Results 1 to 9 of 9
    Active Member Two Rings a42002's Avatar
    Nov 09 2009
    Boca Raton, FL
    Angry How do you remove the immobilizer from an 2002 b6 remote fob??
    Hello, I just purchased a brand new fob "shell" (no electronics inside) for my B6 since mine is in poor condition. Of course I need to open the old fob, remove the circuit board and put it on the new shell and then I have to do the same with the immobilizer, right?
    As far as I know once the fob is opened in two pices , the immo is located on the side with the audi logo and the metal key.
    How the hell do you take that piece apart to get to the immo itself???
    Thanks for your suggestions!!
    Veteran Member Four Rings Dan1969's Avatar
    Aug 16 2009
    08 Silverado 2500HD 6.6 Diesel
    In the OK Corral
    Re: How do you remove the immobilizer from an 2002 b6 remote fob??
    Find the B6 to B7 FOB mod, the instructions on how to take the immobilizer are there. The key blade is where it is, so you have to move the blade from your old shell to your new one.
    17 Jetta S 1.4T, 08 Silvy LTZ 6.6T CCSB
    Previous: 1997 VW Jetta, 2004 Audi A4 3.0Q6MT, 15 Audi A3 2.0T Q DSG
    Feb 17 2004
    Stg 3 '04 A6 2.7T, '14 S4 Prestige S-Tronic
    Sterling, VA
    This should be roughly the same setup as the B6 remote: http://forums.vwvortex.com/zerothread?id=2293184
    Brett - Moderator
    Issue?: email me.
    _____________________
    Stage 3 2004 A6 2.7T 6M
    Aug 26 2005
    Very carefully. The transponder capsule is in the part of the Fob that is glued together. Once the case is separated, then the glass capsule must be gently fussed out without breaking it.
    Nov 09 2009
    Boca Raton, FL
    Quote Originally Posted by Daft View Post
    thanks! but I already read that thread it is a bit different because my fob doesnt have a screw like volkswagens!
    Nov 09 2009
    Boca Raton, FL
    Oh so it is glued! but how can I take it apart it is impossible what kind of glue do they use?
    Feb 19 2007
    2001 BMW 540i M-sport
    Charleston, SC
    Heat the immobilizer capsule with a heatgun. Worked like an absolute charm for me. the capsule just slid right out
    -Sami-
    Veteran Member Four Rings 3.0L AUDI A4's Avatar
    2004 A4
    Central Jersey
    Some B6 Audi keys have a screw as well. My 05 did while my 04 didn't.
    To get the immo chip out, use a small pointed driver and pick away at the glue on the side of the immo chip. I never had a problem with the ten or so immo chips I installed into B7 keys. Some are glued while some are just sitting of a little piece of foam or rubber... weird technique those Germans... lol
    post a pic if you could I will tell you if it looks just like the way I took my chips out. Don't heat it too hot with a heat gun, you may ruin the chip..
    Senior Member Two Rings Juggern@ut's Avatar
    Aug 10 2009
    80 Corolla
    Dirrty Jerzee
    Try THIS
    it puts the lotion in the basket...
