Results 1 to 16 of 16
Thread: Frozen E-brake
    Established Member Two Rings TJR178's Avatar
    Mar 27 2008
    Erie, PA
    Frozen E-brake
    Hi all,
    So I found out that my e-brake is partially frozen this evening while pulling the car in to the garage after washing it. Clutch was in and the car came to a somewhat abrupt stop. It still rolls and drives alright, but I notice that the e-brake lever won't engage until it's 50% pulled.
    Thoughts on fixing this problem?
    Account Terminated Three Rings lotusgardener's Avatar
    Dec 24 2006
    1997 Audi A4
    NW & NE
    Re: Frozen E-brake
    Well, I would start by figuring out which one is dragging and inspect everything. Lubricate if its not completely f-ed.
    Established Member Two Rings esee135's Avatar
    Jun 21 2008
    Re: Frozen E-brake
    Pull the rear wheels and start playing with the rear calipers. The e-brake is a cable pulling a lever on the caliper.
    Mar 27 2008
    Erie, PA
    Re: Frozen E-brake
    I'll pull the rear wheels today and check it out. Thanks guys. I'll report what I find.
    Veteran Member Four Rings terraflata's Avatar
    Sep 14 2008
    '97 Audi 1.8TQM '97 Acura Integra 2002 Dodge Durango
    Chambly, Quebec, Canada
    Items for Sale
    Re: Frozen E-brake
    When my E-brake didnt work, it turned out it was the calipers that were seized.
    Veteran Member Three Rings discontained's Avatar
    Jul 09 2007
    '01 A4 1.8t
    GA
    Re: Frozen E-brake
    water may have got into the handbrake cables causing corrosion & seizures overtime. May need to replace, but I would inspect the rear calipers first.
    For Sale $3,500 -'99 Audi A4 1.8T Quattro 5sp
    -2001.5 Audi A4 1.8T Quattromatic - BT .50 trizzle -RIP
    Mar 27 2008
    Erie, PA
    Re: Frozen E-brake
    Ok, so I inspected the e-brake system and found that my left-rear caliper is the culprit and not the cable itself (from what I can tell).
    I noticed that the lever that the cable attaches to on the caliper wasn't releasing completly. I had to manually release it with my hand. I had my wife engage and disingage the e-brake and each time I had to manually release it on the caliper. I sprayed some WD-40 where the point of contact is, but it didn't loosen anything.
    I'm guessing the internal components in the caliper is the issue now. Thoughts on fixing this? Can I take that bolt out to see if there is corrosion?
    Thanks for the help so far.
    Senior Member Two Rings rdguy's Avatar
    Oct 12 2006
    98 Audi A4 1.8T Quattro & 87 M
    Mississauga
    Re: Frozen E-brake
    keep moving the lever back and forth and spray with WD40 or Liquid Wrench until it loosens up. SHort term fix only but it will buy you some time. THe lever should spring back to the white stop when working correctly. I posted some pitures about a month ago of the caliper totally taken apart if you search for it. Exploded calier view.
    Jun 30 2008
    Erie, Pennsylvania
    Re: Frozen E-brake
    What actually freezes up on the caliper? Is it internal?
    My brother's A4 is doing the same thing - driver side rear isn't releasing quite all the way when the E-brake is let go. Requires pushing it the rest of the way with your hand. I pulled the e-brake one day and he got all mad because he had to reach around and release it manually - my bad.
    Oct 10 2008
    orland park
    Re: Frozen E-brake
    How do your rear brake pads look?
    Veteran Member Four Rings Mantvis's Avatar
    Jun 05 2009
    mk1 Audi TT 180hp, mk1 Audi TT 225hp, mk4 VW GTI
    Chicago, Naperville
    Re: Frozen E-brake
    so dont use the e brake... simple...
    If you don't need both hands on the wheel, then you're NOT driving.
    Mar 27 2008
    Erie, PA
    Re: Frozen E-brake
    I'll check out the exploded caliper, thanks for the tip rdguy. I'm hoping it's something simple in there.
    I'm guessing there's something internally of the caliper that is freezing up walky.
    Brake pads are fine seeknstrike.
    I live in NW PA, which = multiple hills, so sooner or later, I'll have to use the e-brake again Mantvis.
    Oct 12 2006
    Mississauga
    Re: Frozen E-brake
    The lever on the outside of the caliper connects to a spring pack on the inside of the caliper. Weak spring perhaps? I replaced my caliper and solved it that way but had to take the old caliper apart to see for myself how it looked. I did notice a locking pin that the spring pack would insert into but the snap ring holds it in place so could not determine what the failure would be exactly? Looks like the brake fluid would migrate to that area as well so unless dirt is trapped there that may be the problem? I still think a weak spring may be the issue.
    Mar 27 2008
    Erie, PA
    Re: Frozen E-brake
    Looks like I have a Saturday project coming up
    Thanks guys
    Jun 21 2008
    Re: Frozen E-brake
    when my calipers froze, it ended up that the caliper pins were seized inside the pin bore. You'll get uneven wear on the inner/outer pads if the pins are seized (pins are stuck, but the caliper piston can still move the pad associated with the piston.
    BTW, I couldn't even hammer the pins out, they were so seized that I feel sorry for the sucker who gets my rebuilt rear brake cores.
    Mar 27 2008
    Erie, PA
    Re: Frozen E-brake
    ^Yeesh^
    I'm hoping I won't run into that, but I have a feeling I may.
    Thanks for the note man
