Results 1 to 13 of 13
    Veteran Member Four Rings Euromike's Avatar
    Oct 03 2008
    what garage?
    Pittsburgh
    Car shakes 2600rpm+ in 3rd gear only?
    Weirdest problem, my car will shake pretty violently ONLY in 3rd gear and ONLY past 2600rpm. Everyone i talk to is totally stumped. Anyone got any ideas?
    01' B5 S4 Pearl White Stage 3+
    01' B5 S4 Laser Red [For Sale - ish.]
    16' Silverado HD
    12' Tornado Red GTI DSG
    99' Laser Red B5 A4 QM SOLD
    98' Santorin Blue B5 A4 QM SOLD
    Veteran Member Four Rings NeedingAnAudi's Avatar
    Mar 16 2009
    99.5 A4 4.2QM, 01 Nogaro S4 Avant
    Lombard, IL
    Re: Car shakes 2600rpm+ in 3rd gear only?
    You should swap for a b6 3rd gear. Heard you go into lightspeed with those
    Honestly I'm stumped too, just wanted to put a little humor in, did it work?
    Brilliant Black 99.5 A4 Project V8
    Nogaro Blue 01.5 S4
    Alex
    Oct 03 2008
    what garage?
    Pittsburgh
    hahaha yeah, you got me all excited that my post got a reply though! atleast i got a chuckle out of it.
    this problom is driving me nuts. Any way it could be a bent wheel? it feels like its coming from the right rear of the car, ill have to swap out that tire and see if it makes a difference tomorrow. Its just unlikely, wheel bends seem to shake more constantly than a certian RPM in a certian gear
    16' Silverado HD
    Mar 16 2009
    Lombard, IL
    Quote Originally Posted by SantorianA4 View Post
    Sweet.
    I doubt its a bent wheel. Any more info? I'm no expert but at 80 mph on my dad's vette the car would shake like crazy, turned out to be a bad u-joint on the rear axle shaft. Sounds reasonable enough to check to me
    Nogaro Blue 01.5 S4
    Alex
    Active Member Four Rings onemoremile's Avatar
    Mar 09 2004
    99.5 A4 Avant, 01 allroad
    nw michigan.
    If it were a bent wheel it would do that at the same speed regardless of gear.
    Jim
    I Do Werk.
    Veteran Member Four Rings 99blueb5's Avatar
    Mar 10 2008
    01 S4, 99 A4
    Bellevue, WA
    i would also check out any rubbing in your exhaust system, since your under load the car will squat down in the rear showing vibration through the motor to the body, also check out your balance on your tires, i know some of my wheels weights fell off and it would vibrate at only certain speeds but went away past 40, also check out your tranny mounts and engine mounts for excessive movement
    99 A4 1.8TQM:
    APR Stage 3 GT28rs kit, CM FX400 6puck, 3" downpipe, Nuespeed catback,Nuespeed short shift, Cxracing fmic, Forge007 DV, H&R coilovers, APR snub mount, gasket ported head, VDO guages, e codes, 6k's, Fiberimages CF hood/trunk, A8 BBK, IE Rods
    00 B5 S4
    Vast stage 3, Rs4 airbox, ko4's,borla cat back, neuspeed sways, statis coils, jhm fmic, SSAC Dp's
    Veteran Member Three Rings calvin1.8t's Avatar
    Oct 21 2008
    Mk3 vr6
    New Jersey
    i would check the mounts man. that seems like the best bet if not then throw on your shrolock holmes hat and do some serious investigating
    Veteran Member Three Rings revbjeff's Avatar
    Apr 22 2008
    00 2.8QM A4
    Leavenworth, KS
    Maybe it's control arms?
    Oct 03 2008
    what garage?
    Pittsburgh
    Thanks guys. As for mounts, the car is getting an APR snub mount next week when it goes in for a timing belt. I was going to go out today and rotate the tires and see if it changes anything about the shake. I'm hoping it's not control arms! That's some serious extra cash I'm hoping not to spend right now! Haha I'll keep you guys updates. Thanks for the info
    16' Silverado HD
    Oct 03 2008
    what garage?
    Pittsburgh
    Question, if it was control arms, how would I know? Just process of elimination after I ruled out everything else? Or is there somthing I can check?
    16' Silverado HD
    Stage 3 Forum Advertiser Four Rings ECS Tuning-Audi's Avatar
    Oct 02 2006
    Wadsworth,OH
    As stated above, this is a common problem on cars with rear driveshafts: Bad U-Joint
    sales@ecstuning.com | customerservice@ecstuning.com
    Customer Service Hours: 8:00AM to 8:00PM EST
    Sales Team Hours: 8:00AM to 11:00PM EST
    800.924.5172
    OEM Audi Part Number Search with Pricing<--- Click me!
    Oct 03 2008
    what garage?
    Pittsburgh
    Rotates tire to the front, shake got 99% better, i feel it the slightest bit, but i think because the front is made to turn, it absorbs the shake, you know? im having the wheel spin balanced tomorrow. Thanks for the help
    16' Silverado HD
    Jun 14 2005
    Anaheim, CA
    were the lugbolts on tight when you took off your wheels? sometimes they work themselves loose after a while and that can cause vibrations.
    Tracy @ VMR Wheels - Shoot me a PM for a wheel or wheel & tire quote!
    Tracy@Velocitymotoring.com | 714.442.7916 Ext 110 | www.velocitymotoring.com| Instagram | | | Blog
