Results 1 to 35 of 35
    Veteran Member Four Rings Coderedpl's Avatar
    Jul 27 2007
    2012 VW Golf .:R
    Valley Stream (L.I.), NY / NYC
    Stuck on VMR Vent Boost Gauge installation| Vacuum through end cap?
    Hello all,
    So today I received a replacement boost gauge from VMR and I got all excited and happy to get it installed no matter what time so after class i went straight to it.
    I figured out the electrical bits and got the gauge to light up, then i connected the vacuum tubing and routed it into the engine bay somehow.
    Now here comes the problems:
    From what VMR sent me I'm left with these:
    Filter i have an idea what to do, t-fitting, and that other piece???
    First: I made a little hole in the rubber thingy where i routed the vacuum tubing. Its being a big big pain to get back in.
    Now the biggest problem.
    I took off the rubber ending on this part
    Before i go on: What is the T-fitting needed for anyway?
    AND
    This is where the t-fitting provided to me doesnt fit in inside because its too damn small, and the rubber nipple doesnt fit the t-fitting. I managed to push the vacuum tubing inside the hole where the t-fitting was and get a readout on the gauge so I knew it worked.
    So what the crap do i do?
    Do i need the t-fitting on?
    If so, do i get a bigger one from like autozone, pepboys or something?
    My car is stock except for full exhaust + chip.
    Help!
    Current: 2012 Rising Blue 4Dr VW Golf [R 6spd
    Past: 2006 Black Audi S4 tip / 2006 Black A4 2.0T tip
    Senior Member Three Rings WayzataAudi's Avatar
    Feb 18 2009
    B7 A4
    Wayzata MN
    Re: Stuck on VMR Vent Boost Gauge installation
    i dont have one but from what i understand the T fitting keeps your gauge from buzzing or vibrating..no experience with this but im pretty sure you should have it on. there are DIY's on here if you search around a little bit im sure youll find one...GL!
    I <3 Whatever
    Veteran Member Four Rings kurupt_hawaiian's Avatar
    Oct 13 2007
    07 Audi A4 2.0T / 2010 VW GTI
    Kapolei, Originally Molokai
    I didn't put the T-fitting on...and I got no problems.
    Registered Member Two Rings Laxnwarrior's Avatar
    May 14 2009
    Boulder
    put the filter on your vac line anywhere in between where you connected it to the engine and your boost gauge, it will stop needle jumping, and stops buzzing.. its not necessary, but i don't think they'd include it just for fun..
    May 14 2009
    Boulder
    ill take a picture of how mine looks, even though i have a b5, the setup is still the same within the engine. and the grommet is supposed to go inside the hole that you cut from your car so that the vac line, and the electrical wires don't get all cut up over time..
    Senior Member Four Rings dblock110's Avatar
    Apr 11 2009
    usa
    this is a view from the third pic:
    edit:
    about the buzz filter IM NOT SURE SO dont cut the hose yet, just work on getting the connections right, then worry about that huge white they they gave u
    dont look at a pic from a b5 itll jus confuse you
    yes, u need a t fitting or else itll vibrate like crazy
    Senior Member Four Rings jimrobbington's Avatar
    Dec 03 2008
    07 Suzuki SV650
    Parker, Colorado
    The t fitting is only for 1.8t's, I think because you have to run a tube to the DV also to keep it functioning. Our DV's are electronic, so you don't need the T fitting. Hope this helps.
    05.5 A4 2.0T 6spd, REVO Stage 2, Vast Stage 3 clutch, VMR test pipe, custom non-res 2.5" Techtonics exhaust, Borla mufflers, wastegate adjustment, Treadstone TR6 FMIC, custom cold air intake, 034 catch can, BKR7E, 145 bar prv, DW300 LPFP, shiny manually cleaned valves, JHM Short Shifter, KW V1's, 19" V710's, drilled/slotted rotors, Akebono pads, Podi boost gauge, 640 Mod, 18% tint, baby seat.
    Dyno proven 221 whp/302 wtq on 91 oct!
    Jul 27 2007
    2012 VW Golf .:R
    So i just pretty much shove the vacuum tube inside where the cap was?
    I hope i dont need that cap cuz i just lost it when driving lol
    Apr 11 2009
    usa
    in my pic, the silicon tube goes OVER the hole u found, and OVER the t-fitting
    should be a very tight fit
    Dec 03 2008
    07 Suzuki SV650
    Parker, Colorado
    The cap you pull off, you don't need, but you should have a fitting to plug into that, then run the tube straight to your gauge. There should be no other connections in between.
    Dec 03 2008
    07 Suzuki SV650
    Parker, Colorado
    You shouldn't neet to cut the tube in the middle to use the anti-buzz thing. You should be able to use the anti-buzz thing to connect the tube to the silicone fitting.
    Dec 03 2008
    07 Suzuki SV650
    Parker, Colorado
    My gauge from PODI came with a t fitting, but specified that you only need it on a 1.8t engine
    Jul 27 2007
    2012 VW Golf .:R
    I cut the tube right after it went out from inside of the car and put that filter thing on. Maybe i didnt put it on tight enough or something else is wrong because it still buzzes.
    SO i need a silicone fitting? I can just get it from like autozone or something right?
    I guess they provided it incase i put it on a 1.8t.
    Dec 03 2008
    07 Suzuki SV650
    Parker, Colorado
    Maybe you should've gone with Podi, they were a lot more thorough with their package and instructions. Unless the tube fits right over the fitting coming out of the engine, you should have something that looks like this that attaches the tube to the engine.
    Senior Member Three Rings JohnUSMC's Avatar
    Jan 13 2009
    07 B7 A4 2.0T Quattro
    Dallas, TX
    I have the gague, and my T fitting looks different than yours... I installed mine like picture above, but the T fitting had a larger straight piece that the large silicon hose fit around, then the end cap went on the other end...
    The hose to the gauge went on the smaller perpendicular part of the T... Filter I placed in the middle somewhere, under my dash actually...
    The instructions were pretty straight forward, I am guessing you got the wrong gauge kit... I would call them and ask for some help.
    They are pretty helpful.
    Jul 27 2007
    2012 VW Golf .:R
    Yea I don't have that kind of thing. Guess i will visit strauss or pepboys or something. They will have it right?
    Maybe thats why it still buzzes because i dont have the right fitting.
    Dec 03 2008
    07 Suzuki SV650
    Parker, Colorado
    They might have something similar, but it seems to be a very specific piece that they may not carry. You might even have to buy a cheap gauge kit to get a piece like that out of it.
    Jul 27 2007
    2012 VW Golf .:R
    As long as I have find it somewhere. Gauge kit shouldnt be too much.
    Veteran Member Four Rings RedS-line's Avatar
    Mar 19 2008
    2006 A4 S-Line, 1990 944 S2
    i have the kit but did not need the t-fitting cuz the rubber piece they included that goes where you remove the rubber nipple had a fat end to connect to the car and a skinny end just like the end of a t fitting to slip on the vacuum tubing. you are missing a piece
    See my thread for my part out with FREE stuff!!!
    Jul 27 2007
    2012 VW Golf .:R
    Ok, guess I gotta get one of those silicone t-fittings. Currently i just stuck the vacuum tube into the hole where the end cap used to be, since I lost the cap somewhere lol
    Stage 2 Banner Advertiser Four Rings winston@podi.ca's Avatar
    Jun 11 2005
    Pods, gauges and more pods
    Vancouver, BC
    Unfortunately you won't be able to find that silicone t-fitting anywhere as I had them custom made for me for 2.0FSI customers.
    You can purchase it on the podi.ca website if you need it and it comes with the anti-buzz restrictor I also designed.
    If you have any questions about this please let me know.
    iPhone 4/4S Vapor aluminum case sale! $40 shipped! -> click here for details
    Dec 03 2008
    07 Suzuki SV650
    Parker, Colorado
    Should have gone with Podi in the first place. You get a free T shirt too!
    Jul 27 2007
    2012 VW Golf .:R
    got the VMR boost gauge used for cheap so yea
    Dec 03 2008
    07 Suzuki SV650
    Parker, Colorado
    Cheap is good. But that's how you run into these issues with missing pieces, and missing instructions. Good luck though. Seriously, I would just buy the fitting you need from Winston@podi
    Jul 27 2007
    2012 VW Golf .:R
    You know i was just thinking. There is no real need for a T-Fitting the way I see it and from what has been said.
    I went out to strauss and bought a pack of 3 of vacuum end caps (3/8th in size). They are a tight fit but hold under boost and then an idea hit me.
    Why not make a small enough hole and feed the vacuum tube through there??
    How does that sound?
    Dec 03 2008
    07 Suzuki SV650
    Parker, Colorado
    Re: Stuck on VMR Vent Boost Gauge installation| Vacuum through end cap?
    What might work as well, you might be able to find in the garden section of Home Depot. they have all kinds of connections for little hoses for like drip systems. Little fitting like this crappy mspaint drawing(im at work)
    Jul 27 2007
    2012 VW Golf .:R
    That tube you show is just regular vacuum tubing with two ends open right?
    The thing is though. The opening where the cap was and the opening of the vacuum tubing are two completely different sizes which is what worries me. If i get a big tubing and fitting then the vacuum tubing wont be able to go on :/
    Apr 11 2009
    usa
    did u not see my picture?
    Jul 27 2007
    2012 VW Golf .:R
    Quote Originally Posted by dblock110 View Post
    Yea except the T-fitting would need to have the bottom part much smaller than the other two for it to work since my vacuum tubing is not that bigg.
    Senior Member Four Rings staticuxo's Avatar
    Sep 16 2008
    i'm still confused what you're saying, ahah.
    dblock's drawing is exactly how it should be
    '11 S4 - PHANTOM | PRESTIGE | S-TRONIC | SPORTS DIFF | B&O | AWE NON-RES | STāSIS V2 TUNE | ROC-EURO INTAKE | H&R COILOVERS | VOSSEN CV2 20x10 | AG M310 19x9.5 | S-TRONIC KNOB | YAKIMA WHISPBAR | THULE 517 |
    PREVIOUS:
    B8 S5 6MT | B7 S4 6MT | B7 A4 6MT
    Senior Member Three Rings ItsThat2.0T's Avatar
    Oct 28 2007
    Rhode Island
    If that is all you are left with and the gauge works:
    Splice the hose where you fed it into the engine from the firewall. Put one end onto each side of the filter. I have my filter sitting next to my ECU. Make sure the arrow is facing the back of the car. Other than that looks all good to me.
    Ghost edit: You don't need the t-fitting. Just the long hose, the white fitting that goes into the intake manifold, filter.
    '07 Quattro A4 Brilliant Black
    | Premium Package | Carbonio CAI | 35% Tint | Trunk Lid Spoiler | REVO | VMR Vent Boost Gauge |
    2 Pedals.
    Veteran Member Four Rings DoThisMyWay's Avatar
    Aug 24 2004
    B6A4, B7A4
    Sacramento, CA
    If you're in a bind, you could go to Home Depot and get these parts.
    No disrespect to Podi.ca as I am currently using their pod but this was my solution before they had their 2.0T fitting solution or gauge packages.
    2006|A4 Avant 2.0T Quattro S-line
    2005|A4 3.0 Quattro UltraSport
    Jun 11 2005
    Vancouver, BC
    There is no disrespect as there are many ways to solve the problem.
    The silicone t-fitting was designed to provide an elegant plug and play solution.
    Jun 14 2005
    Irvine, CA
    Hi Peter, I looked into this a bit more for you, unfortunately, when you bought the gauge used, the previous owner did not include many of the items that we usually include with the vent kit. It also sounded like the gauge you received had some issues, we were sympathetic to your situation and replaced the gauge and threw in some of the hardware that you needed.
    Unfortunately, for our universal gauge only kits, we do not include any car specific hardware, which would come with the whole vent kit. For your B7, you would need a reducer that would mate the vacuum line to the bigger outlet. Go ahead and shoot me a PM and we can figure out what else you need to get it up and running.
    JB @ VMR | Wheels
    (714) 442-7916 ext. 108 | jb@velocitymotoring.com
    www.velocitymotoring.com | | | Blog
    Jul 27 2007
    2012 VW Golf .:R
    Quote Originally Posted by VMRWheels View Post
    I greatly appreciate it. It came as a shock to me that you guys let me use the hardware and it also made my life that much easier. The vacuum line is the only one i need to figure out and I have a few ideas in mind so no worries. I will be sending the other one back as soon as i can.
    Thanks a lot VMR & Steve specifically!
    Great customer service!
