Results 1 to 14 of 14
    Senior Member Two Rings p.tony's Avatar
    Sep 02 2007
    2000 s4 Stage 3, 1997 Lexus sc300 na-t, 2004 Touareg v8, 2007 Corvette
    Baltimore, MD
    Red oil pressure light is on. Need some help
    I've taken all the steps I know up to this point. Oil pressure light(red oil can) would come on intially during acceleration then go away once I got rolling(no red oil can). In stop and go traffic it would go on and off.
    Next step replaced the oil pressure sender. No light on start up but once I start moving the light comes on and with the new sensor it doesn't go away while driving. Chalked it up as a bad sensor and replaced again. Same thing.
    A lil worried about the light I get the oil pressure checked. Pressure is ok.
    Next step seafoam. Still the light prevails.
    Pulled sensor and cleared out the port as best as posssible and this light will not fcuking go away.
    Btw Ive always used synthetic oil and changed every 3k.
    Suggestions? Anyone.....
    00 C5 2.7t //Stage 3//
    Senior Member Three Rings Asicks's Avatar
    Apr 01 2009
    01 allroad 2.7T 6MT/00 A6 2.7T
    Minneapolis
    Re: Red oil pressure light is on. Need some help
    Quote Originally Posted by p.tony View Post
    This is a shot in the dark...but maybe a clogged breather hose? The spider hose can get clogged up pretty badly.....
    -Scott-
    Mods - Far from stock
    C5UNION
    Reppin' the Midwest
    http://www.audizine.com/gallery/data...fitti_wall.jpg
    Sep 02 2007
    Baltimore, MD
    Where might I find this breather hose you speak of?
    Apr 18 2007
    ny
    Items for Sale
    6 Speed--EPL--034--SPEC--ER--AquaMist--Forge--RS4--RS6--K04 --RNS-E--DTS--PSS9's
    SOLD
    Greg
    C5UNION
    Veteran Member Four Rings 2.slowT's Avatar
    Sep 24 2006
    2002 Audi A6 2.7T
    Minneapolis MN
    Items for Sale
    Quote Originally Posted by A62TURBO View Post
    I think he means on the car
    I like rep too
    2002 A6 2.7T Sport
    2000 A4 Avant Daily
    C5UNION | pictures & timeline
    Sep 02 2007
    Baltimore, MD
    Quote Originally Posted by 2.slowT View Post
    I like rep too
    ditto
    Veteran Member Four Rings Stampy's Avatar
    Oct 02 2007
    A6, A8, X5, etc
    Windy City
    I like rep as well
    Village Idiot!!!
    (\__/)
    (")_(")
    lots of rings in my garage
    Jul 09 2007
    01 A6 4.2 QUATTRO
    Portland, OR
    crankcase vent hose will not cause low oil pressure warning, im not sure about the 2.7t but is there 2 oil pressure sensors, a high and a low pressure, i know there are some vag engines out there that run 2 oil pressure sensors, as well its really important with these cars to get correct application, i had a 12 valve 2.8 A4 a couple years back that i was experincing same problem with, i got an oil pressure sensor from napa,autozone, and kragen and yet still had the light and warning message appearing. Measured my oil pressure and it was good within specs was really racking my brain and figured i would try a factory part. Went to audi and they looked it up by VIN and no more oil light and i drove that car for 3 years happily with no more oil light after that. So in my experince with oil pressure sensor get the factory part and forget it!
    Sep 02 2007
    Baltimore, MD
    They were factory replacements. It's like $22
    Registered Member Two Rings
    Aug 15 2009
    Goodrich, MI
    Did you replace both? Did you put the correct one in the correct spot? You will need to figure out which switch is supposed to open under which conditions, high pressure or low pressure, then check the continuity of the switches under idle and higher speed operation to find the faulty switch. So, for example, if the low pressure switch is normally open and closes when a certain pressure is reached, you check the continuity of that switch with the engine off and it should be non-continuous. Start the engine and run it at a fast idle and the switch should close and be coninuous. The opposite should hold true for the other switch. One of these is probably bad or the wrong switch and needs to be replaced. My guess is that initially your low pressure switch was bad and you replaed both switches with low pressure switches.
    Good luck,
    Bob
    Sep 02 2007
    Baltimore, MD
    I replaced the switch on the bottom of the motor behind the the oil cooler. It has a single plug connector.Don't know which one that is. Where is the location of the other sensor and what is the the state of each(n/o or n/c).
    Established Member Two Rings Nickle's Avatar
    Mar 05 2006
    2001 allroad 6spd
    Colorado Springs, CO
    ps I like rep
    I like rep too
    ditto
    Quote Originally Posted by Stampy View Post
    I like rep as well
    You're all getting rep... because the first step is admitting you have a problem.
    Oct 02 2007
    A6, A8, X5, etc
    Windy City
    we're all rep whores!
    Village Idiot!!!
    (\__/)
    (")_(")
    Established Member Two Rings slickesco's Avatar
    Apr 21 2010
    New York
    did u ever solve problem tony??
