Senior Member
Four Rings
leoqueenie - ohhh, i think i recognize the area now. it's been a while since ive been back to HK :(
ultra - did you get a set of 5x120 redrilled? did you have to use spacers to clear the calipers? i was going to order a redrilled set in the spring. you beat me to it
Four Rings
yes and re-drilled and spacers were not neccessary but then again I do not have bbk yet either should still be fine then too though in our estimations.
Hub rings and you're all set
Forum Moderator
Four Rings
Yeah, but the question we're all dying to know is do they rub with all the VMR girls in your backseat?!?!
Four Rings
haha yes definitely
Active Member
Two Rings
 Originally Posted by leoqueenie
what front spoiler/canard whatever you call it do you have on your car? it looks pretty nice!
Senior Member
Four Rings
its osir. you can search it up on their site. i am pretty sure he has both the chin spoiler and the middle piece as well
Yes, you are right Calbee...it is Osir front chin spoiler and middle piece....
Senior Member
Two Rings
19x8.5 Vmr V710 gunmetal (offset 35)
245-35-19 Hankook ventus v12
2009 A4 Q. H&R oe VMR v710 APR Stage 2
Senior Member
Four Rings
Senior Member
Four Rings
saw this on facebook. it's a 3.0 TDI A5 S-Line with 19" Rotiform Race SJC wheels:
Registered Member
Four Rings
(Alex)-2010 Audi A4-Ibis White-Quattro-Sport Package-6MT
Mods: H&R Spacers-20mm-f/25mm-r, H&R Sport Springs, 20% tint, TI Grille, clear corners, black SP wheels, EUROCODE HFIP and HFTIP, aFe intake filter, AR Track rotors, VAGGED, Roc-Euro SS, etc.
Senior Member
Four Rings
Those are 19's? Look much larger.
"Almost" completely stock.
Registered Member
One Ring
Why are some running 245 35 19 and some running 255 35 19 (both cars seeming to be the same ride height? If I'm running H&r oe sport springs what 19" tires should I run? Are people opting for the narrower 245 because of different ET?
Senior Member
Three Rings
2009 A4 2.0T Quattro Prestige S-Line
APRtune, Carbonio, Downpipe: AWE FMIC : EuroGear : STaSIS ARB : EuroCode Exhaust, Alu-Kreuz : E-Codes : H&R Street Performance Coilover : S5 brake kit : Adam's Rotors : Hawk PC : HRE
Registered Member
One Ring
 Originally Posted by ddun
yup, different ET
Any Idea what range of ET requires either 245 or 255? Im guessing closer to et42 I can run 255 but If I get something closer to an S5 et32 then I need 245?
Senior Member
Three Rings
Yup, i had 255's on an actual S5 wheels ET 32 and it rubbed. With 255's you can probably get away with ET35 and up
Currently I'm on ET26.5 with 245's and no rubbing.
It just depends on how flush you want to push it. If you're set on 255's, 5mm spacers on stock ET43 will be perfect, or any ET38 would be a safe bet.
There's a link on post #1 of this thread with tons of info.
Registered Member
One Ring
Thanks for the help. Almost every wheel I'm looking at is either ET35 or ET38 aside from if i get actual S5 wheels of ET32.
I'm not set on 255. My best friend is leaving the tire place he works at this week so it is my last chance to get tires at cost basically.
Registered Member
One Ring
I went through the suspension/wheel link on the original post and I am even more confused on what to get. I still want to be able to track my A4 on a rare occasion with no rubbing. With the H&R sport springs am I safer to go with 245/19's even on et35/38 or should I just ditch 19's all together and get 18's? I know the wheel width becomes a factor as well...
Senior Member
Four Rings
I asked if they were 20s also, but the guy responded that they are 19s. Shrug.
Forum Moderator
Four Rings
18's are for girls. Your wheel/tire question is too vague without any info on wheel width. In general, I'd say 255's on ET38 and 245's on ET35 if you want to avoid rubbing or rolling your front fenders.
Stage 3 Forum Advertiser
Two Rings
[IMG]http://i1236.photobucket.com/albums/ff442/joe926/IMG_0690.jpg[IMG]
[IMG]http://i1236.photobucket.com/albums/ff442/joe926/IMG_0675.jpg[IMG]
[IMG]http://i1236.photobucket.com/albums/ff442/joe926/IMG_0674.jpg[IMG]
Looks great!
So simple and clean.
[IMG]  [/IMG]  [IMG]<a href="http://s711.photobucket.com/albums/ww118/gordon1877_photos/?action=view&current=A4-1.jpg" target="_blank"><img src="http://i711.photobucket.com/albums/ww118/gordon1877_photos/A4-1.jpg" border="0" alt="Photobucket"></a>[/IMG][IMG]  [/IMG]  sorry about all the pics. just learning how to post on here. 2010 A4 premium W/ Vertini Magic Concave 20x8.5 255-30-20. H&R Springs. Stasis Cat back exhaust.
Active Member
Three Rings
I am interested in the Forgestar CF5 in deep concave style. 19x9.5.. My question is what offset would allow me to still fit 255/35/19's. I'm lowered 60 mm on coilovers. From reading this thread, I was thinking that a +45 et would be necessary...Any advice from any of you offset gurus?
Thanks
Forum Moderator
Four Rings
Thanks
Would you be willing to roll your front fenders? SonicMS in Mountain View will roll them so you have the same clearance front and rear and don't have to sacrifice fitment, run spacers, or staggered offset. With the fronts rolled, you can go ET40-42 (higher for less chance of rubbing under compression on the track). If you don't roll, ET43-45 would be the way to go.
Active Member
Three Rings
Thanks for sharing the wisdom Blake. Much appreciated.
I don't mind rolling the fenders at all.
Forum Moderator
Four Rings
Call up Darwin at SonicMS and tell him Blake from Fresno sent you. They'll take care of you on the wheels too.
Senior Member
Four Rings
Does anyone know the specs of OEM titanium wheels? (width/offset)
Active Member
Two Rings
reads as 19 x 8.5 for the A4's and 19 x 9 for the TT RS
not sure of ET
2010 Audi RS 6 |5.0 V10 TSFI | Phantom Black | Black Leather | Sat Nav | Factory Bluetooth | RS 6 20's | Full Milltek Exhaust
Senior Member
Four Rings
not sure of ET
Thanks. However, ET was what I was really looking for. I got ET38 reps, and I wanted to know what the difference would be from stock. I believe the stocks are in the ranged of ET40+, but I'm not completely sure.
Forum Moderator
Four Rings
ET43
Senior Member
Four Rings
ET43
Thanks Blake!
Senior Member
Four Rings
Dear god....are those 20" concave VB3s?
Might be my next set.
Four Rings
Those are actually 19x10 ET38 with 5mm spacers.
Senior Member
Three Rings
2010 A4 P+ 2.0Q 6MT w/ Sports Package
Ibis White
18" Sport Package
Mods:
KW V1, AWE Dual Exhaust, Raderwerks 19x9 ET28
APR Stage 2 + ECU, APR Carbonio Intake, Eurocode HFC & HFIP, S-Line Side Skirts, 6000k HIDs,6000k HID fogs, Hardwired 9500ix Radar
Tints - 35% Llumar, Vagcom Mods, LED plate bulbs, LED interior lights, Debadged, Blacked out Grill / amber reflectors / rear emblem
Prime Motoring
Senior Member
Four Rings
^^now that is fk'ing beautiful. Nice clean ride bro.
-roger
Work wheels x airrex air suspension x stvbek x Eurocode x ....
Senior Member
Four Rings
2011 Audi S4 BB|6MT|Prestige|Red Nappa|Carbon Inlays|Carbon Grill|Carbon Logo|VAG-COM|Valentine1|3M Clear Bra|H&R OE Springs|35% tint|Carbon Ribbed Rear Diffuser|LM's 225/40/19|Trispoke 225/40/19|10/15mm spacers|Hoen endurance fogs|j-codes|AWE Boost Tap|Podi Boost Gauge|Eurocode Short Shift|Roc-Euro Intake|Whispbars|Skybox|AWE Exhaust
2009 Audi Q7 Prestige
Senior Member
Three Rings
thanks guys
Ibis White
18" Sport Package
Mods:
Prime Motoring
Registered Member
One Ring
 Originally Posted by NJDeVsFaN
That's very nice!! Wat rims r those? What is ur suspension setup? Does it rub? N if u don't mind can u post pic from the rear?
Active Member
Two Rings
these are few pics that were taken of my car in H2Oi
Senior Member
Three Rings
ADV.1 5.2.1 19x10 ET39
KW Ver.1
IMG_7916 by So Lens, on Flickr
IMG_8045 by So Lens, on Flickr
IMG_8153 by So Lens, on Flickr
- You may not post new threads
- You may not post replies
- You may not post attachments
- You may not edit your posts
Forum Rules
