Tried getting the software going today. I kept getting error messages. I tried to update the firmaware of the loader, no luck. I did a force upgrade and the software says it has updated. However, when I try to test the cable it just gets hung up on the checking firmware screen.
Also, the thing wouldnt read my ECU. It just kept giving me random error messages. I was really trying to have this thing running this weekend, but with this glitch I am yet agian at the mercy of someone far away and the not so right now emailing back and forth.
try pming Lou_b5 or a4-drvr.. i think they are both using Maestro as well...
my ride: 2001 A4qtm... 2871r, 440cc, 3 bar, turbo xs dv, custom 3" exhaust, test pipe, Cm fx400 billet LWFW...
90 CQ.. 2bennett... work in progress
2004 AR... bone stock
Timing belts, clutches, and all done in the North Bay. Pm me.
You know my number... give me a call and I'll see if I can help. I've had to do some troubleshooting myself with the software, and may have your answer!
I emailed Chris and he gave me a few suggestions to try. Whne I gte off at 4:30ish (pst) I will go straight home grab the laptop, and get to work. If I cant get the thing to work, I will most definately hit you up. I really would like to send Chris my file by the morning so I can get my new file and start the break in this weekend.
Got the software to work. I guess it needed some time to marinate. I just went to the car plugged it up and voila, it worked like it shoulda yesterday.
I am going to just loop tthe lines on the cooler until I feel confortable plumbing in the cooler. I dont wanna get any trash in there from startup and the first few miles.
Couple days later and still no tune. I hope they get it to me tomorrow so I can get this car on the road this weekend.
On a side note, I have been palying with my wiring harness. I tried to get some pictures of it, I ran the harness quite a bit differently. I also rerouted the fule lines so they didnt cross over through the engine bay. All of this because intially I wanted to relocate all the harness that was stretched to the passengers side of the engine bay since I am going to switch all that stuff off in Maestro anyhow.
I ran the fuel lines straight up and into the grommet that the ac lines run into going to the rain tray/battery area.
The leftover harness comes out through a grommet behind the intake manifold now. I think I will be able to reuse the stock one from the ECU area.
The fuel lines pop out in a grommet in the same area.
The lines that connect that cluster of colorful connecectors bolted to the firewall has bee moved to the battery.
I still have a few things to clean up. I think I also want to use some sort of custom coolant tank, and I am considering relocating the power steering fluid resovoir to the battery tray, and relocate the battery to the trunk. Still need some sort of looming to clean up the wires, and still need to get the resistors onto the unused plugs. yay.......
you getting full adaptation, no cel's and have full readiness? Thats my main concern. I need to go through emissions like months ago, so I dont wanna be riding dirty for too long trying to get this thing figured out. You just have everything unplugged and switched off via Maestro?
No cel because the thing won't light up on my cluster mismatch with the engine harness. The only code I get is for not having n75 plugged in. Dave left to Maryland with it. All other ones are turned off in maestro. vvt, n75, sai, evap, blah blah blah
emissions is a different story. Since I don't have that here I'm of no help. What is "readiness" and "adaptation"?
All I know is that the car starts perfectly each and every time with a smooth idle.
Adaptation I think has to do with the computer compensating in the fuel trims. You can see your adaptaions via vagcom. I also think when you are logging in Maestro you are watching the adpataions. Its how much the ecm is adding or removing to bring the fueling in spec. I think.....
Readiness is what the emissions guy is going to be looking for when he plugs into my obd port. It also can be seen in Vagcom, I dont know about Maestro though, but more than likely.
That sucks. We dont have to do emissions testing over on this side of the state.
Originally Posted by FNK re getting more power from a 2.8 a4
"Paint the exhaust and intake with Ceramic paint (heat repellent), thus increasing the exhaust velocity, thus less striction = more Power"
Well, she runs. Couldnt not get vids or nothing since my phone took a crap on me. After a little while of fighting it it, I gave it a break went and did some other things came back, and she fired right on up. Took a while to get it to stay running after being in motion. It finally got to the point where it will stay running.
I now need to deal with various oil leaks, get some new plugs, and get some tabs. It really started to bog down, But I think that has to do with the fact tha it was getting hot, and needs new plugs. I did the peg the boost gauge routine like all fresh new builds do.
The valvethat stuck was one of the intake vales in cylinder number 2. I think it got stuck open, smacked the piston a few times, got bent over ever so slightly and started to work on the exhaust valve. The timing was dead nutz. I was hoping tit was a blown head gasket, until I remembered hearing metalic tapping sounds as I tried to turn it over. It had just started to happen, I pulled the plugs did a compression check, and realized #2 was dead.
There wasnt ANY visible signs of contact on the piston, but there is no other way to bend the valve that I can think of. Timing was money, and if it wasnt, I had enought timing issure to know it would ben the exhaust valves, and the outer intake valve.
When I dropped off the head he said that it was overheated. I dont know how, but I guess anythings possible. I am hoping the exhaust valve, since it is inconnel, is ok. I dont wanna order a whole new set of them bitches just for one. Just a bent intake valve, R and R, return head and have it back together for the weekend. I hope
Damn man that sucks, I really wonder what happened. Did it somehow have some oil starvation causing the lifter to freeze up in there? Good luck man I can't wait to see this thing all finished up.
- 00 Nogaro S4 - Single Turbo Project / 01.5 - Silver S4 - Stg. 3 / Five other B5s that have all been sold
SO, the news is......my head is warped ~.020". Good news is I will have a freshly built head by the beginning of the week to break again by the weekend since apparently I got money to blow.
I have a few changes that I want to try, including another turbo. Gonna be pretty hectic getting all of this together for the weekend. I really want to see what the fuss is about this turbo on other car forums I've wandered into.
[QUOTE=SpeedWorksAuto;5163733]Adaptation I think has to do with the computer compensating in the fuel trims. You can see your adaptaions via vagcom. I also think when you are logging in Maestro you are watching the adpataions. Its how much the ecm is adding or removing to bring the fueling in spec. I think.....[quote/]
Yes you are correct. Adaption is the process of the computer actually learning what it is supposed to do for fueling for a given throttle position/load.
It's a nice feature to have since it will help build maps vs doing it all by hand. Problem is it only does safe maps. In other words for full on power/trim you will still have to adjust the fuel/boost/timing map if you are looking for the max power.
But again a good starting point. And if you drive like your hairs on fire all the time it will learn that as well. :)
If boost comes in in the mid to late 4k range, imma drive this bitch of a cliff. The whole reason for this build is to make a decent horsepower car with a realy broad power band.
This is a bit of information I have found off one of the other forums I have been reading on........
"Yes it is a 2.4l. 8-8.3:1 compression.
Here were my initial spool results with the VGT rack fully closed and fixed there. This is just the first log I opened.
Here are the the most important things affecting spool
I can't remember what gear for sure but I think its 4th.
8" of 3" pipe for an exhaust
No intercooler
E85
8-8.3:1 compression
stock head, cams, intake manifold
Fairly low timing
1800 1psi
2000rpm 3psi
2500 8psi
2600 10 psi
Its a little slower now, the actuator starts to open the thing up a little sooner than I'd like.
Keep in mind this thing has a compressor in the GT35R size class."
