Originally Posted by
NogaroB6
According to this website most recaros are fitted with the heaters. I will have to contact them to see what else I would need.
If I were you I would do whatever I need to make 100% sure the heaters are in the seats before you do anything else, because if they aren't that's where the biggest part of your expense is likely to be. Not only to purchase the heaters, but to have them installed by a good upholstery shop. You could get a pair of hog ring pliers and rings and try it yourself, but I'd be concerned about screwing up the seats...
Start by pulling the seat so you can get in there from the underside and see if you can see the heaters or reach your hand up there and feel them... If you can't tell, then I'd try to trace the wires, maybe you can find a wiring diagram somewhere... Good luck.
