Results 1 to 13 of 13
Thread: ABS LIGHT
    Senior Member Four Rings Mantvis's Avatar
    Jun 05 2009
    mk1 Audi TT 180hp, mk1 Audi TT 225hp, mk4 VW GTI
    Chicago, Naperville
    Exclamation ABS LIGHT
    so today we in Chi town got some snow. so when i got to my driveway, i got stuck :D :D there was like 3 inches of snow, not even..
    so when i hot stuck i pressed gas i though ill get out. and then the BRAKE and ABS lights went on. what should i do??
    If you don't need both hands on the wheel, then you're NOT driving.
    Account Terminated Three Rings lotusgardener's Avatar
    Dec 24 2006
    1997 Audi A4
    NW & NE
    Re: ABS LIGHT
    Check all of your abs sensors for damage
    Jun 05 2009
    Chicago, Naperville
    Re: ABS LIGHT
    Quote Originally Posted by lotusgardener View Post
    check all of your abs sensors for damage
    omg the car is pissing me off :d
    Veteran Member Four Rings InTTruder's Avatar
    Aug 21 2007
    00 TTQC|01 Avant|05 C230-SSk|96 MkIII Golf
    Augusta, GA
    Re: ABS LIGHT
    Some dirt/snow in the wheel speed sensor on the front is usually the trigger. Quit getting discouraged: it's a sports car and not a vuckin Toyota. A little contact cleaner (remove the wheel/tire for access) and VOILA!
    The Spartans do not enquire how many enemy there are. They enquire only where they are.
    Stage 3 Forum Advertiser Four Rings ECS Tuning-Audi's Avatar
    Oct 02 2006
    Wadsworth,OH
    Re: ABS LIGHT
    Even if it is a bad or broken sensor, your repair costs are very minimal and this is an absolute DIY job. If you have a vag use it, as it will tell you which wheel sensor is broken/malfunctioning. But if I had to guess it is the front wheel on the outside of your turn into your driveway.
    Wheel Speed Sensors - a photo for point of reference
    Jun 05 2009
    Chicago, Naperville
    Re: ABS LIGHT
    no more light :)
    it just turned off it self :)
    thank you all :)
    Aug 21 2007
    Augusta, GA
    Re: ABS LIGHT
    They don't heal. I suspect your ABS sensors all need cleaning. Ignore the warning at your peril, or something serious will occur. You'd hate for your ABS NOT to work when you needed it. Even if it was dirt, that means that some intrusion has occurred.
    Jun 05 2009
    Chicago, Naperville
    Re: ABS LIGHT
    Quote Originally Posted by InTTruder View Post
    is it possible that they just overheated or something?? because i still had summer tires, and every time i braked the abs turned on
    Oct 02 2006
    Wadsworth,OH
    Re: ABS LIGHT
    NO, this almost ALWAYS means your sensor is dirty. If you don't clean it soon it will go bad, and then you'll be buying new ones.
    Jun 05 2009
    Chicago, Naperville
    Re: ABS LIGHT
    Quote Originally Posted by Chris@ECSTuning View Post
    where can i find the sensors on my car?
    Oct 02 2006
    Wadsworth,OH
    Re: ABS LIGHT
    Pull you wheel off and find the thing that looks the like picture! It is clear as day. No plastics or anything over it. Clean the square end on the bottom left of the picture.
    Oct 24 2007
    Santa Monica
    Re: ABS LIGHT
    it can also be a faulty lateral acceleration sensor,
    I knew it as I got both of them dead.
    Aug 21 2007
    Augusta, GA
    Re: ABS LIGHT
    Start with the simple things (ABS sensors) 1st. The LAS is a possible, but not usual, suspect. Do the ABS.
