Results 1 to 38 of 38
    Jun 17 2009
    2018 Allroad Premium plus; 2012 BMW K1300S; 2007 Nissan Titan
    Oakton, VA
    Adding backup sensors
    I did a quick search and nothing came up.
    Anyone add backup sensors to their car? I am not talking about the camera, just the sonar sensors. I saw (I can't remember where) that Bosch had a system available for under $300.
    If you did do it how hard was the install?
    thanks
    Oct 27 2009
    '15 MBZ E400 Cab/'13 Subaru Outback 3.6R
    Miami, FL | Boone, NC
    Re: Adding backup sensors
    Quote Originally Posted by buckeye96 View Post
    thanks
    I saw them as a retrofit kit.....I can't imagine installing them... Cutting holes in bumpers (they are not already there, right?) running wires, etc.
    Veteran Member Four Rings ItsDubC's Avatar
    May 26 2009
    Houston, TX
    I'd say you would definitely need to buy the bumper that has the holes already in it for the backup sensors or whatever. Your dealer should be able to order it. As for the wiring, I have no idea how difficult that'd be.
    OEM+ '09 Meteor Gray A4 2.0T Tip Quattro Prem+ Sport Saloon
    All-Weather Mats • Hόper Optik Stark 30 • APR Stage I • A5 S-line Y-spokes • Hankook Ventus V12 evos • S-line Stone Guards • VAG-COM'd
    Bilstein PSS10s • Eurocode IC Pipe • Avant Dual Exhaust • StopTech Pads • Lamin-X'd • Smoked Ambers • Blesk 5000ks • 034 Trans Mount
    Jun 17 2009
    Oakton, VA
    Buying a bumper with the holes already cut would make it a lot easier. But the wiring would have to be a bitch. That's why I was curious if anyone had done this. I might have a winter project.
    Senior Member Three Rings dieatomic's Avatar
    Sep 23 2009
    2009 A4
    Bergenfield, NJ
    kufatec.com has a retrofit i believe
    http://kufatec.com/index.php?main_pa...ex&cPath=6_149
    2009 A4 2.0T Premium + with Nav /APR S3 K04 Turbo/ AWE FMIC /APR full turbo back quad exhaust with diamond black tips/ S-line supension / 35% Tint / HID Fogs / Euro S4 LED Tail Lights retrofit / CF Trim / OSIR CF / Lusch CF / Rotora 380mm 8pot Front BBK and upgraded rear rotors / R8 V10 Steering Wheel with MA Carbon center and paddles
    Veteran Member Four Rings Ryan_T's Avatar
    May 11 2009
    09 A4 2.0T
    T.O - Canada
    The reason you didn't find a lot of results is because the cost is too prohibitive to justify. The B8 isn't that big of a car, I say just get to know your vehicle well, and save your money.
    Get one of these, instead:
    If you need them on the road, just get out of the car, and place it before you park.
    Ryan - flickr
    Senior Member Two Rings gtrab's Avatar
    Mar 02 2009
    Audi A4 B8, Audi Q5 2013
    El Salvador
    I got my OEM (Audi original) retrofit sensors last week
    The package comes complete with instructions and all required parts
    I talked to my local Audi representative today and they will make the installation, including drilling the holes and everything
    Let me post a pic and OEM part number for you... BRB
    NOW: Audi Q5 2.0T Ibis White
    19" 5-Y spoke wheels 255/50 tires | Exhaust tips | Special lower body paint work | VAG-COM customizations
    EX: Audi A4 B8 CVT deep ocean blue
    19" 5-Y spoke wheels & 255/35 Dunlop SpeedMaxx tires | S4 grille & fogs trims | S-Line side skirts & exhaust tips | "Audi collection" items | Custom paintwork | CTM ECU reprog | VAG-COM
    May 11 2009
    09 A4 2.0T
    T.O - Canada
    So they'll be drilling holes on your existing bumper? Scary. Let us know how it went and how much. I know I said the opposite earlier, but if it turned out nice and affordable...why not.
    Ryan - flickr
    Veteran Member Four Rings DavidB8's Avatar
    Nov 06 2009
    Oakville, ON, Canada
    If they have kept the same premise through out the years I don't think it would be a big deal. I added the emergency cell phone antennas to my B5 which required removing the bumper which only took 4 bolts from inside the trunk. Getting the wiring in and done was easy. Audi left the body plugs in all the right places and harnesses were in the car where needed to just plug it all in. It took a bit of panel removing in the trunk to get to the in car harness but that was it. The panels were not hard to get out and in. May not be the same for this but until you get the kit it's hard to say.
    Mar 02 2009
    El Salvador
    OK guys here's the pic I promissed
    BACK UP (REVERSE) PARKING AID SENSORS FORR AUDI A4 B8
    - Teilenummer (part number) was taken from ETKA
    - Ordered from ibexparts (dot com)
    - The whole kit (OEM Audi) was around 300 EUR plus S&H
    My Audi dealer has installed some of these kits before, this is not new for them, and I have seen them retrofitted on a Q7 and it looked OEM,
    that's why I decided to go for the original AUDI option instead of third-party
    You can see the OEM part number in the box
    PS: the other box is for another gadget I just got
    Jun 17 2009
    Oakton, VA
    How much did the whole thing run you? The hardware and the install?
    thanks
    Mar 02 2009
    El Salvador
    thanks
    around 500 washingtons
    Oct 27 2009
    Quote Originally Posted by gtrab View Post
    That's it???
    That included the kit and the dealer installing it for you?
    Did they install the button inside the car that activates/deactivates it.
    Mar 02 2009
    El Salvador
    dealer ran another 300 for installation:
    the installation was perfect and simple
    holes look exact, looks pre-installed
    but the system is not working at all:
    when I shift to reverse it starts beeping all the time, with or without obstacles, and the audi authorized dealer has no idea
    they have double checked all cabes/connections and everything looks OK, but the beep is annoying and not increasing as you approach an object
    help appreciated
    Sep 13 2009
    2010 A4 2.0T
    Mississauga, Ontario
    help appreciated
    throw the keys at the dealer! They installed it, and charged you plenty for it too!
    Mar 02 2009
    El Salvador
    of course I ain't paying a dime untill they solve it out
    somebody else has experience with this retrofit kit from Audi ???
    Dec 14 2009
    San Antonio, TX
    Anybody have any experience with this, particularly on a US spec A4?? It looks like it converts the LCD screen to accommodate any kind of video. Instead of sensors, I was looking to add a backup camera.
    I do not have MMI (dash and gear shift on the center console look exactly like what's in the photo, but on the left side). I've emailed the company that sells it to ask for installation details, etc., but haven't heard back yet.
    Thanks.
    http://www.xcarlink.co.uk/product.ph...3&cat=0&page=1
    Oct 27 2009
    Quote Originally Posted by Snuffy View Post
    Thanks.
    http://www.audizine.com/forum/showth...light=xcarlink
    Dec 14 2009
    San Antonio, TX
    Thanks.
    Registered Member Two Rings
    Jun 30 2008
    EU
    You may want to check this page:
    Notes on retrofitting parking sensors/Audi Parking System in Audi A4/A5/A6 etc.
    http://a6retrofit.tripod.com/article...ingsystem.html
    My A4/A5 VAG COM codes list:
    http://a6retrofit.tripod.com/articles/a5vagcodes.html
    Friends Audi retrofit site:
    Jun 22 2010
    Sydney,Australia
    gtrab: did you get your reverse sensors working in the end? Also do the retrofit audi oem reverse sensors (if installed by the dealer, i.e. drilling etc) stick out of the bumper or is it the same as factory fitted i.e. doesn't stick out?
    Thanks,
    K.
    Mar 02 2009
    El Salvador
    Quote Originally Posted by k3nnis View Post
    Thanks,
    K.
    Yes I got it fixed, it was very simple in the end: the sensors were not installed in the proper order (murphy's law)
    They work a treat
    And yes they protrude slightly, not that noticeable, but they do
    Jun 22 2010
    Sydney,Australia
    Do you have pics of your bumper? Would like to see how much they protude? Thanks :) So the dealers drilled the holes?
    Mar 02 2009
    El Salvador
    Bumpers already come with marks for the holes, I could've done it, but I preferred to leave it to the dealer because of the wiring
    (In the end I finished working side by side with the workshop guy due to the sensors order stuff and because I couldn't resist :D - check my DIY thread I'm kind of DIY-crazy :p)
    No I don't have pics
    Send me a PM tomorrow and I'll take a pic for you
    Nov 06 2009
    gtrab: did you get your reverse sensors working in the end? Also do the retrofit audi oem reverse sensors (if installed by the dealer, i.e. drilling etc) stick out of the bumper or is it the same as factory fitted i.e. doesn't stick out?.
    Using the factory sensors with the VW mounting hardware mine came out flush. The kit that was installed in this thread are not the OEM sensors that come from factory.
    They work a treat
    How do you install the sensors in the wrong order? That can't of been easy.
    Reaching Me:Please don't ask me questions on the forum or send me private messages as it may be a while before I respond.
    If you need something email me directly at David@audienthusiasts.com I don't frequent this forum very often.
    www.audienthusiasts.com
    Mar 02 2009
    El Salvador
    Quote Originally Posted by DavidB8 View Post
    The ones I used were Audi OEM, check the pic @ post 10, the little box to the right side
    the guys from the dealer...
    LOL Murphy rulez :D
    Jun 22 2010
    Sydney,Australia
    Ok will PM you tomorrow to get pics :)
    DavidB8: You mean Audi has another kit which comes from the factory? i.e. not the Audi OEM pic that was posted by gtrab?
    Nov 06 2009
    We actually had an entire discussion on this before. The kit you bought, albeit an Audi product is not the same as the factory installed parts. The kits I've seen for sale in Europe are actually made by a company called Cobra. You can see a lot of them on eBay UK for some reason.
    Audi isn't known for it's discounts so work this one out:
    Controller :8K0 919 475 H - $134.64
    Parking sensors: 4H0 919 275 A GRU - $70.20 x 4 280.80
    Buzzer: $10.68
    Add the harnesses say..$100
    Mounting hardware.. About $40.
    I bought mine from Europe so they where cheaper than these but this is discount pricing from genuinevw. For someone wanting to do this retro though you could gets parts for half of that off of ebay though.
    This is a factory retro fitted sensor, does yours look like this?:
    Jun 22 2010
    Sydney,Australia
    I'm thinking to take mine to the dealer to do it but not sure what they use? cobra or the audi or something else? I'm going to check with them.
    Veteran Member Four Rings B_Boy's Avatar
    Nov 24 2008
    2014 Infiniti Q50S, 2016 Audi A3
    Items for Sale
    can this rear sensors be added with the rear view camera on a symphony system?
    b_boy
    '15 Q5 3.0T P+ Tech, Sport, S-line, B-O, HGB
    LED Color Match Fog/Int/Ext Lights, VAG-COM, underseat storage bins, Blacked-OUT Valance & W/S Trim, SQ Black Grille
    Tint: 15% F/R, 50% Windshield, Alum Pedals/Shifters, Remote Close hatch, KW HAS, 22x10.5 ET VFS1
    Coming soon: GIAC/APR?
    Jan 27 2011
    Vancouver
    Buzzer: $10.68
    By getting your listed parts, I can have rear backup sensor like yours in photo?
    Nov 06 2009
    Quote Originally Posted by B_Boy View Post
    I never say never, but realistically no. You need an MMI high system for the factory rear view camera.
    Quote Originally Posted by hazuremon View Post
    Well... Yes and no, there is more involved than just that. Your car colour makes a difference. If you have a black car you can get them already painted. If anything else you have to order primer and paint them yourself (which is pretty easy).
    You will need the proper part numbers for the retainers that hold the sensors, you will not get those from Audi as they are VW parts, you also need the sealing rings and tape for the holders. Why don't you wait until you get your car. I am close I hope to getting my fronts working. When that happens I will put a DIY up on my website with all the part numbers and instructions for mounting and painting. Not only that, it means I will have my rear module for sale.
    Jan 27 2011
    Vancouver
    Thanks David. Great information as always. I will probably wait a bit longer while I am waiting for my car and your rear module.. :P
    Veteran Member Three Rings Kandiru's Avatar
    Mar 28 2010
    Isolation, OH
    Quote Originally Posted by ItsDubC View Post
    Thank God my mum is Bulgarian so i can understand these two brave Slovaks:
    No need for new bumper if you are good enough to fly and maintain an RTF RC Helicopter
    like the one in the trunk, or repair stuff in your home.
    2012 S4 6MT Monsoon/Silver-Alc./Diff+B&O+airbags, Mods:R8 V10 St.Wheel, JHM Shifter, Summer: S5 Double Spokes 8T0601025H - Bridgestone RE-11 245/35R19 (ET32), Winter: Hollow Spokes 8K00714994EE - Dunlop 255/35R19 with BFI-5mm-Fr+10mm-Rear & RAD 35mm bolts/locks, Customcargrills upper/lower/L-fog radiators protection, Oil Dipstick, RS4 pedals x4 & Autovation Heel Guard, Seat Bins, Trunk Triangle, Laminx fronts+fogs+edges+bumper, Windesa Sonniboy 8K Curtains
    Senior Member Three Rings EuroEclipse's Avatar
    Dec 30 2009
    2012 Evolution X GSR / 2012 Volkswagen GTI
    Germany/Colorado Currently
    I actually was talking to my Audi dealer about this. They said it takes 2 hours to do and it's about 450 euro total for part and install... Thinking about doing it, but then again I don't back into spaces.
    Mar 02 2009
    El Salvador
    This was one of the first mods I did to my A4. Very useful indeed.
    Jul 12 2009
    San Francisco
    I have the same rear parking sensors installed recently in the car. I now hate the sound of the buzzer.. its too fucking annoying, too loud, and beeps constantly when i'm driving out of garage, due to side sensors.
    It's ok for when really parking on the street - it beeps ok - and its loud. It's part #, kit made by cobra. How do I make this thing less annoying? Less loud, and stop reacting to side obstacles, like getting out from narrow garage?
    Yes, I did drill 4 20mm holes in the bumper to fit rear sensors.
    B6/B7 owners: Buy my OEM suspension for $50 4 springs + 4 Struts
    Jul 16 2008
    Finland
    You can't adjust the volume on the Cobra kit. Find the buzzer and cover it with something to silence it a little.
    BTW, anyone have the part numbers for the VW sensor brackets? David? I want to add the OEM optical parking system but the Kufatec kit is a tad too expensive.
