Results 1 to 24 of 24
    Oct 26 2009
    2004 A4 1.8T Quattro
    Queens NY
    My car is shaking Really bad.... Help
    hey Guys im new to this website.... I just got my 04 1.8t and out of nowhere the car has started to shake real bad and my check engine light is on even if the car is not running the car is shaking extremly....and the gears are not falling in right... its reving alot higher..... I was wondering if anyone has an idea of what this can be.
    ill apreciate it.
    Senior Member Three Rings falconcrest32's Avatar
    May 19 2009
    2008 A4 S-Line Quattro 6MT
    MD/NoVa
    Items for Sale
    Re: My car is shaking Really bad.... Help
    Blown coilpacks.
    dont fret, its an easy fix
    2008 A4 2.0T Quattro S-Line 6-speed *Phantom Black*
    [SIZE=1]| Kohlefaser Luft-Technik Intake | VagCom | Ti Grille | Michelin Pilot Sport A/S 3 | fly300kts Headlights | Pioneer AVIC-8000NEX | Huper Optik Tint | BFI Catch Can | RS4 Front Brakes | GFB DV+ | 034 Snub Mount | JHM TP & DP-Y | Fast Intentions B6 S4 Catback | S4 Recaros Black/Black Alcantara | B8.5 FBSW |
    Veteran Member Three Rings festerfm's Avatar
    Feb 07 2008
    just the a4
    northeast pa
    pat it on the dash and tell your car "it's only an m3.. there's no need to be scared"..
    possible coil pack?
    <--------yes, i used my audi to drag my deer out of the woods. it was heavy, i was cold, car had heat, much less work, and frankly, it was far. the deer was big, i am not, just seemed like the right thing to do. if it werent for the apr2+ i may not have been able to pull that monstrosity out of the woods w/out a helicoptor. i cant afford a helicoptor, i have a hard enough time affording my audi. all this being said, yes. that is an apr2+ awd audi pulling a deer out of the woods.
    May 21 2007
    13 S4
    Northshore, MA
    Items for Sale
    i assume you meant to say if the car IS running it is shaking....
    its most likely the coilpacks. audi is coming out with a recall shortly for these, because they are a known issue and are a common failure. might want to change the spark plugs while youre at it. neither of these jobs are hard to do by any means.
    -Nate
    Current: 2013 Ibis White S4
    Mistake: 2008 BMW 135i
    Previous Audi: 07 Ibis White A4 S-Line Ti Package [SOLD]
    B7A4 Build Thread: http://www.audizine.com/forum/showth...58#post7310258
    Oct 26 2009
    Queens NY
    thanks guys..... any idea why it could of happen?
    Sep 12 2008
    South Central PA
    because our coils suck. /story
    EFR | 7163
    268/260 cams
    I.E. Intake Manifold / 70mm
    BoostManager+
    Meth Head
    Jul 28 2009
    2003 A4 3.0 V6
    SL,UT
    Quote Originally Posted by doublezero30 View Post
    the recall is currently going on right now. not for all 1.8t's though. the number is slim.
    Veteran Member Four Rings mrbacardi35's Avatar
    Sep 18 2006
    Fresno/Los Angeles, CA
    Items for Sale
    after you get that fixed. make sure you carry spare from here on now unless you're one of my co-worker that don't want to listen when i told him to carry spare. his reasoning was its under warranty so they can just tow it. i hope it does happened to him while his out nowhere though...lol
    Oct 26 2009
    Queens NY
    anyone knows how much the coilpacks go for?
    Mar 27 2005
    Here & There
    Quote Originally Posted by parserito View Post
    $25/each. get four of the newest 'R' version and call it good.
    2014 VW Touareg - 4Motion - Midnight Blue
    Veteran Member Three Rings j-rod's Avatar
    Sep 09 2009
    VW Toureg V8
    Dallas, TX
    Yeah, I about shat myself when it started happening to me. I thought it was going to be real bad, but yeah it was just a coilpack. $25 fix.
    The Awesome™
    Web Design & Development
    www.jarodtaylor.com
    Sep 18 2006
    Items for Sale
    after you replaced all four, just keep the other 3 as a spare. also from here on now after all are replaced with the rev r, just replace whatever goes out and not all four since i went through this road. i installed all four at one time and 10K miles later one goes out which got replaced and still no issue for over 50K miles now.
    Veteran Member Four Rings ThatA4T's Avatar
    Jun 10 2009
    98 A4 1.8T Quattro, 66 vw bug Rat Rod
    Denver CO
    i had a coilpack go bad when i was text driving my car lol :) had them replace it before i bought the car.
    If I hit the switch, I can make that ass drop.
    Established Member Two Rings nikothegman2003's Avatar
    Jan 24 2008
    '03 A4 3.0Q, '01 TT-Q cab. '86 Me/Be 300SDL
    Bronx, Westchester, New York
    yea its the coilpacks, get four new STI ones, and does anyone know if the recall is for the 3.0 also?
    Sep 12 2008
    South Central PA
    no, dont get STi coils.
    EFR | 7163
    268/260 cams
    BoostManager+
    Meth Head
    Mar 27 2005
    Here & There
    Quote Originally Posted by Dan[FN]Shank210 View Post
    2nd. Just get the OEM 'R' versions.
    Oct 26 2009
    Queens NY
    can i get them at any store? or just online..... by the way can i still drive the car? or can it cause any problems if i do.... i have to go to work n that my only way there.. i dont mind it shaking until i fix it but i really need to drive it ....
    Sep 09 2009
    VW Toureg V8
    Dallas, TX
    I drove mine a little bit before I was able to get the CP and it was fine. Just sucks driving it that way. I got my CP's from a local Autozone, I think.
    The Awesome™
    www.jarodtaylor.com
    Mar 27 2005
    Here & There
    Don't drive it till you can replace the coil. You will end up running rich and the excess will end up ruining your cat.
    Sep 12 2008
    South Central PA
    Quote Originally Posted by EBG 18T View Post
    exactly
    EFR | 7163
    268/260 cams
    BoostManager+
    Meth Head
    Oct 26 2009
    Queens NY
    Hey guys thanks for everything...... just finished installing the CPs....... NO MORE VIBRATION!!!! =] (i was looking like a 5 year old jumping up n down) thanks alot....
    All i gotta do now is find a way to take the check engine light off...... but thanks again
    Veteran Member Four Rings PDX04a4's Avatar
    Jun 22 2008
    2006 A4 Avant S-line
    SL,UT
    it will go away after a few cycles
    Veteran Member Four Rings BOPOH's Avatar
    Oct 08 2007
    Columbus, OH
    great to hear you fixed everything! did you buy spares?
    Veteran Member Four Rings Vince Stark's Avatar
    Jul 30 2009
    Dallas
    Quote Originally Posted by nikothegman2003 View Post
    Dude FAIL
    Dont ever get STI coils what is wrong with you
