Results 1 to 3 of 3
Thread: tire pressure
    New Member Two Rings piTTsburgher's Avatar
    Feb 16 2004
    2000 TTQC180
    PA
    tire pressure
    my girlfriend has a saturn SL2 (95) and is running KUHMO 732 PLUS tires. the manual says to defer to the specifics on the side of the tire for pressure info, but all it lists on the sidewall is max pressure. after a little internet scouring, it seems 30 lbs front and 28 rear is suggested. she currently has 33 front and 32 rear. any danger in this? any suggestions? should it be higher in the cold weather? thanx.
    Veteran Member Four Rings IndieRockSteve's Avatar
    Feb 12 2004
    2000 A4 Avant
    Brookline, MA
    No danger, and depending on driving conditions and vehicle weight the recommended pressure can vary around 5psi. the only thing to worry is being too low or above the sidewall max pressure.
    in the snow I like to have a little higher as it keeps the grooves a little more solid which helps traction (in theory). Cold weather generally keep a few psi lower, because when they get to driving temps the difference will be a lot higher, and thus the driving psi would be higher. but unless the car feels unsafe to drive I wouldn't worry about the winter difference.
    -Steve
    2002 Allroad 2.7T 6sp
    SS Stage 3 Endurance Clutch, the mods have begun...
    RIP:2000 A4 Avant 1.8T - GIAC ECU and TipChip, K04-015, EvoMS FMIC, Forge BPV, Borla V2 Exhaust, STaSIS Street Sport Koni Coilovers, H-Sport Extreme Sport Sway Bar Set, Flik Artic 18x8.5 wearing Eagle F1 GS-D3, HID ECodes, S4 Gauge Cluster, V1
    "There is more to life than increasing its speed." - Ghandi
    "The charging restless mute unvoiced road keening in a seizure of tarpaulin power." -Jack Kerouac
    Apr 21 2004
    2006 A4 2.0 6mt, 2004 Suburban
    Coopersburg, PA
    She will also get slightly better gas mileage with harder tires. Not as much resistance.
    2006 A4 2.0T 6MT - APR stage 2+ - RS4 rear sway bar -H&R sport springs -APR snub mount -034 HFC -APR hpfp -S-line Bumper -S4 grille
