Results 1 to 11 of 11
    Jan 16 2008
    bosnia and herzegovina
    Cold weather=misfire
    Hi to all,
    I would like to ask why is the cold weather a reason why my car has a misfire problem and that is only during the cold mornings.
    What is the cold weather a reason for it and what could it be connected to?
    Veteran Member Four Rings adub's Avatar
    Nov 20 2008
    spiders
    Orange County
    Re: Cold weather=misfire
    Probably, I had that problem when I took my car to Utah during the winter.
    -Andrew
    Veteran Member Three Rings MisterQuattro's Avatar
    Nov 05 2009
    Long Island, New York
    cold weather ruins everything I hate it :(
    but I love our cars in the snow :)
    2011 Audi S5 - Fully Loaded -
    [RS5 Honeycomb Grill][AWE Track Exhaust][HID Fogs][LED License Plate Bulbs][Vagged]
    2006 A4 2.0T Stage 2+ ~ SOLD!
    V8 Club
    RIZZLES
    Nov 05 2009
    GA
    having the same problem here..
    Veteran Member Four Rings Rotond0000's Avatar
    Apr 30 2007
    Rhode Island
    Items for Sale
    same
    - 2011 A4 2.0T Quattro - 6 Speed Manual - Black/Black - ST Coilovers - 20% Tint - Smoked Tails - Smoked Corners - 6000K Headlights And Fogs - Full LED Interior Lighting Conversion - Custom LED Headlight Strips - RS4 Grill W/ Blacked Out Euro Plate -
    Veteran Member Three Rings A4B7Quattro's Avatar
    Jun 21 2009
    2006 Audi A4 2.0T
    Stafford, Virginia
    Well starting cars in the winter is harder for any car not just ours, but ours take longer then most cars even when its warm out so its double hard i guess lol
    Nov 05 2009
    GA
    why is that??
    Nov 05 2009
    GA
    and will dealers do anything about it under warranty if we keep bitchin about it?
    Senior Member Three Rings killerb7's Avatar
    Apr 27 2009
    05.5 A4 2.0T 6MT
    Orange County, CA
    i dont think dealers can change the weather
    Veteran Member Three Rings audidrver's Avatar
    Mar 31 2007
    CA
    does the problem continue after its warmed up?
    ooooO..................Ooooo
    ...............oooo
    .........o.............o
    Jan 16 2008
    I have a tread started about my last problem with the car.
    After cold mornings, I have this car shaking which started maybe 2-3 weeks ago but I need to admit now it is getting better even if I have not found what is the problem.
    When it is cold weather, my CEL is flashing in the beginning and after that it stay on the board and I can feel this shaking whole the time, even if the car is warmed up.
    Vag Com was getting the codes for cylinder 2 and after I have changed the spark plugs and coil 2 and deleted the codes, they came back again saying it is the cylinder 2.
    I have changed PCV valve and also DV few months ago so I dont believe they could be wrong but I am sure there is some other leak because I can hear it from the engine when I put the car under WOT.
    I did not check for leaks with the leak gauge because I dont have it but I will need to do so...
    more about my problem is here:
    http://www.audizine.com/forum/showthread.php?t=320558
    Thanks
