Avatar
    Apr 26 2008
    2007 A6 Avant
    Newport Beach
    Can you guys help me out with my swap? I picked up the 6 speed that Clint posted (from a 2.7TT) and found a 4.11 rear diff online. I called up Shokan for the remaining parts but they want so damn much for the rest (i.e. B6 3.0 6 speed: front & rear axles, rear crossmember, clutch master cylinder, driveshaft).
    Do any of you have any hook ups to help me with the rest?
    Many thanks.
    -JJ
  26. #186
    Oct 22 2005
    Reppin the Mitten.
    Quote Originally Posted by misterjj2u View Post
    Many thanks.
    -JJ
    How much did they want? I just hawked ebay and junkyards constantly....
    -Vince
  27. #187
    Apr 26 2008
    2007 A6 Avant
    Newport Beach
    I got the rear diff via ebay for $150 (to my door)--shokan wanted $385. Axles are something like $235 EACH!!! Craziness.
    It's hard to find the exact axles since it's so specific. That's one of my biggest worries. Oh, and I just hit up Sami to see if he still had the driveshaft.
    If you have any search suggestions for the axles (or part numbers), I'd appreciate it.
    -JJ
  28. #188
    Oct 22 2005
    Reppin the Mitten.
    JJ, send me a email at ecniv05@g m a i l dot com
    -Vince
  29. #189
    Apr 26 2008
    2007 A6 Avant
    Newport Beach
    email sent! thanks, buddy.
  30. #190
    Oct 22 2005
    Reppin the Mitten.
    Ok...we'll take this to email/gchat.
    -Vince
  31. #191
    Feb 01 2008
    B6 A4 GT3076R
    Uintah, Utar
    I'm so glad these headaches seem to be over for us. Ugh.
    -Tyler-
  32. #192
    Oct 22 2005
    Reppin the Mitten.
    Update: Birdie told me it should be done by next weds! Wish me luck!
    -Vince
  33. #193
  34. #194
    Feb 01 2008
    B6 A4 GT3076R
    Uintah, Utar
    WooHoo!!!!!
    -Tyler-
  35. #195
    Veteran Member Four Rings Dolphin18T's Avatar
    May 17 2007
    So....?
    -Ryan
    Maestro Tuned
    Now with slushbox-delete mod!
  36. #196
    Oct 22 2005
    Reppin the Mitten.
    Good chance it should be done! And I will fly out Saturday morning with Doug to pick the car up! Woot!
    I wondered if anyone had a genuine copy of vag com that can perhaps help me recode my ecu from a tiptronic to manual car around Dowerk RI/CT/NJ area?!
    -Vince
  37. #197
    Senior Member Four Rings vintagespin's Avatar
    Sep 15 2008
    NJ, unfortunately
    Does Doug not?
    -dc
    2005 Dolphin Grey A4 1.8T Quattro 6-speed Sedan
  38. #198
    Dec 03 2005
    connecticut
    Quote Originally Posted by vintagespin View Post
    Does Doug not?
    Not a genuine Ross/Tech cable. This is an excuse for me to get one.
    -Doug
  39. #199
    May 17 2007
    So you know that your ECU will work after you recode? I'm looking around for parts right now. I'm thinking about going with a 5-speed from a 2.8 B5 and rear diff from a 5-speed 3.0 B6.
    -Ryan
    Maestro Tuned
  40. #200
    Aug 10 2008
    Denver, Colorado
    Quote Originally Posted by Dolphin18T View Post
    There is no 5 speed 3.0 B6, only 6 speed. Also, IIRC the 3.0 uses a 4.11 rear end and the 2.8 is 3.89 just like the B6 1.8T.
    -Cam
