Results 1 to 40 of 48
    Senior Member Four Rings jimrobbington's Avatar
    Dec 03 2008
    07 Suzuki SV650
    Parker, Colorado
    DIY: Faulty Trunk Latch
    This is perhaps the easiest DIY I have ever done. It has been cold recently, like really cold, and apparently that is the favorite time for your trunk latch to choose to stop working properly. I heard this happens to a lot of people, and once it stops working 100% of the time, it is only down hill from there. No one wants to look like a loser in a parking lot slamming the trunk of their Audi! So here is goes.
    Tools needed: Flathead, Phillips, 10mm socket wrench, and part #4F5-827-505-D. Thanks to illegitimus for the part number. This is the same part number from VW to Audi. I ordered it online from vwpartsoem.com for only $43.50, but shipping was $11. Still about $3 cheaper than the stealership. Shipping was fast, and I am happy with my purchase.
    There are 2 Phillips screws and 8 clips:
    One screw behind the plastic handle:
    The other screw behind the emergency handle:
    Just pull down on the emergency handle and it will pop out of it's shoulder:
    The 8 clips are roughly as shown:
    These are pretty tough clips, unlike the ones on the door panels, so just pull, it won't harm anything. I started from the bottom, and worked around to the top.
    For the emergency handle, pull the part closest to you down, and then towards you, there is a little tab on the other side, then twist it and shove it through the panel.
    Now you have the two 10mm nuts. Unscrew these, and pull the whole assembly straight down.
    Disconnect the electrical connection, this is the only place I needed a flathead to pry up the tabs.
    Now you have the two braided wires, similar to clutch, brake, and throttle wires on motorcycles. This part on each one, just pull down and it will snap out of place:
    Then slide the wire around, and pull the plug on the end of it out of the hole.
    Then redo everything backwards, and voila, your trunk will again latch. Sorry for so many pictures on a simple DIY, but I figured thorough is better if I am going through the trouble anyway. Also, sorry no dog boner in this one, it was so fast, they didn't even know I was gone!
    05.5 A4 2.0T 6spd, REVO Stage 2, Vast Stage 3 clutch, VMR test pipe, custom 2.5" Techtonics exhaust, Borla mufflers, wastegate adjustment, 034 catch can, BKR7E, JHM Short Shifter, KW V1's, 19" V710's, Podi boost gauge, 640 Mod, 18% tint.
    Dyno proven 221 whp/302 wtq!
    Driving Style: Strategic Aggressor
    Eric Paul Young: "I just tore down my old boy and slapped the internals."
    Senior Member Three Rings Heavy Fluid's Avatar
    Mar 23 2009
    2011 Specialized Camber FSR Comp, 2010 Specialized Stumpjumper FSR Comp
    Michigan
    Re: DIY-Faulty Trunk Latch
    Great DIY. What is the part number for a pair of nail clippers for that pinky nail?
    2005 Brilliant Red A4 2.0T Quattro - bone stock, debadge + OEM carbon covered exhaust tips
    Senior Member Three Rings TheHeggi's Avatar
    Aug 03 2008
    05.5 2.0t A4 + 02 CBR600 F4i
    Redlands, CA
    Well I'll be...this is just what I needed! I was slamming my trunk over and over and over the other night leaving the gf's house and her neighbor came out asking if I was ok...in a suspicious tone...like I was up to no good...*sigh*
    05.5 DG 2.0TM FWD
    [Stasis SS][RS4 Rear Sway][APR 91][AEM intake][034 HFC][podi/stepper boost gauge][Satin Black B6 USPs][S-Line front bumper][RS4 Grille][Satin Black S4 blades][DIY Ti vinyl][DEPO projectors w/6000k]
    Aug 03 2008
    Redlands, CA
    Quote Originally Posted by Heavy Fluid View Post
    DAMN!! I was thinking the same thing lol, but since it was such valuable info to me, I thought I'd let it slide this time....lulz
    Keep that pimp hand strong, playa!
    05.5 DG 2.0TM FWD
    Dec 03 2008
    07 Suzuki SV650
    Parker, Colorado
    Don't worry about my crack nail! How else am I supposed to pick my nose?
    Senior Member Three Rings Übermensch's Avatar
    Nov 11 2009
    OLS
    Thanks for the post
    Senior Member Four Rings ataylor's Avatar
    Dec 15 2008
    stock car parts
    hamp
    nice! my trunk latch was being a bitch until the tire-shop that my car was at this weekend apparently fixed it without even telling me (sweet!)
    if it returns, i'll be back to this thread for sure. thx +rep
    AT
    B7A42.0TQ
    mister_tu: Lion is my favorite OS
    Jan 09 2009
    Connecticut
    GREAT WRITE UP AND PICS!
    My trunk has been a pain in the ass, now i CAN FIX IT.
    May 26 2009
    VA
    Great write up.
    It always cracks me up the things that people notice in these photos. LOL. I guess I need to start being more observant.
    Active Member Two Rings TitanTeamRoper's Avatar
    Dec 14 2008
    05.5 2.0 Frontrak
    BigBearLake=SoCal
    perfect thread, I the idiot in the parking lot slamming the trunk a 100 times, its even worse leaving for work at 3:00 am when is about 15 outside
    06 - 2.0T quattro S-Line, w/nav, premium, and technology package. plus rear Parktronics (Ocean Pearl Blue)
    Ziza LED city lights, Hoen Xenon match FogLights, Eurcode Testpipe, H & R Sport Springs, B5 lowering caps.
    05.5 - 2.0T FrontTrak, Sport suspension ( Light Silver Metallic)
    Factory Bi-Xenon Upgrade, Blacked Out headlight, 15% tint all the way around, Ziza LED City lights,
    Senior Member Four Rings Doctor's Avatar
    Jun 02 2008
    A4 B7 20vt Quattro,Golf MKV GT
    Greece
    Exactly the same issue for me. What a deja vu
    Once it was cold it started not working...But this year, it stoped working at all...I tried fixing it but all I would do is close it one time out of ten with a lot of force..
    So I bought a new one, and changed it as well....And as you I suppose, I noticed that it now closes with almost no effort...as it should...
    Senior Member Four Rings a4dc89's Avatar
    Nov 07 2007
    Land Rover Disco I
    Potomac, Maryland
    my trunk is broken too
    2006 A4 B7 2.0TQ Dolphin Gray Metallic 6MT
    REVO Stage II, 034 HFC, AEM turbo inlet/intake, OEM Piston DV, BSH PCV Fix, HID Fogs/Fog Mod, AWE Boost Gauge, Debadge
    All go no show
    Veteran Member Four Rings Sanjman's Avatar
    Nov 16 2006
    nothing else special
    Skokie, IL
    what's up with the pinky nail????!!! (snort snort?) LOL good write up though!
    Dec 15 2008
    stock car parts
    hamp
    of course, I spoke too soon.. the latch problem is back.
    Time to check out this DIY after work! thx again
    AT
    B7A42.0TQ
    Dec 03 2008
    07 Suzuki SV650
    Parker, Colorado
    Of course, T3wl! If you order the part today from the website I put, you will probably get it Thurs, unless you enjoy the dealership...
    Sep 02 2008
    NoVA
    What are the symptoms of your trunk latch going bad? Mine latches fine, but its always kind of bothered me about how loud / how much force is needed to latch it compared to the doors. Wondering if this will make it latch a lot smoother.
    2006 A4 Arctic White Avant
    Dec 15 2008
    stock car parts
    hamp
    My trunk sometimes does not latch.. and (right now) when it does, the sensor in the car still *thinks* it's open, so my dash display shows the diagram of the car with the flashing trunk INSTEAD of my gas mileage remaining, etc (extremely annoying!)
    anyone know how to turn off this "your trunk is open" notification, for now, untiL i can fix my trunk?
    AT
    B7A42.0TQ
    Dec 03 2008
    07 Suzuki SV650
    Parker, Colorado
    Quote Originally Posted by naiku View Post
    Your trunk may not latch at all some times. You should not have to slam the trunk at all. I did notice that when I replaced the latch, it takes almost no effort to latch it at all. When it is working properly, you should NEVER have to use force to close it. The weight of the trunk itself will latch it.
    Mine did this once before I fixed it, and I hit a bump and it actually popped back open, so the computer is right, the latch mechanism is not totally engaged.
    Active Member Two Rings nferguson's Avatar
    Jun 11 2008
    So, Ca
    Wow...audizine sure does know when I have a problem because magically the exact thread I was looking for shows up on the top of the forum. My trunk has been like this for a week and everywhere I go people just stare at me as I slam my trunk about 20 times. lol
    Dec 03 2008
    07 Suzuki SV650
    Parker, Colorado
    That's why I did this. It was such a popular problem, but no info. You are welcome Audizine!
    Sep 02 2008
    NoVA
    I think mine might just be noisy then, its an Avant, but I can usually pull the trunk down some then let it fall and it latches, just pretty noisy and cheap sounding when it does.
    Dec 15 2008
    stock car parts
    hamp
    yikes.. a bump opened yours up? that could be bad for me :-x thx for the heads-up
    AT
    B7A42.0TQ
    Dec 03 2008
    07 Suzuki SV650
    Parker, Colorado
    I did happen to be on a dirt road, so it was pretty bumpy, but still, be careful.
    Active Member Two Rings sider1681's Avatar
    Oct 18 2008
    2005 Audi A4 3.2L
    Manchester, NH
    This started happening to me last year when it started to get cold, but it never really became a huge problem until this year. Now the damn thing just won't shut; but I can take my key to the latch and it appears to latch.
    I should have gotten this fixed under Audi Care too bad it expired in July. c'est la vie !
    What exactly causes this issue
    Oct 18 2008
    2005 Audi A4 3.2L
    Manchester, NH
    Forgot to add, sometimes the trunk does latch, but the sensor doesn't see it as latch so when I lock my car, the anti-theft 'beep' doesn't appear to engage since it thinks the trunk is open... grrr... luckily it's parked in garage and not on the street.
    Dec 03 2008
    07 Suzuki SV650
    Parker, Colorado
    Probably just poorly made. I bet there's a plastic part inside that wears down or something. The new one looked a little different, so it might be upgraded...
    Jun 02 2008
    Greece
    Because I tried to fix the broken one, just for fun, or in case it actually worked, I found there are some plastic parts, that are replaced with other in the new part. There have been 4 updates in the part number if u see in ETKA...So go figure what problems there were....
    Active Member Two Rings cjnesher's Avatar
    Oct 31 2008
    DG 05 A4 2.0T 07 Passat 2.0T
    Tampa, FL
    Mine just went!
    when my neighbor asked why I was "slamming" my trunk.
    I told him my wife keeps trying to get out!!
    Thanks for the DIY!! and nice pinky....
    Active Member Two Rings mundusrector's Avatar
    Sep 11 2009
    Audi A4 2.0T B7 6MT
    PA
    Thanks...you're the man.
    BTW..that pinky nail is a "Blunt" nail. LOL
    Senior Member Four Rings Sal_B7's Avatar
    Dec 11 2007
    2005 A4 2.0T Quattro 6Spd
    San Diego, CA
    Cool stuff Jimmy! Will come to this if it ever goes out on me!
    '05 A4 2.0T Quattro MT APR Stage 3
    2008 APR Holiday Giveaway Winner!! Thanks APR!!
    FRRG Southern Ring
    Xbox Live ID: Sqzn2zz
    New Member One Ring
    Dec 31 2008
    Florida
    Great job. The wife was getting really mad fighting the trunk. Now I am off the hook on the grocery runs.
    Dec 03 2008
    07 Suzuki SV650
    Parker, Colorado
    glad I could help
    Jul 28 2009
    home
    Thanks for the DIY i can't believe there isnt a recall or TSB or something, it just happened to me today down in Florida, ridiculous.
    Account Terminated Four Rings
    Oct 18 2008
    Delray Beach, FL
    Quote Originally Posted by cjnesher View Post
    Mine just went!
    HEHE! Mine stopped working too for the first time in Florida. It happened a few times in Colorado, but I was hoping with the warmer weather it would stop when I came back to Florida. It has... until the freak arctic front we've had here lately. I hope when the temp goes back up it will be fine. I don't really want to spend $50 when I hardly use my trunk. Spent too much money on my car over winter already lol
    Senior Member Three Rings RJMars's Avatar
    Oct 18 2008
    Minnesota and NJ and MI
    Mine just went!
    Light Silver Metallic 2005.5 A4 2.0T, Quattro, MT, CPO
    Audi Sport rubber mats | red LED footwell & courtesy lights | pure white LED interior & rear plate lights | BMW Shadowline matte vinyl trim | de-badged | dark smoked blinkers | Brilliant Black S-line valence & mirror housings | City Lights w/ fogs mod | Lamin-X Gunsmoke tails | Cupra Lip | glossy black trunk rings | Bosch Icon wipers | "17 USP wheels w/ Nankang SV-1 snow tires | "18 BBS RX wheels w/ Michelin Pilot Sport PS2's
    Veteran Member Four Rings gods_kitchen's Avatar
    05.5 A4 Avant 2.0TQ
    Venice Beach, CA
    anyone got the trunk latch part # for avant? mine just went over the weekend
    Dec 03 2008
    07 Suzuki SV650
    Parker, Colorado
    Quote Originally Posted by gods_kitchen View Post
    I just looked on genuineaudiparts.com, and the avant is not even an option when doing a search. Maybe same part?
    Veteran Member Four Rings BoostedA4tQ's Avatar
    May 24 2004
    Miami
    Thanks for the DIY...just did it and it took me no more than 15 minutes from start to finish to swap it out.
    Now my trunk closes smooth again and no more embarrassing trunk slamming.
    I have opened and closed the truck today over 30 times just enjoying the comfort of being able to lock my trunk without slamming it over and over until it decided to lock.
    DOLPHIN GREY B7 S4
    Dec 15 2008
    stock car parts
    hamp
    Quote Originally Posted by ataylor View Post
    welp, almost a year later.. I'm back.
    I swear the car uses the temp.sensor to give you shit. Dealer wants $300 for a new latch + labor, fuck that.
    With the temps dropping, I'm sure this thread is about to be relevant again :)
    AT
    B7A42.0TQ
    Veteran Member Four Rings Tanner's Avatar
    2006 A4 2.0T quattro
    Markham, ON
    Bumping up an old thread. After having the new latch since April of this year, finally got this done this yesterday as the weather was nice. It was either going to get done or never get done then I'd be cursing at the trunk as it will refuse to close again this winter. Less than 30 minutes to do, albeit one of the clips on the trunk liner ripped off partially so had to glue that one back on.
    So if you cursed at your trunk lid while everybody is staring at you in the parking lot last winter, fix it yourself while you can before winter comes along.
    Mike
