Page 1 of 13 12311 ... LastLast
Results 1 to 40 of 487
    Oct 22 2005
    04 A4-Marley / 11 STi-Nami / 93 Mercedes Benz 300SE-Cruiser / Specialized Enduro-lol
    Reppin the Mitten.
    It's time to say good bye...It's been a good run.
    To my Tiptronic!
    Now that plans are more solidified, I decided to open it to the public. Originally, I was going to be more discreet about this, however, this whole thing will be documented and posted eventually, so I might as well share it earlier with the community. I happened to find a drivetrain semi close to me. Therefore out goes the tiptronic, and in goes a 6 speed manual that I purchased with 40k miles. Here is a list of the parts that are acquired or being acquired currently.
    6 Speed transmission / shifter linkage / shifter boot / shifter knob / Shifter box / front drive shafts / trans crossmember / center drive shaft / rear differential / slave cylinder / pedal assembly / master cylinders / clutch hydraulic lines.
    Obviously with this opportunity to take everything out, as some of you may know, I purchased Dougs stroker motor. Which will mate my 6 speed transmission. And here is my plan.
    Phase I:
    Greg/DTH: Will be supplying me with Clutchmasters Clutch / 034 street density motor, transmission mount, and snub mount / JHM short shifter, solid throw package / RS4 pedals and dead pedal / RS4 shift knob, and a Aluminum manual center piece.
    [B]Drivetrain / Motor Swap: Done at a shop in Rhode Island.
    An AEB head will be replaced with Dougs current non-high flow head. Preparing for future upgrades to the intake manifold.
    I will still use my Eliminator GTRS turbo in this phase as I'm curious what a REAL manual eliminator car can do. So the turbo upgrade will not be immediate, but plans can change.
    Phase II
    Deciding the hardware that will be coupled with my motor. As per usual, I will be aiming for reliability, so I'm not trying to be the fastest car out there. Goal is in the regions of 400AWHP, but with stock drivability. So hardware is not 100% set stone.
    Phase III
    Cry...Because I could of bought a manual car easily to do this and save money. But I'm attached to my car.
    Let the fun begin, I'll post pics of parts this Tuesday/Wensday, and as parts come in. Start date we are aiming for end of January, beginning of February.
    -Vince
    Stockish 2004 Audi A4
    Senior Member Four Rings Greedo's Avatar
    Oct 26 2009
    Re: It's time to say good bye...It's been a good run.
    Sounds like you have a fun little project up your sleeve. Best of luck. I'm sure you'll quite enjoy it when you're done. If it wasn't for my car being my daily (and being lazy and hating city traffic) I would much prefer a 6spd, but for what it is I like my tip.
    Senior Member Three Rings eg6siR's Avatar
    Feb 06 2008
    1993 honda civic Si, 2004 Audi
    pittsburgh pistolvania
    good shit vinny!! i am also working on a BT winter upgrade, i just dont want to let the cat out of the bag just yet... not like i am doing anything special, i just dont want 10 pages in a thread before i even have anything completed... more than likely i will make my build thread the day i finish my winter project.
    snailspeed.net
    04 1.8t 6spd dolphin grey
    "you can go fast cheap but it wont be perfect, or you can build it right and go fast, but it wont be cheap"
    Veteran Member Four Rings aaaudiprotein's Avatar
    Apr 16 2007
    APPLES
    Chicago Burbsss
    Good Luck Vinny!
    But wouldnt that be cheaper to get another car?
    BLACKHAWKS 2010 STANLEY CUP CHAMPIONS
    Windows 7 WAS MY IDEA
    Veteran Member Four Rings nananana4k's Avatar
    Sep 10 2005
    A4 B6 3.0
    Congrats Vinny. Good luck with it all.
    Veteran Member Four Rings 400HPA4's Avatar
    Jul 04 2004
    2002 Audi A4, 2002 GTI 337
    OC
    Phase I is provided by you...you work at DTH, I ain't paying for the stuff
    Senior Member Four Rings vintagespin's Avatar
    Sep 15 2008
    NJ, unfortunately
    i could sort of sense this from some of your earlier posts. good stuff. this will be neat to watch
    -dc
    2005 Dolphin Grey A4 1.8T Quattro 6-speed Sedan
    Feb 12 2004
    DG 2004.5 A4 1.8T USP
    Austin, Texas
    Woah Vinny, you scared me man! Glad to see you are keeping your ride, its one of my favs on the board!
    Good luck with the build!
    --Asif
    Saint Cloud, Fl
    should be a good build to follow..... good luck
    Veteran Member Four Rings Audized's Avatar
    Oct 22 2006
    Vancouver, BC
    Sounds very exciting. I've been considering doing this tranny swap as I'm emotionally attached to my car as well.
    Keep us posted throughout the whole progress. Good luck with the swap!
    Feb 19 2007
    2001 BMW 540i M-sport
    Charleston, SC
    Good stuff Vinny Should have bought my 6spd manual driveshaft. Its special
    Last edited by AvanTTix; 12-20-2009 at 02:17 PM. Reason: Remove personal/private AZer info.
    -Sami-
    Mar 27 2005
    Ducati S2R & Land Rover Discovery 2
    Tampa Bay Area
    should be a fun and involving project.
    2004 A4 1.8TQ6MT - Dolphin Grey
    -Maestro Stage III with a built block
    -STaSIS/Ohlin/Swift Suspension w/ H-Sport Sways
    -STaSIS/Alcon 355mm Mono4 BBK & 305mm Rear
    -STaSIS 4:1 Center Diff & STaSIS LSD Rear Diff
    -19" RS10 Forged wheels w/ Nitto NT-05
    -Laser Intercepter Dual + Bel STI Magnum
    301hp & 331 ft/lb uncorrected
    on 93 oct
    Senior Member Four Rings IVRINGS's Avatar
    Mar 27 2009
    03 Audi A4
    Columbus, Ohio
    Back to the build guys! So what Clutchmasters Clutch are you going with. I've been looking at the FX300 and FX400. I've been liking the idea of FX400 if I got GT30 or bigger, but wanted your intake on what you are doing.
    Hahaha...dood! If the movie director wanted the car in the next fast and furious, I'd definitely submit the car! :-P - BoostBeeyatch
    Jul 04 2004
    OC
    We have a 240mm version that CM will be making for us, which will offer just a little more clamp for either the FX300 or 400.
    I need to get five orders together to have the flywheels cut.
    Standard size is 228mm
    Forum Moderator Four Rings biketsai's Avatar
    Jun 04 2007
    01' A4 1.8TQM;05 USP; Cannondale CAAD9
    Austin/DFW, TX
    BetaAlphaTau Member #12
    01' A4 1.8TQMS 5spd swapped
    My 5-Speed Swap DIY
    - B6 USP
    Sep 23 2006
    Central Illinois
    Agressive undertaking but best of luck. I'm glad someone picked up Dougs motor so I could stop thinking about engine swaps right now.
    Oct 15 2006
    From a couple to a few...
    Centreville, VA
    best of luck, please do take pictures. i won't ever have to do this, but i would love to see it to learn.
    '03 A4 1.8TQMS
    RS4 Rear Sway Bar, APR Snub Mount/TIP/TB Hose, Forge 007P DV, SB OFE SS, Bilstein/H&R, B5S4 Brakes, Hawk HPS, 034 HFC, Milltek Exhaust
    S4 Side Blades, Aero Wipers, RS4 Pedals, OEM HID, DIY Plasti-Dip Grill, BlitzSafe
    '04 A4 3.0Q Tip Cabriolet
    Blitzsafe
    '04 Suzuki SV650
    Cabrio air wasn't enough...
    Senior Member Four Rings AudiA4Turbo22's Avatar
    Dec 06 2007
    '03 Audi A4 1.8TQ Tip, '08 Mbz ML550, '10 Mbz S550
    As for the Build, GL man, finally someone stepped up to the plate, I decided not to as I want to build the most powerful tip on the road.
    -Kirk
    BetaAlphaTau Member #58
    Veteran Member Four Rings maclem8223's Avatar
    Oct 16 2006
    04' A4 USP 1.8T QM
    RSM, California
    good luck to you vinny in all your endeavors. It willbe a good build and respect the responsiblity you have had to take on with the business and everything.
    ~Matt~
    BetaAlphaTauMemeber #45
    USPMemeber #1001
    04' 1.8T Q6M 2871R Revo Tuned
    Site Moderator Four Rings AvanTTix's Avatar
    B6 A4 1.8T Avant, MKI TT 1.8T 225hp Roadster
    San Francisco, CA
    Good luck w/ your project/build Vinny...
    Let us know if you decide you want this thread to be moved to the Projects and Builds sub-forum...
    PS: I removed personal info from this thread and the post that led to it. That particular topic has no place here and is none of AZ business.
    Stéph - Moderator
    MY2003 B6 A4 1.8T Avant
    : DenimBlue||Ebony||5-Speed MT||Quattro||Premium Package||Sport Package
    MY2002 MKI TT 1.8T Roadster: BrilliantWhite||RedAmber w/ Baseball Optic||6-Speed MT||Quattro||Premium Package||Audio Package
    Sep 02 2005
    Land of beer and supermodels
    It's about time someone did the swap on the B6 Make sure you document it well, I may follow suit next year, once I get a new daily driver.
    2003 B6A4 || Bridgestone | BBS | STāSIS | ÖHLINS | Brembo | Rawtek turbo-back | Malone Tuned | DTH | EuroGear USA ||
    2012 B8A5 S-Line || Bridgestone | Volk Racing | H&R DRA | KW ADS coils | Rawtek quad tip cat-back | JL Audio | E-Codes front & back||
    Oct 22 2005
    Reppin the Mitten.
    Thank you everyone for having my back.
    Steph, thanks for cleaning it up.
    Kirk, more props to you, but you have Ray as a contender in that category. Last time I checked he's on his way building his motor as well paired with the tiptronic. So good luck buddy.
    Max, I'll do the best of my ability. As I most likely won't be supervising this while the mechanic does this, unless he can do this in a timely manner, but who am I kidding. For something like this i'd rather give him plenty of time and not have any hickups. I'll try to get him to document everything. I'll take pictures of each and every part for others reference.
    -Vince
    Senior Member Four Rings B6JoeS4's Avatar
    Sep 13 2008
    '05 S4 MT6 pollution machine
    Chicago NW Burbs
    Im glas you are doing the manual swap. my plans are to buy a donor car in the springtime to do the swap.
    my only concern right now is getting all of the computers to work with eachother. im worried about what the ecu is going to do when it goes to look for a tiptronic and finds nothing.
    definitely let me know how you are going about making it work right
    GO: 2.5" trexturk catless dp's // 2.5" x- piped cb // JHM Stg 3 // 034 LWFW // JHM 93 // JHM SS // JHM LW Rotors // Apikol Snub // Stern Street Motor // Stern Trans // JHM LWCP // 034 MAF hose // RS4 Sway
    SHOW: 18" Enkie RPF1 // FK Coils // 35% Tint // Ecodes // HID fogs // Pioneer F90BT // RS4 Shifter // RS4 Pedals // B7 Console // Valentine 1
    AudiRevolution.net
    Stage 3 Forum Advertiser Four Rings Sales@RAI's Avatar
    Jun 22 2009
    Dundalk, MD
    Wow that sounds like an absolutely insane project. I thought my build was expensive! haha.
    You want 400awhp on the eliminator?
    Veteran Member Four Rings mrbacardi35's Avatar
    Sep 18 2006
    2002 a4 1.8t quattro
    Los Angeles, CA
    Quote Originally Posted by 400HPA4 View Post
    is it going to be aluminum or steel fw?
    **MIKE**
    Veteran Member Four Rings alexza4's Avatar
    Apr 23 2007
    03-A4||08-X5||01-///M3
    Good stuff Vinny! I thought holly shit another one bit the dust after reading your title... Good luck with the project and keep us posted.
    2003 A4 QM EFR 6758 on meth
    In Limbo Two Rings
    Jul 29 2009
    Michigan
    Quote Originally Posted by Clint@R.A.I. View Post
    Oh heck no on the GTRS. I doubt its possible. Thats phase 2. After I put the motor and tranny in. I'll be putting something bigger after. Just haven't had much luck with deciding what turbo/manifold/tuning etc etc. So i'm taking it slow rather then rushing in and doing it all at once. Just enjoying the phases of modding.
    Jun 04 2007
    Austin/DFW, TX
    Quote Originally Posted by B6JoeA4 View Post
    You wanna know what the ECU does when it goes looking for the TCU and its not there?! It automatically resets itself in manual mode! Whenever I removed my TCU after the swap (even before recoding), the cluster said "Press clutch to start car".
    My 5-Speed Swap DIY
    - B6 USP
    In Limbo Two Rings
    Jul 29 2009
    Michigan
    Quote Originally Posted by biketsai View Post
    Biketsai, I read your thread, and i have to give you props for doing it. I'd never be able to do this by myself like you did. I hope the b6 ecu does the same. I need to go unplug my TCU to try it if it applies to the b6 chassis.
    Jul 04 2004
    OC
    Quote Originally Posted by mrbacardi35 View Post
    Aluminum, 14lbs. If the clutch proves itself popular, then billet steel as well.
    Jun 22 2009
    Dundalk, MD
    Quote Originally Posted by vinny@dth View Post
    well your car is going to be a bunch faster even with that same turbo either way, so that should be fun
    Jul 04 2004
    OC
    I'll set him up with a 360AWHP tune on the GTRS, then all of that fueling and associated fueling hardware will carry over to the HTA 30R
    515 will be his number on the 30R
    Dec 03 2005
    audi, chevy, jeep, lots and lots of bicycles
    connecticut
    Hi Vince. Just saw this thread now, but gotta head across town for the evening. Good stuff! Let me know how tomorrow goes.
    -Doug
    2002 A4 2008cc GT-3076R turbocharged Avant
    397awhp/371awtq on straight 93oct and 96*F ambient
    Tuned by Autospeed Performance
    I am selling an Authentic B6 Sportec Front Bumper. PM me for info.
    Dec 03 2005
    connecticut
    It should from what I have been told. Vince just has to unplug the TCU and let me know what he sees (been asking him for weeks to do it but he's been quite busy). Worst case, I have an '04 6spd ECU we can use.
    -Doug
    Jul 04 2004
    OC
    AMB ECM is not transmission specific...
    Senior Member Four Rings Elliott's Avatar
    Oct 28 2007
    Good luck Leslie!
    Oct 20 2008
    2002 A4 Avant 1.8T Quattro
    Orlando, FL
    I've always wondered about this also, seeing it took me a month to find an avant and I didn't want to take the chance on not finding another one. What kind of problems would there be mating it to a stock motor? What about the pedal assembly? How hard is that to swap over?
    Senior Member Four Rings NightRoller USP's Avatar
    Aug 23 2008
    2004 1.8t Blk/Blk USP
    Congrats and Goodluck Vinny!!!!
    I will surely be watching this thread.....good things are soon to come!
    Jacob
    AWE ll APIKOL ll PODI
    USPCLUBMEMBER#190
    Sep 13 2008
    Chicago NW Burbs
    Where is the TCU on a 3.0? ill go unplug it now if someone can tell me where the thing is.
    AudiRevolution.net
    Veteran Member Four Rings wolfdog's Avatar
    Nov 22 2006
    Wow, Vinny. I didn't know you bought Doug's motor. This is going to be GREAT to follow. Good call on the manual switch. I wish you luck!
    2002 A4 TQMS
    REVO 1+ w/Genesis 380s, 034 HFC, K&N drop-in, 710N, Neuspeed snub, StopTech SS lines w/Hawk HPS, Conti DWS, full Votex
    12/23/09 - I'd just like to say my car has been phenomenal to me. Runs strong, like a champ. I don't think I'm ever going to sell it. I'd rather throw $7k into it for a complete refresh than buy a new A4 that has no oil dipstick.
    12/5/10 - 100k miles and counting!
