Results 1 to 33 of 33
    Veteran Member Four Rings Sanjman's Avatar
    Nov 16 2006
    nothing else special
    Skokie, IL
    DIY: Spark Plugs for Dummies - update for B7 A4's
    I wanted to update the DIY from: http://forums.audiworld.com/showthread.php?p=20493264
    so people understand the differences for our B7's.
    You should follow the above with my B7 updated picture here:
    1) Remove torx screws (sorry typo in the picture)
    2) Pull off the wiring/hose off the clamp to allow better mobility
    3) Push the plastic wire container and the coilpacks together as it helps loosen up the locking tab mechanism for easier removal.
    4) Pull down on tab to unlock the connection. You might here a click but sometimes you just have to tug between the coilpack and the wiring to see they have been disconnected. As the other DIY says you can leave the wiring plugged into the coilpack. I DO NOT RECOMMEND DOING THAT. Since the old DIY has soft wiring. This is hard plastic or metal and makes it impossible to maneuver all coilpacks out still attached. I tried it, I was able to get the front 3 out, but the 4th was difficult and I ended up cracking the harness connector. Luckily it still works for me but just one or 2 tabs of that connector broke off. The wiring is still in intact. A buddy recommended using the right hand to hold the coilpack and the left hand holding the harness with your left thumb on the tab pushing down . With one strong pulling motion you should be able to pull it apart. I have soft skin (teheheee) so I used a flathead screw driver... may not be a good for your tabs.
    5) With a strong grip pull the coilpack straight out. Some people say these click in and out. On mine that was not the case. They slid in and out very tightly but actually should click onto the spark plug itself.
    6) Follow the rest of the steps in the above DIY. I took the advice of putting anti-seize on the threads of the new plugs and putting a very thin layer of dielectric grease on the plug end (not the ignitor side. DO NOT touch this side at all except with gapping tool. (I verified each spark plug was gapped to factory spec of .028 since I also used OEM spark plugs). I recommend wiping off the grease of the gap tool as my brand new one came with it greased probably to avoid corrosion etc.
    Other tips:
    *Make sure you use the 5/8" spark plug socket and make sure the rubber washer is still in the socket, otherwise you will not have any other way of safely removing the old plugs and putting in the new plugs without dropping them.
    *When inserting new plugs, be sure to SLOWLY place the plugs in. You don't want to drop the plug or have it hit the wall or mess up the threads or tip in any way. You can break the tip and if that happens you will risk dropping that broken piece into your engine while having to pay for another spark plug or you may end up changing the gap. I don't think you want to risk it... so be careful.
    *When torquing the plugs, I recommend you start with a smaller torque (15 ft-lbs) and slowly move up on it to the recommended 22 ft-lbs of torque. When trying to get the torque wrench to click, apply pressure to it very slowly as there is still chance of overtorquing. (I'm a little OCD, but this is how I like to do it)
    *Like I said, I'm a little OCD so I made sure I put the coilpacks in to whichever one it came from.
    Senior Member Four Rings AWDTURBO's Avatar
    Oct 28 2008
    DTM B7 Audi A4 Quattro
    Newark, NJ
    Re: Spark plugs for dummies DIY update for B7 A4's
    Good man, nice DIY!
    Brilliant Black B7 A4 w/ DTM Conversion
    Stage 2+
    Prime Motoring
    Senior Member Three Rings CleverA4Name's Avatar
    Dec 09 2009
    2006 A4 2.0T Quattro 6MT
    Portland, OR
    nice DIY! thanks!
    Senior Member Three Rings spitfire11's Avatar
    May 02 2007
    B7 A4, Mk2 GTI VRT
    San Antonio, TX
    Re: Spark plugs for Dummies DIY - update for B7 A4's
    Good work +rep. Saved for when I need to reference this
    '08 Ibis White A4 2.0T, Quattro, 6-Speed, S-Line Titanium
    APR Stage II 91/93/100, 034 High Flow Cat, RS4 RSB, RS4 Pedals, Smoked Side Markers, 9500i Hardwired, RS4 Grille/CC Mod/Filler Plate, Vag-Com Mods, Debadged, Llumar 30%, Thule Rack, 19" V710, Conti Extreme Contact DW
    '96 Emerald Mica A4 2.8 12v, Quattro, 5-Speed (SOLD)
    Bilstein/Vogtland Suspension, Neuspeed 19mm RSB, Magnaflow 2.5" Exhuast, V&S Shifter, 15% Tint, Debadged
    Senior Member Four Rings RedS-line's Avatar
    Mar 19 2008
    2006 A4 S-Line, 1990 944 S2
    very nice. you didnt wanna try ngk one step colder plugs?
    How to sell an item in the classifieds:
    10% off- Brand new in box from authorized retailer on special
    20% off- New, never used, private seller, box optional
    30% off- Used but in great condition, all parts present
    40% off- used, may be damaged or missing parts
    50% off+ Handyman's ''dream''
    DUH! an Audi
    los angeles, CA
    going to add to FAQ.
    can you maybe upload those photos to the AZ gallery, so we can keep those in the system?
    -randy
    Oct 18 2009
    WA
    hey Randy, been trying to get a hold of you since Thursday through PMs/emails and posts regarding those wheels you have for sale.
    2007 Audi A4 2.0TQ S-line Brilliant Red
    Mods: RS4 Rear Sway | APR Snub Mount | Billy Boat Cat-Back Exhaust | APR Stage I fully-loaded | De-badged
    DUH! an Audi
    los angeles, CA
    i sent ya a pm....you didnt get? shoot me another one, ill be near my comp.
    Senior Member Three Rings rlopez's Avatar
    Nov 09 2006
    Landcruiser, Prius, AudiA42.0T (6M), Sport Suspension
    Denver Colorado
    Very nice graphics and detailed DIY. Just in time; I need to change plugs in about 1K miles and this will come in very handy.
    RLo
    Formula 1 window tint Premier Series, RS4 Reps, PSS9s, Velocity Snub Mount
    Active Member Four Rings Tusin's Avatar
    Mar 16 2009
    Anchorage, AK
    Great DIY. One thing though. I would not use a screw driver to remove the wire connectors to the coilpacks. Or to "make them click".
    All you have to do (and I told this to a friend with a 1.8T, but of course he did not listen and broke a tab). Is push the connector towards the coilpack, using your thumb pull the lever towards you and then pull the connector toward you, in one motion. SUPER easy.
    Nov 16 2006
    Skokie, IL
    Quote Originally Posted by Quattro View Post
    -randy
    Sure! I'll upload right now and relink the pics
    Quote Originally Posted by Tusin View Post
    Good call... my coilpacks were stuck in the socket pretty bad and I did break the tab... but inserting the screwdriver on the wrong side I'll update the DIY as well with your suggestion.
    Nov 16 2006
    Skokie, IL
    Quote Originally Posted by RedS-line View Post
    I should have... but I wasn't sure on what the gap should be on those. People had their own recommendations for the gap and kept me uneasy as I don't want to risk myself getting stuck in 0 degree weather as Chicago has tons of those days.
    I also heard that the stock plugs are superb from my AZ research.
    Sep 30 2009
    08 A4, 87 Jag XJ6, Lex RX300, HD Street Rod, Grumman Yankee AA1A
    Indiana
    very nice. you didn't wanna try ngk one step colder plugs?
    Perhaps I missed something. What is the reason to consider going with a colder plug. Are folks having pre-ignition problems?
    May 26 2009
    VA
    Nice DIY. Really appreciate it.
    Nov 16 2006
    Skokie, IL
    Quote Originally Posted by Brillo View Post
    None unless your car is modded and the car runs hotter due to it. So people with mods that increase boost or internal temps then its better to use, but I think foul much more quickly in normal driving. At least that is what I read in other forums.
    Nov 09 2006
    Denver Colorado
    You've definitely saved a lot of "B7" owners a lot of fruitless research, anguish, and restlessness on this DIY. Definitely saved this for use and will save me hundreds of $$ by doing this project on my own--confidently.
    RLo
    Nov 04 2009
    Norcal
    Quote Originally Posted by Sanjman View Post
    I just went APR 91 with full exhaust and TP. I asked APR what plugs to run with that and they said stock and stock heat range at .030 gap.
    Of course I then didn't listen to that and bought ngk iridiums 1 range colder. Now I'm thinking I should have stuck with their reco.
    Nov 16 2006
    Skokie, IL
    Quote Originally Posted by rlopez View Post
    no prob
    Active Member Two Rings vtsquid's Avatar
    Jan 02 2010
    2010 Ibis White A4 2008 Ocean Blue A4 Tip
    VERMONT
    Thanks for this DYI.I plan on doing my plugs soon.There is no mention of WHICH PLUG to use???Can someone help out with this please? (2008 A4 2.0T w/TIP).Thanks.
    HIS: 2010 A4 2.0L 6MT Premium W/18 Inch Sport PKG Ibis White
    HERS: 2008 A4 2.0L Quattro Tiptronic Premium Ocean Blue
    Nov 16 2006
    Skokie, IL
    What "plug" you want to is up to you... it was MENTIONED several times what I went with OEM and why...
    OEM is Bosch spark plugs... I know you can get them from your dealership, genuinedaudiparts.com, and ECS
    AUDI part number: 101905631B-4
    Bosch #FR6KPP332S
    Jan 02 2010
    VERMONT
    Thanks sanj.Great write-up BTW.I was able to get NGK Iridium plugs for $7.90 from my local parts store.I'll try them and if they don't do OK then I'll go with the BOSCH.-Andy.
    Senior Member Three Rings Kerby's Avatar
    Nov 10 2008
    I park on the street.
    Brooklyn, NY
    Damn it I need a DIY for a 3.2... HELLLLPPPPPP
    Soon
    HPF M3
    Gone
    G37S
    B7 A4
    E39 M5
    SC300 TT
    Sep 27 2008
    Phoenix
    How many turns is 22 ft lbs? I don't have a torque wrench and will be attempting this soon.
    Senior Member Two Rings matthewb2795's Avatar
    Mar 13 2010
    2005 Buell XB12s
    Michigan
    I really would not risk "going by turns." Get a good torque wrench, itts a good investment. Stripping a plug is nothing anyone wants to deal with.
    -2007 Brilliant Black Audi A4 Titanium S-line, 6-Speed-
    STaSIS SS Coilovers / RS4 Rear Sway Bar / Podi Electric Boost Gauge / APR Tune / 034 Turbo Inlet Pipe /18" RS4 Reps (previous owner's mistake, looking to fix this soon)/ H&R TRAK+ Spacers 15f, 20r - Final ET 27f, 22r
    Seeking OEM B7, or B8 Ti wheels, PM me!
    Sep 27 2008
    Phoenix
    Quote Originally Posted by matthewb2795 View Post
    I found this today: http://www.nology.com/torque.html. I will try this tomorrow.
    Active Member Two Rings jpg323s's Avatar
    May 11 2010
    2003 A4 B6 Avant, 2007 S40 T5 AWD, 1968 AMC Javelin 390
    Colorado Springs, CO
    THANK YOU!!!!
    Current Set-Up:
    Custom Intake w/K&N Cone
    APR TIP
    GFB WRX Hybrid BOV
    Custom 2.5" Exhaust - Magnaflow Race Muffler & Thermal R&D Rear Mufflers
    Slotted Rotors up front & Slotted/Dimpled in the rear w/EBC Redstuff all around
    RS4 Rear Sway
    "Only the dead have seen the end of war"
    Nov 16 2006
    Skokie, IL
    Quote Originally Posted by wootwoot View Post
    I'd be wary of this... might as well just buy a torque wrench... or borrow it from autozone for free.
    Senior Member Four Rings eMacPaul's Avatar
    Jul 25 2008
    Everett, WA
    Buy yourself a torque wrench for $20.
    2007 A4 2.0T CVT Cabriolet S-Line Phantom Black
    APR, K&N air filter, Podi boost gauge, chrome-stripped grille, RS4 RSB
    Smoked side reflectors & markers, smartTOP, Eibach Pro-Kit, 12F/15R spacers, ER SMIC
    Xenon match DRLs, HID fogs, city w/ fogs, S4 mirrors, red LED interior, CC, 034 HFC + Magnaflow 14829
    Senior Member Four Rings Stewy's Avatar
    Jan 24 2010
    2007 Audi A4 S-Line 6MT, 2012 F-350 Super Duty, 2003 Suzuki GSX-R750
    Vancouver, B.C., Canada
    I've done countless plug swaps without one, not to worry. 22 ft/lbs is "snug" if that makes sense. Don't crank the heck out of it, just seat the plug and crush the washer, and maybe another 1/4 turn.
    2007 Audi A4 S-Line 2.0T FSI - APR Stage II+, APR HPFP, JHM 4:1 Center Differential, Carbonio (APR) intake, AWE Tuning FMIC, 034 Motorsport turbo inlet pipe, BSH catch can, OEM "D" DV, APR test pipe, Neuspeed exhaust, H&R coilovers, ECS Stage 4 BBK with Pagid pads, RS4 rear sway bar, Neuspeed short shift, Neuspeed snub mount, Defi MeterBF gauges with Defi-Link, Vag'd, de-badged, Huper Optik tint, RS4 grille, EU amber tails, 19" Hartmann RS4 replicas and H&R Trak+ wheel spacers
    Nov 16 2006
    Skokie, IL
    lol... i think everyone's definition of "snug" is different based on strength and tool length (no pun intended?)
    Senior Member Three Rings audib7maniac's Avatar
    Oct 23 2009
    New York, NY
    How difficult is to swap out the spark plugs on our engine? i ordered new Sp and CP, should be in by tuesday or wed this coming week. I will be trying this for the first time, wish me luck lol
    As of Right Now: Vorsteiner CF Hood, E-Code Bi-Xenon, Stasis SS Coils, RS4 Rear Sway Bar. CC Mod, 20% tint,, Febi-Bilstein Control Arm Kit, APR Fuel Pump, Unitronic Stage 2, Custom Quad 3" turbo back exhaust (3" Tp, 3" DP, 3" straight Pipe), DTM Front & Rear Bumper, VMR Vent Boost Gauge
    AMS AUTOWERKS FTW!
    Active Member Three Rings yungcotter's Avatar
    Jun 09 2010
    queens New York
    Not difficult .you just need a t20 torx to remove the ignition Wire the coil packs just pull out and a Sparkplug socket. I just did mine in my schools parking lot took 20 minutes.
    Sent from my Droid using Tapatalk
    06 A4 2.0T, Quartz Gray, Quattro Tiptronic.
    APR Stage 2,RS4 Rear Sway bar, Carbonio Intake, Smoked tails,
    Hawk HPC ceramic pads, Zimmerman cross drilled Rotors, Tyrolsport rigid caliper sliders AWE Exhaust
    S-Line Trunk, Podi Boost gauge, Hard wired Passport 9500ix, HiD Projector Retrofit
    -Theo
    Active Member Four Rings BoSNiaN's Avatar
    Jun 02 2011
    Thanks for the DIY! Just did it today and I am kinda surprised at how much force is required to disconnect the coils from that rail....I used a flat head to hold the tab down and pulled with all my strength on the rail to try to detach it. I don't know about others, but my 3rd one was VERY difficult to detach...I had to reconnect all of them, disconnect it first, then do all the others
    Also, looks like a coil blew in chamber 4 people it had a bunch of dried oil residue but the car did get the coils replaced under the recall so I am not too worried...
    p.s: to get the coils out of the chamber, life is easier if you use 2 flat head screw drivers, engage them in the top part of the coils, and pull up with equal force on both sides
    2006 A4 2.0T 6 SPD MT // Dolphin Grey on Black // Sport + Premium Package // Quattro
    ==> Complete Mod List <==
